Posted on
BeoMaster 4000
Bang & Olufsen BeoMaster 4000
BeoMaster 4000
The amplifier section of this receiver had outstanding technical data: harmonic distortion was less than 0.1% at maximum power output and 0.06% at 50 mW. Frequency range was 20-30.000 Hz and effective bandwidth 10-35.000 Hz.
Frequency correction facilities were the LOW filter which reduced rumble on records (12 dB per octave at 80 Hz) and the HI filter which damped hiss (12 dB per octave at 4000 Hz). With the LOUDNESS control you could switch between objective and subjective linear reproductions. Beomaster 4000 had facilities for stereo and ambio reproduction. There were sockets for a record player and two tape-recorders, one allowing A\B monitoring. The headphone connection was placed on the receiver’s front. All inputs could be adjusted to give equal volume from all programme sources. The FM section had six pre-set stations. A light indicator assisted accurate tuning and an illuminated meter indicated the strength of a station. Field effect transistors, ceramic filters and integrated circuits were used.
When combined with a built-in record deck, the music centre was known as Beocenter 3500.
Receivers and amplifiers with the ambio function were products which, apart from stereo, could also reproduce the ambience or sound information of a room. Ambient information was included on most stereo vinyl recordings but could not be reproduced by a sound system with two loudspeakers or an ordinary stereo amplifier. Bang & Olufsen systems with the ambio function had facilities which electronically subtracted the difference signal (i.e. the difference between left and right channels) which contained ambient information. This information was fed into two extra loudspeakers which were placed as side speakers in a room. Ambiophony was an extension of stereo reproduction and enhanced the sense of realism. It could be used with nearly all stereo programme materials.
“Ambio is an extension of the type of sound reproduction known today as stereo.
Ambio is reproduced through four loudspeakers – two more than required for stereo.
Ambio is sensed as being more spatial and acoustically more life-like than conventional stereo. The sound picture has greater depth because you get the added feeling of being present of the concert hall, listening to the actual performance. Ambio is based on the principle that in the concert hall you not only receive sound impressions directly from the performing group, you also get reflections from the wall and ceiling. The spatial sensation is instrumental in providing the auditory experience and even a two-speaker stereo system will not bring it out fully. And you cannot accomplish the effect by connecting additional speakers to a conventional stereo amplifier because you still have the same left and right front signals merely distributed to more speakers.
In the Beomaster 4000 the left and right channels are subtracted from each other electronically and the resulting difference signal contains a certain amount of spatial information which is fed to the two new side speakers.
Many existing stereo records, FM broadcasts and tape recordings contain this spatial effect to a greater or lesser extent. In a concert hall, room acoustics will be recorded together with the actual programme material, appearing as time-delayed signals in both left and right channels. Recordings made in a strongly damped studio contain few time-delayed signals and the spatial sensation will therefore depend on how the producer mixed the sounds from the various instruments, perhaps adding acoustical effects by electronic means.
Multi-channel records such as SQ records, which are intended for use in a four-channel matrix system in order to bring out the sound effects , can be played successfully through the Beomaster 4000.
A good quality stereo turntable will provide ambio reproduction of both stereo and SQ records through your Beomaster 4000″
BeoMaster 4000 Product Details
Type Numbers
2406
2408 (US) (1972 - April 1977)
Designer
Manufactured
1972 - 1977
Colour Options
Rosewood, Teak
BeoMaster 4000 Product Specification
Power output 2 x 60 watts/ 8 ohms
2 x 40 W / 4 ohms
2 x 100 W / 8 ohms
2 x 55 W / 4 ohms
Speaker Impedance 4 ohms
Harmonic Distortion < 0.06 %
Intermodulation < 0.3 %
Frequency Response 20 – 30000 Hz
Signal-to-noise ratio > 58 dB
Channel Separation > 45 dB
Bass control: +/- 17 dB
Treble control +/- 14 dB
FM tuner: Range 87.5 – 104 MHz
Power supply:110 – 130 – 220 – 240 V, 50 – 60 Hz
Power Consumption: 20 – 275 W
Dimensions W x H x D: 9.5 x 58 x 27cm
Weight: 10 kg
RIAA amplifier: built-in
Connections: Tape 1 DIN
Tape 2 DIN
Phono DIN
Speakers 2 sets
Language
User Guide
EN
BeoMaster 4000 User Guide
Service Manual
EN
BeoMaster 4000 Service Manual
BeoMaster 4000 FAQs
Please let us know
Posted on
BeoCord VX4500
Bang & Olufsen BeoCord VX4500
BeoCord VX4500
Beocord VX4500, Type 4535 was a basic version of the BeoCord VX5000. It lost the digital video effects but looked very similar outwardly.
