The BeoVision 8000 was the non remote version of the Beovision 8800 but, apart from this feature, shared all the other qualities with this set.
In common with the Beovision 8800 it had a 14W amplifier with a two way speaker system – a feature that made it stand out from other sets at the time. Not a big seller as those willing to buy a 26″ set were likely to opt for the Beovision 8800 with the remote control.
BeoVision 6 – 22 is an LCD 16:9 TV set introduced on 10 November 2003. It is fitted with a 51cm (diagonal) LCD screen which is coated similar to the Avant. Active speakers are positioned at the base of the monitor, similar to the MX range of television sets. The rear of the unit is curved, similar to that of BeoSound 1.
The unit is available in one colour only – Black – and is primarily designed for link-rooms: i.e. as an extra set for the kitchen or bedroom.
BeoVision 6 – 22 may be fitted with a motorised base which turns the set and also regulates the inclination. Standing possibilities include a low floor stand similar to BeoVision 5, wall bracket or a high floor stand high (as with BeoVision 1).
This new LCD TV can be used as a PC monitor, too. When watching normal TV programmes, ‘TV’ on the Beo4 is selected; however, by combining the BeoVision 6 to your PC as a monitor via the rear-mounted DVI socket (see further details at BeoTech) and selecting ‘PC’ on the remote control, BeoVision 6 may be used in conjunction with your home computer.
In 2004 BeoVision 6-26 was introduced to complement this 51cm model.
Press release Struer – November 2003
BeoVision 6 does away with the limits to LCD technology
Bang & Olufsen’s first LCD television is compact, simple and can be placed anywhere. And it also gives a sharp picture, no matter where you are in the room.
A compact television that can be placed… well, where there isn’t any space. A television that can hang on the wall or stand on a chest of drawers, and that can be tilted and turned in all directions – that is the idea behind BeoVision 6 from Bang & Olufsen.
BeoVision 6 is the first television based on LCD technology offered by Bang & Olufsen.
“Nevertheless, LCD technology has been extremely interesting to Bang & Olufsen ever since it came on the market, because it fits in perfectly with our philosophy of compact, simple and stylish televisions – televisions that don’t visually dominate the room you’ve put them in. But not until now has the technology been mature enough for both the image quality and durability to measure up to Bang & Olufsen’s standards,” says President and CEO Torben Ballegaard Sørensen.
A range of technologies patented by Bang & Olufsen, such as Adaptive Black, Motion Adapted Progressive Scan and Digital Adaptive Luminance Peaking, put this LCD monitor in shape to deliver the image quality the company is known for. See the appendix “VisionClear”.
Fits in anywhere
One of the biggest problems of LCD technology has been the restricted viewing angle – in other words, the image is not visible if you look at the screen from an oblique angle. Although LCD technology has made considerable progress in this area, too, Bang & Olufsen’s engineers were still not satisfied.
“Our ambition was to create a television that you could hang somewhere like the kitchen wall. And it would be no good if you could only enjoy it if you were seated at the dining table, and couldn’t see the picture if you stood at the worktop,” explains Sørensen.
The solution was to equip the BeoVision 6 with a range of stands and wall fittings that make it easy both to turn the television from side to side and to tilt it up and down. The tilt function was a challenge to Bang & Olufsen’s developers. The first prototypes were either too clumsy and complicated or they were too difficult to operate. When the answer occurred one day to one of Bang & Olufsen’s engineers, it was so simple that it was difficult to understand why nobody had thought of it before.
A design that allows the television to revolve around its own centre of gravity is both simple and discreet – and at the same time it makes it possible to tilt a television weighing 18 kilos at the push of a finger. The rear of the BeoVision 6 is curved. Visually, this makes it appear even flatter than it is in reality, and at the same time its curved shape makes it possible to turn the television through greater angles, both on and off the wall.
The sound is half the experience
It has always been Bang & Olufsen’s philosophy that the sound is half the experience of a television. For this reason, equal effort has been put into sound and picture in the BeoVision 6. The slightly slanting sound panel under the screen contains two 7,5cm bass reflector speakers and an ingeniously designed bass port. This integrated speaker system gives BeoVision 6 what it takes to deliver a stereo sound that surprises most people!
