Posted on
BeoGram 3500
Bang & Olufsen BeoGram 3500
BeoGram 3500
Another incarnation of the lightweight B&O tangential turntable, this one was designed to match the Beomaster 3500 with it’s ‘battleship grey’ trim on the dust cover and was supplied with an MMC4 cartridge. A RIAA was built into this model.
BeoGram 3500 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1990 - 1993
Colour Options
Grey
BeoGram 3500 Product Specification
Wow and flutter, DIN < +/- 0.06 %
Rumble DIN weighted > 80 dB
Rumble DIN unweighted > 55 dB
Speeds
33 – 45 rpm.
Speed deviation < +/- 0.2 %
Power supply
5976: 220V
5977: 120V
5978: 100V
Power consumption < 10 watts
Dimensions W x H x D 42 x 7.5 x 32.5 cm
Weight 5.3 kg
Language
Service Manual
EN
5976, 5977, 5978, 5979
BeoGram 3500 Service Manual
BeoGram 3500 FAQs
Please let us know
Posted on
BeoGram 3300
Bang & Olufsen BeoGram 3300
BeoGram 3300
It’s better both for your records and for sound quality to play a record the way the master was made – in a straight line from the edge to the centre. This tangential arm record player did just that, giving a far more precise reading of the signals in the groove. The MMC4 cartridge made a vital contribution too; it was feather-weight, with a stylus pressure of only 1,2 grams, giving outstanding sound quality but minimising wear and tear on your records.
There’s more protection too – invaluable for all-night parties. The electronically controlled tangential arm was suspended so that it isolated mechanical vibrations from the cartridge. The suspension chassis was also thoroughly engineered to neutralise vibrations. So keep on dancing – the record player can take it! Beogram 3300 was part of Beosystem 3300 although may be used as a stand-alone item.
One of many tangential decks all utilising the same basic design, the 3300 was noticeable mainly for its grey finish and slightly lurid graphics. Very much a child of the 80s, it was replaced by the 3500 and 4500.
BeoGram 3300 Product Details
Type Numbers
5931 (1987 - June 1990)
5935 (AUS) (1987 - Sept 1988)
5933 (USA) (1987 - June 1990)
Designer
Manufactured
1987 - 1990
Colour Options
Grey
BeoGram 3300 Product Specification
Tonearm: Tangential Optimum Pivot Point
Motor Servo-controlled DC
Wow and flutter: < 0.06 %
Rumble DIN weighted: >80 dB
Rumble DIN unweighted: >55 dB
Speeds: 33-45 rpm
Speed deviation: <+/- 0.2 %
Power supply: 190 – 265 V
Power consumption: < 10 W
Weight 5.3 kg
Link compatibility: Data Link
Language
User Guide
EN
BeoGram 3300 User Guide
User Guide
NL
Service Manual
NL
5931, 5933, 5934, 5935
BeoGram 3300 Service Manual
BeoGram 3300 FAQs
Please let us know
Posted on
BeoGram 1201
BeoGram 1201
BeoGram 1201 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoGram 1201 Product Specification
Please let us know
David Lewis
BeoGram 1201 FAQs
Please let us know
Posted on
BeoGram 6000 (1981)
Bang & Olufsen BeoGram 6000 1981
BeoGram 6000 (1981)
Beogram 6000 – Type 5751 – was a fully automatic record player with one-touch operation.
Put a record on the turntable, touch START and let Bang & Olufsen technology do the rest. The lightweight, low inertia tone arm was fitted with the MMC 20EN pick-up cartridge. This had a naked elliptical diamond and a low Effective Tip Mass which, together with the lightweight arm, secured excellent tracking performance and minimum record wear.
The patented spring suspension system effectively prevented external knocks and vibration from affecting tracking and sound quality. This later radial 6000 model was fitted with Datalink and was really a Beogram 2402 with new electronics in the same design. It really did not match the Beomaster 6000 and was a short lived and frankly unpopular model but was offered as a cheaper alternative to the tangential tracking and tangential drive Beogram 6006. These decks were both replaced by the Beogram 6002. This deck had the newer MMC3 cartridge and was a strange amalgam of the two earlier decks in that it had a simplified tangential arm but belt drive for the platter
BeoGram 6000 (1981) Product Details
Type Numbers
5751
Designer
Manufactured
1981 - 1981
Colour Options
Rosewood, Teak, White, Oak
BeoGram 6000 (1981) Product Specification
Speeds 33-45 rpm.
