Posted on
BeoVision 4402
BeoVision 4402
BeoVision 4402
Beovision 4002 and 4402 were colour receivers with 26″ screens. Natural colours, sharp, precise image definition and high-fidelity sound reproduction are all features you can take for granted, according to the 1970 – 80 Bang & Olufsen product catalogue. Their high reliability levels were due to modular construction techniques and low heat-generation. Beovision 4002 consumed only 110 watts – less than a black and white set of years previously.
Both sets were extremely easy to use. There were facilities for presetting up to eight stations so that subsequent programme selection was just a matter of pressing one button. This turned the set on at the same time.
Beovision 4402 had the additional convenience of a cordless (ultrasonic) remote control. The set could also be supplied equipped for Teletext reception. There was automatic synchronisation of VCR programmes on all channels.
BeoVision 4402 Product Details
Type Numbers
3501 (1977 - Dec 1980)
3503 (GB) (1977 - June 1980)
3521 (1977 - May 1982)
3541 (B, 16 CH) (1977 - March 1979)
3522 (GB) (1977 - Jan 1981)
3543 (NL) (1977 - Aug 1981)
Manufactured
1977 - 1982
Colour Options
Picture tube size: 66cm Cabinet: wood veneer Number of programmes: 8 VHF - UHF Easy touch Range: UHF 21 - 69, VHF 2 - 12 Start time: approx. 5 sec Aerial impedance: 75 ohms coaxial Speakers: 1 forward-facing pressure chamber Sound power output: 6.5 W Harmonic distortion: < 0.8 % Frequency range: +/- 1.5 dB 60 - 15,000 Hz Power bandwidth: 60 - 20,000 Hz Bass control: +/- 5 dB / 100 Hz Treble control: +/- 10 dB / 10,000 Hz Power supply: 180 - 265 V Power consumption: 110 W Standby: 0 W Dimensions W x H x D: 69.5 x 49 x 46cm Weight: 36 kg Undercarriages: Cross-base with castors 3043, Table with castors 3055
BeoVision 4402 Product Specification
Please let us know
Documents will be listed here
BeoVision 4402 FAQs
Please let us know
Posted on
BeoVision 3502
BeoVision 3502
BeoVision 3502
Beovision 3502 and 3802 – designed by David Lewis – were two 22″ colour TV receivers whose cabinets were of a moulded synthetic material. They were elegant and practical, according to B&O’s catalogue of 1979 – 80; the material was shock- and shatter-proof and fire-retardant. Dirty marks could be wiped off easily with a damp cloth.
Operation was easy and problem-free via the large, logically designed operation panels. Additionally in the 3802 model, all functions could be operated from a distance via the remote control module. Both receivers could accommodate a VCR without further technical adjustment. Beovision 3802 could also be equipped for Teletext reception. Automatic cut-off circuitry ensured the correct balance between colours without the need for regular adjustment by an engineer. High-bright picture tubes allowed for satisfactory viewing in daylight conditions. Modular chassis and low power consumption (and therefore less heat) ensured greater reliability.
BeoVision 3502 Product Details
Type Numbers
3506 (1977 - Jan 1981)
3507 (GB) (1977 - Feb 1981)
Designer
Manufactured
Please let us know​
Colour Options
White or Aubergine
BeoVision 3502 Product Specification
Picture size: 56 cm
Start time: 5 sec
Automatic cut off
AFC
Number of programs 8 VHF – UHF
Easy touch
Ranges VHF 2 – 12, UHF 21 – 69
Deflection angle: 110° in line
Aerial impedance: 75 ohms coaxial common VHF – UHF
Sound section:
Power output EMS: 1000 Hz 6.5 W
Distortion at specified output: < 0.8 %
Frequency response:
Amplifier +/- 1.5: dB: 60 – 15,000 Hz
Acoustical +/- 10 dB: 60 – 20,000 Hz
Power supply: 180 – 265 V
Power consumption 110 W
Stand by: 0 W
Dimensions W x H x D: 61 x 41 x 42cm
Weight 27 kg
Finishes: aubergine or white
Undercarriages: Trumpet stand 3054, Cross-base with castors 3043, Table with castors 3056
BeoVision 3502 FAQs
Please let us know
Posted on
BeoVision 3000SJ
BeoVision 3000SJ
BeoVision 3000SJ
” Beovision 3000 Colour SJ is a colour television receiver built like a deluxe PAL receiver with a delay module for the PAL system. The receiver is compatible, which means it is capable of receiving either black-and-white or colour programmes, and the transition is automatic so that you avoid manual operation of buttons or similar controls “
In the summer of 1963, Bang & Olufsen began the development of the first colour television, with engineer Bent Moller Pedersen and an apprentice. Testing the new receivers was still a problem, because there were not many places where colour test cards could be received. It came as a relief to the technicians when, in 1966, Hamburg began to broadcast test cards.
