Posted on
BeoVision 8902
BeoVision 8902
BeoVision 8902
Beovisions that put the future at your fingertips
As yet, none of us need 32 TV channels, let alone 100. But satellite re-broadcasting systems and cable TV, including regional and community networks, may in the future change that.
Therefore, Bang & Olufsen equipped all their luxury Beovision models with an advanced digital tuner that had the capacity for receiving 100 UHF channels, 32 of which could be stored in the set’s microcomputer memory for instant recall at the touch of a button.
The real boon for most viewers is that you could locate, store and recall any of these stations without leaving your armchair. All you had to do was to touch a key on the Beovision Video terminal. So although the company gave their “future-safe” luxury TV range more micro-electronics, more features and more connection possibilities than ever before, they had, at the same time, made all this complex technology even more accessible – instantly. To borrow a phrase from the computer industry, Bang & Olufsen’s ’02-Series’ TVs were (and still are) extremely “user-friendly”.
Beovisions 5502, 7702, 8802 and 9002 all shared the same advanced chassis design and offered the same user-benefits. They were true “luxury” sets because all the features and facilities which, in other brands, are offered as ‘extras’ were offered as standard on Bang & Olufsen sets.
The Beovision Video Terminal supplied with Beovisions 5502, 7702, 8802 and 9002 offered a plethora of operational benefits. In addition there was also an advanced ‘tune and store’ function that allowed you to you operate the automatic tuning system from the comfort of your chair.
One touch of the ‘tune’ button started the digital tuner scanning the wavelengths of the UHF band. When it found a station, it stopped – giving you the opportunity to either reject or accept it. If it was an unsatisfactory reception from a distant transmitter (or simply a station you didn’t like!), you just pressed ‘tune’ again to continue the search. When you found a station you enjoyed, on a channel giving a good, clear reception, you could instruct the set’s microcomputer to remember that transmission frequency by pressing ‘store’ followed by your own choice of pre-set programme number (e.g. for BBC2 you might designate pre-set number 2). Thereafter, whenever you wanted to watch BBC2, you simply touched button ‘2’ on your remote Terminal.
Up to 32 different TV stations could be located and stored in this way, so your Beovision really was ‘future-safe’ because it had plenty of spare capacity to accommodate new programme sources as and when they come ‘on stream’.
The (then) latest type of Beovision Video Terminal also had a button marked ‘sound’. This was only effective with Bang & Olufsen stereo TVs – Beovision 7802 and Beovision 8902, for example.
BeoVision 8902 Product Details
Type Numbers
7210 (1984 - Jan 1986)
7022 (D, TXT, OSCAR) (1984 - May 1987)
7292 (D, TXT, OSCAR) (1984 - Dec 1986)
7006 (G) (1984 - May 1986)
7230 (GB) (1984 - April 1987)
7233 (GB, TXT) (1984 - Feb 1987)
7270 (MULTI) (1984 - May 1986)
7277 (MULTI, TXT, ANTIOPE) (1984 - Aug 1986)
7020 (OSCAR) (1984 - Jan 1987)
7290 (S-CH) (1984 - May 1985)
7021 (S, TXT) (1984 - May 1987)
7211 (S, TXT) (1984 - Aug 1985)
Designer
Please let us know
Manufactured
1984 - 1987
Colour Options
Wood Effect or White
BeoVision 8902 Product Specification
Picture tube size: 66cm
Cabinet: wood veneer
Features: stereo sound with stereo enhancement
Bilingual sound
Number of programmes 32 VHF – UHF, Range UHF 21 – 69, VHF 2 – 12
or VHF 46.25 – 105.25 MHz and 113.25 – 294.25 MHz
Picture tube 30 AX 110° in line self-converging
Start time Approx. 5 sec
Aerial impedance 75 ohms coaxial
Speakers: 2 set Log Line system: Woofer: 10 cm
Tweeter: 5 cm
Sound power output 2 x 14 W / 8 ohms
Harmonic distortion < 1 % at 15 W, < 0.5 % at 14 W
Intermodulation < 1 %
Frequency range +/- 1.5 dB 30 – 20,000 Hz
Power bandwidth 30 – 50,000 Hz
