Posted on
BeoMaster 8000
Bang & Olufsen BeoMaster 8000
Beomaster 8000 was an advanced FM receiver with a rated output of 2 x 150 watts IHF A-202. It had the power, precision and overall performance to reproduce all types of music with the utmost fidelity.
The radio section united the principle of the modern digital frequency synthesizer tuner with a precise, automatic fine-tuning system to give unparalleled accuracy and long-term stability of reception. The set’s control panel gave instant access to all sound sources – an associated record deck and two tape decks and any of 9 user-programmable FM stations. The visual feedback indicated which sources were playing and their volume settings. Controls for secondary functions were protected beneath a hinged lid.
The infra-red BeoLab Terminal was for its time, complex technology tamed. It gave easy, direct access to music and allowed the control of a musical experience from anywhere in your room and operate Beogram 8002 and Beocord 8004 if these were part of your system. A single touch is all there was between what you wanted and the fulfilment of your wish. Radio programmes, cassettes and records were all available at the touch of a button.
In the early 1980s the technical quality of records, tapes and FM transmissions was vastly improved. Improvement meant increased dynamic range.
Increased dynamic range in sound sources makes great demands on hi-fi components. They must accommodate a greater range of tones: from the very faintest tinkle of a triangle to the loudest roll of the bass drum; and reproduce each tone accurately. This requires powerful, serious hi-fi components. Power to accommodate the dynamics, and accuracy to ensure that the fundamentals and harmonics of each tone are reproduced faithfully, i.e. with the intervals and relative intensity that gives each instrument its characteristic quality.
The 2 x 150 watts RMS Beomaster 8000 high fidelity FM receiver had the power, precision and overall performance level to help you achieve this goal. Up to the time of its introduction, it was Bang & Olufsen’s most accomplished receiver to date. During its construction phase, the company focused on one major goal: that none of its circuits or components should be able to limit or distort the sound signals it received before the amplifier’s power output level was exhausted.
In accordance with this, a special circuit registered, and the “clipping” function indicated when you should regulate volume level, if you wanted to ensure continued undistorted sound. Volume was controlled by a 60-step electronic attenuator. This regulated both channels together, in balance, and allowed precise adjustments.
A digital frequency synthesizer tuner was incorporated. It was a further development of other constructions since this tuner locked stations onto their actual transmission frequencies, rather than using a mere internally-generated frequency reference.
Beomaster 8000 had the most comprehensive user-programmable facilities imaginable. They were placed out of view in the programming compartment because you didn’t need to use them every day. The primary controls were external. To keep you informed, whenever the music system was in use, the status of the primary settings was displayed on the Beomaster’s large communication panel. Beomaster 8000 formed the heart of the Beosystem 8000.
Posted on
BeoMaster 901
Bang & Olufsen BeoMaster 901
Beomaster 901, by 1977/78 was Bang & Olufsen’s simplest receiver. However, no compromises were made on quality. The tuner section covered Long, Medium and FM wavebands with a very high standard of reception quality.
Tuning was by ways of a slider which moved smoothly along a clearly marked scale. An illuminated indicator and AFC (Automatic Frequency Control) circuit helped to make tuning easy and accurate. The MONO control button disconnected the built-in stereo decoder when correct stereo reception was impaired by bad weather conditions or other interference.
Beomaster 901’s large tuning scale had tuning facilities for FM, Long and Medium wave stations. The tuning slider had small thumbwheels to aid fine tuning. AFC locked the receiver to the desired station
The stereo amplifier had a powerful output of 2 x 20 watts RMS and special Darlington-coupled transistors in the output stages kept distortion to a minimum – less than 0,3% at full power. There were connections for two pairs of loudspeakers and a pair of headphones. Sockets were also provided for the connection of a tape recorder, a record-player and AM and FM aerials. Easy-to-use sliders controlled volume, balance, bass and treble and there were slim push-buttons for selecting waveband or tape or record input.
FM room aerial
In order to receive FM programmes, an FM aerial must be connected to the Beomaster 1001. Within a certain radius of the transmitter you could use the Bang & Olufsen FM room aerial, type 8902010. This aerial was easily fitted and the telescopic elements could be pulled out and positioned favourably.
Beomaster 901 could be made up as part of the Beosystem 901 including the the Beogram 1102 record player, Beocord 1101 cassette deck and 2 Beovox Uni-Phase S25 or P30 loudspeakers.
Posted on
BeoMaster 6000 (1981)
Bang & Olufsen BeoMaster 6000 1981
This extremely distinctive and beautiful FM stereo receiver from Bang & Olufsen used the very latest technology, both in its complex audio circuitry and in the microcomputer-based control systems which made it such an effortless and pleasurable product to use – whether or not you decided to include the optional remote control facility. The specialist radio section concentrated on the superb sound quality available from FM transmissions.
It covered the entire FM band from 87,5 to 108 MHz and incorporated the most advanced techniques for accurate, drift-free stereo reception.
The amplifier gave 2 x 75 watts RMS with an extremely low level (0,8%) of harmonic distortion. Clean, clear sound – always. Two 24-hour timers allowed you to play or record any sound source automatically. You didn’t even have to be at home. Or, if you wanted to be sure of hearing the same news programme every evening you could set the Repeat function to remember for you – day after day.
Connections included sockets for a record deck and two tape decks (DIN or RCA phono plugs) plus graphic equaliser, headphones and two pairs of loudspeakers.
Beomaster 6000 formed the heart of Beosystem 6000 and was designed by Jacob Jensen.
