Posted on
BeoCenter 2300 DAB
Bang & Olufsen BeoCenter 2300 DAB
BeoCenter 2300 DAB
This special 2300 was produced in 500 examples for a test of DAB by Danish Radio.
Built on B&O’s 2300 platform, the 2300 DAB was modified with a Motorola Power PC 821 processor to control the special DAB-functions. The DAB receiver itself was placed in the accompanying “black-box” made by Bosch/Blaupunkt.
The radio can be used directly via the push buttons, or with help from a remote control unit, which is a modified computer made by Apple Newton NotePad.
A PCMCIA (PC Card) slot on the top left-hand side of the back casing was another difference from the ordinary 2300.
Mounting Options
BeoCenter 2300 DAB Product Details
Type Numbers
7400
Designer
Manufactured
1995 – 1995
Colour Options
Aluminium, Black
BeoCenter 2300 DAB Product Specification
Please let us know
Language
Reference Guide
EN
BeoCenter 2300 Reference Guide
User Guide
EN
BeoCenter 2300 User Guide
User Guide
EN
Setup Guide
EN
BeoCenter 2300 Setup Guide
Install Guide
EN
BeoCenter 2300 RDS Install Guide
Service Manual
EN
BeoCenter 2300 Service Manual CD Replacement
Service Manual
EN
2611,2612,2613,2614, 2615, 2616, 2617, 2618, 2619, 2620
BeoCenter 2300 DAB FAQs
Please let us know
Posted on
BeoCenter 2300
BeoCenter 2300
Beocenter 2300 was dedicated to the CD enthusiast who, for example, like to store the titles of favourite CDs, or permanently skip unwanted tracks. It was known as Beosystem 2300 when connected to the BeoLab 2500 active speakers. It was eventually surpassed by BeoSound 3000 when it included more features and received a facelift in 2001.
Beocenter 2300 was developed from the idea of a flexible music system that could compete with the sound quality of heavy music systems. Thanks to the advent of active speakers, this was a possibility with both Beocenter 2300 and its similarly-equipped sibling (which also had cassette tape recording and playback) the Beocenter 2500. With active speakers, each of the powerful bass and treble units were equipped with their own separate amplifiers. In addition, the electronic cross-over network ensured full bass reproduction.
The loudspeakers were located on both sides of a centre console, where two clear glass covers automatically glided to the side when a hand was passed in front of them. Behind the glass covers there was access to the operating panel, receiver, CD player and a cassette recorder.
The receiver allowed the option of presetting 2 x 20 FM/AM radio stations. The cassette recorder featured Auto Reverse, Automatic Recording level, search function and Bang & Olufsen’s HX-PRO recording system, a system which ensures that the sensitive treble range is captured in recording. The memory in Beocenter 2300’s CD player allowed you to edit up to 100 CDs.
Both systems could be operated via their operating panel or a Beolink 1000 or Beolink 5000 remote control. There were sockets for headphones and connection to additional sound sources; extra loudspeakers can also be connected.
Beocenter 2300 was available with loudspeaker panels in cobalt grey, black, white, cerise or jade and could be made up to the Beosystem 2300 when incorporated with the BeoLab 2500 active loudspeakers.
Mounting Options
BeoCenter 2300 Product Details
Type Numbers
2611 (EU) (1994 – June 2000)
2616 (EU) (Two-way) (1991 – June 2000)
2617 (GB) (Two-way) (1991 – June 2000)
2612 (GB) (1994 – June 2000)
2618 (USA)(1994 – June 2000)
2619 (J) (1994 – June 2000)
2620 (AUS)(1994 – June 2000)
2615 (KOR) (1994 – June 2000)
2626 (TWN) (1996 – June 2000)
2611 EU FM-AM RDS 230V
2612 GB FM-AM-RDS 230V
2515 KOR FM-AM 220V
2616 EU FM-AM 230V
2617 GB FM-AM 230V
2618 USA-CDN FM-AM 110V (BeoSound 2300)
2619 J FM-AM 100V
2620 AUS FM-AM 240V
2626 TWN FM-AM 120V
Designer
Manufactured
1991 – 2000
Colour Options
Aluminium, Black
BeoCenter 2300 Product Specification
Tuner: Built-in
Pre-tuned radio programs 2 x 20 FM or AM
Radio ranges FM 87.5 – 108 MHz; 76 – 90 MHz (Japan)
LW 150 – 350 kHz
MW 520 – 1610 kHz
Compact disc: built-in
Disc size 12 cm, 8 cm
Frequency range 20 – 20,000 Hz +/- 1 dB
Signal-to-noise-ratio Typical 101 dB, A-weighted
D/A converting Bitstream, Analogue filtration
Features Programming, Scan, Random, Edit, Naming
Remote control: Beo4
Connections: Power Link 2, AUX 1
FM aerial 75 ohm 1
AM aerial (Dedicated) 1
Headphone/Mini-Jack 1
Link compatibility: Master Link (via Beolink® Converter)
Master Control Link (via ML/MCL converter)
Dimensions W x H x D 32 x 36 x 16cm
Weight: 6.9 kg
Power consumption: typical 23 W/stand-by 5.5 W
Optional RDS kit
Wall bracket system 2201 2087
Wall bracket, center 2052
Stand 2051 Aluminium, Black, Blue, Green, Red
Language
Reference Guide
EN
User Guide
EN
User Guide
EN
Setup Guide
EN
Install Guide
EN
Service Manual
EN
Service Manual
EN
BeoCenter 2300 FAQs
BeoCenter 2300 doors are slow to open.