Signal-to-noise ratio > 55 dB
Bass control +/-8 dB / 100 Hz
Treble control +/-9 dB / 10,000 Hz
Power supply: 180 – 265 V
Power consumption 80 (70 – 160) W
Stand-by < 2 W
Dimensions W x H x D 89.5 x 49 x 45.5 cm
Weight 41 kg
Connections: Headphones output Max. 10.5 V / 200 ohms
External speakers 8 ohms
Tape output 600 mV / 1 kohms
Amplifier output 600 mV / 1 kohms
AC socket, Audio/video IN/OUT DIN 6 pin
Video input 1 Vpp 75 ohms FBAS
Video output 1 Vpp 75 ohms
Audio input 600 mV / 100 kohms
Audio output 600 mV / 1 kohms
Documents will be listed here
BeoVision 8902 FAQs
Please let us know
Posted on
BeoVision 700
BeoVision 700
BeoVision 700
Beovision 700 won the iF Design Award in 1966
BeoVision 700 Product Details
Type Numbers
Please let us know​
Manufactured
1966 - 1969
Colour Options
Please let us know​
BeoVision 700 Product Specification
Please let us know
BeoVision 700 FAQs
Please let us know
Posted on
Beovision 7000
Beovision 7000
Beovision 7000 offered identical performance as the Beovision 7700 but with direct manual operation of up to 12 stations.
Beovision 7000 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1981 - 1982
Colour Options
Teak or rosewood
Beovision 7000 Product Specification
Please let us know
Beovision 7000 FAQs
Please let us know
Posted on
BeoVision 7100
BeoVision 7100
BeoVision 7100
These high quality remote control colour TVs had 8 channels which could be pre-tuned for instant access via the infra-red Video Terminal. Volume level and picture adjustments could also be made without moving more than a finger. Bass and treble tone and picture contrast adjustments were made via the controls sited behind the set’s front fascia.
All models used the 30AX in-line self-converging picture tube with its High Bright characteristics. Bang & Olufsen’s unique Permanent Colour Truth circuitry ensured that the balance between colours was always correct. Together, these features guaranteed a top quality picture that would not deteriorate as the set got older.
Teletext was available as an optional feature on all three models. When fitted, Teletext was accessible via the same Video Terminal used for ordinary entertainment viewing.
Beovisions 5100, 7100 and 8100 came complete with a smooth gliding undercarriage. Apart from screen size and cabinet options, they were technically identical in all respects.
Sound output was 6 watts RMS. Connections were provided for an extension speaker and tape recorder; the tape socket had an alternative function – you could use it to feed the TV sound through your hi-fi system. (From B&O Catalogue Supplement Winter 1982/83)
BeoVision 7100 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1981 - 1984
Colour Options
Please let us know​
BeoVision 7100 Product Specification
Please let us know
BeoVision 7100 FAQs
Please let us know
Posted on
BeoVision 7102
BeoVision 7102
In the days before widescreen, active speakers and Dolby Digital modules, the catalogue of 1985 stated that: “it would be foolish to spend more money that you needed. Why pay for multiple features and facilities when all you wanted was the best possible picture quality, good sound and instant remote access to all available UHF TV channels?”. Unfortunately, those days have long since gone!
The most sensible and economic answer to such a modest set of demands was right there, it stated, in the ‘traditional’ Beovision 5102, 7102 and 8102. All three sets were identical; it was only the size of the tubes that differed. You obtained the same type of picture tube as in the luxury sets (the Beovision 5502, 7702 and 8802 range, for example): automatic colour balance, high reliability… and a bright, clear, natural-looking picture. Sound quality was 6 watts RMS.
The remote control was identical too – the Beovision Video Terminal was used on all of the sets. You could tune across the entire UHF band and store up to 32 station frequencies in the set’s microcomputer memory for instant recall. The Beovision Video Terminal made it easy to control.
