Posted on
BeoSound 2 (2016)
Bang & Olufsen BEOSOUND 2
BeoSound 2 (2016)
Captivating no matter where you place it, this powerful home speaker sounds as beautiful as it looks.
Aesthetic functionalism
Beosound 2 is designed for flexibility. Delivering the morning news from the kitchen table or playing discreetly from the living room floor. With its clean lines and small footprint, it has an adaptable design that fits in everywhere in your home.
A seamless piece of beauty
Crafted in high-grade aluminium with incredible attention to detail. But our material choice go well beyond aesthetics. It also provides superior acoustic properties thanks to its material stiffness and seamless surfaces that eliminate any distortion of your sound.
The essence of control
Beosound 2 has a built-in proximity sensor that makes the control panel light up when your hand is hovering over the controls. The top of the speaker works as a minimalistic control panel. Simply tap one of the four favourite buttons to start one of your preferred radio stations or playlists, turn the wheel to adjust the volume and tap on one of the arrows to change tracks.
Active RoomSense
Beosound 2 works out where it is in the room to give you perfect playback, every time. Ensuring bass, mids and highs are never too overpowering or weak. Wherever you place it, it gives a standout performance. No muddiness. No fuzziness. Just pure, clean sound. As the artist intended.
BeoSound 2 (2016) Product Details
Type Numbers
Please let us know​
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoSound 2 (2016) Product Specification
Recommended Room Size
10-60 m²
100-600 ft²
Speaker Configuration
1 x ¾” tweeter
2 x 2″ mid-range
1 x 5 ¼” woofer
Amplifier
1 x 15 W class D for tweeter
2 x 15 W class D for mid-range
2 x 30 W class D for woofer
Total: 105 W
Frequency Range
33 – 23.400 Hz.
Maximum Sound Pressure Level (SPL) @1m
94 dB SPL
Bass Capability
84 dB SPL
Stereo Pairing
Pair two Beosound 2 3rd Gen to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Acoustic Lens Technology
Adaptive Bass Linearization
Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Polymer
Dimensions (Width x Height x Depth) (cm)
20 W x 43.1 H x 20 D cm
Weight
4.1 kg
Power consumption
Typical 15 W
Standby: 4,5 W
Power supply
Power supply built-in
Power cable
Bluetooth Version
Bluetooth 5.3
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac/ax
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x Ethernet
1 x Line-in via USB-C
1 x Power
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Language
Quick Start Guide
EN
BeoSound 2 3rd Gen Quick Start Guide
User Guide
EN
BeoSound 2 3rd Gen User Guide
Data Sheet
EN
BeoSound 2 3rd Gen Data Sheet
BeoSound 2 (2016) FAQs
Please let us know
Posted on
BeoGram 4000C
Bang & Olufsen BEOGRAM 4000C
BeoGram 4000C
The original iconic turntable which set the standard for all record players that came after – reimagined for contemporary use.
Launched in the 1970s, the Beogram 4000 series turntables defined the aesthetic of an era: becoming a classic with music lovers, collected by art museums and included in design history books
Step 1
Disassembly and inspection
Step 2
Refurbishment and restoration
Step 3
Recreation and upgrade
We wanted to revisit the Beogram turntables to celebrate how there are unchanging values which make a product beautiful and unique. Values that have held true at Bang & Olufsen since 1925.
Now, with the Beogram 4000c Recreated Limited Editions, we meticulously source and restore original units. These editions honour our rich heritage, celebrating timeless values while adapting to the modern sound systems.
The Beogram 4000c Recreated Limited Editions is the first instance of Bang & Olufsen’s Classics Initiative: in the near future we will be revisiting more of our most iconic products, reimagining them for now and coming decades.
STEP 1
The Beogram 4000 series reimagining process begins by bringing the selected turntables back home to Struer, Denmark – the same facilities where they were created. Every Beogram is disassembled manually then thoroughly inspected to assess each unit’s needs.
STEP 2
Every single component of each Beogram is painstakingly cleaned. New parts are added – from the smallest screw and ball bearing to the drive belt – ensuring perfect functionality. Once this process is complete, each Beogram is individually tested then fine-tuned until we know it will achieve the precision performance we demand from all of our products.
