Posted on
BeoVision 8100
BeoVision 8100
These high quality remote control colour TVs had 8 channels which could be pre-tuned for instant access via the infra-red Video Terminal. Volume level and picture adjustments could also be made without moving more than a finger. Bass and treble tone and picture contrast adjustments were made via the controls sited behind the set’s front fascia.
All models used the 30AX in-line self-converging picture tube with its High Bright characteristics. Bang & Olufsen’s unique Permanent Colour Truth circuitry ensured that the balance between colours was always correct. Together, these features guaranteed a top quality picture that would not deteriorate as the set got older.
Teletext was available as an optional feature on all three models. When fitted, Teletext was accessible via the same Video Terminal used for ordinary entertainment viewing.
Beovisions 5100, 7100 and 8100 came complete with a smooth gliding undercarriage. Apart from screen size and cabinet options, they were technically identical in all respects.
Sound output was 6 watts RMS. Connections were provided for an extension speaker and tape recorder; the tape socket had an alternative function – you could use it to feed the TV sound through your hi-fi system. (From B&O Catalogue Supplement Winter 1982/83)
BeoVision 8100 Product Details
Type Numbers
3381 (1981 - Feb 1984)
3341 (F) (1981 - Nov 1984)
3382 (GB) (1981 - Feb 1984)
3343 (MULTI) (1981 - Feb 1984)
Designer
Please let us know
Manufactured
1981 - 1984
Colour Options
Teak or rosewood
BeoVision 8100 Product Specification
Picture tube size: 66cm
Cabinet: wood veneer
Number of programmes: 32 VHF – UHF
Range: UHF 21 – 69, VHF 2 – 12
Picture tube: 30 AX 110° in line self converging
Start time: approx. 5 sec
Speakers:
Full range: 13cm
Sound power output: 6 W
Harmonic distortion: < 0.3 %
Intermodulation: < 2.5 %
Frequency range: +/- 1.5 dB 40 – 20000 Hz
Power bandwidth: 10 – 35000 Hz
Signal-to-noise ratio: > 55 dB
Bass control: +8 -5 dB / 100 Hz
Treble control: +9 -6 dB / 10000 Hz
Power supply: 180 – 265 V
Power consumption: 75 (65 – 130) W
Stand-by: < 2 W
Dimensions W x H x D: 77 x 49 x 45.5cm
Weight 39 kg
Connections: external speaker 4 – 8 ohms
Tape output 700 mV / 470 kohms
Amplifier output 700 mV / 1 kohms
Finish: teak, rosewood
Documents will be listed here
BeoVision 8100 FAQs
Please let us know
Posted on
BeoVision 8102
BeoVision 8102
In the days before widescreen, active speakers and Dolby Digital modules, the catalogue of 1985 stated that: “it would be foolish to spend more money that you needed. Why pay for multiple features and facilities when all you wanted was the best possible picture quality, good sound and instant remote access to all available UHF TV channels?”. Unfortunately, those days have long since gone!
The most sensible and economic answer to such a modest set of demands was right there, it stated, in the ‘traditional’ Beovision 5102, 7102 and 8102. All three sets were identical; it was only the size of the tubes that differed. You obtained the same type of picture tube as in the luxury sets (the Beovision 5502, 7702 and 8802 range, for example): automatic colour balance, high reliability… and a bright, clear, natural-looking picture. Sound quality was 6 watts RMS.
The remote control was identical too – the Beovision Video Terminal was used on all of the sets. You could tune across the entire UHF band and store up to 32 station frequencies in the set’s microcomputer memory for instant recall. The Beovision Video Terminal made it easy to control.
Sound output was 6 watts. Connections were provided for an extension speaker and a tape recorder; the tape socket had an alternative function – you could use it to feed the TV sound through a hi-fi system. And connecting a Loop Amplifier would allow a person with a hearing aid to enjoy TV sound more fully.
All three models could be supplied with or without Teletext facilities. The slim-line cabinets were identical in design but offered an alternative in materials and finish: a furniture-crafted wood cabinet finished in rich-grained natural teak or rosewood; Beovision 5102 was also finished in natural grey.