Posted on
BeoCenter 2800
Bang & Olufsen BeoCenter 2800
Beocenter 2800 was a unique combination of FM/AM tuner, a 2 x 25 watts RMS hi-fi power amplifier and record player. The tuner section offered Long and Medium wave reception as well as FM. There were facilities for pre-setting the four FM stations you listen to most frequently. Ceramic filters, AFC, split-supply output and a phase-locked loop decoder were some of the features that ensured outstanding reception and reproduction of even distant stations.
The record player was fully automatic – one master switch controlled all operations. The anti-skating device was built into the arms suspension and worked automatically. Electronic Servo Drive (ESD) ensured constantly correct speed. There were sockets for tape deck, two sets of stereo speakers and headphones.
This was a compact, space-saving unit which was easy to use thanks to automatic circuits and logical controls. Beocenter 2800 could be made up as part of the Beosystem 2800, when linked together with other compatible Bang & Olufsen products
Posted on
BeoCenter 1600
Bang & Olufsen BeoCenter 1600
Beocenter 1600 was a combined FM stereo tuner, hi-fi amplifier and cassette recorder with extra operational convenience in the tuner section – facilities for presetting the 4 FM stations you listen to most frequently. The hi-fi amplifier was relatively powerful and had low distortion and a wide frequency range so that the tuner’s excellent qualities could be exploited fully.
The built in cassette recorder was very easy to use – recording level was regulated with the same sliding potentiometer on both channels and monitored by an illuminated indicator. A Selector switch was available to choose between normal or chromium dioxide tapes.
Beocenter 1500 and Beocenter 1600 were at the time of their production, two of the market’s most compact audio systems, but despite their small external dimensions they could fill a large room with sound. All the push buttons of Beocenter 1500 were of solid aluminium, and the solid aluminium front panel on the Beocenter 1600 was anodised – a process which was more expensive and more demanding but which also made the set more robust and resistant to marks and scratches.
Combined with two speakers from the Beovox Uni-Phase range of loudspeakers, Beocenter 1600 would then make up Beosystem. 1600.
Posted on
BeoCenter 1500
Bang & Olufsen BeoCenter 1500
Beocenter 1500 was a combined FM/AM tuner, hi-fi stereo amplifier and cassette recorder with a specification level that was unique for combination units in that price bracket. In the AM section, which covered long and medium waves, Bang & Olufsen placed an emphasis on the set’s ability to separate stations from each other. The FM section had outstanding channel separation and stereo reception. The amplifier’s technical specifications were way above the average and fulfilled accepted hi-fi norms by a wide margin.
The built-in cassette recorder had its own operation panel but was otherwise fully integrated with the rest of Beocenter 1500. There was a switch for normal and chrome tapes; recording level was monitored on an illuminated indicator: red signified overload and green meant that all was well. The tape heads were of a super Permalloy and had a higher performance level and longer useful lifetime than ordinary heads.
Beocenter 1500 had connections for record player, two sets of stereo speakers, headphones and an extra tape deck.
Beocenter 1500 and Beocenter 1600 were, at the time of their production, two of the market’s most compact audio systems, but despite their small external dimensions they could fill a large room with sound. All the push buttons of Beocenter 1500 were of solid aluminium, and the solid aluminium front panel on the Beocenter 1600 was anodised – a process which was more expensive and more demanding but which also made the set more robust and resistant to marks and scratches.
Posted on
BeoGram CD 3500
Bang & Olufsen BeoGram CD 3500
The sound reproduction achieved by Bang & Olufsen’s CD 3500 CD player was truly outstanding. It played both 12cm and 8cm compact discs and had an ingenious ‘step’ function which allowed you to go straight to a chose track selected from anywhere on the disc. The CD player was one of the most technologically-advanced pieces of hi-fi on the market at the time and yet was one of the easiest to operate. The explicit display always indicated what the CD player was doing all the time – for example, which track was being played, and how many tracks there were on the played compact disc.
Beogram CD 3500 could be used as part of the Beosystem 3500 hi-fi system.
Posted on
BeoGram 3300
Bang & Olufsen BeoGram 3300
It’s better both for your records and for sound quality to play a record the way the master was made – in a straight line from the edge to the centre. This tangential arm record player did just that, giving a far more precise reading of the signals in the groove. The MMC4 cartridge made a vital contribution too; it was feather-weight, with a stylus pressure of only 1,2 grams, giving outstanding sound quality but minimising wear and tear on your records.
There’s more protection too – invaluable for all-night parties. The electronically controlled tangential arm was suspended so that it isolated mechanical vibrations from the cartridge. The suspension chassis was also thoroughly engineered to neutralise vibrations. So keep on dancing – the record player can take it! Beogram 3300 was part of Beosystem 3300 although may be used as a stand-alone item.
One of many tangential decks all utilising the same basic design, the 3300 was noticeable mainly for its grey finish and slightly lurid graphics. Very much a child of the 80s, it was replaced by the 3500 and 4500.
Posted on
BeoGram 6000 (1981)
Bang & Olufsen BeoGram 6000 1981
Beogram 6000 – Type 5751 – was a fully automatic record player with one-touch operation.
Put a record on the turntable, touch START and let Bang & Olufsen technology do the rest. The lightweight, low inertia tone arm was fitted with the MMC 20EN pick-up cartridge. This had a naked elliptical diamond and a low Effective Tip Mass which, together with the lightweight arm, secured excellent tracking performance and minimum record wear.
The patented spring suspension system effectively prevented external knocks and vibration from affecting tracking and sound quality. This later radial 6000 model was fitted with Datalink and was really a Beogram 2402 with new electronics in the same design. It really did not match the Beomaster 6000 and was a short lived and frankly unpopular model but was offered as a cheaper alternative to the tangential tracking and tangential drive Beogram 6006. These decks were both replaced by the Beogram 6002. This deck had the newer MMC3 cartridge and was a strange amalgam of the two earlier decks in that it had a simplified tangential arm but belt drive for the platter