STEP 3
We then create new design elements – from the hand-crafted wooden frame to an updated finish on the minimalistic and intuitive control pad – to enhance the original beauty of the Beogram. Our final step is to upgrade the technology – installing a preamplifier and adding a new pickup cartridge – to make the Beogram easily integrate with contemporary home speaker setups..
Innovative looks, innovative technology
The innovative tangential tonearm was striking in its day, and part of the reason the original Beogram was an instant classic. But it wasn’t for looks. The way the tonearm was built made it able to play vinyl at an angle that was as close as possible to the way the record was cut. This made it truthful to the original recording, staying honest to the artist’s intentions.
Jacob Jensen
When Jacob Jensen designed the Beogram 4000 Series turntable in 1972, he was looking to the future of audio design. His aim was to completely rethink the turntable to achieve a better-performing product that would stand the test of time. ‘No-one should care about how bridges are built – the point is to find out how to get to the other side in the best possible way,’ he explained.
The collaboration between Bang & Olufsen and designer Jacob Jensen is legendary, and set one of the most influential standards for product design
BeoGram 4000C Product Details
Type Numbers
BeoGram 4002 – Type 5511, 5513, 5521, 5524
BeoGram 4004 – Type 5525, 5527
BeoGram 6000 – Type 5512
Designer
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoGram 4000C Product Specification
Pickup Cartridge and Stylus
Pickup Cartridge: SMMC 20 CL (Moving Micro Cross principle)
Stylus: Nude Contact Line Diamond
Recommended tracking force: 1.3 g
Tonearm
Tangential tracking
Frequency range
50, 60 Hz
Playback Speed
33 & 45 rpm
Controls
Automatic pickup movement
Automatic record-size
Automatic speed selection
Electronic lift system
Dial for speed: 2 pointers
Drive system: Belt
Wow and flutter
Wow and flutter, DIN: <± 0.05 %
Wow and flutter, WRMS: <± 0.025 % Rumble Rumble DIN unweighted: > 42 dB
Rumble DIN weighted: >65 dB
Speed deviation: < 0.02 % Speed control range: > 6 %
Drive system: Belt
Motor
Controlled synchronous
Stylus pressure range
Stylus pressure range: 0 – 1.5 gram
Channel Separation 1000 Hz: > 25 dB
Channel Separation 400 – 10.000 Hz: > 20 dB
Channel difference: < 1.6 dB
Intermodulation: < 1%
Materials
Oak Wood
Stainless Steel
Aluminium
Weight
12 kg
Dimensions
49 w x 10 h x 38 d cm
Dust Cover
Hinged and detachable
Power Supply
110 + 130 + 220 + 240 volts
Power consumption
40 watts
Power Frequency
50 + 60 Hz
Wired Outputs
DIN 5-pin
Line out
Compatibility
Beogram 4000c is compatible with all Bang & Olufsen speakers excluding Bluetooth portable speakers. Beolab 20, Beolab 18 and Beolab 17 can connect to Beogram 4000c via Beosound Core.
Language
Design Story
EN
Beogram 4000c Design Story
User Guide
EN
Beogram 4000c User Guide
Technical Sound Guide
EN
Beogram 4000c Technical Sound Guide
BeoGram 4000C FAQs
Please let us know
Posted on
BeoSystem 9000C
Bang & Olufsen BEOSYSTEM 9000C
BeoSystem 9000C
The Beosystem 9000c is a beacon of beautiful sound, and your personal record store window. Paired with the Beolab 28 speakers, we’ve brought the Beosound 9000 CD player to the present.
Imagined in London. Born in Denmark.
Your home your choice
isn’t just for show. It is the show.
Only 200 of these exist
We’ve stripped the original Beosound 9000 CD player to its core and rebuilt it from the ground up. Guided by design legend David Lewis’ original vision to proudly display your music, instead of hiding it in a black box. Its tall, transparent form makes a gallery of your albums. A duo of Beolab 28s showcase the unbeatable fidelity of your CDs. It’s a goosebump-raising partnership of acoustics and aesthetics. This is Beosystem 9000c.
All the benefits of cutting-edge tech. All the beauty of classic design.