Sound output was 6 watts. Connections were provided for an extension speaker and a tape recorder; the tape socket had an alternative function – you could use it to feed the TV sound through a hi-fi system. And connecting a Loop Amplifier would allow a person with a hearing aid to enjoy TV sound more fully.
All three models could be supplied with or without Teletext facilities. The slim-line cabinets were identical in design but offered an alternative in materials and finish: a furniture-crafted wood cabinet finished in rich-grained natural teak or rosewood; Beovision 5102 was also finished in natural grey.
BeoVision 7102 Product Details
Type Numbers
7400 (1984 - Aug 1986)
7420 (GB) (1984 - Dec 1986)
7423 (GB, TXT) (1984 - Aug 1984)
7401 (S, TXT) (1984 - Oct 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
teak or rosewood
BeoVision 7102 Product Specification
Picture tube size: 56cm
Cabinet: grey metallic or rosewood
Number of programmes 32 ( VHF – UHF); range UHF 21 – 69, VHF 2 – 12
Picture tube: 30 AX 110° in line self converging
Start time: approx. 5 sec
Speakers: full range
Sound power output: 6 W
Harmonic distortion: < 0.3 %
Intermodulation: < 2.5 %
Frequency range: +/- 1.5 dB 40 – 20000 Hz
Power bandwidth: 10 – 35,000 Hz
Signal-to-noise ratio: > 55 dB
Bass control: +8 -5 dB / 100 Hz
Treble control: +9 -6 dB / 10,000 Hz
Power consumption 75 (65 – 130) W
Stand-by < 2 W
Dimensions W x H x D 67.5 x 43.5 x 41.5cm
Weight 29 kg
Connections: external speakers (min. 4 ohms)
Tape output: 600 mV / 1 kohms
Amplifier output: 600 mV / 1 kohms
BeoVision 7102 FAQs
Please let us know
Posted on
BeoVision 7202
BeoVision 7202
BeoVision 7202
BeoVision 7202 Product Details
Type Numbers
7500 (1984- March 1986)
7501 (S, TXT) (1984 - Jan 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoVision 7202 Product Specification
Features: Stereo sound. stereo enhancement, bilingual sound
Number of programmes: 32 VHF – UHF
Range: UHF 21 – 69, VHF 2 – 12
Picture tube: 30 AX 110° in line self- converging
Sound power output: 2 x 5 W / 4-8 ohms
Harmonic distortion: < 0.5 %
Frequency range: +/- 1.5 dB 40 – 20,000 Hz
Power bandwidth: 30 – 30,000 Hz
Signal-to-noise ratio: > 5 dB
Treble control: +/- 8 dB / 10,000 Hz
Power consumption: 85 (70 – 160) W
Stand-by: < 2 W
Dimensions W x H x D: 76.5 x 43.5 x 43.5cm
Weight 31 kg
Connections: External speakers 4 – 8 ohms
BeoVision 7202 FAQs
Please let us know
Posted on
BeoVision 7700
BeoVision 7700
BeoVision 7700
Beovision 7700 was a 22″ colour TV with remote control of up to 16 stations. You could also adjust brightness, colour and sound levels – and switch the TV off – without moving from your chair.
True high fidelity sound was a natural accompaniment to the excellent video performance of this set, thanks to a 14 watts sound amplifier and log-line dual speaker system. There were also sockets for connecting optional headphones and an extension loudspeaker, and an additional connection for recording the TV sound on a cassette deck or feeding it through your hi-fi system.
