Posted on
BeoMaster 6000 (1981)
Bang & Olufsen BeoMaster 6000 1981
This extremely distinctive and beautiful FM stereo receiver from Bang & Olufsen used the very latest technology, both in its complex audio circuitry and in the microcomputer-based control systems which made it such an effortless and pleasurable product to use – whether or not you decided to include the optional remote control facility. The specialist radio section concentrated on the superb sound quality available from FM transmissions.
It covered the entire FM band from 87,5 to 108 MHz and incorporated the most advanced techniques for accurate, drift-free stereo reception.
The amplifier gave 2 x 75 watts RMS with an extremely low level (0,8%) of harmonic distortion. Clean, clear sound – always. Two 24-hour timers allowed you to play or record any sound source automatically. You didn’t even have to be at home. Or, if you wanted to be sure of hearing the same news programme every evening you could set the Repeat function to remember for you – day after day.
Connections included sockets for a record deck and two tape decks (DIN or RCA phono plugs) plus graphic equaliser, headphones and two pairs of loudspeakers.
Beomaster 6000 formed the heart of Beosystem 6000 and was designed by Jacob Jensen.
BeoMaster 6000 (1981) Product Details
Type Numbers
2251 (1981 - May 1986)
2252 (GB) (1981 - May 1987)
2253 (US) (1981 - Feb 1987)
2254 (J) (1981 - Dec 1982)
Designer
Manufactured
1981 - 1987
Colour Options
Rosewood, Teak, White
BeoMaster 6000 (1981) Product Specification
Continuous power output per channel: 75 W at 8 ohms
Total harmonic distortion: < 0.08 %
IHF Intermodulation: < 0.05 %
Bass control at 40 Hz: +/- 11 dB
Treble control at 12.500 Hz: +/- 11 dB
Power supply:
2251 220V
2252 240V
2253 120V
2254 100V
Power consumption: 50 – 320 W
Dimensions W x H x D: 52.5 x 15 x 38cm
Weight: 14 kg
RIAA amplifier: built-in
Connections: Speakers 2 sets
Phono: DIN
Tape 1: DIN
Tape 2: Phono
LINE IN/OUT DIN
Headphones jack
BeoMaster 6000 (1981) FAQs
Please let us know
Posted on
BeoCenter AV5
Bang & Olufsen BeoCenter AV5
BeoCenter AV5
” Picture this. The perfect picture “
BeoCenter AV5 was, at first glance, merely a television set. However, what you saw was just half the picture. The AV5 was in fact a fully integrated, compact digital home entertainment system, comprising a CD player, FM radio and powerful loudspeakers… as well as a television!
On top of the AV5 a CD player elegantly lifted open to allow you to drop in your CD and listen.
BeoCenter AV5 therefore offered the best of both worlds and allowed you decide. At the touch of a button, two motor-drive loudspeakers stretched silently out to each side of the TV set. It was a simple, welcoming gesture but one that also ensures a special performance every time you switch on. The extra width allowed the loudspeakers to combine with the ear-shattering centre bass to produce optimal stereo sound in its full perspective. It was something you could hear – and feel – every time you watched a movie or listened to the in-built radio or played a CD. Indeed, BeoCenter AV5 was so versatile that at the time of its introduction, it could also play CD-i discs.
Devoting efforts in creating the perfect sound didn’t mean that Bang & Olufsen had forgotten what they knew about creating the perfect picture. On the contrary. The AV5’s 63cm super flat picture tube, combined with the contrast screen’s anti-reflective coating, delivered a sharper picture, with more depth and perspective, than you had ever seen before. So when the AV5’s electronic curtains glided open you could be sure that what lay behind them was pure entertainment.
Another original Bang & Olufsen feature added to daylight viewing comfort. It was a small electronic sensor that registered the prevailing light conditions in the room and adjusted the picture, so that it was always sharp, no matter whether a reading lamp was lit or sunlight suddenly poured through the window.