Beosound 9000c is an icon of the past. With an ear to the future. A new anodised floor stand and fabric cable add texture to the famous silhouette. Want to truly bring past into present? The integration of Beoconnect Encore enables the player to connect seamlessly with two Beolab 28s – and all their modern features. Sound you can direct as you choose. Bass that adapts to any room and placement. Precise stereo coordination. In an age where CDs are considered obsolete, Bang & Olufsen celebrates the legacy of the CD with the Beosound 9000c. As champions of fidelity, we meticulously recreated this iconic CD player to give you every note, detail and beat of your collection. Like you’ve never heard it before. It’s not just about the superior sound. It’s feeling the music in your hands. Lingering on the artwork. Carefully choosing your lineup. With a 90s style control panel and six-CD changer to play with, Beosystem 9000c brings that back in the biggest way possible. Every listening session becomes an event. Each time you press play, you touch the music and it touches you.
The engineering of Beosystem 9000c isn’t just for show. It is the show.
The CD clamp accelerates as quickly as a sports car. An LED ring shines as it takes your discs for a spin. And with that speed comes seamless switching between individual album tracks – no matter which CD they’re on. It’s a single, endless stream of sound. 31 years before digital got there. All housed under a glass case to keep the artwork and movement as crystal clear as the music.
Soho, London, 1995. Bang & Olufsen designer David Lewis walks past a record store window and stops in his tracks. He sees six CDs, laid out in a row. A gallery of album art. It gets his mind turning: imagine you could put your music on display, instead of hiding it away in a black box. The idea for the Beosound 9000 was born. A six-CD changer and record store window in one. Designed so that everyone can bring a CD to the mix. And fill the home with an endless stream of beautiful sound.
BeoSystem 9000C Product Details
Type Numbers
Please let us know​
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoSystem 9000C Product Specification
Number of CDs
  • 6 CDs
  • 15-50 m²
  • 150-500 ft²
  • Per Speaker:
    • 1 x 1″ tweeter
    • 3 x 3″ full range
    • 1 x 6.½” woofer
Amplifier
  • Per Speaker:
    • 1 x 100 watt, Class D, tweeter
    • 3 x 100 watt, Class D, full range
    • 1 x 225 watt, Class D, woofer
    • Total: 625 W
Frequency Range
  • 27 – 23.000 Hz
Maximum Sound Pressure Level @1m
  • Per Pair: 110 dB (SPL)
Bass Capability
  • Per Pair: 95 dB (SPL)
  • Active Room Compensation
  • Adaptive Bass Linearization
  • Beam Width Control
  • Thermal Protection
  • Presets available and fully customisable through the Bang & Olufsen App
Materials
  • Beosound 9000c:
    • Aluminium
    • Polymer
    • Glass
  • Beolab 28:
    • Aluminium
    • Fabric
    • Polymer
  • Beosound 9000c with Floor Stand: 38.2 W x 137 H x 38.2 D cm
  • Per speaker with Floor Stand: 25.3 W x 137 H x 25.3 D cm
Weight
  • Beosound 9000c: 24.6 kg
  • Per Speaker: 18.6 Kg
Power Consumption
  • Beosound 9000c:
    • Typical: 12 W
    • Standby: < 1.2 W
  • Beolab 28:
    • Typical: 30 W
    • Network standby: 4.5 W
    • Standby: 0.5 W
Power Supply
  • Beosound 9000c: 100-240V 50/60Hz mains cable
  • Beolab 28: 100-240V 50/60Hz mains cable
Bluetooth Version
  • Bluetooth 5.0
Bluetooth Codecs
  • Android: SBC
  • iOS: SBC, AAC
Wi-Fi
Beolab 28:
  • Dual-Band Wi-Fi (2.4 & 5 GHz)
  • IEEE 802.11 b/g/a/n/ac
Streaming Services
  • Beolab 28:
  • Apple AirPlay
  • Spotify Connect
  • Google Cast
  • TIDAL Connect
  • B&O Radio
  • Deezer
  • QPlay 2.0
Beolink Multiroom
  • Yes
Wireless Powerlink / WiSA
  • Yes (up to 24 bit / 96 kHz)
  • Beosound 9000c:
    • 1 x AM aerial
    • 1 x FM aerail
    • 1 x Masterlink
    • 1 x Powerlink (DIN)
    • 1 x Digital output (SPDIF)
    • 1 x AUX socket (DIN)
    • 1 x AC power
  • Per Beolab 28 speaker:
    • 2 x Ethernet
    • 1 x Power Link (RJ45)
    • 1 x Line-in/Optical combi-jack
    • 1 x USB-C (Service)
    • 1 x USB-A (Service)
    • 1 x Power
Remote Control
  • Bang & Olufsen App
  • Beoremote One BT
  • Beoremote Halo
On-Device Controls
  • Yes
BeoSystem 9000C FAQs
Please let us know
Posted on
BeoVox 1
BeoVox 1
BeoVox 1 provides an elegant and discrete in-wall or in-ceiling two-way passive loudspeaker solution with excellent sound performance and numerous placement options in one solution.