BeoVision 7700 Product Details
Type Numbers
3313 (1981 - Aug 1983)
3323 (B) (1981 - Nov 1983)
3330 (D) (1981 - June 1983)
3363 (D, TXT) (1981 - Jan 1982)
3373 (D, TXT, OSCAR) (1981 - Nov 1983)
3333 (F) (1981 - Feb 1984)
3314 (GB) (1981 - May 1983)
3374 (GB, TXT) (1981 - April 1982)
3414 (GB, VIEW DATA) (1981 - Feb 1984)
3407 (MONITOR) (1981 - Dec 1985)
3334 (MULTI) (1981 - Feb 1984)
3344 (MULTI/OSCAR) (1981 - Dec 1983)
3353 (S, TXT) (1981 - May 1983)
3413 (VIEW DATA) (1981 - Feb 1984)
Designer
Please let us know
Manufactured
1980 - 1982
Colour Options
BeoVision 7700 Product Specification
CTV system IPAL
Picture size: 56cm nominal
Cabinet: wood
Number of programmes: 16 UHF channels 21 – 69
Picture tube: 110 degrees in-line self-converging
Start time: approx 5 seconds
Sound power output: 14 watts
Harmonic distortion: <0,3%
Frequency range +/- 1,5dB: 40 – 20000 Hz
Power supply (50 – 60Hz): 180 – 265 V
Power consumption: 65 – 130W
Consumption at normal use: 75W
Standby: <2W
Dimensions (WxHxD): 67,5 x 43,5 x 41,5cm/29Kg
Finishes: teak or rosewood
Standard features: Undercarriage (34cm high), headphones/ext speaker output, Channel indication, tape/amp output
Optional accessories: Loop amplifier, Teletext decoder, Video FBAS kit
BeoVision 7700 FAQs
Please let us know
Posted on
BeoVision 7702
BeoVision 7702
BeoVision 7702
“As yet, none of us need 32 TV channels, let alone 100. But satellite re-broadcasting systems and cable TV, including regional and community networks, might soon change that” (1983 catalogue)
Therefore, Bang & Olufsen equipped all the luxury Beovision models with an advanced digital tuner that had the capacity for receiving 100 UHF channels, 32 of which could be stored in the set’s microcomputer memory for instant recall at the touch of a button.
The real boon for most viewers is that you could locate, store and recall any of these stations without leaving your armchair. All you had to do was touch a key on the Beovision Video terminal. So although B&O gave its “future-safe” luxury TV range more micro-electronics, more features and more connection possibilities than ever before, they made, at the same time, all the complex technology even more accessible – instantly. To borrow a phrase from the computer industry, Bang & Olufsen’s ’02-Series’ TVs were “user-friendly”.
Beovisions 5502, 7702, 8802 and 9002 all shared the same advanced chassis design and offered the same user-benefits. They were true “luxury” sets because many ‘extras’ offered by other companies, were given as standard by Bang & Olufsen.
The Beovision Video Terminal supplied with Beovisions 5502, 7702, 8802 and 9002 offered a plethora of operational benefits. In addition there was also an advanced ‘tune and store’ function that allowed you to operate the automatic tuning system from the comfort of your chair.
One touch of the ‘tune’ button started the digital tuner scanning the wavelengths of the UHF band. When it found a station, it stopped – giving you the opportunity to either reject or accept it. If it was an unsatisfactory reception from a distant transmitter (or simply a station you don’t like!), you just pressed ‘tune’ again to continue the search. When you found a station you enjoy, on a channel giving a good, clear reception, you could instruct the set’s microcomputer to remember that transmission frequency by pressing ‘store’ followed by your own choice of pre-set programme number (e.g. for BBC2 you might designate pre-set number 2). Thereafter, whenever you wanted to watch BBC2, you simply touch button ‘2’ on your remote Terminal.
Up to 32 different TV stations could be located and stored in this way, so your Beovision really is ‘future-safe’ because it has plenty of spare capacity to accommodate new programme sources as and when they come ‘on stream’.
The latest type of Beovision Video Terminal also had a button marked ‘sound’. This was only effective with Bang & Olufsen stereo TVs – Beovision 7802 and Beovision 8902.
Beovision 5502 had a 50cm screen and measured 62cm wide, 40cm high (71.5cm including stand) and 39cm deep.
Beovision 7702 had a 22″ screen. Dimensions were 67.5cm wide, 43.5cm high ( 76cm including stand) and 41.5cm deep.