There is some tape over the IR receivers designed to make the doors less sensitive.
Simply removing this will cure the problem! It was placed there as the doors were thought to be over-sensitive when first introduced. The tape is in position 9001 and 9019 (Refer to service manual!)
BeoCenter 2300 clock keeps resetting itself
You need to upgrade the Software to Version 1.2 in order to rectify this problem.
This upgrade available from your nearest Bang & Olufsen dealer.
Posted on
Beovox S80
Bang & Olufsen Beovox S80
Beovox S80
There was a 7,5cm mid-range/phase-link unit combined with a 20,5cm woofer and 2,5cm dome tweeter to provide a wide frequency response and no audible phase distortion. Overload protection was automatic. The cabinet was of pressure chamber construction. Optional pedestals and wall-fixing kits were available.
Beovox S80 Product Details
Type Numbers
6414 (1981 – 1982)
Designer
Manufactured
1981 – 1982
Colour Options
Rosewood, Teak, White, Oak
Beovox S80 Product Specification
RMS power handling capacity 80 W
Music power handling capacity 110 W
Impedance: 8 ohms
Frequency response 4+ -8 dB 50 – 22,000 Hz
Frequency response +/- 4 dB 70 – 20,000 Hz
Sensitivity: 4 watts
Distortion 250 – 1000 Hz
<1.8%
Distortion > 1000 Hz <0.7%
Woofer: 21 cm, throw +/- 3 mm
Phase-link, mid-range: 7.5 cm dome
Tweeter: 2.5 cm dome
Net volume: 24 litre
Gross volume: 37 litre
Dimensions W x H x D: 26.5 x 53 x 27.5 cm
Weight 9 kg
Language
Service Manual
EN
BeoVox S80.2 Service Manual
Beovox S80 FAQs
Please let us know
Posted on
Beovox S80.2
Beovox S80.2
Beovox S80-2 speakers gave neutral sound reproduction with the added realism afforded by depth definition and perspective.
Beovox S80.2 Product Details
Type Numbers
6434 (1984 – 1986)
Designer
Manufactured
1984 – 1986
Colour Options
Beovox S80.2 Product Specification
RMS power handling capacity 80 watts
Music power handling capacity 110 watts
Impedance: 8 ohms
Distortion 250 – 1000 Hz: <1.8%
Woofer: 21cm, throw +/- 3 mm
Phase-link, mid-range: 7.5cm dome
Tweeter: 2.5cm dome
Dimensions W x H x D: 26.5 x 53 x 27.5cm
Weight 9 kg
Language
Service Manual
EN
Beovox S80.2 FAQs
Please let us know
Posted on
BeoSound A5
Bang & Olufsen BeoSound A5
BeoSound A5
Powerful portable speaker
Huge sound anywhere – in the home or outdoors. Beosound A5 is a Wi-Fi and Bluetooth speaker with long-lasting battery and wireless charging built in.
Music’s next move
Beosound A5 goes where no portable speaker has gone before. Acoustically. Aesthetically. Effortlessly. Elegant looks disguise a world of power and precision that brings huge sound anywhere – in the home, or out in the wild. Serious bass. Seriously smart. With A5, you won’t know what’s hit you. Stream anything wirelessly. Connect other speakers seamlessly. All in a grab-and-go package that’s designed to be updated over time instead of replaced, so it’ll always be by your side. This is music’s next move.
Sound. All around.
With 360-degree sound dispersion, everyone can tune into the music – or easily narrow the sound direction for those private listening sessions. It all happens in the B&O app.
Sound. All around.