VisionClear
Bang & Olufsen brings together objective parameters of image quality with subjective elements of viewing comfort into a combined whole, in which the perceived image is unsurpassed. At Bang & Olufsen, the designation VisionClear means that image quality and viewing comfort are inseparable. The exceptionally high image quality is achieved by elements such as Motion Adaptive Progressive Scan, Adaptive Luminance Peaking, Colour Transient Improvement (CTI) and Adaptive Black.
The further development of Bang & Olufsen’s own Adaptive Luminance Peaking system increases the image quality further by reinforcing powerful fields of light in relation to the change in light signal present in the image. This function strengthens large light shifts proportionally less than small ones, resulting in amore uniform visual experience. The Colour Transient Improvement used in BeoVision 6 also ensures a high degree of dimensional precision.
How black is black?
The correct level of black is ensured through the use of advanced Adaptive Black hardware. The right colour setting is obtained by allowing BeoVision 6 to adjust the light automatically while the television is in use. The electronics “read” the image on the screen and automatically increase the colours if the image is very pale, while the technology prevents black details from gradually turning grey during image shift.
Screen, user, surroundings
By focusing on a number of elements, viewing comfort – which involves an interplay between screen, user and surroundings – is accorded a high priority. Automatic image control sensors meter the background light in the room where the television is located, and ensure the best possible image at all light levels. A special anti-reflection-treated contrast screen also reduces the effect of external light incidence by over 80%. The result is that the contrast is markedly improved, which in turn provides a richer screen colour experience. Elements such as Hollywood-like electronic curtains, that open and close automatically, and Active Image Format Optimisation (in which the current screen image is automatically scanned and the best image format then presented on the screen) are included to add extra dimensions to the viewing experience. BeoVision 6 also uses digital noise reduction to decrease the noise in the image.
Mounting Options & Stands
The tilt table mount was available for counter top mounting, designed to allow the bass port on the underside of the TV to ‘breath’. Motorised floor and table stands were complimented by a wall mount bracket which gave manual tilt and turn
BeoVision 6 – 26 is a flat 26″ widescreen television based on LCD technology. It is the second member of the BeoVision 6 family and holds all the virtues and conceptual elements of the current 22” version. This new model is provided with the newer – Mark III version of the Beo4 remote control.
LCD technology makes it possible to offer a television that combines an extremely slim depth with an outstanding picture quality. Complemented by a powerful integrated loudspeaker system the 26″ widescreen makes BeoVision 6 – 26 very suitable as a main room television which can function as a Beolink master and even as master unit in a home-cinema setup.
The compact and flat design makes BeoVision 6 – 26 a very flexible television which will fit most homes. With a broad and unique stand selection, the user is offered great freedom in placing the TV to blend in with most environments.
BeoVision 6 – 26 Press Release September 2004
Bang & Olufsen has now released the BeoVision 6 – 26 television, the newest addition to the BeoVision 6 family. With a 26” widescreen, a powerful loudspeaker system, and the option of a digital surround sound module, the BeoVision 6 – 26 can fill the role as a main room television, and yet at only 18 cm deep, still offers the flexibility and versatility of the smaller 22” BeoVision 6 – 22.
“The BeoVision 6 idea is for an elegant and simple plug-and-play television concept that integrates picture and sound in a compact cabinet, designed to integrate easily into your home,” says Torben Ballegård Sørensen, CEO, Bang & Olufsen and adds: “The BeoVision 6 – 26 has a bigger screen and optional surround sound, and those who wish to experience the BeoVision 6 idea as their home cinema can now do so.”
The flexible TV
In addition to connections for BeoLab loudspeakers, external entertainment sources and earphones, the BeoVision 6 – 26 television offers digital interface with a PC. It can also enter into any home system with all Beolink-enabled Bang & Olufsen products. Beolink is Bang & Olufsen’s unique home integration system, based on the principle of ‘move and share the experience – not the equipment’, with everything controlled by the Beo4 remote control.