Beovision 8802 had a 26″ screen and measured 77cm wide, 49cm high (80cm including stand) and 45.5cm deep.
All three models had slim cabinets finished in a choice of natural teak or rosewood. White finish was available to special order.
BeoVision 7702 Product Details
Type Numbers
7410 (1984 - Dec 1986)
7070 (B) (1984 - Jan 1987)
7072 (D, TXT, OSCAR) (1984 - Aug 1986)
7492 (D, TXT,S-CH) (1984 - Sept 1986)
7450 (F) (1984 - May 1986)
7002 (G) (1984 - July 1986)
7430 (GB) (1984 - March 1987)
7433 (GB, TXT) (1984 - Feb 1987)
3418 (MONITOR) (1984 - Feb 1987)
7470 (MULTI) (1984 - Dec 1986)
7490 (MULTI/OSCAR) (1984 - Dec 1985)
7796 (RGB) (1984 - Aug 1986)
7411 (S, TXT) (1984 - Dec 1986)
7071 (S, TXT, OSCAR) (1984 - Feb 1987)
7798 (VIDEO) (1984 - Sept 1986)
Designer
Please let us know
Manufactured
1984 - 1987
Colour Options
Please let us know​
BeoVision 7702 Product Specification
Range, UHF 21 – 69, VHF 2 – 12
Picture tube: 30 AX 110° in line self-converging
Start time: approx: 5 sec
Speakers:
Woofer: 8cm
Tweeter: 5cm
Log line system
Sound power output 14 W
Power consumption: 75 (65 – 130) W
Stand-by: < 2 W
Dimensions W x H x D: 67.5 x 43.5 x 41.5cm
Weight: 29 kg
Connections: headphones output max. 7.5 V / 200 ohms
External speaker: min. 4 ohms
Amplifier output: 600 mV / 1 komhs
BeoVision 7702 FAQs
Please let us know
Posted on
BeoVision 7802
BeoVision 7802
BeoVision 7802
As yet, none of us still need 32 terrestrial TV channels, let alone 100. But satellite re-broadcasting systems and cable TV, including regional and community networks, may change that.
Bang & Olufsen, in the mid-1980s equipped all their luxury Beovision models with an advanced digital tuner that had the capacity for receiving 100 UHF channels, 32 of which could be stored in the set’s microcomputer memory for instant recall at the touch of a button.
The real boon for most viewers is that you could locate, store and recall any of these stations without leaving your armchair. All you had to do was to touch a key on the Beovision Video terminal. So although B&O gave their “future-safe” luxury TV range more micro-electronics, more features and more connection possibilities than ever before, they had, at the same time, made all this complex technology even more accessible – instantly. To borrow a phrase from the computer industry, Bang & Olufsen’s ’02-Series’ TVs were “user-friendly” (1983 catalogue).
In 1985, to celebrate Bang & Olufsen’s diamond anniversary – 1925 – 1985 – a special edition of Beovision 7802 was released. The television was finished in a dark veneer (ivory-coloured) in place of the standard teak and rosewood finishes.
A small ’emblem’ was included on the top right-hand side to commemorate this special occasion.
Beovisions 5502, 7702, 8802 and 9002 all shared the same advanced chassis design and offered the same user-benefits. They were true “luxury” sets because all the features and facilities which, in other brands, were offered as ‘extras’ were standard in Bang & Olufsen sets.
One touch of the ‘tune’ button started the digital tuner scanning the wavelengths of the UHF band. When it found a station, it stopped – giving you the opportunity to either reject or accept it. If it was an unsatisfactory reception from a distant transmitter you just pressed ‘tune’ again to continue the search. When you found a station on a channel that offered good, clear reception, you could instruct the set’s microcomputer to remember that transmission frequency by pressing ‘store’ followed by your own choice of pre-set programme number (e.g. for BBC2 you might designate pre-set number 2). Thereafter, whenever you wanted to watch BBC2, you simply touched button ‘2’ on your remote Terminal.