Stream wirelessly and connect with other speakers to feel immersed from room to room. Guests? With 360-degree sound dispersion, everyone can tune into the music – or easily narrow the sound direction for those private listening sessions. It all happens in the B&O app.
Stream it all, easily.
This portable powerhouse is primed to bring it all together. Stream on WiFi with Airplay or Google Cast. Multiple speakers? Use Beolink Multiroom to create soundscapes around the home. No connection? Bluetooth is just a tap away.
Fluid sweet spot
Beosound A5 adapts to you. When stereo paired, a single tap in the B&O app let the speakers fix an ideal stereo image on your phone’s position. That way your music will always sound exactly like it was envisioned in the studio. Change of scenery? No problem, tap again to redirect the sweet spot to your new nook. *Fluid Sweet Spot only works when using Beosound A5 in a stereo setup with Apple iPhone (Apple iPhone 11 or newer).
Easy control.
And it’s easy to play your way: pause, change volume, skip tracks and access your preferred radio stations or playlists by using the favourites buttons.
BeoSound A5 Product Details
Type Numbers
Please let us know​
Manufactured
April 2023 -
Colour Options
Please let us know​
BeoSound A5 Product Specification
Recommended Room Size
10-50 m²
100-500 ft²
Speaker Configuration
1 x 0.8″ tweeter
2 x 2″ full-range
1 x 5 ¼” woofer
Amplifier
1 x 70 W class D for tweeter
2 x 70 W class D for full-range
1 x 70 W class D for woofer
Total: 280 W
Frequency Range
32-23.000Hz
Maximum Sound Pressure Level (SPL) @1m
101dB SPL
Bass Capability
80dB SPL
Stereo Pairing
Pair two Beosound A5 to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Thermal Protection
Adaptive Bass Linearization
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Wood / Paper Weave
Polymer
Dust and Waterproof Rating
IP65 (Wood components and paper weave may be damaged by water)
Dimensions (Width x Height x Depth)
28.5 W x 18.7 H x 13 D cm
Weight
3.7 KG
Power Consumption
Typical 25 W
Network standby: 3.7 W
Standby: 0.5 W
Power Supply
USB-C Power Supply
USB-C Cable
Battery Playtime
Up to 12 hours
Other
Wireless Qi Charging.
Charge your smartphones and other compatible devices wirelessly on the top surface.
Bluetooth Version
Bluetooth 5.3
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Ultra-Wide-Band
Yes
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac/ax
Streaming Services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x USB-C (Charging & Service Port)
Remote controls
Bang & Olufsen App
Beomote One BT
Beoremote Halo
On-Device Controls
Yes
Language
Quick Start Guide
EN
BeoSound A5 Quick Start Guide
User Guide
EN
BeoSound A5 User Guide
Data Sheet
EN
BeoSound A5 Data Sheet
BeoSound A5 FAQs
Please let us know
Posted on
BeoLit 1000
Bang & Olufsen Beolit 1000
BeoLit 1000
This portable radio has a specification superior to those of most mains table models and is elegantly styled, with all the controls placed on the top panel.
The Beolit 1000 offers outstandingly fine reception: on all its five bands, distant stations tune in without noise and interference even when located on adjacent frequencies. The FM section features a separate dial drive and additional push-button selection of up to three pre-tunable FM stations. The extended Long Wave band includes the navigation bands, and on the SWII band (the ‘Europe’ band) you can find all the popular European entertainment stations. The built-in Short Wave expander permits you to spread stations for supreme ease of tuning. There are sockets for connection of an external aerial, extension speaker and external power supply.
The Beolit 1000 brings you external tonal quality. Audio output is 2.5 watts on the internal dry cells. Via a suitable mains converter the Beolit 1000 will deliver no less than 7.5 watts of audio output, making it ideally suited to use as a home radio set. It has individual bass and treble controls and gramophone and tape-recorder jacks.
You can use the Beolit 1000 in a car, with the specially designed lockable car-mounting bracket which operates on 6 or 12 volts and negative and positive earthing, and incorporates filters to suppress ignition interference. The bracket automatically cuts out the built-in power supply of the Beolit 1000 and cuts in the car battery, the car aerial and an extension speaker. When powered from the car battery the set will deliver 7.5 watts of audio output.
Available in teak, Brazilian rosewood and black goatskin finish. Dimensions: 201 mm high, 359 mm wide and 70 mm deep
In 1972 the Museum of Modern Art in New York (MoMA) chose seven Bang & Olufsen products designed by Jacob Jensen to be included in their Design Collection as representing excellent examples of the Museum’s criteria for quality and historical importance; design, in fact, which had influenced the twentieth century. Beolit 1000 was one of those seven products.