BeoCord VX4500 Product Details
Type Numbers
4560 (1990 - Oct 1991)
4567 (AUS, A2) (1990 - Oct 1991)
4563 (East, A2, VPS) (1990 - Oct 1991)
4562 (GB) (1990 - Oct 1991)
4569 (GB, Nicam) (1990 - Oct 1991)
4568 (HK, GB) (1990 - Oct 1991)
4561 (Nicam, A2) (1990 - Oct 1991)
4564 (Nicam, A2, VPS) (1990 - Oct 1991)
Designer
Manufactured
1990 - 1991
Colour Options
Please let us know​
BeoCord VX4500 Product Specification
Description: Cassette format VHS
Tape heads 3 video, 2 Hi-Fi audio
TV channels VHF band 46 – 300 MHz
Hyper-band 300 – 470 MHz
UHF channels 21 – 69
Number of programmes 99
Play channel UHF 37 (adjustable 30 – 39)
Sound, compatible normal/Hi-Fi Stereo, Hi-Fi sound
Decoder TV stereo
A2 built-in (Not in type 4532/38)
Decoder bilingual sound A2 built-in (Not in type 4532/38)
Max. playing time, audio/video: 4 hrs, E240
Max. playing time, audio only 8 hrs, E-240
Fast forward and rewind Approx. 6 min. E240
Counter Tape counter, remaining time
Time programming 8 programmes up to a year
Slow motion video tape Variable speed
Still picture video tape Noiseless
Search forward: 5 x normal speed
Search rewind: 5 x normal speed
Index search Track no., digital picture index
Tape speed VTR 23.39 mm/sec.
Tape speed ATR 11.7 mm/sec.
Recording system HQ
Frequency range black/white: 2.5 MHz
Signal-to-noise ratio luminance 47 dB
Signal-to-noise ratio chrominance Amplitude modulation 38 dB
Pulse modulation 50 dB
Placement min. height: 22 cm
Dimensions W x H x D 54 x 8.5 x 30 cm
Weight 9.1 kg
Connections: RF in 75 ohms
RF out 75 ohms
AV Link 21-pin
AV decoder 21-pin
Camera pause Jack
Remote sensor Jack
Headphone Jack
Microphone Jack
Language
User Guide
EN
BeoCord VX4500 User Guide
Service Manual
EN
BeoCord VX4500 Service Manual
BeoCord VX4500 FAQs
Please let us know
Posted on
BeoCord V8000
Bang & Olufsen BeoCord V8000
BeoCord V8000
BeoCord V8000 video tape recorder matched the Beovision MX range of Bang & Olufsen televisions in looks as well as performance.
You could store a channel on the Beovision MX TV and it was automatically communicated to the V8000. Recording was a simple matter of selecting the programme directly from Teletext using the Beo4 remote control. It could be positioned by using one of the stands as part of a Beovision TV.
BeoCord V8000 rewound a three-hour tape in 95 seconds and it shifted from fast forward to play in a split second.
Other features included NTSC stereo playback. Looks-wise it embodied a black fascia with a choice of cabinets in pearlescent shades of blue, green, red, grey and black, plus glossy grey and glossy white.
BeoCord V8000 Product Details
Type Numbers
4609 (I, PAL, NICAM I)
4601 (B/G, PAL, NICAM B/G)
Designer
Manufactured
1998 - 2005
Colour Options
Blue, Green, Red, Black, Silver, Grey, White
BeoCord V8000 Product Specification
Dimensions W x H x D / Weight:
38 x 10 x 28 cm / 4.3 kg
Cabinet finish:
White, black, silver, red, green, blue
Remote control: Beo4, Beo1
Tuner range: VHF, S, Hyper, UHF
CTV system: According to type: B/G/L/L/I/D/K PAL, SECAM*
TV programmes: 99
Stereo decoder: According to type: NICAM + A2, NICAM
Improved picture quality: Automatic optimised for own and rental tapes
Recording system:
HQ
PAL
Type 4605: PAL, SECAM, ME
SECAM to PAL transcoded recordings Slow motion: 1/2,1/12 x normal speed
Still picture: Noiseless
Tape counter: Time left, time used
Track marker: Set and erase
Timer programming: 8, 1 year
Sound system: Hi-Fi stereo
Video playing time, E-240: SP 4 hours, LP 8 hours (NTSC: SP, EP, LP)
Audio playing time, E-240: LP 8 hours
Connections:
AV: AV Link 21-pin socket
Camcorder IN: 3 phono sockets
V-Tape decoder: AV 21-pin socket
RF input socket: 75 ohms
RF output socket: 75 ohms
Cassette system: VHS
Quickloading: Yes
Subtitles from Teletext: Yes, in colours