Up to 32 different TV stations could be located and stored in this way, so your Beovision really was ‘future-safe’ because it had plenty of spare capacity to accommodate new programme sources as and when they came ‘on stream’.
This latest type of Beovision Video Terminal also had a button marked ‘sound’. This was at that time only effective with Bang & Olufsen stereo TVs – Beovision 7802 and Beovision 8902.
BeoVision 7802 Product Details
Type Numbers
7510 (1984 - May 1986)
7030 (D, TXT, OSCAR) (1984 - May 1987)
7592 (D, TXT, OSCAR) (1984 - Dec 1986)
7007 (G) (1984 - Oct 1986)
7530 (GB) (1984 - Oct 1986)
7533 (GB, TXT) (1984 - Jan 1987)
7570 (MULTI) (1984 - Dec 1986)
7511 (S, TXT) (1984 - May 1986)
7031 (S, TXT, OSCAR) (1984 - May 1987)
7032 (S, TXT, OSCAR) (1984 - Feb 1987)
7577 (TXT, ANTIOPE, MULTI) (1984 - May 1986)
Designer
Please let us know
Manufactured
1984 - 1987
Colour Options
Please let us know​
BeoVision 7802 Product Specification
Cabinet: teak, rosewood veneer, white, black (special edition)
Features: stereo sound, stereo enhancement, bilingual sound
Speakers, 2 set Log Line system: woofer: 10cm, tweeter: 5 cm
Sound power output: 2 x 14 W/ 8 ohms
Harmonic distortion: < 1 % at 15 W, < 0.5 % at 14 W
Intermodulation: < 1 %
Frequency range: +/- 1.5 dB 30 – 20000 Hz
Power bandwidth: 30 – 50000 Hz
Bass control: +/-8 dB / 100 Hz
Treble control: +/-9 dB / 10,000 Hz
Power consumption: 80 (70 – 160) W
Stand-by: < 2 W
Dimensions W x H x D: 76.5 x 43.5 x 42cm
Weight: 31 kg
Connections: headphones output max. 10.5 V / 200 ohms
External speakers: 8 ohms
Video input: 1 Vpp 75 ohms FBAS
Video output: 1 Vpp 75 ohms
Audio input: 600 mV / 100 kohms
Audio output: 600 mV / 1 kohms
BeoVision 7802 FAQs
Please let us know
Posted on
BeoVision 6-22
BeoVision 6-22
BeoVision 6-22
BeoVision 6 – 22 is an LCD 16:9 TV set introduced on 10 November 2003. It is fitted with a 51cm (diagonal) LCD screen which is coated similar to the Avant. Active speakers are positioned at the base of the monitor, similar to the MX range of television sets. The rear of the unit is curved, similar to that of BeoSound 1.
The unit is available in one colour only – Black – and is primarily designed for link-rooms: i.e. as an extra set for the kitchen or bedroom.
BeoVision 6 – 22 may be fitted with a motorised base which turns the set and also regulates the inclination. Standing possibilities include a low floor stand similar to BeoVision 5, wall bracket or a high floor stand high (as with BeoVision 1).
This new LCD TV can be used as a PC monitor, too. When watching normal TV programmes, ‘TV’ on the Beo4 is selected; however, by combining the BeoVision 6 to your PC as a monitor via the rear-mounted DVI socket (see further details at BeoTech) and selecting ‘PC’ on the remote control, BeoVision 6 may be used in conjunction with your home computer.
In 2004 BeoVision 6-26 was introduced to complement this 51cm model.
Press release Struer – November 2003
BeoVision 6 does away with the limits to LCD technology
Bang & Olufsen’s first LCD television is compact, simple and can be placed anywhere. And it also gives a sharp picture, no matter where you are in the room.
A compact television that can be placed… well, where there isn’t any space. A television that can hang on the wall or stand on a chest of drawers, and that can be tilted and turned in all directions – that is the idea behind BeoVision 6 from Bang & Olufsen.
BeoVision 6 is the first television based on LCD technology offered by Bang & Olufsen.
