Posted on
BeoVox S75
Bang & Olufsen Beovox S75
The S75 was a four way speaker designed for stand mounting and was a suitable match for any of the receivers offered at the time. It could be regarded as the bigger brother of the fabled S45.2 and replaced the very similar S60 in the speaker range.
The cross over was changed along with a redesign of the cabinet. The result was a speaker with more bass emphasis than the S60 but still with a soaring top end. Criticism could be levelled that the bass was at times slightly overblown, but for rock music, it hit the spot.
The extra size also emphasised the cabinet makers’ skill with the rosewood model in particular often showing a wonderful selection of flame veneer.
Although these speakers lack the accuracy of the S45.2, many will find the extra bass an attraction and will choose these in front of their fabled brother.
Beovox Uni-Phase S75
Pressure chamber speaker with linear phase sound reproduction and wide frequency range: 36 – 20000 Hz. Was suitable for placement in a shelving system but also available with aluminium pedestal for those who prefer a free-standing model. Speaker units included a 25cm woofer, a special 12,5cm Phase Link unit, a 5cm mid-range dome and a 2,5 dome tweeter. Volume was 40 litres; weight 11kg
Posted on
BeoVox S40
Bang & Olufsen Beovox S40
Beovox S30 and S40 both used a two-unit configuration and pressure chamber design to reproduce music faithfully and clearly.
They handled up to 30 watts and 40 watts respectively and were ideal for mounting within a shelving system. Beovox S40 worked in conjunction with Beosystem 2300 if that is how you wished to use them. They featured a 20cm bass driver (woofer) and a 2,5cm dome treble unit (tweeter) offering wide frequency response and clean, clear sound reproduction.
Posted on
BeoCenter 3300
Bang & Olufsen BeoCenter 3300
Beocenter 3300 combined a powerful AM/FM stereo receiver with an automatic record player. Technically identical to the Beomaster 2200, the receiver section offered programmes on FM, long and medium wavebands and up to 2 x 40 watts RMS amplification with low distortion levels. It also had the same logical operation facilities.
The record player had a spring-suspended rotatory mechanism and an electronic servo drive system which ensured accurate turntable speed – even during variations in the mains current supplies. A special pendulum leaf spring suspension made the arm and platter immune to external shock and vibration which causes most other record players to mistrack and damage the record and sometimes even the stylus.
All functions of the record player were operated by touching a single button. The start/play/stop cycle is entirely automatic and moves, lifts or lowers the arm much more delicately than could the human hand. The MMC 20E cartridge carried an elliptical diamond stylus.
Beocenter 3300 had sockets for a tape deck, an extra record player, headphones and two sets of stereo speakers. The unit could be made up as part of the Beosystem 3300, when linked together with other compatible Bang & Olufsen products.
Posted on
BeoCenter 2600
Bang & Olufsen BeoCenter 2600
Beocenter 2600 consisted of a 2 x 25 watts RMS AM/FM receiver and a hi-fi cassette deck. The radio section covered Long, Medium and FM wavebands. A red/green LED indicator made recording easy and accurate, whether your sound source was the radio or a microphone (not supplied) connected to the hidden socket. A separate record player could be added if required.
For the cassette section, you could use both ferric and chrome tapes. The Dolby B Noise Reduction circuits ensured clean, noise-free recordings every time and the Super-Permalloy tape head was hard wearing with a long service life.
Beocenter 2600 could be made up as part of the Beosystem 2600, when linked together with other compatible Bang & Olufsen products.
Posted on
Beovox S80
Bang & Olufsen Beovox S80
There was a 7,5cm mid-range/phase-link unit combined with a 20,5cm woofer and 2,5cm dome tweeter to provide a wide frequency response and no audible phase distortion. Overload protection was automatic. The cabinet was of pressure chamber construction. Optional pedestals and wall-fixing kits were available.
Posted on
Beovox S80.2
Beovox S80-2 speakers gave neutral sound reproduction with the added realism afforded by depth definition and perspective.
Posted on
BeoLit 1000
Bang & Olufsen Beolit 1000
This portable radio has a specification superior to those of most mains table models and is elegantly styled, with all the controls placed on the top panel.
