Posted on
LC2 Light Controller
A part of the Bang & Olufsen complete home entertainment solution is the light control system which allows for the adjustment of light-settings of a single lamp, room or entire house with a Beolink® remote control.
You can also program local and global light-settings so that when you press ‘LIGHT’ and ‘1’ on the relevant remote control all the lights in the room adjust to their preset lux-settings which are stored in memory-location ‘1’. Nine local light settings can be stored with the dimming of each light unit being made individually.
Posted on
Control Center VTR
Bang & Olufsen BeoCord VX7000
The Control Center VTR was a special version of the Beocord VX 7000. It fitted neatly and unobtrusively in the AV 9000 Control Center and provided similar functionality to that offered by the VX 7000. There were a few differences though. Firstly, the tape transport keys were replaced by two sensi-touch fields, one for rewind and one for eject. Secondly (and inexplicably), the “track” mode had been removed from the digital display on the front of the machine.
The Control Center VTR was uprated alongside the Beocord VX 7000, and in particular was modified to use the Beo 4 remote control when this became available.
The Control Center VTR was withdrawn alongside the rest of the Beosystem AV 9000. The AV 9000 was replaced by the Beovision Avant, which was fitted with an integrated video recorder, so a new version of the Control Center VTR was not necessary.
Posted on
BeoLink Active
BeoLink Active
This comprises a control box, an IR receiver and a mains lead.
This allowed the connection of active BeoLab speakers which would then have independent control of volume and tone settings. Both audio and video sources could be selected and there was also the option of using the Beolink receiver to enable the Timer, alter the volume and enable play or initiate Stand By.
Posted on
BeoGram 3000 (1967) Thorens
In 1967, B&O found themselves with a world leading Hi-Fi system in the Beolab 5000 but no suitable source for the reproduction of LPs. In a move now commonplace, they simply outsourced and used the motor unit of the Thorens TD124 Mk II – probably the best available to them at this time. They added their own ST/L arm and re-christened it the Beogram 3000.
This deck was sold in those areas allowed by Thorens which initially did not include the UK. A different model was supplied there.Highly sought after by collectors now despite really having little to do with B&O! Some even dispensed with the B&O arm and use an SME tone-arm.
These days the Beogram 3000 Thorens is a sought after model, offering probably the best performance of any Beogram. Because it is basically a Thorens deck, parts are readily available in re manufactured form.
The standard arm was the ST/L but a few were fitted with the rare ST/P arm. This was a 12″ arm but used the earlier SP2 cartridge rather than the SP8 which was fitted to the ST/L when used in the Beogram 3000.
The lid fitted was a lift off device and was high to clear the lift mechanism of the arm.
Posted on
BeoGram 3000 (1985)
BeoGram 3000 (1985)
Beogram 3000 was a specially designed tangential record deck with a lightweight tone arm featuring the patented suspension system – Optimum Pivot Point – which prevented internal vibrations from interfering with sound reproductions.
Beogram 3000 had an MMC 4 pick up for optimum sound and minimal record wear. A record sensor automatically record size and with it, the correct speed. The platter reduces static electricity and thereby dust in the grooves, and the pendulum suspension made Beogram 3000 ‘danceproof’. The search system worked both forwards and backwards and the new Active Light system was all automatic, giving you light when you needed it, for searching and changing your records etc.. A repeat function allowed you to play the same record up to 7 times in a row.
Beogram 3000 was designed to be used within Beosystem 3000. Beogram 3000 does not have a built in RIAA amplifier and relies on this being in the receiver used with it. Beomaster 3000 – which this deck was designed to work with – has the RIAA built in as do almost every receiver before this time, including the Beomaster 8000. Later equipment such as the Beomaster 7000 and Beomaster 3500 and Beomaster 4500 transferred the RIAA to the record player as this allowed a longer cable to be fitted to the record player and gave better siting options.
Posted on
Beoplay Eleven
High-fidelity ANC earbuds
Beoplay Eleven wireless earbuds boast improved noise cancellation and multipoint Bluetooth for a seamless listening experience anywhere.
Hear. Stand out.
Beoplay Eleven catches eyes as well as ears with a gem-like touch surface. A masterclass in precision craft. Fashioned from exclusive hardened glass, cool to the touch. Put your high-fidelity earbuds to rest in your pearl-blasted aluminium case – though you’ll rarely want to.
A sound fit
Play with ease and wear with comfort. The soft in-ear piece, made of premium silicone that moulds to you. So light. So poised. So comfortable you’ll want to keep them in.