On screen display: Yes
Playback of tapes recorded in:
NTSC 3.58 and NTSC 4.43 in Hi-Fi stereo sound
S-VHS (VHS quality)
Disc sizes: 12 cm – 8 cm
Frequency range: 20Hz – 20KHz
Playback the and rewind: Approx. 95 sec. E-180
Search forward/backward: PAL, SECAM: 5 x and 11 x normal speed,
Signal-to-noise-ratio SP mode:
Luminance >= 48 dB
Chrominance >= 38 dB (AM)
Chrominance >= 31 dB (PM)
Sound, compatible Hi-Fi/normal:
Stereo Hi-Fi/mono fixed head
Tape heads: 2 LP video, 2 SP video, 2 Hi-Fi sound
Sound frequency range: 20 – 20,000 Hz, 1 3 dB
Hi-Fi distortion: <= 1%
Signal-to-Noise ratio A-weighted: > 63 dB
Modulator tuning range: 471 – 855 MHz, System I
Power supply: 180 – 240 volts/50 Hz
Power consumption: Typical 22 watts / standby< 2.1 watts
Language
User Guide
DK
BeoCord V8000 MS User Guide
User Guide
EN
User Guide
FIN
User Guide
DE
User Guide
NL
User Guide
DK
BeoCord V8000 MX User Guide
User Guide
EN
User Guide
FIN
User Guide
DE
User Guide
NL
Exploded View
EN
BeoCord V8000 Exploded View
BeoCord V8000 FAQs
Please let us know
Posted on
BeoCord VX7000
Bang & Olufsen BeoCord VX7000
BeoCord VX7000
Beocord VX7000 video cassette recorder was operated and programmed with the Beo4 remote control (although could equally, if not be better controlled, through the previous two-way Beolink 5000 remote control unit) through Beovision MX models.
All channels stored on the TV were simultaneously stored on the VX7000. In 1995 a new model was released specifically designed to operate through the Beo4 remote control unit and lost the two-way communication that had been one of its greatest selling points.
Features: hi-fi stereo VCR; NICAM/A2, PAL/NTSC converter; Beo4 remote control (1995 models onwards); black fascia; cabinet in the same colour schemes as the Beovision MX7000 plus black.
BeoCord VX7000  Product Details
Type Numbers
BeoCord VX7000 VHS VCR
4587 (AUS) (1993 - Oct 1995)
4581 (EUN) (1993 - May 1994)
4580 (FMS) (1993 - May 1994)
4585 (FMS) (1993 - Oct 1995)
4589 (GBN) (1993 - Oct 1995)
4588 (HK) (1993 - Oct 1995)
4586 (NZ) (1993 - Oct 1995)
4584 (UVS) (1993 - Aug 1995)
4583 (VPS) (1993 - Oct 1995)
Beocord VX7000 Beo4 (One-way)
4617 (AUS) (1995 - Dec 1997)
4614 (EEU) (1995 - Dec 1997)
4611 (EU) (1995 - Dec 1997)
4613 (EU) (1995 - Dec 1997)
4610 (F) (1995 - Dec 1997)
4615 (F) (1995 - Dec 1997)
4619 (GB) (1995 - Dec 1997)
4618 (HK) (1995 - Dec 1997)
4616 (NZ) (1995 - Dec 1997)
Designer
Manufactured
1993 - 1997
Colour Options
White, Black
BeoCord VX7000  Product Specification
Dimensions W x H x D/Weight 54 x 8.5 x 30 cm/8.5 kg Cabinet finish White, Black Terminal recommended via Beovision: Beolink 5000 Tuner range VHF, S, Hyper, UHF UHF (4589) CTV system B/G PAL PAL I (4589) B/C/PAL/SECAM (4585) TV programmes 59 Stereo decoder NICAM + A2 Recording system HQ Slow motion 1/7 normal speed Still picture Noiseless Tape counter Track, time left, time used Timer programming 8, 1 year Sound system Hi-Fi stereo Video playing time, E-240 SP 4 hours, LP 8 hours Audio playing time, E-240 LP 8 hours Power consumption / Minimum 34 watts/10 watts Cassette format VHS Picture functions: Playback tapes recorded in NTSC 4.43 MHz or PAL 60 Hz Fast forward and rewind Less than 5 min. E-240 Search forward SP 7 x and 15 x normal speed Search backward SP 2 x and 7 x normal speed Search forward LP 5 x and 13 x normal speed Search backward SP 2 x and 5 x normal speed Tape heads 5 video, 2 Hi-Fi audio Connections: AV AV Link 21-pin socket Camcorder IN 3 phono sockets RF IN 75 ohms RF OUT 75 ohms Camera pause Jack 2.5 mm socket
