Posted on
BeoCord 3500
Bang & Olufsen BeoCord 3500
Beocord 3500 was part of Beosystem 3500, a budget-priced system for those who wanted to get onto the Bang & Olufsen bandwagon but could not afford, or did not want to have, the extra features that say, Beosystem 4500 had to offer.
It included specifications such as Dolby B Noise Reduction and a Sendust head for longer life of the recording/playback head, otherwise the features were identical to the Beocord 4500. Its only difference was the grey finish instead of its more expensive brother’s polished surfaces.
Posted on
BeoCord 3300
Bang & Olufsen BeoCord 3300
You had the benefits of the very latest technology with this cassette recorder when it was first introduced. Such as the patented HX Pro recording system which enriched the sound image by giving vastly superior reproduction of the treble range.
You were certain to approve of the wealth of useful features too. For example, if the record finished while you were recording, the tape stopped automatically and restarted automatically when you turn the record over.
When you pressed STOP after a recording, a four-second pause was inserted between tracks with the automatic search system. Clever stuff – all designed to make life easier and more fun. Beocord 3300 was part of Beosystem 3300 although it could also be used as a stand-alone item.
Posted on
BeoCord 1900
Bang & Olufsen BeoCord 1900
Beocord 1900 equalled Bang & Olufsen’s top-of-the-line cassette deck (Beocord 5000) in terms of specifications and performance, but it but it did not have the same wide range of facilities and operational refinements.
This does not mean that the Beocord 1900 was difficult to operate. On the contrary, the slanting front panel which contained all the operational facilities made the set’s controls handy and easily accessible. The cassette eject mechanism was air damped so that delivery was gentle and controlled. Two large VU meters enabled accurate setting of recording levels.
The microphones socket was placed discreetly under a sliding panel together with a balance control which enabled signal level adjustment in both channels. All the features which characterised high quality and high performance levels in cassette decks were incorporated. These included a combined recording/play-back Sendust tape head and Dolby B Noise Reduction circuits.
Beocord 1900 used precision techniques that ensured stable tape drive and the highest standards of recording and playback. Yet despite its comprehensive facilities it was easy to use and harmonised comfortably with many different Beosystems.
Beocord 1900 could be made up as part of the Beosystem 1900 or Beosystem2400, when linked together with other compatible Bang & Olufsen products.
Posted on
BeoCord 1700 (1973)
Bang & Olufsen BeoCord 1700 (1973)
Beocord 1700 was a high-fidelity cassette recorder which combined quality with the convenience of compact cassettes.
The tape-heads in Beocord 1700 were high density ferrite heads which offered high sound quality and a longer useful lifetime than any other type of tape heads available in the mid-1970’s. There was a push button for switching between chromium dioxide and normal tapes in order to secure the best performance from either type. There were two VU meters with dB scales: one for each channel. Recording levels could be accurately adjusted by using the two independent sliders for right and left channels. There was an automatic stop at the end of the tape.
The 3-digit tape counter had a supplementary memory function which automatically stopped the tape at a ‘0’ reading. Sockets for mono/stereo microphone and headphones were hidden under a sliding panel on the top of the unit. Frequency range was 30-14.500 Hz and signal-to-noise ratio was better than 52dB with chromium dioxide tapes. This figure could be further improved by the Dolby noise reduction system which was available as an optional accessory.
The plug-in unit fitted inside the cabinet and after the necessary adjustments, the “filter” button was replaced by a “Dolby” button which was used to switch the system IN or OUT as required. Wow and flutter was less than ± 0.12 % (JIS) or ±0.2 % (DIN).
Beocord 1700 could be used as part of Beosystem 1700 together with suitable speakers.
Posted on
BeoCord 1700 (1981)
Bang & Olufsen BeoCord 1700 (1981)
Beocord 1700 matched the Beomaster 1700 both physically and technically. It combined high performance with easy, straightforward operation.
Ferric, chrome or metal tapes could be used. The Sendust tape head, Dolby B circuits and Peak Programme Meter all contributed to high quality recording and playback. You could switch between all modes of play without fear of tangling the tape or damaging the mechanism.
Posted on
BeoVision Eclipse 65
Bang & Olufsen BeoVision Eclipse 65
Our goal with Beovision Eclipse was crystal clear: merge images so lifelike they almost seem unreal with sounds so powerful they literally break out of the picture. No easy task, but the result is quite simple: we designed the definitive TV.
All-in-one music system
Beovision Eclipse has a three-channel sound system, providing the ability to deliver speech-optimised centre channel audio as well as powerful stereo performance.
Clear-cut visions
A sharp, black glass screen cutting straight through an organic aluminium body. It’s a bold and clear design statement of picture and sound in perfect alignment.
See what the world’s best TV sound will do for your movies
Powerful enough to compete with many stand-alone music systems, a Beovision TV is the centre of any luxury home cinema experience. Learn how to get the most out of its truly impressive capabilities.
Statement design
Any way you look at it; from the front, the side or from the rear, Beovision Eclipse looks stunning. Every little detail is carefully attended to and our use of high-quality Materials provides the aesthetic freedom to place the TV anywhere you want.
Picture, pitch black
The OLED screen technology brings you a whole new TV experience thanks to more than 8 million self-lit pixels. Enjoy the deepest blacks, richest colours and realistic picture quality. The most important aspect of your viewing experience.
Sound, pitch perfect
The integrated speaker system holds a powerful 450 watts 3-channel setup with the ability to outperform even the most potent soundbar on the market. Expect an exceptional sound performance that brings your viewing experience to a new and exciting level.
Connectivity
For your listening pleasure, Beovision Eclipse supports music streaming via Apple AirPlay , Bluetooth and Google Cast. It integrates seamlessly with other Multiroom products letting you customise and expand your entire home music experience.
Controls
Your TV experience has never been as easy or as personal as this. Escape the constraints of flow TV and dive straight into your favourite content with a single click. The world’s premier Smart TV platform, webOS, just keeps getting smarter.
Posted on
BeoVision Eclipse 55
Bang & Olufsen BeoVision Eclipse 55
Clear-cut visions
Statement design
Connectivity
Controls
Posted on
BeoVision Avant CTV
Bang & Olufsen BeoVision Avant CTV
Performance in a simpler package.
The Avant CTV was available only in 28″ widescreen format and filled a perceived gap at the bottom of the range. It offered the same high quality picture and sound provided by the VCR and DVD models but with no additional video sources.
It was replaced in 2003 by the introduction of the Beovision 3 28″ which seemed to offer much the same package but rather cheaper. One would however be mistaken if one thought was getting the same set as the Avant CTV was built upon the more expensive chassis , as was the BeoVison 3 32, whereas the BV3-28″ utilised the cheaper MX chassis.
The sound quality of the Avant CTV was every bit as good as its more expensive brethren though one did have to specify the anti reflection coated screen as an extra.