BeoVision 8102 Product Details
Type Numbers
7100 (1984 - Aug 1986)
7120 (GB) (1984 - Aug 1984)
7123 (GB, TXT)(1984 - Aug 1984)
7101 (S, TXT) (1984 - Sept 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoVision 8102 Product Specification
Cabinet: grey metallic or rosewood
Number of programmes 32 ( VHF – UHF); range UHF 21 – 69, VHF 2 – 12
or VHF 46.25 – 105.25 MHz and 113.25 – 294.25 MHz
Speakers: full range
Power bandwidth: 10 – 35,000 Hz
Treble control: +9 -6 dB / 10,000 Hz
Stand-by: < 2 W
Weight: 39 kg
Connections: external speakers (min. 4 ohms)
Tape output: 600 mV / 1 kohms
Amplifier output: 600 mV / 1 kohms
BeoVision 8102 FAQs
Please let us know
Posted on
BeoVision 8202
BeoVision 8202
BeoVision 8202
BeoVision 8202 Product Details
Type Numbers
7200 ( 1984 -Dec 1985)
7201 (S, TXT) ( 1984 - Oct 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoVision 8202 Product Specification
Picture tube size: 66 cm
Features: Stereo sound. stereo enhancement, bilingual sound
Picture tube: 30 AX 110° in line self-converging
Sound power output: 2 x 5 W / 4-8 ohms
Harmonic distortion: < 0.5 %
Frequency range: +/- 1.5 dB 40 – 20,000 Hz
Power bandwidth: 30 – 30,000 Hz
Signal-to-noise ratio: > 5 dB
Treble control: +/- 8 dB / 10,000 Hz
Power consumption: 85 (70 – 160) W
Stand-by: < 2 W
Dimensions W x H x D: 89.5 x 49 x 45.5 cm
Weight 41 kg
Connections: external speakers 4 – 8 ohms
Audio input: 600 mV / 100 kohms
Audio output: 600 mV / 1 kohms
BeoVision 8202 FAQs
Please let us know
Posted on
BeoVision 8800
BeoVision 8800
BeoVision 8800
Beovision 8800 marked a brand-new generation of televisions with significant technical improvements. One of the most important enhancements was probably the remote control, which now worked with infrared light instead of ultrasound, and had practically all the same functions we use today. Thus, it could also operate text-TV, a brand-new service offered to viewers, introduced in 1983. The remote control took on something of a cult status. Being cast in zinc, the remote control was much more pleasant to handle; as zinc conducts heat, you didn’t get clammy hands from handling it for an extended period.
Beovision 8800 had remarkable sound compared to other televisions. The engineers had managed to incorporate a built-in two-way loudspeaker system driven by a 14W amplifier. The energy consumption was only 75W, which is in fact on a par with today’s standards. But, back then, a television used more energy if you turned up the volume or increased the picture contrast. These factors are no longer very significant.
This system concept was new. It was now possible to use the same remote control for both the TV and the video recorder. Bang & Olufsen blazed new trails by fusing two remote control units into one. The technology should exist for the sake of people – not the other way around. This philosophy has been pervasive from the very beginning. And it is refreshed at regular intervals. For example, quoting a sales brochure from the 1970s asserts: “There is something that distinguishes Bang & Olufsen radically from everybody else. We are just as interested in what our products are used for as we are in their technological capabilities.
To us, coming up with a technically satisfying design is not enough. It also needs to be satisfying to use. It should operate intuitively. Knobs, buttons and dials need to be positioned logically and consistently so they can be understood and operated by children and adults alike. This might make people think the technology is less advanced. Nothing could be further from the truth. On the contrary, well-thought-out operation makes heavy demands on ingenuity, often requiring unconventional, sometimes radical solutions.
The objection is frequently heard that people quickly become accustomed to operating technical equipment even if it is complicated and illogical. We do not believe that this is necessarily so. In fact, people often find complicated things annoying – and give up trying to make sense of each of the functions they have paid for. There is simply no excuse for not thinking through the functions and their operation. Even when we’re talking about the most advanced high-fidelity equipment, the technology is there for the sake of the people – and not the other way around.”