A Bang & Olufsen colour television laboratory with three technicians was set up for a week at a pub 25 km north of Hamburg! In 1967, Bang & Olufsen began producing colour televisions – not without a certain cautious scepticism. Director Jens Christian Sonderup wrote to retailers in the summer of 1967: “At the moment, no one can say with any degree of certainty how sales of colour televisions will develop. Let us be clear about one thing, though: colour television will not be the bread and butter of the sector during the coming season… We must all hope and believe that the radio sector will prove to be a match for colour TV. in B&O circles, let us as usual err on the side of healthy development.” Weighing in at 52 kg, the Beovision 3000 Colour S.1 was an investment for the company in a market that was still feeling its way between different international standards.
The introduction of colour television brought with it some new concepts that were unknown in the days of black-and white reception: colour saturation and colour tone. The picture tube was now 63cm, but it could not be manufactured with sufficient perfection and accuracy for the three electron guns in the picture tube to line up properly on the interior of the picture tube. It was therefore necessary to make some manual adjustments (convergence adjustments) in production as well as in subsequent servicing. The set had to be adjusted at regular intervals. That had also been taken into consideration in this unit. Chief Engineer Knud Hoist and Engineer Bent Moller Pedersen wrote the following instructions with the service technicians (rather playfully) in mind: “Here is B&O’s unconventional solution on the deployment of the convergence buttons. Remove the small panel at the front of the set by lifting it with a coin. The flap can then be pushed far back enough to allow easy access to the convergence buttons while, at the same time, their effect can be seen by looking at the screen. One reason why we have done this is in order not to impose a requirement for future colour TV technicians to be born with extra-long arms!
Despite the director’s cautious scepticism, Chief Engineer Knud Hoist had no doubt that colour television was the way ahead. Speaking in a radio lecture, he said: “If we don’t open the front door to colour television by introducing a Danish colour TV, it will come in by the back door as foreign broadcasts over our borders. Continuing to exclude colour television for much longer from parts of the country that are not covered by Germany will create such a great demand backlog that both the manufacturing sector and the retail sector will both find it difficult to cope when it is finally released. It would be much more desirable to accept what is otherwise an inevitable, slow penetration of colour television into Denmark – and to act accordingly.”
(Taken from Beolink Magazine: ‘The First 50 Years of Television’ © Bang & Olufsen a/s 2002)
” Its 625-line only circuitry initially made it of limited use, as BBC1 and ITV were not widely receivable on this standard, leaving BBC2 as the only viewable programme. Beovision 3000 made up for this though by offering the best quality colour picture yet seen, so good in fact that in certain areas it remained unsurpassed for years after it was withdrawn. When B&O released its first solid state colour sets in 1974, these had to be modified in the field, as their contrast levels seemed ‘washed out’ compared to the then 6 year old 3000s!
Quality was achieved at the cost of considerable complexity. It is well known that cost was not a factor in the design of the 3000, and so any extra parts or stages that could possibly up the performance were added without question. The result was a set with 18 valves, 53 transistors and 48 diodes arranged on two massive chassis. Technical highlights included decoder circuitry working at high voltage to improve colour linearity, DC controlled static convergence, apparently less susceptible to mains voltage variations, separate line scan output stage and EHT generator employing two transformers and two sets of large valves, which improved geometry and dimensional stability, an electronic EHT stabiliser which helped to ensure uniform focusing, and of course, a comprehensive audio amplifier employing three transistors, one valve and heavy negative feedback, all driving a high quality loudspeaker.
These sets demonstrated to the new British market that B&O’s televisions were every bit as good as their audio, and started a long line of development which can be directly traced to the current models. “
BeoVision 3000SJ Product Details
Type Numbers
36xx Introduced July 1968
Designer
Please let us know
Manufactured
1968 - 1970
Colour Options
Teak or rosewood
BeoVision 3000SJ Product Specification
Tuning:
VHF and UHF Push-button tuner (6 push-buttons) All push-buttons could be set for any desired channel on VHF (bands I and III, channels 2-11) of UHF (channels 21 – 70)
Knobs Volume control with push push mains on-off switch. Bass, treble, brightness, contrast, colour saturation and tint controls located in drawers, contrast knob automatically controlled monochrome and colour signal. Tint control was mechanically indexed in normal position. Vertical hold on back of set
Push buttons Colour switch (on back of set)
Sound
Power output: 3.5 W at 10 % distortion
Distortion: 1 % at 3 W
Tone control ranges: bass +/- 12 dB at 100 Hz; treble +/- 12 dB at 10 kHz
Sound detector: Ratio detector
Sound intermediate-frequency: 5.5 MHz, 2 stages
Picture tube 25-in. shadow mask tube, Type A 53 – 11 X
Video intermediate-frequency 38,9 MHz – 3 stages plus additional output stage for chroma
Chroma (Colour) intermediate-frequency 4,43 MHz – 3 stages. 30 dB AGC control range
PAL-delay line Type DL 1 64 microseconds
Luminosity delay-line (Y-delay) 0,75µ sec Reference oscillator Crystal controlled
Picture tube control Colour difference method (output for brightness signal R – Y, B – Y and G – Y)
Synchronization Automatic line hold
Automatic reference oscillator synchronization
Automatic PAL synchronization
AGC Keyed cideo IF control range: 50 dB
Tuner control range: Approx 30 dB with delay
Chroma control range: 30 dB
Special feature Automatic colour-section cut-out when receiver is tuned to monochrome picture
Valves and semiconductors
Valves 14 + picture tube
Transistors 64 off.