In 1968 Beolit 1000 won the prestigious iF Design award.
BeoLit 1000 Product Details
Type Numbers
Please let us know​
Designer
Jacob Jensen
Manufactured
1968 – 1972
Colour Options
Rosewood, Teak, Black Leather
BeoLit 1000 Product Specification
Please let us know
Language
User Guide
EN
BeoLit 1000 User Guide
Service Manual
EN
BeoLit 1000 Service Manual
Service Manual
Multi
BeoLit 1000 FAQs
Please let us know
Posted on
Beolit 611K de luxe
Bang & Olufsen Beolit 611K de Luxe
Beolit 611K de luxe
Beolit 611 de Luxe was an AM/FM portable radio with two telescopic aerials side by side. It received FM, LW, MW and F (SW) bands, and had a little visual meter (top left of the radio) for battery level and tuning adjustment for maximum station reception.
On the bottom there was an output for external aerial and speaker so that the Beolit could be used as a car radio when the handle was detached. The handle unclipped from the body by pressing it on both sides. There were seven push-button keys in white on the top of the unit, together with separate bass and treble controls as well as two separate tuning controls and tuning strength indicator.
Once the base of the unit is removed, the car radio antenna socket can be seen to the left and on the right are two outputs: one for external or car speaker and one for a tape recorder. Also in the right-hand section is situated the serial number. The batteries go under the white section in the centre.
The seven white-coloured push-buttons on the top are from left to right: On/Off, AFC, L (LW), M (MW), F(SW), tape and FM.
Beolit 611K de luxe Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
Beolit 611K de luxe Product Specification
Please let us know
Language
Service Manual
EN
BeoLit 611K Service Manual
Service Manual
EN
BeoLit 611T Service Manual
Beolit 611K de luxe FAQs
Please let us know
Posted on
Beolit 611T de luxe
Bang & Olufsen Beolit 611T de Luxe
Beolit 611T de luxe
Beolit 611T de luxe Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
Beolit 611T de luxe Product Specification
Please let us know
Language
Service Manual
EN
Service Manual
EN
Beolit 611T de luxe FAQs
Please let us know
Posted on
BeoCord 2000 (1983)
Bang & Olufsen BeoCord 2000 1983
BeoCord 2000 (1983)
Designed as a perfect match, both physically and technically, for the Beomaster 2000, this advanced slim-line cassette deck was nonetheless a serious hi-fi product in its own right, combining a high-performance specification with supreme ease of operation.
Despite its unassuming appearance, Beocord 2000 contained a full pay-load of advanced circuitry plus a few extra features rarely found in cassette decks within this price frame. The primary controls – those concerned with tape movement – were totally electronic and designed on the Sensitouch principle. There were no knobs to turn or keys to press; a light fingertip touch was sufficient to activate any function.
Ferric, chrome or metal tapes could be used, and Dolby B noise reduction was included to ensure clean, hiss-free recordings. A clearly calibrated scale and input slider, together with large Peak Programme Meter, made it quick and easy to set accurate recording levels. These controls were placed adjacent to the cassette tray beneath a hinged lid which sprang open at a touch.
Beocord 2000’s built-in microcomputer made operation fast and foolproof. It was possible to switch directly between any and all tape transport modes without harming the tape, the mechanism or the motor. Microcomputer intelligence also opened the way for additional control functions that contributed in a very practical way to daily enjoyment of taped music.
A NEXT control allowed for easy track location (tape scan): one touch fast winds the tape to the next signal gap and plays the following track – automatically. So if you wanted to hear, for example, track number 5, just touch-and-wait four times and the place would be found for you. Similarly, you could repeat play-back of a favourite track up to five times with just a single touch. It’s such a convenient way of listening to exactly what you want, when you want.
Beocord 2000 had a socket for data-link connection to Beomaster 2000 so that direct switching was possible between Beomaster, Beogram and Beocord in the Beosystem 2000. The deck could also be data-linked to Beomaster 5000 or Beomaster 6000, when all tape functions could be operated via the receiver’s remote control system. Beocord 2000 could be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products. It was also part of Beosystem 3000 if that is how you wished to use it.
BeoCord 2000 (1983) Product Details
Type Numbers
2921 (1983 – May 1987)
2925 (AUS) (1983 – Sept 1986)
2922 (GB) (1983 – May 1987)
2923 (USA) (1983 – Dec 1986)
Designer
Manufactured
1983 – 1987
Colour Options
Metal Grey, Aluminium
BeoCord 2000 (1983) Product Specification
Compact cassette: C46-C60-C90-C120
Noise reduction system: Dolby B
Tape switch: manual ferro/chrom/metal
Wow and flutter DIN: <+/- 0.2%
Fast forward and rewind: C60 100 sec.