Touch CD on the Beo4 remote control and the AV5 moved on its motorised stand to face the viewer’s favourite viewing position. And active speaker stretched out from each side. On top, a CD player elegantly lifted open to allow you to drop in your CD and listen. The superior sound of the AV5 was made possible by the creation of a ‘soundscape’ that widened the perspective of the sound to make each individual instrument clear and distinct. Combined with an inbuilt, ear-shattering centre bass, the AV5 delivered a sound so rich and true that the effect was remarkably similar to a dedicated surround system.
Like every other Bang & Olufsen product, Beovision AV5 was designed and crafted with the greatest care. To ensure that the powerful centre bass unit didn’t interfere with the steadiness of the picture, it was mounted on an intricate suspension system, which in turn was anchored to a special aluminium chassis. The CD unit was perhaps the most robust then, on the market, to allow it to cope with the demanding environment – electronic noise, hot air and interference – in which it had to perform. And on top of all that, the entire unit was ‘torture tested’ hundreds of thousands of times to make sure that it could cope with the rigours of daily use!
Beovision AV5 construction
The rear of the AV5 is removed by undoing four screws. It may have taken some 150 tools and six construction engineers to make the parts and components, but as far as possible, one size of screw was used to assemble the AV5. The result was, up to 1999, the most advanced piece of electronic design ever to leave the Struer assembly line. Yet everything follows a strictly modular pattern, making maintenance and servicing logical and straightforward.
How can 15 centimetres make a world of difference if you’re already sitting in front of the television, ideally positioned between the stereo loudspeakers?
If you want the full perspective of, say a symphony and you want to be able to identify each instrument in the orchestra, a distance of 80 centimetres is the absolute minimum. You must also make sure that the loudspeakers deliver exactly the same performance and have the same harmonic balance. This can only be obtained by the painstaking measurement, trimming, and pairing of every single tweeter and baffle that goes into the AV5 (or into any other Bang & Olufsen loudspeaker for that matter). Some manufacturers obtain “spatial effect” by reversing the signal phase on one side. This creates a broader perspective, but makes it impossible to locate voices or single instruments.
Flat as a pancake
The picture tube was a new 25″ ‘super-flat state-of-the-art’ tube. It delivered excellent focus, which, combined with the anti-reflective coating of the contrast screen, was experienced as a sharper picture with more depth and better resolution.
The antlers
The fact the loudspeakers disappeared into the front wall, calls for a special bearing structure. In the AV5, the heaviest component was the picture tube, which was fixed to a set of aluminium “antlers”, a moulded aluminium space-frame which also carried the loudspeakers and most of the wiring. Cast in two pieces, it was custom-designed to hold wiring and fixtures that traditionally, would have been mounted with additional clamps and screws. Aluminium has the advantage of being light, but rigid and non-vibrating. It will not conduct sound or allow oscillations that could affect sound or picture reproduction.
‘Dance steady’ is a term that B&O takes dead seriously. It refers to a product’s ability to perform effortlessly, no matter how animated the surroundings. The company’s secret remedy is rubber suspension. Inside the AV5, almost every vital unit was isolated from the bearing structure by little rubber sleeves. The transformer, the CD print card, the CD drive and last but not least, the centre bass, since it was the source of a sizeable proportion of the vibration pattern. Dance steadiness is measured on a vibrating table to determine the design of each individual rubber sleeve.
On and on and on…
Imagine that you’d turn the AV5 on and off maybe 10 times a day over the next ten years and multiply that by 5 for safety. That’s equivalent to turning it on and off 180,000 times over 10 years. In B&O’s torture chambers in the dungeons in Struer, the loudspeakers on the guinea pig AV5 were stretched well beyond the first 500,000 times!