Dimensions W x H x D/Weight 54 x 8.5 x 30 cm/8.5 kg Cabinet finish White, Black Terminal recommended via Beovision: Beo4 Tuner range VHF, S, Hyper, UHF UHF (4589) CTV system B/G PAL PAL I (4589) B/C/PAL/SECAM (4585) TV programmes 59 Stereo decoder NICAM + A2 Recording system HQ Slow motion 1/7 normal speed Still picture Noiseless Tape counter Track, time left, time used Timer programming 8, 1 year Sound system Hi-Fi stereo Video playing time, E-240 SP 4 hours, LP 8 hours Audio playing time, E-240 LP 8 hours Power consumption / Minimum 34 watts/10 watts Cassette format VHS Picture functions: Playback tapes recorded in NTSC 4.43 MHz or PAL 60 Hz Fast forward and rewind Less than 5 min. E-240 Search forward SP 7 x and 15 x normal speed Search backward SP 2 x and 7 x normal speed Search forward LP 5 x and 13 x normal speed Search backward SP 2 x and 5 x normal speed Tape heads 5 video, 2 Hi-Fi audio Connections: AV AV Link 21-pin socket Camcorder IN 3 phono sockets RF IN 75 ohms RF OUT 75 ohms Camera pause Jack 2.5 mm socket
Language
Date
Setup Guide
EN
4581, 4583, 4586, 4587, 4589
11-92
BeoCord VX7000 Setup Guide
User Guide
DK
11-92
BeoCord VX7000 User Guide
User Guide
EN
11-92
User Guide
FR
11-92
User Guide
DE
11-92
User Guide
NL
11-92
Service Manual
Multi
11-92
BeoCord VX7000 Service Manual
BeoCord VX7000  FAQs
Please let us know
Posted on
BeoCord VX5500
Bang & Olufsen BeoCord VX5500
BeoCord VX5500
A special Bang & Olufsen feature was ‘spontaneous videotaping’. If you wanted to record the programme you were watching it was simply a matter of pressing ‘record’ twice on the remote control handset – and the VCR would automatically find the right channel and start taping.
You could with Beocord VX5500 play back in slow motion all the way down to still. You could use the picture-in-picture module with the VCR and the B&O TV on which you had it linked up to and it was also possible to keep your video tapes organised. By using a graphic ‘notebook’ you could name every video tape you record. Then you use the Beolink 5000 or Beolink 1000 terminal to simply order up the number of your recording.
BeoCord VX5500 Product Details
Type Numbers
4567 (AUS) (1991 - Aug 1992)
4561 (EU) (1991 - June 1993)
4560 (EU) (1991 - April 1993)
4535 (FMS) (1991 - May 1993)
4569 (GB) (1991 - Aug 1992)
4562 (GB) (1991 - Jan 1993)
4568 (HK) (1991 - Aug 1992)
4566 (NZ) (1991 - June 1992)
4536 (US) (1991 - Oct 1991)
4563 (VPS) (1991 - March 1993)
Designer
Manufactured
1991 - 1993
Colour Options
Black, White
BeoCord VX5500 Product Specification
Cassette format: VHS
Decoder TV stereo
4 hours, E-240
Max. playing time, audio only 8 hours, E-240
Fast forward and rewind: approx. 6 min. E-240
Recording system HQ
Signal-to-noise ratio chrominance amplitude modulation 38 dB
Dimensions: W x H x D 54 x 8.5 x 30 cm
Weight: 9.1 kg
RF out 75 ohms
AV Link 21-pin
AV decoder 21-pin
Camera pause Jack
Remote sensor Jack
Headphone Jack
Microphone Jack
Language
User Guide
EN
BeoCord VX5500 User Guide
Setup Guide
EN
BeoCord VX5500 Setup Guide
BeoCord VX5500 FAQs
Please let us know
Posted on
BeoCord VX5000
Bang & Olufsen BeoCord VX5000
BeoCord VX5000
Designed by David Lewis, Beocord VX5000 was the flagship of the range in the late 1980’s, with the ability to display live pictures from up to nine different channels simultaneously. A TV guide that was hard to beat! The VX5000 worked best with a Bang & Olufsen TV, simply because they were made for each other. You could choose from either the contemporary MX or the classic LX series.
Beocord VX5000: the multi-role video recorder
Step by Step
When you wanted to analyse a Wimbledon championship down to the last detail you would find the slow motion facility a real boon. And of course it was superb for picking up tips to improve your sporting style. You could also freeze frames, not only on video, but also in the middle of a direct broadcast; the picture quality remained at its impressive best.