Beovision 8800 became a classic, remaining in production until the launch of the Beovision LX family.
(Taken from Beolink Magazine: ‘The First 50 Years of Television’ © Bang & Olufsen a/s 2002)
BeoVision 8800 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1980 - 1982
Colour Options
Please let us know​
BeoVision 8800 Product Specification
Picture tube size 26″ – 66 cm
Cabinet Wood
Features Infrared cordless remote control
Number of programmes 16 VHF – UHF
Range VHF 2 – 12
VHF 46 – 130, 130 – 300 MHz only for type: 3325, 3323, 3321, 3373, 3374, 3371, 3372
Picture tube 30 AX 110° in line self converging
Start time Approx. 5 sec.
Aerial impedance 75 ohms coaxial
Speakers Woofer 4″ – 10 cm
Tweeter 2″ – 5 cm
Log line system
Sound power output 14 watts
Harmonic distortion < 0.3 %
Intermodulation < 2.5 %
Frequency range +/- 1.5 dB 40 – 20,000 Hz
Power bandwidth 10 – 35,000 Hz
Signal-to-noise ratio > 55 dB
Bass control +8 -5 dB / 100 Hz
Treble control +9 -6 dB / 10,000 Hz
Power supply 180 – 265 volts
Power consumption 75 (65 – 130) watts
Stand-by < 2 watts
Dimensions W x H x D 77 x 49 x 45.5 cm
Weight 39 kg
Connections:
Headphones ouput Max. 7.5 V / 200 ohms
External speaker Min. 4 ohms
Tape output 30 mV / 470 kohms
BeoVision 8800 FAQs
Please let us know
Posted on
BeoVision 8802
BeoVision 8802
BeoVision 8802
“As yet, none of us need 32 TV channels, let alone 100. But satellite re-broadcasting systems and cable TV, including regional and community networks, might soon change that” (1983 catalogue)
Therefore, Bang & Olufsen equipped all the luxury Beovision models with an advanced digital tuner that had the capacity for receiving 100 UHF channels, 32 of which could be stored in the set’s microcomputer memory for instant recall at the touch of a button.
Beovisions 5502, 7702, 8802 and 9002 all shared the same advanced chassis design and offered the same user-benefits. They were true “luxury” sets because many ‘extras’ offered by other companies, were given as standard by Bang & Olufsen.
The Beovision Video Terminal supplied with Beovisions 5502, 7702, 8802 and 9002 offered a plethora of operational benefits. In addition there was also an advanced ‘tune and store’ function that allowed you to operate the automatic tuning system from the comfort of your chair.
One touch of the ‘tune’ button started the digital tuner scanning the wavelengths of the UHF band. When it found a station, it stopped – giving you the opportunity to either reject or accept it. If it was an unsatisfactory reception from a distant transmitter (or simply a station you don’t like!), you just pressed ‘tune’ again to continue the search. When you found a station you enjoy, on a channel giving a good, clear reception, you could instruct the set’s microcomputer to remember that transmission frequency by pressing ‘store’ followed by your own choice of pre-set programme number (e.g. for BBC2 you might designate pre-set number 2). Thereafter, whenever you wanted to watch BBC2, you simply touch button ‘2’ on your remote Terminal.
Up to 32 different TV stations could be located and stored in this way, so your Beovision really is ‘future-safe’ because it has plenty of spare capacity to accommodate new programme sources as and when they come ‘on stream’.
The latest type of Beovision Video Terminal also had a button marked ‘sound’. This was only effective with Bang & Olufsen stereo TVs – Beovision 7802 and Beovision 8902.
Beovision 5502 had a 50cm screen and measured 62cm wide, 40cm high (71.5cm including stand) and 39cm deep.
Beovision 7702 had a 22″ screen. Dimensions were 67.5cm wide, 43.5cm high (76cm including stand) and 41.5cm deep.
Beovision 8802 had a 26″ screen and measured 77cm wide, 49cm high (80cm including stand) and 45.5cm deep.
All three models had slim cabinets finished in a choice of natural teak or rosewood. White finish was available to special order.