“It can’t be done”
Buffers, shielded cables and a couple of brave hearts went into one of the most challenging technical solutions in the AV5. To make room for the CD player in the upper corner, it was necessary to separate the drive from the control unit. In an environment as compact and loaded with “electronic noise” as the AV5, a lot of sources could create interference and laser is a fragile technology. Servo signals have to travel a longer distance and streams of hot air will not make working conditions any more stable. As a result, the AV5’s CD player was one of the most robust on the market at the time of the AV5’s production.
BeoCenter AV5 Product Details
Type Numbers
8200 (NEU) (1997 - Jan 2002)
8202 (HK) ( 1997 - Jan 2002)
8203 (GB) ( 1997 - Jan 2002)
8204 (ITA) ( 1997 - Jan 2002)
8205 (AUS) ( 1997 - Jan 2002)
8206 (EEU) ( 1997 - Jan 2002)
8207 9OTHER) ( 1997 - Jan 2002)
8208 (F(GB)) ( 1997 - Jan 2002)
Designer
Manufactured
1997 - 2001
Colour Options
Black, Blue, Green, Red, Tan and Silver
BeoCenter AV5 Product Specification
Remote control included: Beo4
Stand turning function: +/- 35 degrees, remote operated
Picture tube: 63cm , Black line SF, Black Matrix
Visible picture: 59cm
Curtain: electronic
Contrast screen: anti-reflex coated
VisionClear
Auto picture adjustment
Auto cut-off
Wideband CTI
Adaptive Luminance Peaking
Scan Velocity Modulation 1
Teletext Improved Teletext, (about 350 pages)
FastText (FLOF), 7 languages, 4 memory pages per programme
CTV system B/G, PAL, SECAM, NTSC AV, Nicam (optional)
Tuner range 45 – 860 MHz, VHF, S, Hyper, UHF
TV programmes 79, named by Teletext
Sound Stereo, active speakers
Sound pressure level 97 dB stereo
Stereo decoders According to type:
A2 + NICAM B / G / L (optional)
A2 + NICAM B / G / I (optional)
NICAM I (optional)
Sound system bass reflex, 2 x two-way ‘side-system’ + ‘centre bass’
Frequency range 55 – 20000 Hz
FM receiver tuner range: RDS 87.5 – 108 MHz
Radio programmes: 59
CD: built in
Disc size 12cm , 8cm
Frequency range 20 – 20,000 Hz +/- 1 dB
Signal – to – noise – ratio Typical 100 dB, A weighted in audio mode
Playback the following:
8200, -03, -04, -05, -06, -08
8202(HK), 8207(TAI) CD-A
CD-A, Photo-CD, Video-CD, CD-I, CD-Graphics, CD-Ready
Satellite module: (optional)
Tuner range 950 – 2150 MHz
Programmes 119 TV/ Radio
Sound systems Mono/ Stereo
Satellite radio: yes
Down conv. supply 14/18 Volts control, Tone control (22 Khz)
Input DiSEqC (One way control)
2 x F-connector (2 x 75 ohms) Connections: V.TAPE-AV-Decoder 3 x 21-pin sockets, AV for S-VHS in/out
Camcorder / auxiliary 3 x Phono sockets/YC input 4-pin socket
Stereo headphones Mini jack
Beolink 1 Master Link
Beolink video distribution System modulator according to type
I optional, G optional
RF out
Link compatibility: 1 Master Link
Optional features/modules: Satellite 4158
NICAM decoder 4144
Set-top box Controller 4167
System modulator 4155 (EU) 4160 (GB)
Positioner (external) 4170 (EU) 4171 (GB)
Power Positioner (external) 4172 (EU) 4173 (GB)
AV2 Expander box 8089086
Picture in picture module Not available
Specifications: Dimensions W x H x D/ Weight:
On mode : 63 x 97 x 55cm / 69 kg
Standby mode: 81 x 97 x 55cm / 69 kg
Cabinet finish: pearlescent shades of black, blue, green, red, dark tan and silver
