Beocord Stereomaster was a reel-to-reel tape recorder which was novel for its time in that it had an Automatic Stop Function for if the tape should break during play. There were two variations – Type T was designed to be transportable; Type K was designed for a more static position.
The tape recorder is ready just to plug in as the connections have been built in the bottom of the furniture cabinet.
The new B&O Beocord Stereomaster Tape Recorder is the ideal recorder for the discriminating tape amateur. For the first time in the world you can have an amateur tape recorder with a built-in mixing panel for simultaneous mixing of three input signals.
Here, for the first time, is an all-transistor Hi-Fi tape recorder comprehensive professional specifications, including:
Synchronous motor of the Pabst type
Separate recording and playback heads
Recording quality may be checked at any time, either before recording (at the recording amplifier output) or after (at the tape monitoring amplifier output)
Equipped with two V. U. meters.
Three dual-input channels with slide-potentiometer adjustment.
Professional standards for speed, wow and flutter.”
BeoCord StereoMaster Product Details
Type Numbers
Please let us know
Designer
Please let us know
Manufactured
1963 - 1964
Colour Options
Please let us know
BeoCord StereoMaster Product Specification
Signal-to-noise ratio 1/2 track: better than 55 dB 1/4 track Better than 50 dB Power Consumption, Motor 27 W Power Consumption, Amplifier No signal: 8W. Full volume: 20W Bias Current, AMPEX 521 ½ track: 2,3 mA. 1/4 track: 1,9 mA BASF LGS 35 ½ track: 2,6 mA. 1/4 track: 2,1 mA Recording Characteristic DIN 1962 Channel Separation Better than 45 dB Supply Voltage Switchable between 95, 110, 125, 205, 220 and 235 V, 50 c/s
Erase Frequency 100 kc/s Reel Diameter Max. 18 cm Number of tracks 2 or 4 tracks Tone Control Range + 10 dB at 50 c/s + 10 dB at 10,000 c/s Power output 22 8W, harmonic distortion < 1% at 5 W Line output voltage 800 mV + 4 dB (47 k ohms) External speaker Impedance: 4 ohms Weight Type K: 16 kg Type T: 18 kg
Dimensions, Type T (Transportable model) 45 cm width 35 cm depth Height inclusive of speakers: 27cm Height exclusive of speakers: 19cm
Dimensions, Type K 45 cm width 35,5 cm depth Height inclusive of lid: 21cm
Beocord 3500 was part of Beosystem 3500, a budget-priced system for those who wanted to get onto the Bang & Olufsen bandwagon but could not afford, or did not want to have, the extra features that say, Beosystem 4500 had to offer.
It included specifications such as Dolby B Noise Reduction and a Sendust head for longer life of the recording/playback head, otherwise the features were identical to the Beocord 4500. Its only difference was the grey finish instead of its more expensive brother’s polished surfaces.
BeoCord 3500 Product Details
Type Numbers
4966 (1990 - March 1994)
4967 (GB) (1990 - Feb 1993)
4968 (USA) (1990 - March 1991)
Designer
Please let us know
Manufactured
1989 - 1993
Colour Options
Grey, Black
BeoCord 3500 Product Specification
Compact cassette: C46-C60-C90-C120 Recording system: HX PRO Direct operation: Sensi touch Tape transport system: Auto reverse Search system: Track numbers Noise reduction system: Dolby B NR Tape switch: Auto ferro/chrom/metal Tape head: Sendust
Wow and flutter DIN: <+/- 0.15% Fast forward and rewind: C60 75 sec Frequency range chrome: 30 – 18,000 Hz +/- 3 dB
Signal-to-noise ratio CCIR/ARM: Metal Dolby B NR: >64 dB Chrome Dolby B NR: >63 dB Ferro Dolby B NR: >62 dB
Power supply: 4961 220V 4962 240V 4963 120V 4964 100V 4965 240V Power consumption: 18 W Dimensions W x H x D: 42 x 7 x 24.5cm Weight: 4.5 kg
Connections: AudioLink