“Nevertheless, LCD technology has been extremely interesting to Bang & Olufsen ever since it came on the market, because it fits in perfectly with our philosophy of compact, simple and stylish televisions – televisions that don’t visually dominate the room you’ve put them in. But not until now has the technology been mature enough for both the image quality and durability to measure up to Bang & Olufsen’s standards,” says President and CEO Torben Ballegaard Sørensen.
A range of technologies patented by Bang & Olufsen, such as Adaptive Black, Motion Adapted Progressive Scan and Digital Adaptive Luminance Peaking, put this LCD monitor in shape to deliver the image quality the company is known for. See the appendix “VisionClear”.
Fits in anywhere
One of the biggest problems of LCD technology has been the restricted viewing angle – in other words, the image is not visible if you look at the screen from an oblique angle. Although LCD technology has made considerable progress in this area, too, Bang & Olufsen’s engineers were still not satisfied.
“Our ambition was to create a television that you could hang somewhere like the kitchen wall. And it would be no good if you could only enjoy it if you were seated at the dining table, and couldn’t see the picture if you stood at the worktop,” explains Sørensen.
The solution was to equip the BeoVision 6 with a range of stands and wall fittings that make it easy both to turn the television from side to side and to tilt it up and down. The tilt function was a challenge to Bang & Olufsen’s developers. The first prototypes were either too clumsy and complicated or they were too difficult to operate. When the answer occurred one day to one of Bang & Olufsen’s engineers, it was so simple that it was difficult to understand why nobody had thought of it before.
A design that allows the television to revolve around its own centre of gravity is both simple and discreet – and at the same time it makes it possible to tilt a television weighing 18 kilos at the push of a finger. The rear of the BeoVision 6 is curved. Visually, this makes it appear even flatter than it is in reality, and at the same time its curved shape makes it possible to turn the television through greater angles, both on and off the wall.
The sound is half the experience
It has always been Bang & Olufsen’s philosophy that the sound is half the experience of a television. For this reason, equal effort has been put into sound and picture in the BeoVision 6. The slightly slanting sound panel under the screen contains two 7,5cm bass reflector speakers and an ingeniously designed bass port. This integrated speaker system gives BeoVision 6 what it takes to deliver a stereo sound that surprises most people!
VisionClear
Bang & Olufsen brings together objective parameters of image quality with subjective elements of viewing comfort into a combined whole, in which the perceived image is unsurpassed. At Bang & Olufsen, the designation VisionClear means that image quality and viewing comfort are inseparable. The exceptionally high image quality is achieved by elements such as Motion Adaptive Progressive Scan, Adaptive Luminance Peaking, Colour Transient Improvement (CTI) and Adaptive Black.
The further development of Bang & Olufsen’s own Adaptive Luminance Peaking system increases the image quality further by reinforcing powerful fields of light in relation to the change in light signal present in the image. This function strengthens large light shifts proportionally less than small ones, resulting in amore uniform visual experience. The Colour Transient Improvement used in BeoVision 6 also ensures a high degree of dimensional precision.
How black is black?
The correct level of black is ensured through the use of advanced Adaptive Black hardware. The right colour setting is obtained by allowing BeoVision 6 to adjust the light automatically while the television is in use. The electronics “read” the image on the screen and automatically increase the colours if the image is very pale, while the technology prevents black details from gradually turning grey during image shift.
Screen, user, surroundings
By focusing on a number of elements, viewing comfort – which involves an interplay between screen, user and surroundings – is accorded a high priority. Automatic image control sensors meter the background light in the room where the television is located, and ensure the best possible image at all light levels. A special anti-reflection-treated contrast screen also reduces the effect of external light incidence by over 80%. The result is that the contrast is markedly improved, which in turn provides a richer screen colour experience. Elements such as Hollywood-like electronic curtains, that open and close automatically, and Active Image Format Optimisation (in which the current screen image is automatically scanned and the best image format then presented on the screen) are included to add extra dimensions to the viewing experience. BeoVision 6 also uses digital noise reduction to decrease the noise in the image.