Power consumption/ minimum: typical 112 W/ standby <1.5 W
Market specifications:
Market: Type: Country: Active CTV system Basic CTV system *)
NEU 8200 A-B-CH-D-DK-E-GR-I-N-NL-P-S-SF-Other B/G B/G
HK 8202 Hong Kong B/G/D/K/M/I B/G/D/K/M/I
GB 8203 UK, South Africa I I
ITA 8204 Itali B/G B/G
AUS 8205 AUS, NZ B/G B/G
EEU 8206 East Europe B/G/D/K B/G/D/K/M/I
TAI 8207 Thailand, Other B/G/D/K/M/I B/G/D/K/M/I
FGB 8208 North France, Cannel Island B/G/L/L´/I B/G/L/L´/I
*) Basic CTV systems can be switched ON in Service menu
Language
Product Information
EN
BeoCenter AV5 Product Information
Reference Guide
EN
BeoCenter AV5 Reference Guide
Beo 4 User Guide
EN
BeoCenter AV5 BEO 4 User Guide
User Guide
EN
BeoCenter AV5 User Guide
User Guide
DK
User Guide
ESP
User Guide
FR
User Guide
GER
User Guide
IT
User Guide
NL
BeoCenter AV5 FAQs
Please let us know
Posted on
BeoCenter 2800
Bang & Olufsen BeoCenter 2800
BeoCenter 2800
Beocenter 2800 was a unique combination of FM/AM tuner, a 2 x 25 watts RMS hi-fi power amplifier and record player. The tuner section offered Long and Medium wave reception as well as FM. There were facilities for pre-setting the four FM stations you listen to most frequently. Ceramic filters, AFC, split-supply output and a phase-locked loop decoder were some of the features that ensured outstanding reception and reproduction of even distant stations.
The record player was fully automatic – one master switch controlled all operations. The anti-skating device was built into the arms suspension and worked automatically. Electronic Servo Drive (ESD) ensured constantly correct speed. There were sockets for tape deck, two sets of stereo speakers and headphones.
This was a compact, space-saving unit which was easy to use thanks to automatic circuits and logical controls. Beocenter 2800 could be made up as part of the Beosystem 2800, when linked together with other compatible Bang & Olufsen products
BeoCenter 2800 Product Details
Type Numbers
2630 (1978 - June 1980)
Designer
Manufactured
1978 - 1980
Colour Options
BeoCenter 2800 Product Specification
Power output RMS DIN 2 x 25 watts / 4 ohms, 2 x 20 watts / 8 ohms
Harmonic distortion < 0.1 %
Intermodulation < 0.15 %
Frequency range 20 – 30,000 Hz
FM tuner range FM 87.5 – 108 MHz
LW 150 – 350 kHz
MW 520 – 1610 kHz
Record player:
Automatic record-size 17 and 30 cm
Speeds 33 – 45 rpm
Wow and flutter < +/- 0.09 %
Rumble unweighted > 42 dB
Rumble weighted > 62 dB
Speed deviation < 0.05 %
Speed control range > +/- 3 % Pickup:
MMC 3000 Stylus – spherical diamond
Radius of curvature 15 µm
Frequency range 20 – 20,000 Hz +2 -3 dB
Stylus pressure range 0 – 2 g
Power supply:
110 – 130 – 220 – 240 V
Power consumption 20 – 150 W
Dimensions W x H x D 50 x 12 x 37cm
Weight 13 kg
Connections: Tape recorder DIN
Headphone jack
Language
Date
Service Manual
EN
2630
06-77
BeoCenter 2800 Service Manual
BeoCenter 2800 FAQs
Please let us know
Posted on
BeoCenter 2002
Bang & Olufsen BeoCenter 2002
BeoCenter 2002
BeoCenter 2002 Product Details
Type Numbers
2101 (1981 - Feb 1982)
Designer
Please let us know
Manufactured
1981 - 1982
Colour Options
Plastic wood
BeoCenter 2002 Product Specification
Power output RMS DIN: 2 x 25 watts / 4 ohms
Harmonic distortion -26 dB < 0.15%
Harmonic distortion < 0.2%
Intermodulation < 0.4%
Frequency range +/- 1.5 dB 20 – 25,000 Hz