The 26” widescreen LCD monitor and the two-way active stereo loudspeakers positioned full-length below the screen are placed against a frame of brushed aluminium. The curved rear of the cabinet is coated in a resilient black soft-touch lacquer, making the BeoVision 6 – 26 television attractive to look at from all angles.
A complete viewing and listening experience
Bang & Olufsen’s VisionClear picture competences ensure the best possible picture from the LCD monitor in all situations. VisionClear covers a range of technologies that the viewer experiences in the form of greater viewing comfort, but hardly notices.
BeoVision 6 – 26 represents the complete application of VisionClear. When BeoVision 6 – 26 is switched on, the TV automatically adjusts contrast levels, brilliance and colour to match the current light conditions – and will carry on doing so until the television is switched off again. The anti-reflection coating on the contrast screen reduces significantly the effect of incoming light on the screen. The dark-tinted contrast screen in front of the LCD monitor makes the screen darker when not showing an image.
At Bang & Olufsen, the listening experience is considered as important as the viewing experience. The compact, two-way active stereo loudspeakers are placed attractively under the picture and indicate a strong sound performance. The BeoVision 6 – 26 television offers the viewer a superior home cinema listening experience when used with any BeoLab loudspeakers, with the television’s loudspeakers functioning as a powerful mono centre loudspeaker.
Place it anywhere
The many placement options complement the compact design perfectly. The motorised turn function on the floor and table stand is controlled from the Beo4 remote control, turning the television towards the viewer, and reducing the viewing angle. The manual tilt mechanism also contributes to the best possible viewing conditions and means the BeoVision 6 – 26 can be placed at the height that suits best on the floor, table, or wall.
“A genuine Bang & Olufsen product is more than the sum of the parts that went into its manufacture. The comprehensive stand programme, to name but one example, provides more than placement flexibility for BeoVision 6 – 26; it also changes the identity of the television, depending on where and how the television is used,” concludes Torben Ballegård Sørensen.
Founded in 1925 in Struer, Denmark, Bang & Olufsen a/s is world renowned for its distinctive range of quality consumer electronic products that represent our vision: Courage to constantly question the ordinary in search of surprising, long-lasting experiences.
The following stands are all available for use with BeoVision 6 – 26:
Motorised floor stand, Motorised table stand, Table stand and Wall bracket:
Item & Part Number:
BeoVision 6 – 26 – 1816125
Table Stand – 1409066
Motorised Floor Stand – 1409111
Motorised Table Stand – 1409211
Wall Bracket – 1409311
Dolby Digital Surround Sound – 1400501
The tilt table mount was available for counter top mounting, designed to allow the bass port on the underside of the TV to ‘breath’. Motorised floor and table stands were complimented by a wall mount bracket which gave manual tilt and turn.
In 1970, a young designer, David Lewis, created one of the world’s first transportable TVs – Beovision 600 – long before small portable TVs became widespread. Beovision 600 was a black and white TV with a solid handle and weighed just over 13kg. Compared to the pocket-sized TVs of today, it could hardly be called portable. Nevertheless, it was transportable with a 44cm screen and excellent sound quality. The TV set won the iF Design Award in 1970.
Full transistorisation meant that sound and picture appeared at the press of a button, a new and unusual feature at the time. The cabinet was made of plastic and the handle was concealed when not in use. Six pre-set stations could be operated by one press of a button and all settings were concealed in small compartments to prevent inquisitive little fingers fiddling with them. It also featured a retractable flex.
All in all, a pioneering TV design which, in later years, was copied by many other TV manufacturers. Beovision 601 replaced its predecessor in 1973, fitted with several new features which were missed out on Beovision 600.
Beovision 6000 was a luxurious colour TV receiver with a 66cm screen and cordless, ultrasonic remote control (designed by David Lewis).