Wow and flutter < +/- 0.06 %
Rumble weighted > 65 dB
Rumble unweighted > 45 dB
Motor Servo controlled DC
Drive system Belt
Power supply
180 – 265 (110) V
Power consumption 8 watts
Dimensions 44 x 8.5 x 37 cm
Weight 6.5 kg
Recommended stylus pressure MMC 20 EN 12 mN / 1.2 gram
Language
Language
User Guide
EN
BeoGram 6000 User Guide
Service Manual Part 1
EN
5501, 5502
BeoGram 6000 Service Manual
Service Manual Part 2
EN
5501, 5502
Service Manual
EN
5514, 5515
Service Manual
EN
5502, 5505
Service Manual
EN
5751, 5753, 5754
BeoGram 6000 (1981) FAQs
Please let us know
Posted on
BeoGram 2000 (1983)
Bang & Olufsen BeoGram 2000 1983
BeoGram 2000 (1983)
This radial-tracking record deck had a lightweight turntable (only 400g) to minimise torque at starting. The automatic cueing system was also very fast-acting, so it was only a matter of a few seconds between touching the PLAY control and hearing the music.
The tone arm had built-in anti-skating and carried the MMC 4 pickup, ensuring accurate tracking and excellent sound quality. Normal PLAY and STOP functions were entirely automatic and could be operated with the lid closed; manual buttons for playing non-standard discs were located on the deck plate. In addition to automating the setting of correct speed and cueing position for each record, the Beogram’s built-in microcomputer allowed a REPEAT function, which could be programmed for up to 7 plays of the same record.
Drive was provided by a tacho-controlled DC motor via a flat rubber belt, so turntable speed was always accurate and could not be affected by fluctuations in the mains supply.
When used with Beomaster 2000, an electronic data-link allowed Beogram 2000 to be operated by the Beomaster’s controls. Beogram 2000 could also be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products.
BeoGram 2000 (1983) Product Details
Type Numbers
5821 (1983 - March 1988)
5825 (AUS) (1983 - Sept 1986)
5823 (US) (1983 - May 1987)
Designer
Manufactured
1983 - 1987
Colour Options
Aluminium
BeoGram 2000 (1983) Product Specification
Speeds: 33 – 45 rpm
Wow and flutter DIN < +/- 0.07 %
Rumble DIN weighted > 75 dB
MMC 4 cartridge
Recommended tracking force 12 mN / 1.2 g
Power supply:
5821-5825: 190 – 265 (90 – 130) V
2823: 120 V
Dimensions W x H x D: 42 x 8 x 32.4cm
Weight 6 kg
Language
Date
User Guide
EN
BeoGram 2000 User Guide
User Guide
EN
Service Manual
EN
5811, 5813, 5814, 5815
BeoGram 2000 Service Manual
Service Manual
EN
5240
Supplement Service Manual
EN
10-84
BeoGram 2000 Supplement  Service Manual
BeoGram 2000 (1983) FAQs
Posted on
BeoGram 1800 (1968)
Bang & Olufsen BeoGram 1800 1968
BeoGram 1800 (1968)
This was a rare and interesting model. It boasted a new arm and motor compared to the Beogram 1000 but retained quite a lot of the design and the uninspired rubber mat.
It also had a most unusual dust cover with a metal surround with only the top panel being transparent. This design was to be seen also in the prototype Beogram 6000 but not in any production model.
BeoGram 1800 (1968) Product Details
Type Numbers
5213 (1968 - Dec 1972)
Designer
Manufactured
1968 - 1972
Colour Options
BeoGram 1800 (1968) Product Specification
Speeds: 45 and 33,3
Rumble: better than 55 dB (DIN B.)
Wow and flutter: +/- 0.15 peak value
Amplifier:
Max. 3.5 V RMS = 10 V pp (corresponding to 58 cm/sec./1000 Hz)
Pickup:
SP 10 A type 5425
Stylus pressure 1 g (2 g max)
Output:
5 mV – 1000 Hz / 47 k ohms
Voltage:
110 – 220 volts AC
Power consumption 22 W
Dimensions W x H x D: 43.8 x 13.2 x 32.3 cm
Weight 6.5 kg
Language
Date
Brochure
EN
BeoGram 1800 Brochure
User Guide
EN
BeoGram 1800 User Guide
Service Manual
EN
12-82
BeoGram 1800 Service Manual
Service Manual
Multi
07-70
5213
Service Manual
EN
08-83
581x
EN
10-84
BeoGram 1800 Supplement Service Manual
BeoGram 1800 (1968) FAQs
Please let us know
Posted on
BeoGram 1500 (1978)
Bang & Olufsen BeoGram 1500 1978
BeoGram 1500 (1978)
Beogram 1500 combined ease of operation and advanced technology in a simple, straightforward way. All its operations were controlled via a single button.
Another advantage of this totally integrated design was its immunity to external shock and vibrations. The electronic servo drive system ensured correct turntable speed at all times. The low-mass arm had built-in bias compensation, and the MMC 20S pickup tracked at only 1,5 grams.
The unique pendulum spring suspension helped make the Beogram range of record players immune to the external shock and vibrations which would cause most other record decks to mistrack and damage the record groove.
Beogram 1500 could be made up as part of the Beosystem 1500, when linked together with other compatible Bang & Olufsen products.