The Beolit 1000 offers outstandingly fine reception: on all its five bands, distant stations tune in without noise and interference even when located on adjacent frequencies. The FM section features a separate dial drive and additional push-button selection of up to three pre-tunable FM stations. The extended Long Wave band includes the navigation bands, and on the SWII band (the ‘Europe’ band) you can find all the popular European entertainment stations. The built-in Short Wave expander permits you to spread stations for supreme ease of tuning. There are sockets for connection of an external aerial, extension speaker and external power supply.
The Beolit 1000 brings you external tonal quality. Audio output is 2.5 watts on the internal dry cells. Via a suitable mains converter the Beolit 1000 will deliver no less than 7.5 watts of audio output, making it ideally suited to use as a home radio set. It has individual bass and treble controls and gramophone and tape-recorder jacks.
You can use the Beolit 1000 in a car, with the specially designed lockable car-mounting bracket which operates on 6 or 12 volts and negative and positive earthing, and incorporates filters to suppress ignition interference. The bracket automatically cuts out the built-in power supply of the Beolit 1000 and cuts in the car battery, the car aerial and an extension speaker. When powered from the car battery the set will deliver 7.5 watts of audio output.
Available in teak, Brazilian rosewood and black goatskin finish. Dimensions: 201 mm high, 359 mm wide and 70 mm deep
In 1972 the Museum of Modern Art in New York (MoMA) chose seven Bang & Olufsen products designed by Jacob Jensen to be included in their Design Collection as representing excellent examples of the Museum’s criteria for quality and historical importance; design, in fact, which had influenced the twentieth century. Beolit 1000 was one of those seven products.
In 1968 Beolit 1000 won the prestigious iF Design award.
Posted on
BeoCord 2000 (1983)
Bang & Olufsen BeoCord 2000 1983
Designed as a perfect match, both physically and technically, for the Beomaster 2000, this advanced slim-line cassette deck was nonetheless a serious hi-fi product in its own right, combining a high-performance specification with supreme ease of operation.
Despite its unassuming appearance, Beocord 2000 contained a full pay-load of advanced circuitry plus a few extra features rarely found in cassette decks within this price frame. The primary controls – those concerned with tape movement – were totally electronic and designed on the Sensitouch principle. There were no knobs to turn or keys to press; a light fingertip touch was sufficient to activate any function.
Ferric, chrome or metal tapes could be used, and Dolby B noise reduction was included to ensure clean, hiss-free recordings. A clearly calibrated scale and input slider, together with large Peak Programme Meter, made it quick and easy to set accurate recording levels. These controls were placed adjacent to the cassette tray beneath a hinged lid which sprang open at a touch.
Beocord 2000’s built-in microcomputer made operation fast and foolproof. It was possible to switch directly between any and all tape transport modes without harming the tape, the mechanism or the motor. Microcomputer intelligence also opened the way for additional control functions that contributed in a very practical way to daily enjoyment of taped music.
A NEXT control allowed for easy track location (tape scan): one touch fast winds the tape to the next signal gap and plays the following track – automatically. So if you wanted to hear, for example, track number 5, just touch-and-wait four times and the place would be found for you. Similarly, you could repeat play-back of a favourite track up to five times with just a single touch. It’s such a convenient way of listening to exactly what you want, when you want.
Beocord 2000 had a socket for data-link connection to Beomaster 2000 so that direct switching was possible between Beomaster, Beogram and Beocord in the Beosystem 2000. The deck could also be data-linked to Beomaster 5000 or Beomaster 6000, when all tape functions could be operated via the receiver’s remote control system. Beocord 2000 could be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products. It was also part of Beosystem 3000 if that is how you wished to use it.
Posted on
BeoCord 1600 (1981)
Bang & Olufsen BeoCord 1600 1981
Beocord 1600 matched the Beomaster 1600 and Beogram 1600 both physically and technically. It combined high performance with easy, straightforward operation.
Ferric, chrome or metal tapes could be used. The Sendust tape head, Dolby B Noise Reduction circuits and Peak Programme Meter all contributed to high quality recording and playback. You could switch between all modes of play without fear of tangling the tape or damaging the mechanism.