The slim remote control module allowed you to select up to eight TV programmes, adjust volume, brightness and colour strength from the correct viewing and listening position. You could also switch the set off without moving away from your armchair. The ‘recall’ facility provided a digital on-screen display indicating the channel currently being viewed. The reset function automatically returned volume, colour and brightness to pre-set levels.
Beovision 6000 was the first TV with dedicated remote control. Successor to the Beovision 3000 (1967) which was Bang & Olufsen’s first colour TV. The design of the TV set itself was by Henning Moldenhawer.
Picture quality was outstanding, with sharp, bright, precise image definition and natural colours. The automatic cut-off circuit monitored the balance of colours fifty times a second, guaranteeing long-term colour truth.
Sound reproduction was of hi-fi quality because Beovision 6000 was fitted with a 6,5 watts RMS amplifier which had a wide frequency range and less than 0,8% harmonic distortion. The loudspeaker was of a pressure-chamber construction as used in many hi-fi audio systems. There were separate controls for bass and treble and sockets for connecting headphones and additional speakers. The receiver could also be equipped with a module for Teletext reception and video cassette programmes could be reproduced without additional technical adjustment.
Beovision 6000’s genuine wood-finished cabinet had a unique tambour screen door for protecting the screen when the set was not in use. The self-styled wooden undercarriage with smooth-running castors was both practical and elegant.
Beovision 6000 was replaced by Beovision 6002 in 1977, again with the same stylish cabinet and sliding, tambour door.
Henning Moldenhawer (Beomaster 900 designer) once dubbed the concept of remote control Terminals as “feel commanders”. This meant that the product could be operated by the thumb on one hand – almost as if the user was feeling his way through a new type of Braille, allowing the eye to concentrate on the TV picture itself.
Beovision 6002 was a luxurious colour TV receiver with a 66cm (viewable) screen and cordless, ultrasonic remote control. The slim remote control module allowed you to select up to eight TV programmes, adjust volume, brightness and colour strength from the correct viewing and listening position. You could also switch the set off without moving away from your armchair. The ‘recall’ facility provided a digital on-screen display indicating the channel currently being viewed. The reset function automatically returned volume, colour and brightness to pre-set levels.
Sound reproduction was of hi-fi quality because Beovision 6002 was fitted with a 6,5 watts RMS amplifier which had a wide frequency range and less than 0,8% harmonic distortion. The loudspeaker was of a pressure-chamber construction as used in many hi-fi audio systems. There were separate controls for bass and treble and sockets for connecting headphones and additional speakers. The receiver could also be equipped with a module for Teletext reception and video cassette programmes could be reproduced without additional technical adjustment.
Beovision 6002’s genuine wood-finished cabinet had a unique tambour screen door for protecting the screen when the set was not in use. The self-styled wooden undercarriage with smooth-running castors was both practical and elegant.
The Beovision 601 was visually very similar to the Beovision 600, but it used a mildly redesigned chassis. The changes centred mostly around the receiver section, which made greater use of integrated circuits that the previous model had done.
The Beovision 601 was the last true Bang & Olufsen portable television, in as much as it was designed and produced by them in Denmark. It would be the late 1980’s before another portable model would appear, which was the disappointing MX 1500, a Philips set made in a Philips factory in Italy.
BeoVision 5 was Bang & Olufsen’s first home cinema plasma screen.
With its big screen, advanced sound system, original positioning options and sophisticated remote control, the BeoVision 5 sets the standard for plasma solutions, especially when it comes to integration in the home. Until the discovery of plasma technology, the idea of having a TV screen hanging on the wall was restricted to the realm of science fiction films. Now the dream has become a reality, and Bang & Olufsen has brought it one step closer by offering a plasma solution that is more than just a “picture on the wall”.
BeoVision 5 is the natural choice for people wanting to combine large-scale audio-visual experiences with a high degree of flexibility in the positioning of the TV screen. All of Bang & Olufsen’s expertise in picture handling and screen technology has been deployed in order to improve the already sharp picture from the big 42-inch screen of BeoVision 4. Brushed aluminium encases both the screen and a special integrated active loudspeaker reproducing high-quality stereo sound.