BeoVision 8802 Product Details
Type Numbers
8802
7702
5502
Designer
Please let us know
Manufactured
1984 - 1987
Colour Options
Teak, rosewood or white
BeoVision 8802 Product Specification
Sound system: mono
Consumption normal use watts: 75
Stand by watts: 2
Video Terminal
TV programmes: 32
AV programmes: 3
CTV system
I PAL
UHF: 21-69
Dimensions:
Width: 77 cm.
Height: 49 cm.
Depth: 45.5 cm.
Picture:
High Bright in-line
Selfconverging
Automatic contrast
Programme and channel display
High Fidelity amplifier.
Log-line Compact 2-way speaker system
Sound output RMS watts : 14
Controls: Beovision Video Terminal.
Prepared for satellite TV and Teletext.
Stereo and bilingual broadcasts via stereo decoder and connection to your stereo music system.
Connections:
AV socket 21pin
External speaker
Headphone
Audio amplifier/tape, loop amplifier
Options:
Teletext module
Dual video simulcast interface
BeoVision 8802 FAQs
Please let us know
Posted on
BeoVision 8900
BeoVision 8900
BeoVision 8900
BeoVision 8900 Product Details
Type Numbers
3391 (1981 - Dec 1983)
3392 (D) (1981 - Dec 1983)
3327 (OSCAR) (1981 - Nov 1983)
Manufactured
1981 - 1983
Colour Options
Please let us know​
BeoVision 8900 Product Specification
Features: stereo sound with stereo enhancement
Bilingual sound
Number of programmes: 16 VHF – UHF
Range VHF 2 – 12
UHF channels: 21 – 69
Picture tube:
Speakers, 2 set Log Line system
Woofer: 10cm
Tweeter: 5cm
Sound power output 2 x 15 W/ 8 ohms
Harmonic distortion < 1 % at 15 watts, <0.5% at 14 W
Intermodulation < 1 %
Frequency range 30 – 20,000 Hz +/- 1.5 dB
Power bandwidth 30 – 50,000 Hz
Bass control +/- 8 dB/100 Hz
Treble control +/- 8 dB/ 10,000 Hz
Power consumption 85 (70 – 160) W
Stand-by < 2 W
Dimensions W x H x D 89.5 x 49 x 45.5cm
Weight 41 kg
Connections: Headphones output Max. 10.5V/200 ohms
External speakers 8 ohms
Tape output 600 mV/ 1 kohms
Amplifier output 600 mV/ 1 kohms
AV socket, Audio/video IN/OUT DIN 6 pin
Video input 1Vpp ohms FBAS
Video output 1Vpp 75 ohms
Audio input 600 mV/ 100 kohms
Audio output 600 mV/ 1 kohms
Remote control: Video Terminal
BeoVision 8900 FAQs
Please let us know
Posted on
BeoVision 8902
BeoVision 8902
BeoVision 8902
Beovisions that put the future at your fingertips
As yet, none of us need 32 TV channels, let alone 100. But satellite re-broadcasting systems and cable TV, including regional and community networks, may in the future change that.
Therefore, Bang & Olufsen equipped all their luxury Beovision models with an advanced digital tuner that had the capacity for receiving 100 UHF channels, 32 of which could be stored in the set’s microcomputer memory for instant recall at the touch of a button.
The real boon for most viewers is that you could locate, store and recall any of these stations without leaving your armchair. All you had to do was to touch a key on the Beovision Video terminal. So although the company gave their “future-safe” luxury TV range more micro-electronics, more features and more connection possibilities than ever before, they had, at the same time, made all this complex technology even more accessible – instantly. To borrow a phrase from the computer industry, Bang & Olufsen’s ’02-Series’ TVs were (and still are) extremely “user-friendly”.
Beovisions 5502, 7702, 8802 and 9002 all shared the same advanced chassis design and offered the same user-benefits. They were true “luxury” sets because all the features and facilities which, in other brands, are offered as ‘extras’ were offered as standard on Bang & Olufsen sets.
The Beovision Video Terminal supplied with Beovisions 5502, 7702, 8802 and 9002 offered a plethora of operational benefits. In addition there was also an advanced ‘tune and store’ function that allowed you to you operate the automatic tuning system from the comfort of your chair.
