There were no fussy buttons to spoil the clean looks of Beovision L2802. You controlled it entirely with the Beolink 1000 remote control terminal. Only a discreet red light told you that the TV was ready and awaiting your commands. The flat-square 66cm picture tube gave you a clear, undistorted view, even if you were not sitting right in front of the screen. Bang & Olufsen’s own VisionClear system regulated the colour balance 50 times a second, and in variable light conditions the picture always looked good, with automatic contrast regulation and the contrast screen.
As specialists in good sound, Bang & Olufsen are always very particular about loudspeakers. That is why both Beovision LX and L models incorporated a special bass-reflex speaker system, giving you genuine hi-fi quality to enhance your stereo video tapes. You could also have a NICAM decoder fitted, ready to receive stereo broadcasts of TV programmes.
Beovision LX models had Bang & Olufsen’s powerful Teletext module fitted as standard. However, for the Beovision L2802 and L2502 models, this was left out. This was the only difference between the LX2802 and L2802 models.
L2502 had a 63cm screen; the specifications were the same as the 66cm model.
A classic Bang & Olufsen TV has always been a good investment. However, if you didn’t need the advanced features that Beovision LX had to offer, the alternative TV was the ‘L’ range. It offered same design, same engineering, same quality, but different pricing and different colours.
Beovision LE 6000 and Beovision ME 6000 housed all the basic qualities that were the hallmarks of a Bang & Olufsen TV. However, they lacked some of the more specialised B&O facilities such as Beolink and AV integration.
Both Beovision LE 6000 and were equipped with Black Line picture tubes, which made the picture sharper. A toned-contrast screen in front of the tube enhanced the contrast level, making the picture more pleasant to watch. And Bang & Olufsen’s Colour Transient Improvement improved the sharpness of colour transitions, which eliminated irritating shadows. The powerful loudspeakers – under the screen on Beovision ME 6000 and to the side of the screen on Beovision LE 6000 – were based on the full-tone bass reflex loudspeaker system that gives sound power and fullness. Both were equipped with A2 and NICAM stereo systems.
They had Teletext that could be operated with the help of the remote control. The same remote control operated all video functions, if you connected a Bang & Olufsen video recorder.
Beovision LE6000 came first in ‘oil’ black, with both the ME/LE 6000 models available in the latter stages of production in ‘rubber’ black. Neither model could be connected to a motorised stand.
TV and video in all simplicity
A Bang & Olufsen TV is always a good investment. But perhaps you didn’t want all the highly advanced functions in Bang & Olufsen’s video systems. In that case, you could choose a television like Beovision LS instead. It had the same classic lines as Beovision LX and the quality again was extremely high. There was just a slight difference in design and technical specifications. For example, unlike Bang & Olufsen’s video systems, Beovision LS and its VCR partner, Beocord V3000, could not be included in a Beolink® system.
Beovision LS was available as a 66cm or a 63cm TV – the LS5500 and LS4500 (as well as two further models – LS5000 and LS6000). All materials were of the finest quality and as always, attention to detail was meticulously made. For example, it was real wood that was used in the rosewood model and not plastic laminate. The glass screen in front of the picture tube was made of a high-quality glass, from Europe’s leading glassmaker. It served two functions: it captured the light reflections that struck the screen, minimising their effect on the picture. And at the same time, it unified the appearance of the television.
Picture and sound in high quality
You obtained the same distinguished picture on a Beovision LS as on the more advanced TVs in Bang & Olufsen’s range. The philosophy behind Bang & Olufsen’s TV picture is that it should appear as natural as possible. One of the reasons for this choice is that your eyes tire quickly if colours are too strong. In comparison with other brands, this philosophy can make a Bang & Olufsen picture seem less like a picture postcard. But Bang & Olufsen would rather be compared to reality than to glossy reproduction.
The sound in Beovision LS4500 and LS5500 also lived up to the expectations you had for a Bang & Olufsen TV. The amplifier in the built-in two-way bass-reflex speakers was, in fact, the same fine quality that was used in audio systems.
Beovision LS5500 66cm television was the result of generations of development and provided superb natural colour which is balanced automatically up to 50 times every second. Its powerful loudspeakers were set smoothly on each side of the screen which stretched from the very top to the bottom of the cabinet. Fast Teletext access was provided together with, satellite compatibility and NICAM digital stereo sound including Beolink 1000 remote control.
Beovision LS5500 could be happily married to Beocord V3000 video cassette recorder and both Teletext and NICAM stereo sound were standard on both the Beovision LS4500 and LS5500.
Beovision LS5000 and LS6000 TV and video in all simplicity
Beovision LS was available as a 66cm or a 63cm TV – the LS5000 and LS6000 (as well as two further models – LS4500 and LS5500). All materials were of the finest quality and as always, attention to detail was meticulously made. For example, it was real wood that was used in the rosewood model and not plastic laminate. The glass screen in front of the picture tube was made of a high-quality glass, from Europe’s leading glassmaker. It served two functions: it captured the light reflections that struck the screen, minimising their effect on the picture. And at the same time, it unified the appearance of the television.
The sound in Beovision LS5000 and LS6000 also lived up to the expectations you had for a Bang & Olufsen TV. The amplifier in the built-in two-way bass-reflex speakers was, in fact, the same fine quality that was used in audio systems.
Beovision LS6000 66cm television was the result of generations of development and provided superb natural colour which is balanced automatically up to 50 times every second. Its powerful loudspeakers were set smoothly on each side of the screen which stretched from the very top to the bottom of the cabinet. Fast Teletext access was provided together with, satellite compatibility and NICAM digital stereo sound including Beolink 1000 remote control.