In the construction are selected high-quality loudspeaker units (one 16.5 cm woofer and one 2.5 cm tweeter) and applied a carefully designed cross-over network to improve its acoustic performance so the sound dispersion in the treble area is optimised.
Most in-wall loudspeakers are either round or square, but Bang & Olufsen has chosen the elegant, discrete, oval design for BeoVox 1 applying typical Bang & Olufsen craftsmanship. It will be available with either a white or black grille but at launch only the white version is available to order.
Many loudspeakers designed for installation in a wet environment may show an IP rating. This applies to products which can be dangerous to touch when water is in the vicinity because it may splash through the product surface and into the electronics. However, BeoVox1 is a product which is not directly connected to mains electricity so it may be installed directly over a bath or in a wet environment without the need to quote an IP rating.
BeoVox 1 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
2007 -
Colour Options
White, Black
BeoVox 1 Product Specification
Grille cover finish
White, black
Maximum input level
80 watts
Impedance
6 ohms
Effective Frequency range
50 – 20.000 Hz
Crossover frequency
3.000 Hz
Sensitivity
87 dB +/-2dB
Cabinet principle
Infinite baffle
Net volume, bass
18 litres if InWall cabinet is used
Magnetically shielded
No
Woofer
6½”
Tweeter
1”
Operation, Slide switch for treble damping
1: low, 2: medium, 3: maximum damping
Protection
Sealed for wet room use
Language
Service Manual
EN
BeoVox 1 Service Manual
BeoVox 1 FAQs
Please let us know
Posted on
BeoVox 2
Bang & Olufsen BeoVox 2
BeoVox 2
The Beovox 2 is a passive loud speaker designed for in wall or in ceiling mounting. An unusual feature is the ability to turn the speaker to focus the sound in a particular direction. This is designed to be done at the time of installation and once directed , the speaker is fixed in this position.
There are two models, the 2.1 which has a 3/4″ tweeter and 3″ midrange/woofer and the larger 2.2 which has the same tweeter but boats a 5″ midrange/woofer. This allows the reproduction of deeper notes to be achieved.
The 2.1 is 18cm in diameter whereas the 2.2 is 23cm.
BeoVox 2 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
2011 -
Colour Options
Black and White
BeoVox 2 Product Specification
Please let us know
Language
Service Manual
EN
BeoVox 2 Service Manual
BeoVox 2 FAQs
Please let us know
Posted on
BeoVox 901
Bang & Olufsen BeoVox 901
BeoVox 901
Beovox 901 were 4 ohm, 20 watt passive speakers produced in the early 1970s.
They were designed as part of the very successful Beosystem 901 and matched the output of the Beomaster 901 and its derivatives perfectly.
BeoVox 901 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1972 - 1973
Colour Options
Rosewood, Teak
BeoVox 901 Product Specification
Dimensions: (W x H x D) 240 x 330 x 113mm
Language
Service Manual
EN
BeoVox 901 Service Manual
BeoVox 901 FAQs
Please let us know
Posted on
BeoVox 1001
Bang & Olufsen BeoVox 1001
BeoVox 1001
The Beovox 1001 was a very similar loudspeaker to the Beovox 1200 (Beosystem 1200 version), but to match the new black finish of the Beomaster 1001 the metal grille was made black.
Sadly, the designers did not take the opportunity to fit a dome tweeter (as fitted to every other Beovox loudspeaker of the period), so the original (and outmoded) 2.5” cone type remained. As the Beomaster 1001 offered the facility of Ambiophonic stereo, 4 Beovox 1001s could be connected, and the model was also suggested for use with the Beogram 1500-1 record player.
