Posted on
Terminal 3300 Remote Controller
Bang & Olufsen Terminal 3300 Remote Controller
The Terminal 3300 could be seen as a transitional model as though it kept the Beosystem remote design, it did in fact use the Beolink 1000 codes and a Beosystem 3300 can be operated using a Beolink 1000.
Terminal 3300 Remote Controller Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1986 - 1989
Colour Options
Grey
Terminal 3300 Remote Controller Product Specification
Please let us know
Terminal 3300 Remote Controller FAQs
Please let us know
Posted on
Terminal 5000 CD Terminal (CD 50)
Bang & Olufsen Terminal 5000 (CD 50) CD Terminal
Rarely seen remote that was an optional accessory for the BeoGram CD50. This required an optional board to be fitted so finding the remote is only the easy part!
Terminal 5000 CD Terminal (CD 50) Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1985 - 1986
Colour Options
Please let us know​
Terminal 5000 CD Terminal (CD 50) Product Specification
Please let us know
Terminal 5000 CD Terminal (CD 50) FAQs
Please let us know
Posted on
Terminal 5000 Remote Controller
Bang & Olufsen Terminal 5000 Remote Controller
A small remote for use with the Beosystem 5000, this followed the same design as the earlier one way system remotes and was one way, controlling basic functions. Actually very useful as the MCP 5000 was too heavy to casually carry around!
Terminal 5000 Remote Controller Product Details
Type Numbers
2039 (1983 - 1986)
Designer
Manufactured
1983 - 1986
Colour Options
Grey
Terminal 5000 Remote Controller Product Specification
Dimensions: 6 x 4 x 17cm
Radio programmes: 6 FM or AM
Other programmes: PH-T1
Beocord Controls: 4
Beogram Controls: 1
Compact Disc Controls: Yes
Volume Control: Yes
Muting: Yes
Terminal 5000 Remote Controller FAQs
Please let us know
Posted on
Terminal 6000 Remote Controller
Bang & Olufsen Terminal 6000 Remote Controller
Terminal 6000 Remote Controller Product Details
Type Numbers
2035
Designer
Please let us know
Manufactured
1981 - 1987
Colour Options
Please let us know​
Terminal 6000 Remote Controller Product Specification
Radio programmes: 7 FM
Beocord Controls: 6
Beogram Controls: 1
Volume Control: Yes, 3 preset
Muting: Yes
Reset: Yes
Terminal 6000 Remote Controller FAQs
Please let us know
Posted on
Video Terminal
Bang & Olufsen Video Terminal
Video Terminal
Your key to operational comfort
Around half of Bang & Olufsen’s colour TVs in the late 1970’s and early 1980’s were supplied complete with an advanced remote control handset – the Beovision Video Terminal. It was called a Video Terminal because it did so much more than just switch on the set or change programmes for you.
For normal entertainment viewing you simply touched the required programme number. Volume level, colour strength and picture brilliance could be adjusted up and down as desired – or returned instantly to a pre-determined norm by pressing RESET. You could even mute the sound instantly (perhaps if the phone rang) or check through the programmes showing on all the other channels – all at the touch of a single button.
The same terminal also controlled Teletext viewing on sets fitted wit the optional Teletext circuitry. And for those who chose to include Bang & Olufsen video cassette recorder (like Beocord Video 8800) as part of their domestic entertainment system, the controls for operating all the primary VCR functions were also right there in your hand. The Terminal let you make recordings, play the tape or wind it to any position without having to move from your comfortable armchair.
The Beovision Video Terminal was supplied with, for example, Beovisions 5100, 7100 and 8100. The Terminals for other models in the B&O range included all these keys and functions plus three more. Of course, it was still possible to operate a Beovision even if the remote Terminal was temporarily mislaid or out of action. The set’s direct controls were mounted in a hinged compartment behind the loudspeaker grille. The panel pivoted outward at a touch and in addition to the direct function controlled governing picture and sound adjustments and programme scanning, it contained the buttons for pre-tuning the buttons. Your dealer could use these to tune the set as part of the installation service. Thereafter you would probably never need to touch them again.