Diodes 61 off
Dimensions and weight: W x H x D 76 x 87.5 x 57.5cm / weight 73 kg
Power supply: voltage 200 – 220 – 240 V AC
Frequency 50 Hz
Power consumption Approx 330 W
Connections: Inputs VHF aerial, 75 ohms
UHF aerial, 75 ohms
Outputs: extensions speaker, 3 – 5 ohms (switching feature provided in jack)
BeoVision 3000SJ FAQs
Please let us know
Posted on
BeoVision 3000KJ
BeoVision 3000KJ
BeoVision 3000KJ
BeoVision 3000KJ Product Details
Type Numbers
Designer
Please let us know
Manufactured
1968 - 1970
Colour Options
Teak or rosewood
BeoVision 3000KJ Product Specification
Tuning:
Sound
Transistors 64 off.
Diodes 61 off
Frequency 50 Hz
UHF aerial, 75 ohms
BeoVision 3000KJ FAQs
Please let us know
Posted on
BeoVision 3100
BeoVision 3100
BeoVision 3100
BeoVision 3100 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1972 - 1973
Colour Options
Please let us know​
BeoVision 3100 Product Specification
Please let us know
BeoVision 3100 FAQs
Please let us know
Posted on
BeoVision 3200
BeoVision 3200
BeoVision 3200
BeoVision 3200 Product Details
Type Numbers
3613 (1970 - Dec 1971)
3614 (SJ) (1970 - Dec 1971)
3618 (SJ, GB) (1970 - Dec 1971)
Designer
Please let us know
Manufactured
1970 - 1971
Colour Options
Please let us know​
BeoVision 3200 Product Specification
Picture tube: 26-in. A 65 – 120 X
Dimensions W x H x D: 74.7 x 85.7 x 57cm
Weight: 55 kg
Voltage: 200 – 220 – 240 V
Frequency: 50 Hz
Power consumption: 330 W
Tuning: VHF (bands I and III), channels 2 – 11, or UHF (channel 21 – 70)
Sound
Distortion: less than 1 % at 3 W
Speakers: one forward-facing speaker in undercarriage, full tonal range; one side-facing mid-range and bass speaker
Tone control range: bass +/- 12 dB at 100 Hz
Treble: +/- 12 dB at 10,000 Hz
Sound detector: ratio detector
Sound intermediate frequency: 6 MHz – 2 stages
Connections: Inputs VHF aerial, 75 ohms unbalanced
UHF aerial, 75 ohms unbalanced
Outputs: extension speaker, 3 – 5 ohms (switching feature provided in speaker socket
Connection of a tape recorder requires installation of a Type 3031 transformer
BeoVision 3200 FAQs
Please let us know
Posted on
BeoVision 3400
BeoVision 3400
BeoVision 3400
Beovision 3400 Type numbers: 3230, 3231, 3232, 3235 was a 66cm television fitted with sliding tambour doors to protect the screen.
BeoVision 3400 Product Details
Type Numbers
3230 (1971 - Dec 1973)
3231 (1971 - Dec 1973)
3235 (K) (1971 - Dec 1973)
3232 (SJ, GB) (1971 - Dec 1974)
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Rosewood, Teak, White
BeoVision 3400 Product Specification
Picture tube: 66cm – 140 x 110°
Tuning:
VHF (bands I and III), channels 2 – 12, and UHF (channels 21 – 70)
Sound:
Power output: 3 watts RMS
Frequency Response: 70 – 15,000 Hz +/- 1.5 dB
Distortion: lower than 1 % at 3 W
Tone Controls: Bass: +/- 10 dB at 150 Hz
Treble: +/- 10 dB at 10,000 Hz
Speakers: 1 x tweeter, forward-facing
1 x all-range unit, side-facing speaker
Frequency response: 80 – 13,000 Hz DIN 45570
Special feature: automatic colour section cut-out when monochrome programme is being received
Dimensions W x H x D: 67.9 x 49.5 x 46.5cm
Weight: 43 kg
Power supply: 200 – 220 V
Power consumption: 360 W
Outputs: extension speaker, 3 – 5 ohms (switching feature provided in socket)
Tape recorder output required installation of Type 3031 transformer
BeoVision 3400 FAQs
Please let us know
Posted on
BeoVision 3500
BeoVision 3500
BeoVision 3500
Beovision 3500 type number: 3907 was a 56cm colour television designed by David Lewis and Henning Moldenhawer. It could be placed on two types of stand – the trumpet stand (shown above) and the cross foot stand.