Mounting Options & Stands
The tilt table mount was available for counter top mounting, designed to allow the bass port on the underside of the TV to ‘breath’. Motorised floor and table stands were complimented by a wall mount bracket which gave manual tilt and turn
BeoVision 6-22 Product Details
Type Numbers
9202 - (UK): I, PAL, SECAM, NTSC on AV
9203 - M/I/D/K PAL, SECAM, NTSC on AV
9205 - B/G, PAL, SECAM, NTSC on AV
Designer
Manufactured
2003 - 2006
Colour Options
Please let us know​
BeoVision 6-22 Product Specification
LCD unit TFT LCD
Screen size 51cm (diagonal) – 16:9
Resolution 1280 x 720 x 3 pixels
Dimensions 591 x 478 x 163 mm
Weight About 18 kg
Power consumption Typical: 90 W – Standby: 0.5 W
Active speakers Bass reflex – one unit per channel
Frequency range 85 Hz – 20.000 Hz
Max. sound pressure level 94 dB
Part Numbers
BeoVision 6, coated glass & PowerLink module as standard
1813819
Table stand
1408166
Motorised floor stand
1408211
Motorised table stand
1408311
Wall bracket
1408466
DVD Controller
1402166
MasterLink module
1401500
RF Modulator module
1401800
BeoVision 6-22 – Full specifications:
Types: 9202, 9203, 9205
Dimensions/ Weight: 59 x 48 x 16 cm / 18 kg
Cabinet finish: Black/aluminium
Remote control included: Beo4
Power consumption: Typically 87 W, stand-by 0.5 W
Picture: 16:9, 22″ TFT LCD
Resolution: 1280 x 720
Contrast screen: Yes, Anti-reflex coated
Teletext: Level 2.5, approx. 2000 pages, Wide Screen Signalling (WSS); VPT (Video Programming by Teletext); 9 memory pages per programme; 17 Teletext languages in 7 groups
TV System:
Type No 9202 (UK): I, PAL, SECAM, NTSC on AV
Type No 9203: M/I/D/K PAL, SECAM, NTSC on AV
Type No 9205: B/G, PAL, SECAM, NTSC on AV
Tuning: 99 programmes, auto-tune, programme move and automatic naming
Tuner range: 45 – 860 MHz, VHF, S, Hyper, UHF
Stereo decoders: A2 + NICAM
Menu languages: English, Danish, Dutch, Spanish, Italian, German, French, Swedish
Set Top Box Controller (STB-C): Built in – Supports one STB (IR-blaster included)
Luminance of white typ. 450 cd/m2 (centre of screen)
Contrast ratio typ. 500:1 (min. 400:1) (centre of screen)
Response time typ. 15 msec.
Viewing angle typ. 85 degrees (min. 75 degrees)
Loudspeakers: Stereo sound
Power amplifier module: 2 units
Frequency range: 85 – 20,000 Hz
Max. sound pressure level: 94 dB
Cabinet principle/ Net volume: Bass Reflex / 1 litre per side
Driver unit: 1 x 90mm cone (per side)
Magnetic shielded: No
Connections Input TV: 1 x 75 ohms aerial female
V.TAPE – AV: 2 x 21-pin SCART sockets
Camcorder/Auxiliary: 3 x Phono sockets (video in/audio L-R in), auto detection (video)
Headphone socket: 1 x Mini jack
Power link: 2 PL connectors (Right and Left)
STB-Controller output: 1 x Mini jack (supports one STB)
PC input: DVI-D connector/audio L-R in
Motorised stand: 5 pole DIN connector
Optional Extra
System modulator: Type 4016 (EU) 4018 (GB)
Master link module: Type 4015
Stands:
Table stand (black):
4081 (type 1408166)
Motorised table stand (aluminium):
4083 (type 1408311)
Motorised floor stand (aluminium):
4082 (type 1408211)
Wall bracket (aluminium):
4084 (type 1408466)
BeoVision 6-22 FAQs
Please let us know