Damping factor > 30
Input tape copy 600mV / 15 kohms
Signal-to-noise ratio phono > 78 dB
Output external tape 30 mV / 100 kohms
Output headphone Max. 2.8 V / 22 ohms
Channel separation 1000 Hz > 50 dB
Bass control at 40 Hz +/- 14 dB
Treble control at 12.500 Hz +/- 14 dB
Tuner:
FM range 87.5 – 108 MHz
AM range LW 147 – 350 kHz
AM range MW 520 – 1610 kHz
Power supply: 110 – 130 – 220 – 240 V
Power consumption: 18 – 135 W
Dimensions W x H x D: 73.5 x 12.5 x 38cm
Weight:11.2 kg
Record player:
MMC 20S
Stylus Spherical diamond
Recommended tracking force 15 mN / 1.5 gram
Frequency range 20 – 20,000 Hz +/- 3 dB
Speeds 33 – 45 rev. / min.
Wow and flutter, DIN < +/- 0.09%
Wow and flutter, WRMS < +/- 0.045%
Tape Recorder:
Compact cassette C60 – C90
Tape head Super Permalloy
Noise reduction Dolby NR
Tape switch Manual ferro-chrom
Wow and flutter < +/- 0.2 %
Speed deviation < +/- 1.5%
Fast forward and rewind C60 75 sec.
Frequency range ferro-chrome 30 – 14,000 Hz
Signal-to-noise ratio Chrome Dolby NR > 63 dB
Chrom > 56 dB
Connections: headphones, microphone
BeoCenter 2002 FAQs
Please let us know
Posted on
BeoCenter 1600
Bang & Olufsen BeoCenter 1600
BeoCenter 1600
Beocenter 1600 was a combined FM stereo tuner, hi-fi amplifier and cassette recorder with extra operational convenience in the tuner section – facilities for presetting the 4 FM stations you listen to most frequently. The hi-fi amplifier was relatively powerful and had low distortion and a wide frequency range so that the tuner’s excellent qualities could be exploited fully.
The built in cassette recorder was very easy to use – recording level was regulated with the same sliding potentiometer on both channels and monitored by an illuminated indicator. A Selector switch was available to choose between normal or chromium dioxide tapes.
Beocenter 1500 and Beocenter 1600 were at the time of their production, two of the market’s most compact audio systems, but despite their small external dimensions they could fill a large room with sound. All the push buttons of Beocenter 1500 were of solid aluminium, and the solid aluminium front panel on the Beocenter 1600 was anodised – a process which was more expensive and more demanding but which also made the set more robust and resistant to marks and scratches.
Combined with two speakers from the Beovox Uni-Phase range of loudspeakers, Beocenter 1600 would then make up Beosystem. 1600.
BeoCenter 1600 Product Details
Type Numbers
2606 (1975 - June 1978)
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoCenter 1600 Product Specification
Sound system and loudspeaker 2 sets of stereo
FM pre-tuning: 4
Power output: 1000 Hz RMS 2 x 22 watts / 4 ohms; 2 x 19 watts / 8 ohms
Music power 2 x 40 watts / 4 ohms; 2 x 25 watts / 8 ohms
Speaker impedance 4 ohms
Harmonic distortion: 1000 Hz 50 mV DIN 45 500 < 0.1 %
Intermodulation: DIN 45 500 < 0.1 %
Frequency range: +/- 1.5 dB DIN 45 500 20 – 30,000 Hz
Bass control at 40 Hz: +/- 17 dB
Treble control at 12,5000 Hz: +/- 14 dB
Tuner: FM range 87.5 – 108 MHz
Compact cassette: C60 – C90
Tape head: Super Permalloy
Iron oxide tape: Yes
Chromium dioxide tape: Yes
Indicator system: Dual light
Counter: 3 digits
Stop at end of tape: Yes
Wow and flutter, DIN: < +/- 0.3 %
Speed deviation: < +/- 1.5 %
Fast forward and rewind: 90 sec.