We all know how complicated programming some video recorders can be. With the Bang & Olufsen range you don’t need a degree in pure maths to succeed. A ‘menu’ on the screen gave you straightforward instructions. So easy that you would want to take advantage of programming that lets you preset recordings of up to six different programmes up to one year in advance!
There was a very handy Search function too; acting like the ‘Track Searching’ on an audio cassette recorder, it took you to the programme you want with minimal fuss and bother.
Video or all-night music
The VX5000 gave you the choice of either four hours of video, or up to eight hours of top-quality hi-fi sound to last the whole night through!
Beocord VX5000 was designed specially be use in conjunction with Beovision MX5000 TV when, together, you could pull in a live picture from another channel on the screen while you continued with the programme you were already watching. Very handy when you were waiting for a specific programme on another channel to start. Much the same could be done in later years with the advent of Picture-in-Picture – a module bought as an accessory for fitting into your television.
BeoCord VX5000 Product Details
Type Numbers
4537 (AUS) (1989 - Oct 1991)
4531 (EU) (1989 - Jan 1992)
4530 (EU) (1989 - Jan 1992)
4532 (GB) (1989 - Oct 1991)
4539 (GB NICAM) (1989 - Dec 1991)
4538 (HK) (1989 - June 1991)
4536 (US) (1989 - Oct 1991)
4533 (VPS)(1989 - Jan 1992)
Designer
Manufactured
1993 - 1997
Colour Options
Grey, Black, White
BeoCord VX5000 Product Specification
Decoder TV stereo
4 hours, E-240
Fast forward and rewind Approx. 6 min. E-240
Slow motion video tape Variable speed Still picture video tape Noiseless
Still picture TV program Digital
Recording system HQ
2.5 MHz
22 cm
Weight 9.1 kg
RF out 75 ohms
AV Link 21-pin
AV decoder 21-pin
Camera pause Jack
Remote sensor Jack
Headphone Jack
Microphone Jack
Language
User Guide
EN
BeoCord VX5000 User Guide
User Guide
DE
Service Manual
EN
BeoCord VX5000 Service Manual
BeoCord VX5000 FAQs
Please let us know
Posted on
BeoCord V6000
Bang & Olufsen BeoCord V6000
BeoCord V6000
Beocord V6000 was a hi-fi stereo video cassette recorder designed to work with Beovision models ME6000 and MS6000.
Together they formed an integrated unit in which TV and video cassette recorder automatically share all commands and can be operated by the same remote control. This combination was designed to be used as a standalone TV/VCR combination. The VCR had all playback facilities as any standard VCR. It also had VPS/PDC and NTSC playback. The video recorder was controlled via a Beolink 1000 handset through the Beovision television.
Bang & Olufsen’s new generation of TV and video systems at the time that the V6000 was released, made it simpler an more comfortable to watch TV. All data stored in the TV: time and programme channels, were automatically stored in the VCR as well. The same applied when you connected your TV and video recorder to a Beolink system – the clocks on the various units within the system were automatically synchronised.
BeoCord V6000 Product Details
Type Numbers
4401 (EU) 1993 - May 98
4409 (GB) 1993 - May 1998
4403 (VPS) 1993 - May 1998
Designer
Manufactured
1993 - 1998
Colour Options
Black
BeoCord V6000 Product Specification
Dimensions WxHxD/Weight: 43,5 x 10 x 37cm/6kg
Cabinet finish: Black
Terminal recommended via Beovision: Beolink 1000
Tuner range VHF-S-Hyper-UHF
CTV system B/G PAL
PAL I (4409)
TV programmes 59
A2 (4403)
Recording system HQ
Slow video 1/6 x normal speed
Synchronous Programme Recording: PDC/VPS compatible
Power consumption 22 watts/9 watts
Sound system: Hi-fi stereo
Playback tapes recorded in NTSC 4.43 MHz, mono sound
Fast forward and rewind Approx. 95 sec. E-180
Search forward/backward 3 x and 11 x normal speed
Video Playing time E-240: SP 4 hours, LP 8 hours (NTSC SP/EP)
Audio Playing time E-240: LP 8 hours
Power supply: 180-240 volts/50 Hz
Connections: AV EURO-AV, Beovision 21-pin
AUX, decoder 21-pin
RF input 75 ohms
RF output 75 ohms
Language
User Guide
EN
BeoCord V6000 User Guide
User Guide
FR
User Guide
DE
User Guide
NL
BeoCord V6000 FAQs
Please let us know