By 1975, colour television had become commonplace in homes throughout Western Europe. And a lot of those homes were furnished in white – the ‘in’ colour of the 1970s. Television, as a lot of home furnishings, followed this trend and Beovision 3500, with its trumpet base and cross-base on wheels, reflected what was happening in the world of interior design. The cabinet was made of moulded plastic and its appearance was markedly different from most other televisions of the era.
Beovision 3500 was Bang & Olufsen’s first fully transistorised television; this meant that very little warm up time was necessary for picture and sound. The choice of television channels had increased considerably over the previous years and the controls were adapted accordingly. “In everyday use, you select your TV programmes using the easy-touch push buttons at the top. Each of these can be set to one TV channel; this is done once only using the scaled potentiometer dials. These eight dials are only visible when the panel is opened; this is where you or your dealer can set the VHF and UHF channels that you are able to receive. Beovision 3500 has automatic frequency control, AFC, which locks the TV stations once they have been selected.” said the sales literature in 1975.
With Beovision 3500 it was clear that an icon had been created. The cabinet was made of moulded plastic and its appearance was markedly different from most other televisions of the time. However, the wooden cabinet was retained in the similarly-styled Beovision 3600 model. From 1975, Bang & Olufsen was also able to equip all its televisions with Automatic Cut-off Control.
An invention by the young engineer Erik Albert Jensen made waves internationally in the television sector. Cut-off Control ensures that the colour balance is maintained throughout the service life of the television. No fewer than 50 times each second the three electron beams are measured and corrected independently, thus avoiding any annoying deviations in colour.
BeoVision 3500 Product Details
Type Numbers
Please let us know​
Manufactured
1974 - 1977
Colour Options
Please let us know​
BeoVision 3500 Product Specification
Plastic cabinet
Automatic cut off, AFC
Aerial impedance 75 ohms coaxial, common VHF-UHF
Power output RMS 1000 Hz: 6.5 W
Distortion at specified output: < 1 %
Frequency response:
Amplifier +/- 1.5 dB: 60 – 20,000 Hz
Bass control +/- 5 dB: / 100 Hz
Treble control +/- 10 dB: / 10,000 Hz
Power supply: 220 – 240 V
Power consumption: 180 W
Dimension W x H x D: 61 x 41 x 42cm
Weight 29.5 kg
BeoVision 3500 FAQs
Please let us know
Posted on
BeoVision 3600
BeoVision 3600
BeoVision 3600
Beovision 3600 type number: 3908, 3909, 3938 was a 56cm colour television with a wooden surround.
BeoVision 3600 Product Details
Type Numbers
3908 (1974 - Feb 1977)
3909 (1974 - Feb 1977)
3938 (AUS) (1974 - Dec 1975)
Manufactured
1974 - 1977
Colour Options
Please let us know​
BeoVision 3600 Product Specification
Picture size: 56cm
Automatic cut off
Tuner: AFC
Aerial impedance: 75 ohms coaxial, common VHF-UHF
Frequency response:
Amplifier +/- 1.5 dB:60 – 20,000 Hz
Power consumption 180 W
Weight 29.5 kg
BeoVision 3600 FAQs
Please let us know
Posted on
BeoVision 3602
BeoVision 3602
BeoVision 3602
Like other Bang & Olufsen colour TVs, Beovision 3602 had the automatic cut-off regulating circuit which ensured natural colours throughout the set’s useful lifetime. The in-line picture tube allowed for easier and better convergence in order to avoid the usual discoloured edges – not least when viewing a black & white transmission.
Internally the Beovision 3602 was identical to the Beovision 3502 so one obtained the same outstanding picture quality and equally good sound reproduction from the large, forward-facing loudspeaker.
On the easy-touch panel one could select programmes and turn on the set in the same action. Regulators that are not used often are hidden in tow touch-release compartments – one for sound and one for video adjustments. Power consumption was exceedingly low – only 110 watts and the low heat generation made this set suitable for placing in a shelving unit.
BeoVision 3602 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1977 - 1979
Colour Options
Teak or rosewood
BeoVision 3602 Product Specification
Please let us know
BeoVision 3602 FAQs
Please let us know