As a result, BeoVision 5 does not require any additional equipment to fulfil the standards that Bang & Olufsen is renowned for. BeoVision 5 can also function as a centre for distributing sounds and pictures throughout the house via Bang & Olufsen’s unique distribution system: ‘Beolink®’.
BeoVision 5 works with the entire range of Beolink® products and can also connect with the Bang & Olufsen DVD 1 and the Beocord V8000 video recorder. All products can be operated with the Beo4 remote control.
The positioning is quite something, too. Imagine brushed aluminium, gathered at 45-degree angles at the corners, surrounding both the plasma screen and the sound system. Inspired by classical art, it can be hung on the wall in its entirety as a single object -just like a picture in a gallery. However, a TV that hangs on the wall is not intended to represent the ultimate in mobility for some users who prefer greater freedom in their options for their personal home décor. Should it be positioned in the middle of the room on a base? Should the base be motorised so that you can rotate the television from your armchair using the remote control? What about a drawer system in the same design to conceal the DVD player, satellite receiver or video recorder? Or what about leaning the television against the wall, if you don’t want to hang it up? Everything has been thought of!
BeoVision 5 is a unique 108cm (42 “) plasma home cinema concept from Bang & Olufsen. With its obvious associations to the art-of-painting, this plasma master is truly a work of art in itself. This is reflected in its outstanding design affording the user many different placement and colour options. The design of BeoVision 5 was orchestrated by David Lewis, Bang & Olufsen’s chief designer.
The combination of a a high quality plasma display and Bang & Olufsen’s competences in video signal processing means that the picture on BeoVision 5 is the best in the industry. Its advanced sound system, using B&O’s active loudspeaker technology, provides a sonic experience that perfectly matches the outstanding quality of the picture. The built- in loudspeakers, placed below the screen, function as both a centre channel when used in a surround sound set up or as a superb stereo sound system when the BeoVision 5 is used as a stand alone TV.
Operationally, BeoVision 5 has much in common with the BeoVision Avant which means that it can be a system master, together with an audio system to distribute picture and sound around the house.
Picture and Sound Quality merge exquisitely in the new BeoVision 5 from Bang & Olufsen. Containing a striking 108cm 16:9 plasma screen and a pair of powerful built-in active loudspeakers, BeoVision 5 is framed elegantly in your choice of five shades of brushed anodised aluminium. Years of Bang & Olufsen expertise unite these fields to prove that the beauty also has brains.
The screen
With its large screen, advanced sound system, original placement possibilities and multifaceted Bang & Olufsen virtues within operation, BeoVision 5 sets new standards for plasma solutions, not least regarding integration into the home environment
Until the advent of plasma technologies, the idea of hanging a television set on the wall has been confined to the realm of science fiction films. Now that the dream has become reality, Bang & Olufsen takes this possibility a step further by offering a plasma solution that encompasses much more than a simple ‘picture on the wall’. BeoVision 5 is therefore a natural choice for people wishing to combine great viewing and listening sessions with flexibility in placement.
The frame
All Bang & Olufsen picture competencies are utilised to enhance the already razor sharp image of the large plasma screen. The 16:9 picture tops a pair of integrated active loudspeakers offering an enveloping stereo sound built with all the acoustic competencies for which Bang & Olufsen is known. As a result, BeoVision 5 does not require additional equipment to measure up sound- and picture-wise to demanding Bang & Olufsen standards. Furthermore, BeoVision 5 can serve as a Beolink® master, distributing sound and picture throughout the home in Bang & Olufsen’s unique distribution system. Full compatibility with all Beolink®-enabled Bang & Olufsen products is included, as well as seamless connections with Bang & Olufsen’s DVD 1 and Beocord V8000 VCR. Operation of all Bang & Olufsen items is carried out using the Beo4 remote control.
The placement
Offering a selection of brackets and stands, Bang & Olufsen offers a multitude of placement possibilities for BeoVision 5.