One touch of the ‘tune’ button started the digital tuner scanning the wavelengths of the UHF band. When it found a station, it stopped – giving you the opportunity to either reject or accept it. If it was an unsatisfactory reception from a distant transmitter (or simply a station you didn’t like!), you just pressed ‘tune’ again to continue the search. When you found a station you enjoyed, on a channel giving a good, clear reception, you could instruct the set’s microcomputer to remember that transmission frequency by pressing ‘store’ followed by your own choice of pre-set programme number (e.g. for BBC2 you might designate pre-set number 2). Thereafter, whenever you wanted to watch BBC2, you simply touched button ‘2’ on your remote Terminal.
Up to 32 different TV stations could be located and stored in this way, so your Beovision really was ‘future-safe’ because it had plenty of spare capacity to accommodate new programme sources as and when they come ‘on stream’.
The (then) latest type of Beovision Video Terminal also had a button marked ‘sound’. This was only effective with Bang & Olufsen stereo TVs – Beovision 7802 and Beovision 8902, for example.
BeoVision 8902 Product Details
Type Numbers
7210 (1984 - Jan 1986)
7022 (D, TXT, OSCAR) (1984 - May 1987)
7292 (D, TXT, OSCAR) (1984 - Dec 1986)
7006 (G) (1984 - May 1986)
7230 (GB) (1984 - April 1987)
7233 (GB, TXT) (1984 - Feb 1987)
7270 (MULTI) (1984 - May 1986)
7277 (MULTI, TXT, ANTIOPE) (1984 - Aug 1986)
7020 (OSCAR) (1984 - Jan 1987)
7290 (S-CH) (1984 - May 1985)
7021 (S, TXT) (1984 - May 1987)
7211 (S, TXT) (1984 - Aug 1985)
Designer
Please let us know
Manufactured
1984 - 1987
Colour Options
Wood Effect or White
BeoVision 8902 Product Specification
Bilingual sound
Number of programmes 32 VHF – UHF, Range UHF 21 – 69, VHF 2 – 12
Picture tube 30 AX 110° in line self-converging
Speakers: 2 set Log Line system: Woofer: 10 cm
Tweeter: 5 cm
Sound power output 2 x 14 W / 8 ohms
Harmonic distortion < 1 % at 15 W, < 0.5 % at 14 W
Frequency range +/- 1.5 dB 30 – 20,000 Hz
Bass control +/-8 dB / 100 Hz
Treble control +/-9 dB / 10,000 Hz
Power consumption 80 (70 – 160) W
Stand-by < 2 W
Dimensions W x H x D 89.5 x 49 x 45.5 cm
Weight 41 kg
Connections: Headphones output Max. 10.5 V / 200 ohms
Tape output 600 mV / 1 kohms
Amplifier output 600 mV / 1 kohms
AC socket, Audio/video IN/OUT DIN 6 pin
Video input 1 Vpp 75 ohms FBAS
Video output 1 Vpp 75 ohms
Audio input 600 mV / 100 kohms
Audio output 600 mV / 1 kohms
BeoVision 8902 FAQs
Please let us know
Posted on
BeoVision 700
BeoVision 700
BeoVision 700
Beovision 700 won the iF Design Award in 1966
BeoVision 700 Product Details
Type Numbers
Please let us know​
Manufactured
1966 - 1969
Colour Options
Please let us know​
BeoVision 700 Product Specification
Please let us know
BeoVision 700 FAQs
Please let us know
Posted on
Beovision 7000
Beovision 7000
Beovision 7000 offered identical performance as the Beovision 7700 but with direct manual operation of up to 12 stations.
Beovision 7000 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1981 - 1982
Colour Options
Teak or rosewood
Beovision 7000 Product Specification
Please let us know
Beovision 7000 FAQs
Please let us know
Posted on
BeoVision 7100
BeoVision 7100
BeoVision 7100
BeoVision 7100 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1981 - 1984
Colour Options
Please let us know​
BeoVision 7100 Product Specification
Please let us know
BeoVision 7100 FAQs
Please let us know