More music, less noise
Beoplay Eleven wireless earbuds boast our best noise cancellation technology in an earbud to date – further refined by our cunning pressure-relief outlets. Turn off your surroundings. And when you need it, our improved Transparency Mode brings you back with just a tap.
Clearer call quality
Large crowd or stubborn wind, it’s all the same to Beoplay Eleven. We’ve dialled up the calling experience with a slightly larger-than-usual microphone inlet, for clearer quality. Padded with a fine mesh that effectively filters wind from voice.
Powerful, portable sound
Portable sound should take you places. And power’s the kicker. This little jewel sports a 9.2mm driver in each earbud. In any environment.
Dust and waterproof
When it rains, Beoplay Eleven still delivers impeccable sound. An IP57-rated build means it’ll stay dry on the inside and blocks sand and particles.
Posted on
Master Control Link 30 – MCL30
Master Control Link 30 makes it possible for you to have music all over the house from a BeoSystem 3000
Remote control of all primary functions in the BeoSystem 3000
Can also be used for the BeoSystem 6000
Connection of up to 4 link units
Easily mounted with only one cable
wide range of installation accessories
MCL30 can convey the operation from the terminal 3000.
With a loudspeaker button on the Master Control Link you activate the loudspeakers in the link room, and not you can operate all the functions from the terminal 3000.
There is a wide range of accessories. How and for what they should be used is described in the Master Control Link handbook.
Note that there can be connected 4 link rooms, and that the total length of the cable should not exceed 150 meters.
When connected to BeoMaster 6000, MCL-kit type 1006/1007 should be used as well.
Posted on
BeoVision M 20
BeoVision M 20
“The device appears as a well-formed cabinet from the front. From the rear, the encapsulation of the picture tube is so well done that the device may be enjoyed from all angles. The stacked-build of the device makes it possible to place it in a corner. Technically it contains many new functions, including the integration of a contrast screen that reduces disturbances from incoming light.”
So wrote The Danish Design Council when presenting their 1986 ID prize for exceptional design to David Lewis and Bang & Olufsen for the Beovision MX 2000. Launched in season 1984/85 as Beovision M20, the basic conceptual elements of the Beovision MX exist virtually unchanged into the 21st century, with 2002’s release of Beovision MX8000.
“Beovision MX2000 gives the impression of lightness and extended freedom of positioning. Now, all of a sudden, the TV could be positioned anywhere – even in the middle of a room”
The MX concept began as Beovision M20 in a modest grey cabinet and without a contrast screen. It sort of heralded what a monitor television by Bang & Olufsen might look like. Basically, a monitor is just a screen with a box around it. In the mid-1980s, the emphasis was on the picture and efforts to achieve a monitor look. The clean screen. Bang & Olufsen elected to make the television slim by placing the loudspeakers below the screen. This broke with the practice of several decades of placing the loudspeakers at the sides of the picture tube.
The latest MX 8000 model incorporates active loudspeakers and the sound has become even better. Previously, and with its Beovision MX 7000, Bang & Olufsen introduced yet another element that, so far, is unique to he company: a motorised base. Now the television turned to face the viewer – not vice versa.
Bang & Olufsen had a lot of difficulty explaining Bang & Olufsen’s picture quality, which comprises many individual factors that have been optimised over the years. In 1985 – 86, the decision was made to combine everything that came under the term “picture quality” into a single concept – VisionClear. MX2000 was born out of the ideas for the M20 and was further equipped with VisionClear, including a contrast screen. The MX family became extremely popular and remains so (it is still being produced and sold). Designer David Lewis created a cabinet that fitted around the back of the picture tube, thereby achieving the purely psychological effect of making the picture tube appear smaller than it actually is. Beovision MX 2000 gave the impression of lightness and extended freedom of positioning. Now, all of a sudden, the TV could be positioned anywhere – even in the middle of the room.
Bang & Olufsen’s first television in the the US market was a variant, Beovision MX 5000 US. But, because of sales factors and market conditions at the time, it was not a great success.
Big sound
In 1984, TV sound was produced by passive log-line loudspeakers, producing either stereo or mono sound. Whether coming from a television programme or VHS, Betamax or Video 2000 VCR, it was only experienced as coming from the TV itself. Today, multi-channel surround sound systems provide enveloping sonic experiences in the home. Back then the user listened to two 7-watt speakers in the TV itself. Today six powerful active speakers are becoming more and more popular.
In 2002, important dialogue emerges from the powerful active loudspeakers which, following the original MX design, are sill located directly below the screen.