Frequency range, DIN 40: 12,500 Hz
Signal-to-noise ratio Chrome: > 52 dB
Erasure: > 65 dB
AUX: 50 mV / 22 kohms
Output radio: 800 mV / 22 kohms
Power consumption: 20 – 170 W
Dimensions W x H x D 66 x 8.5 x 26cm
Weight 8.8 kg
Connections: Phono DIN
Headphone jack
Extra tape recorder DIN
Language
Date
Service Manual
EN
2606
05-83
BeoCenter 1600 Service Manual
BeoCenter 1600 FAQs
Please let us know
Posted on
BeoCenter 1500
Bang & Olufsen BeoCenter 1500
BeoCenter 1500
Beocenter 1500 was a combined FM/AM tuner, hi-fi stereo amplifier and cassette recorder with a specification level that was unique for combination units in that price bracket. In the AM section, which covered long and medium waves, Bang & Olufsen placed an emphasis on the set’s ability to separate stations from each other. The FM section had outstanding channel separation and stereo reception. The amplifier’s technical specifications were way above the average and fulfilled accepted hi-fi norms by a wide margin.
The built-in cassette recorder had its own operation panel but was otherwise fully integrated with the rest of Beocenter 1500. There was a switch for normal and chrome tapes; recording level was monitored on an illuminated indicator: red signified overload and green meant that all was well. The tape heads were of a super Permalloy and had a higher performance level and longer useful lifetime than ordinary heads.
Beocenter 1500 had connections for record player, two sets of stereo speakers, headphones and an extra tape deck.
Beocenter 1500 and Beocenter 1600 were, at the time of their production, two of the market’s most compact audio systems, but despite their small external dimensions they could fill a large room with sound. All the push buttons of Beocenter 1500 were of solid aluminium, and the solid aluminium front panel on the Beocenter 1600 was anodised – a process which was more expensive and more demanding but which also made the set more robust and resistant to marks and scratches.
BeoCenter 1500 Product Details
Type Numbers
2603 (1976 - Jan 1978)
Designer
Manufactured
1976 - 1978
Colour Options
Rosewood, Teak
BeoCenter 1500 Product Specification
Power output: 2 x 20 watts/ 8 ohms
2 x 19 watts/ 4 ohms
Music power: 2 x 40 watts/ 8 ohms
2 x 25 watts/ 4 ohms
Speaker Impedance: 4 ohms
Harmonic Distortion: < 0.1 %
Intermodulation: < 1.0 %
Frequency Response: 20 – 30,000 Hz
Signal-to-noise ratio: > 50 dB
Channel separation: > 50 dB
Bass control:+/- 17 dB
Treble control: +/- 14 dB
FM tuner: Range 87.5 – 104 MHz
AM tuner: Range 147 – 350 kHz
520 – 1610 kHz
Frequency range, DIN chrome: 40 – 12,500 Hz
Signal-to-noise ratio DIN chrome: > 52 dB
Erasure: > 65 dB
Power consumption 20 – 170 W
Dimensions W x H x D: 66 x 8.5 x 26cm
Weight 8.8 kg
Headphone jack
Language
Date
Service Manual
EN
2603
05-83
BeoCenter 1500 Service Manual
BeoCenter 1500 FAQs
Please let us know
Posted on
BeoGram CD 3500
Bang & Olufsen BeoGram CD 3500
BeoGram CD 3500
The sound reproduction achieved by Bang & Olufsen’s CD 3500 CD player was truly outstanding. It played both 12cm and 8cm compact discs and had an ingenious ‘step’ function which allowed you to go straight to a chose track selected from anywhere on the disc. The CD player was one of the most technologically-advanced pieces of hi-fi on the market at the time and yet was one of the easiest to operate. The explicit display always indicated what the CD player was doing all the time – for example, which track was being played, and how many tracks there were on the played compact disc.