BeoVox 1001 Product Details
Type Numbers
6246
Designer
Manufactured
1971 - 1978
Colour Options
Rosewood, Teak, White
BeoVox 1001 Product Specification
Dimensions: (HxWxD): 340 x 280 x 140mm
Power handling: 20W (40W peak)
Language
Service Manual
EN
BeoVox 1001 Service Manual
BeoVox 1001 FAQs
Please let us know
Posted on
BeoVox 5700
Bang & Olufsen BeoVox 5700
BeoVox 5700
Beovox 5700 high fidelity loudspeaker was of studio monitor quality with minimum distortion and maximum power handling capacity.
The loudspeaker was designed to handle 60 watts RMS or 100 watts music power with a distortion of less than 1% over the entire frequency range of 25-20,000 Hz. In order to produce these qualities, Beovox 5700 was fitted with a 25cm ABR (Auxiliary Bass Radiator) unit and a 25cm bass unit which together produced a clear powerful bass reproduction. Its mid-range dome was 5,5cm in diameter and its dome tweeter was 2cm. Dispersion was 160 degrees.
Trumpet stand
Owing to its size, Beovox 5700 could be preferably used as floor-standing speakers. For this reason Bang & Olufsen designed the trumpet stand, type 8906007. This stand had a top on which the loudspeaker could be placed, not only elegantly, but also practically so that a good sound dispersion could be achieved.
Beovox 5700 could be used with Beosystem 4000, an uncompromising stereo system, top of its range in the mid-1970s.
BeoVox 5700 Product Details
Type Numbers
6229 (1972 - April 1974)
6253 (1972 - June 1975)
Designer
Please let us know
Manufactured
1971 - 1975
Colour Options
Rosewood, Teak
BeoVox 5700 Product Specification
DIN power handling capacity 60 watts
Music power handling capacity 100 watts
Impedance 4 ohms
Frequency range 35 – 20,000 Hz
Harmonic distortion < 1 %
Sensitivity 3 watts
Net volume 45 litre
Woofer: 22,5cm and ABR 25cm
Mid-range 6cm Dome
Tweeter 2cm Dome
Crossover frequency 600 – 6000 Hz
Dimensions W x H x D: 36 x 66 x 30 cm
Weight 22.5 kg
Language
Service Manual
EN
BeoVox 5700 Service Manual
BeoVox 5700 FAQs
Please let us know
Posted on
BeoVox 3702
Bang & Olufsen BeoVox 3702
BeoVox 3702
Beovox 3702 Type 6244 was a high-fidelity pressure chamber loudspeaker with high specifications and intermediate power handling capacity.
It was a three-unit loudspeaker system, which means that the entire frequency range was covered by three separate units: bass, mid-range and tweeter or treble unit. Its frequency range was 40-20 000 Hz and it had a power handling capacity of up to 40 watts RMS or 75 watts music. Distortion was lower than 1% over the entire range.
The bass unit had a 20cm diameter speaker, the mid-range 8cm, the tweeter 2,5cm. Beovox 3702 met DIN high-fidelity norms.
BeoVox 3702 Product Details
Type Numbers
6244
Designer
Manufactured
1972 - 1974
Colour Options
BeoVox 3702 Product Specification
Dimensions: height 50cm, width 25cm, depth 25cm
Language
Service Manual
EN
BeoVox 3702 Service Manual
BeoVox 3702 FAQs
Please let us know
Posted on
BeoVox 5702
Bang & Olufsen BeoVox 5702
BeoVox 5702
Trumpet stand
BeoVox 5702 Product Details
Type Numbers
6257 (1971 - Jan 1975)
6251 (GB) (1971 - Oct 1973)
Designer
Please let us know
Manufactured
1971 - 1975
Colour Options
Rosewood, Teak
BeoVox 5702 Product Specification
Impedance 4 ohms
Sensitivity 3 watts
Net volume 45 litre
Mid-range 6cm Dome
Tweeter 2cm Dome
Weight 22.5 kg
Language
Service Manual
EN
BeoVox 5702 FAQs
Please let us know