Video Terminal Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1981 - 1987
Colour Options
Bronze
Video Terminal Product Specification
Dimensions: 3,5 x 2,5 x 21cm
TV programmes: 32
TV Channels: 21 – 69
Satellite & AV:3
Video Tape: 6
Teletext: 6
Controls: Volume
Controls: Brilliance – Colour
Stand-by: Yes
Video Terminal FAQs
Please let us know
Posted on
MMC1
Bang & Olufsen MMC1
MMC1
The MMC1 was the top of the range of B&O’s new cartridge range.
It was only available as an upgrade – even the top of the range Beogram 8002 was only fitted with the MMC2. The MMC1 had a line contact diamond mounted on a tubular sapphire cantilever.
The tubular construction offered less weight than a solid cantilever but with immense stiffness. The diamond profile was similar to that of the MMC20CL being line contact. The way to look at these cartridges was to imagine an elliptical profile but with both the front and rear facets being scooped out. In this way the vertical contact surface was maximised and the horizontal element kept to a minimum.
The MMC1 and MMC2 were essentially the same cartridge with the MMC1 using the best specified diamond tips. The MMC system was carried over from the SP series but taken to an even smaller level.
MMC1 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1984 - 1996
Colour Options
Silver and Black
MMC1 Product Specification
Description Nude multi-radial Contact Line diamond, mounted on a sapphire cantilever
Tracking force – grams 1
Diamond Stylus Cont. line nude
Cantilever tube Sapphire Effective tip mass mg 0,25
Compliance mg/mN 30
Frequency 20-20000 Hz=/-dB 1
Channel separation 1000>dB 30
Output mV/cm/s RMS 0,6
Cartridge weight gram 1,6
MMC1 FAQs
Please let us know
Posted on
MMC2
Bang & Olufsen MMC2
MMC2
The MMC2 was the replacement in the B&O line up for the very successful MMC20CL.
Like the MMC1, it boasted a sapphire tubular cantilever and line contact diamond. It was fitted as standard to the top of the range Beograms such as the 8002 and the 7000.
MMC2 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1985 - 1996
Colour Options
Silver and Black
MMC2 Product Specification
Effective tip mass mg 0,3
Compliance mg/mN 30
Frequency 20-20000 Hz=/-dB 1,5
Channel separation 1000>dB 25
MMC2 FAQs
Please let us know
Posted on
MMC20CL
Bang & Olufsen MMC20CL
MMC20CL
The top of the range cartridge from B&O, this boasted a single crystal sapphire cantilever and a Contact Line stylus derived from the Pramanik stylus of the MMC6000.
This cartridge was well thought of by many outside the normal B&O user base and was favourably reviewed in many magazines. It achieved something not many B&O products ever managed – it was described as offering value for money!!
MMC20CL Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1979 - 1985
Colour Options
Silver
MMC20CL Product Specification
Please let us know
MMC20CL FAQs
Please let us know
Posted on
MMC20E
Bang & Olufsen MMC20E
MMC20E
Prior to the release of MMC1 – 5 cartridges, Bang & Olufsen had the following MMC range of combined styli and cartridges:
MMC cartridges were available with standard ½” mounting brackets, or with easy plug-in, lightweight connectors. These enabled you to mount MMC cartridges onto non-Bang & Olufsen arms. The cartridges plugged directly into Beogram pickup arms without additional mounting gear
MMC 20 S was a stereo cartridge with a spherical framed diamond
MMC 20 E was fitted with a framed elliptical diamond which has a high polish
MMC 20EN had a naked elliptical diamond, mounted on a tiny tapered cantilever
MMC 20 CL utilised a Contact Line naked diamond mounted on a single crystal sapphire cantilever. This shape ensures maximum groove contact. This was the most highly-specified cartridge in the MMC 20 range
In 1958, Bang & Olufsen introduced the first stereo pickup cartridge ever made in Europe. This was called the SP1. Since then, many design innovations and the creative use of new materials have kept B&O’s cartridges at the forefront of audio technology. By 1979 – 80, Bang & Olufsen’s cartridges were represented by the MMC 20 series. MMC stands for ‘Moving Micro-Cross’; the patented moving-iron principle upon which all B&O cartridges were based. This unique system employed a cross-shaped armature which, among other advantages, guaranteed exceptional stereo separation since each channel moves on a separate axis.