Beogram CD 3500 could be used as part of the Beosystem 3500 hi-fi system.
BeoGram CD 3500 Product Details
Type Numbers
5171
5172
5173
5174
5175
Designer
Manufactured
1988 - 1994
Colour Options
Grey
BeoGram CD 3500 Product Specification
Power supply:
5171: 220V
5172: 240V
5173: 120V
5174: 100V
5175: 240V
Power consumption: 23 W
Dimensions W x H x D: 42 x 7 x 24.5cm
Weight: 4.5 kg
Link compatibility: Datalink
Frequency range: 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio: > 100 dB / 110 dB A-weighted
Dynamic range: > 96 dB
Harmonic distortion incl. noise: < 0.0025% at 0 dB;
< 0.025 at -20 dB
Channel separation: > 101 dB
Channel difference: < 0.08 dB
Converter system: 16 bit, 4 x oversampling 176.4 kHz
Low pass filter: Digital + Bessel/elliptical analogue
Damping: > 20,000 Hx > 50 dB
Phase error between L and R 0 degree at 20 – 20,000 Hz
Output analogue: 1.3 V RMS at 0 dB
Output digital: For digital equipment
BeoGram CD 3500 FAQs
Please let us know
Posted on
BeoGram 608
Bang & Olufsen BeoGram 608
BeoGram 608
Understanding the numbering of these Beograms is really quite easy: the ‘V’ in ‘608V’ means that it was powered with AC voltage and ‘F’ meant that it had a built-in preamplifier. The designation 608, 609 and so on, indicated the year the product was marketed.
Beogram 608 was a turntable without a built-in RIAA preamplifier and was produced for the 1962 season (internally many were date-stamped e.g. September 1961 would indicate the year it left the factory).
Beogram 42 was basically the same as Beograms 6xx but with a larger platter and longer tonearm. The longer tonearms could, like the preamplifier and platter, be refitted.
BeoGram 608 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoGram 608 Product Specification
Please let us know
BeoGram 608 FAQs
Please let us know
Posted on
BeoGram 42V/VF
Bang & Olufsen BeoGram 42V_VF
BeoGram 42V/VF
The B&O 4-speed record player is an important step on the road to full musical enjoyment, being designed specially with a view to vibrationless and rumbleless operation. This feature is of great importance when playing stereo records as the pickup stylus must be sensitive to vibrations in all directions in order to be capable of “scanning” the record properly.
Understanding the numbering of these Beograms is really quite easy: the ‘V’ in ‘608V’ means that it is powered with AC voltage and ‘F’ means that it has a built-in preamplifier. The designation 608, 609 and so on, indicates the year the product was marketed. There was also a ‘U’ version for both AC and DC voltages. Beogram 608 for example, was a turntable without a built-in RIAA preamplifier and was produced for the 1962 season (internally many were date-stamped e.g. September 1961 would indicate the year it left the factory).
The difference between the models 41xx and 42xx was that the 41xx had a small turntable and the 42xx model had a larger turntable.
BeoGram 42V/VF Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1963 - 1965
Colour Options
Rosewood, Teak, White, Oak
BeoGram 42V/VF Product Specification
Please let us know
BeoGram 42V/VF FAQs
Please let us know
Posted on
BeoGram 41V/VF
BeoGram 41V/VF
BeoGram 41V/VF Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1963 - 1965
Colour Options
BeoGram 41V/VF Product Specification
Please let us know
BeoGram 41V/VF FAQs
Please let us know