Beovision LS5000 and LS6000 could be happily married to Beocord V3000 video cassette recorder and both Teletext and NICAM stereo sound were standard on both the Beovision LS5000 and LS6000.
With its 63cm screen, Beovision LX2500 was the smallest member of the LX family in 1987. But no sacrifices were made in sound and picture excellence, nor was Beovision LX2500 ever caught out by new technical developments. No Master Control Link or additional speakers were required when installing a Beovision LX say, in the bedroom. The set came fully-equipped with a Master Control Link and all sound from the central music system could be fed through the TV speakers
Installing a Beovision LX2500 in a study placed communication and information at your fingertips. Using a Beolink 1000 remote-control Terminal you could remote control and utilise all the features of the central system, including Teletext TV and video. And adding a home computer, video games and printer to the Beovision LX2500 used advanced electronics in a thoroughly practical way.
Beovisions LX2800 and LX2500 were identical in every detail except for the size of the picture screen.
Two television sets that were available but without Teletext, hi-fi sound or extra connection facilities were the Beovision L2800 and L2500. Other than these extra features, L2800 and L2500 were identical to the Beovisions LX2800 and LX2500.
Beovision Beovisions LX2800 and LX2500
Designed by David Lewis, the televisions were released in 1986. At the time, the LX range was special as it was the first type of television to include a contrast-screen and automatic picture control called VisionClear. It was controlled by a ‘V Terminal’, the forerunner of Beolink 1000. It was also the first TV range with an Audio/Aux Link and hi-fi speakers.
Beovision Beovisions LX2800 and LX2500 features:
Flat-square picture tube. Part of the VisionClear system which provides picture of studio quality
In-line self-converging picture tube, also part of the VisionClear system. Reduces the chance of inadvertent mixing of picture colours and ensures perfect pictures throughout the life of the TV.
Automatic Cut-off – yet another part of the VisionClear system. An electronic circuit which adjusts the colour balance 50 times every second. A patented Bang & Olufsen innovation which ensures that you get lifelike colours – automatic and operates all the time.
Contrast screen – the most visually outstanding part of the VisionClear system. A Bang & Olufsen screen which reduces the effect of incident light. This ensures clear colours and optimum contrast conditions even in bright light.
Automatic contrast control – the picture’s contrast level is automatically adjusted to match the light levels in the room.
Remote-controlled channel tuning – included all relevant TV channels. You could use the buttons on the Beolink 1000 terminal to order the frequency of a specific TV channel and let the electronics take care of search, tuning and fine tuning. With the exception of the automation, it was the same search system that you used when you wished to find a new station on your radio.
AFC – A circuit that ensures perfect fine tuning and operated completely automatically.
Fine tuning – a manual feature which gave you access to sharp, stable pictures when reception conditions were poor or if the frequency of a signal deviated from standard settings e.g. in the case of cable TV, home computers etc. Fine tuning adjustments could of course, be stored in the memory.
2 x 15 watts sinus power output – the newly developed LX2800 and LX2500 speakers were based on the bass reflex system which gave the sound image extra depth and detail in hi-fi quality.
When there was a simulcast you could also send sound from the radio out through the speakers of Beovisions LX2800 and LX2500.
Stereo width adjustment ‘increased’ the distance between the speakers and gave a wider, richer sound image.
Enhanced mono broadcasts – the special stereo width circuit also improved the sound quality of mono broadcasts.
Extra hi-fi speakers – you could use the speakers on Beovision LX2800 or LX2500 as an extra pair of speakers for your hi-fi system as part of a Beolink® system.
Built-in Teletext decoder – the (then) new, ‘flickerless’ computer-controlled Teletext decoder (CCT) meant that you had the latest news right at hand as well as a whole host of information channels.
Computer-controlled Teletext (CCT) – had two memories so you could immediately ‘leaf’ up to two pages ahead on Teletext or back to the previous page. One touch and no waiting. Another memory store remembered up to four pages of Teletext information and provided immediate access to the TV listings or the complete Pools results, for example. This short-term memory was erased when the TV was returned to stand-by.
Three Teletext alphabets – if you received Teletext from a country with an alphabet that differed from your own, the Teletext alphabet switched over automatically.
Video recordings of Teletext subtitles – for the first time ever, it was possible to record the Teletext subtitles along with the TV programme itself. This was a big help for the hard-of-hearing
Completely stable and ‘flickerless’ picture from home computers and TV games.
Built-in clock – When Teletext was broadcast, you could bring the correct time on-screen, either for a few seconds or for as long as you liked.
Advanced TV technology at its most elegant
Beovision 2802 was the latest version of the classic Bang & Olufsen TV. Fully remote controlled, it was created specially for those who require all the features of today’s TV – and who also seek a timeless design that would blend perfectly into their living environment. Slim and elegant, Beovision LX2802 came in either traditional natural woods or a contemporary white finish.
To the finest detail
B&O is renowned for its attention to detail and craftsmanship. You won’t find any fussy buttons on B&O’s sets – because, with full remote control, they simply aren’t necessary. Absolutely nothing looks out of place or superfluous with a Bang & Olufsen TV. The materials are always selected with the utmost care. The closest attention is always paid even to the design of the back of the TV. The company believes that appearances matter a great deal, because you’ve got to live with a TV day in, day out. On or off, it should be easy on the eye.
The perfect picture – from any angle
You don’t have to sit bang in front to get a good view of Bang & Olufsen TV sets. The 66cm flat-square picture tube of these Beovisions gave a clear, undistorted picture even when viewed from the side. Combine that with the specially developed VisionClear system, and you’ve got eye-opening picture quality. The colour balance and contrast are regulated automatically, 50 times every second. There’s even a contrast screen to make sure that your picture’s always in harmony with the light levels in the room. Razor-sharp quality – and it’s built to last.