The job of any pickup cartridge is to transform the record’s physical profile (groove modulation) into corresponding electrical signals (which are then amplified or enlarged by the amplifier and turned into audible sound waves by the loudspeaker.
A cartridge must perform three separate and exacting tasks if it is to do this job successfully. It must function mechanically (the movements of the stylus in the groove); it must function magnetically (using the physical movements to create changes in a magnetic field); and it must function electrically (using the changes in magnetic flux to generate an electrical current). At each stage, one type of energy is transferred into another, quite different, type. And the transfer must be perfect, with no energy lost and none added from extraneous sources.
No cartridge will ever reach this ideal unless the Laws of Physics can be repealed. However, by understanding the relationships between the three transfer stages and continually applying refined engineering techniques, B&O’s belief was that each stage of cartridge improvement would bring each successive cartridge closer to the ideal. The MMC20 series therefore represented the closest that modern technology at that time, could possibly afford.
Record wear and the cartridge
If you take music seriously the value of your record collection is likely to be high. Many of your records are likely to be irreplaceable. You will also know that the signals pressed into your vinyl discs are very fragile indeed. The pickup cartridge can be the disc’s worse enemy since an ill-suited cartridge can mark a record for life in a single play.
While B&O is aware that cartridge specifications are inter-related, their research shows consistently that Effective Tip Mass (ETM) is one of the major factors affecting record wear. ETM is the equivalent of the amount of inertia the groove ‘sees’ in moving or accelerating the stylus tip. Consequently, the higher the ETM value, the higher the force required for a given constant acceleration. Obviously, more force results in more wear.
Three elements contribute to ETM. The stylus tip (diamond) contributes with its entire weight and mass. The armature contributes between 5 – 20% of its weight and mass; the cantilever around 30%. B&O has been able to reduce ETM substantially by refining these elements and building them into an integrated unit. The result is a system which not only reduces damage to the groove walls dramatically, but also provides exceptional performance at all frequencies.
Bang & Olufsen cartridges have always been highly acclaimed for their low ETM values. The ETM of the MMC 20CL is a mere 0,3mg and in the standard MMC 20 range,, only 0,5mg.
MMC cartridges were manufactured by Bang & Olufsen as totally integrated units. This means that the elements were matched, balanced and sealed at the factory. Using a computer-supported testing programme,, each sealed unit was meticulously tested and it’s performance information automatically registered and packed with each cartridge. The information given included output voltage, relative voltage output (channel balance), channel separation and frequency response. Individually-calibrated frequency response curves were also supplied with the higher-specified MMC 20CL cartridges
MMC20E Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1979 - 1985
Colour Options
Black
MMC20E Product Specification
Please let us know
MMC20E FAQs
Please let us know
Posted on
MMC20EN
Bang & Olufsen MMC20EN
MMC20EN
The MMC20EN was the standard cartridge fitted to the top of the line Beogram 4002 and 4004.
It was a development of the very successful MMC4000 and retained the naked elliptical diamond stylus seen on that model. A fine tapered cantilever was also fitted and provided excellent performance.
MMC20EN Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1979 - 1985
Colour Options
Silver
MMC20EN Product Specification
Please let us know
MMC20EN FAQs
Please let us know