Frequency range chrome: 30 – 15,000 Hz +/- 3 dB
Signal-to-noise ratio: CCI/ARM
Metal Dolby B: > 56 dB TDK-MA
Chrome Dolby B: > 56 dB TDK-SA
Ferro Dolby B: > 55 dB BASF LH I
Power supply:
2921 220
2922 240
2923 120
2925 240
Power consumption: max 20 W
Dimensions W x H x D 42 x 7 x 24.5cm (12.5cm with lid raised)
Weight 3.8 kg
Language
Instruction Manual
EN
BeoCord 2000 de luxe Instruction Manual
User Guide
EN
BeoCord 2000K User Guide
User Guide
EN
BeoCord 2000 User Guide
Technical Guide
EN
BeoCord 2000 Technical Guide
Service Manual
EN
BeoCord 2000 Service Manual
Circuit Diagram
EN
BeoCord 2000 Circuit Diagram
Service Manual
EN
BeoCord 2000 de luxe Service Manual
Circuit Diagram
EN
BeoCord 2000 de luxe Circuit Diagram
BeoCord 2000 (1983) FAQs
Please let us know
Posted on
BeoCord 2000 Deluxe K (1965)
Bang & Olufsen BeoCord 2000 Deluxe K
“One of the best semi-professional fully transistorised hi-fi stereo tape recorders. It has professional data for speed, wow and flutter that meet international standards for studio tape recorders. New modern design concepts distinguish the Beocord 2000 de Luxe K from conventional tape reorders. Here are some of them: 4-track recording/2-track and 4-track playback; built-in 4-channel mixer section with twin faders for both mono and stereo recordings provides individual control and mixing of microphone, gramophone, radio and line signal inputs.
These faders make it possible to balance channels during recording. An aurally compensated twin fader makes it possible to balance playback volume levels, too. These features permit recordings of every kind, such as Multi-playback, or sound-on sound; that is, rerecording from one track to another whilst making another recording on the other track.
Synchro-playback – this feature consists of synchronising two recordings on separate tracks which you do wish to mix by recording, and may be used for language laboratory purposes and for automatic control of lantern slides. Echo – adding echo to both mono and stereo recordings. The amplifier equipment is an outstanding new system consisting of no less than seven fully transistorised easily replaceable amplifier units.
Monitoring: separate records and playback heads with individual amplifiers permit both before-the-tape and off-the-tape monitoring. Power output is 2 x 8 watts undistorted.
Frequency response: 7.5″/sec 30-20 000 Hz (+/- 2 dB: 40 – 16 000Hz), 3.75″/sec 30 – 16 000 Hz (+/- 2dB: 40 – 12 000Hz), 1.7/8″: 50 – 8 000Hz (+/- 2 dB: 50 – 6 000Hz)
Recording level is indicated by two illuminated V.U. meters which indicate the sum of signals in each of the two tracks that can be recorded simultaneously.
Slack absorbers: Two smooth-running specially engineered slack absorbers take up slack, ensuring absolutely smooth starting and stopping at all tape speeds.
Electronic protection circuit prevents damage due to electrical overloads. No other tape recorder in this price bracket has these professional standards for electrical and mechanical specifications. Fine low-noise tape drive motor mounted on rugged non-torsion steel chassis. Four tape heads, 4-track recording but – a remarkable feature – the instrument plays back both 2-track and 4-track tapes.
The erase head (long-life dual-gap ferrite erases “right to the bottom” (70dB). The 2000 de Luxe permits recording from one tape recorder to another, parallel recording on a number of tape recorders, and simultaneous copying of both tracks. The Beocord may also be used as: public address system, permanently installed hi-fi control centre, and orchestra and guitar amplifier.” – taken from the 1967 – 1968 Bang & Olufsen product catalogue .
BeoCord 2000 Deluxe K (1965) Product Details
Type Numbers
4136, 4137
Designer
Please let us know
Manufactured
1965 – 1969
Colour Options
Teak, rosewood
BeoCord 2000 Deluxe K (1965) Product Specification
Please let us know
Language
Instruction Manual
EN
User Guide
EN
User Guide
EN
Technical Guide
EN
Service Manual
EN
Circuit Diagram
EN
Service Manual
EN
Circuit Diagram
EN
BeoCord 2000 Deluxe K (1965) FAQs
Please let us know