This deck was the basic model of its time but the inherent design of this deck meant that the performance was extremely similar to the top of the range radial decks. Very easy to set up and simple to use, a true bargain buy in later years.
BeoGram 1500 (1978) Product Details
Type Numbers
5714 (1978 - July 1980)
5716 (F) (1978 - Nov 1979)
Designer
Manufactured
1978 - 1980
Colour Options
BeoGram 1500 (1978) Product Specification
Sound system Stereo, matrix
Output DIN 8.5 mV /47 kohms
Speeds: 33 – 45 rpm.
Tonearm: radial
Stylus pressure range 0 – 2 g
Automatic record-size: Yes, 17 and 30 cm
Automatic pickup movement Yes
Automatic speed selection Yes
Wow and flutter, DIN: < +/- 0.09 %
Rumble DIN unweighted: > 42 dB
Rumble DIN weighted: > 62 dB
Speed deviation: < 0.05 %
Speed control range: > +/- 3 %
Tracking error: 0.126°
Lift system: Mechanical
Antiskating: Yes, automatic
Pickup: MMC 3000 or MMC20S
Recommended stylus pressure: 1.2 g
Stylus: diamond spherical
Radius of curvature:15 µm
Motor: Servo controlled DC
Drive system: Flat belt
Turntable: 30cm / 500g
Power supply: 220 (110 – 130 – 240) V
Power consumption: 8 W
Dimensions: 44 x 8.5 x 33cm
Weight 6 kg
BeoGram 1500 (1978) FAQs
Please let us know
Posted on
BeoGram & RIAA Pre-Amplifiers
Equalising the phono signal
Vinyl records have three basic problems: it is physically impossible to press them with ridges that end up allowing low frequencies to come out at the same reproduction level as mid and high frequencies.
Bass compensation is therefore needed during playback. Secondly, records produce a certain amount of hiss which is covered up in post-production by boosting the gain of the high frequencies before pressing. Counter-EQing during playback compensates for this. Finally, magnetic cartridges produce a weak signal which must be boosted to match the rest of the amplification and this too is done during playback. In the mid-1950s, compensation standards were established by the Recording Industry Association of America.
The resulting RIAA preamp has been built into every hi-fi and stereo amplifier with phono or turntable inputs since then. A separate RIAA preamp is necessary when you are connecting a turntable to a mixer which does not have one built in.
The phono preamplifier is the key component needed to match the output of the turntable to the line input of the amplifier or audio mixer. If you’ve tried connecting a turntable to a modern amp or hi-fi unit and you’re not happy with the results, it’s probably because you don’t have a suitable turntable input.
Manufacturers tend not to include a turntable input anymore because the vast majority of customers don’t play vinyl. However, you can still obtain turntables and magnetic pick-up cartridges. The signal from these pick-ups is much smaller than from a CD, tape deck, radio tuner or auxiliary source – so if you connect to any of those inputs you’ll not have much volume. Also the tone will be totally wrong – all treble and no bass. What you need then is a phono preamplifier, it connects between turntable and amplifier or hi-fi unit. It lifts the signal to the required level and restores the tonal balance.
Pre-amplifiers explained
Retrieving the signal from a record groove takes carefully balanced engineering to restore the sound back to the original so it can be applied to the input of an amplifier or audio mixer.
All gramophone records are cut with falling bass (LF) and rising treble (HF) below and above some mid-range frequency (MF). It’s this trick that makes it possible to keep the groove a constant width.
It is a phono preamplifier’s job (otherwise known as gramophone amplifiers, turntable pre-amps or vinyl disc equalisers) to precisely perform the opposite effect to that of the record cutting machine. This is called equalisation (EQ for short) which boosts the bass and cuts the treble by just the right amount. It also has to amplify the tiny signal from the pick-up cartridge, with minimal noise and distortion, so it’s big enough to drive an amplifier.
The following list of B&O Beogram turntables shows those with built-in RIAA pre-amplifiers and those without
It is important to note that pre-amplifiers may have been installed by a 3rd party. While we believe this list to be correct, we do recommend that you fact check with the relevant manuals.
RIAA Built-in
RIAA option (CD4 demodulator)
There is a switch on the right hand side of the deck to identify them
RIAA factory option
RIAA not installed
Posted on
BeoLab 12-1
Bang & Olufsen BeoLab 12-1
BeoLab 12-1
BeoLab 12-1 Product Details
Type Numbers
6230
Designer
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoLab 12-1 Product Specification
Please let us know
Language
  Date
Service Manual
EN
12-02
6232
BeoLab 12-3 Service Manual
BeoLab 12-1 FAQs
Please let us know
Posted on
BeoLab 12-2
Bang & Olufsen BeoLab 12-2
BeoLab 12-2
BeoLab 12-2 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoLab 12-2 Product Specification
Please let us know
Language
  Date
Service Manual
EN
12-02
6232
BeoLab 12-2 FAQs
Please let us know