The sound
Featuring a pair of active loudspeakers located directly below the plasma screen, BeoVision 5 can provide up to 96 dB of stereo sound on its own. A built-in Dolby Digital® surround sound decoder offers a wealth of sonic experiences – and even includes automatic detection of this 5.1 channel digital sound format.
Connect any active loudspeakers from Bang & Olufsen’s BeoLab range, and be moved by the deep bass and tingling highs found in today’s digital entertainment offerings. Let your home cinema experience be led by the BeoLab 2 subwoofer, a double balanced passive radiator system where an 850 W ICEpower® amplifier (Long Term Maximum Output Power), supplies the fuel for the single active 22cm woofer and two 22cm passive radiators..
The many facets of BeoVision 5 plasma TV
VisionClear elements shine through
Once again Bang & Olufsen has succeeded in combining the objective parameters of picture quality and the subjective elements of viewing comfort to provide an extensive and enveloping viewing experience.
An exceptionally high level of Picture Quality is achieved through the employment of elements including motion compensated progressive scan, Digital Adaptive Luminance Peaking, Digital Colour Transient Improvement (CTI) and adaptive black. Presenting all horizontal lines at once, the BeoVision 5 digital interpolation system eliminates disturbing motion artefacts caused by viewing an interlaced scan on a large screen. By calculating object movement in pixels per field, new pictures are interpolated according to object motion.
Further development of Bang & Olufsen’s own Digital Adaptive Luminance Peaking circuitry adds additionally to the Picture Quality by amplifying the peaking according to the level of luminance shifts present. This purely digital function peaks large luminance shifts proportionally less than small shifts, providing a uniform visual experience. Furthermore, the wideband Digital CTI employed in BeoVision 5 assures a high degree of dimensional precision thanks to a gentler amplification than compared to standard CTI circuits.
How black is black?
Maintaining a proper black level is ensured by the employment of advanced adaptive black circuitry. Correct colour saturation is assured as the brilliance level is automatically adjusted during viewing by BeoVision 5. Reading the content of the current on-screen image, BeoVision 5 automatically increases colour saturation on very light images on the one hand, whilst keeping black details from drifting into grey upon a content shift.
The screen, the user, the surroundings
The field of Viewing Comfort, which involves the interactions between the screen, the user and the surroundings receives great attention through a number of elements. Automatic Picture Control sensors found in the striking “magic eye” found on the top right-hand corner of the BeoVision 5 monitors the amount of ambient light in the room and ensures the best possible picture quality under all lighting situations.
A special dark coloured anti-reflection coated contrast screen also reduces amount of incoming light by more than 80%. The resulting increase in contrast provides a richer on-screen colour experience. Enticing elements such as Hollywood-like electronic curtains, which automatically open and close and Active Picture Format Optimisation, where the transmission signal is read and the optimal picture format is presented automatically additionally highlight the user experience.
Adaptive Bass Linearisation
Protection against low-frequency damage at a high volume level is provided for all Bang & Olufsen BeoLab speakers by Bang & Olufsen’s patented Adaptive Bass Linearisation (ABL) circuitry. ABL monitors the displacement of the loudspeaker units and reduces the output level if any risk of mechanical damage arises. The ABL circuit has very fast attack- and release times for optimum protection and sound performance.
Furthermore, both the BeoLab 2 and the BeoLab 1 loudspeaker feature patented thermal protection circuitry which guards against overheating and burn-out by monitoring the physical temperature of the woofer. An NTC resistor mounted on the rear of the magnet system in combination with a sophisticated simulation of the voice coil temperature triggers an automatic reduction of output if the temperature should exceed the critical level.
Standard features: MasterLink, Picture-in-Picture, Set top box controller, RF Modulator, Dolby Digital Surround Sound (which also supports Dolby Pro Logic Surround Sound) and DTS (Digital Theatre System).
Dimensions: The active speakers within BeoVision 5 are the same as the latest (2002) model of the BeoVision Avant. The unit is 17cm wide at the bottom and around 10cm at the top of its 1,10m frame. It leans 9 degrees back and rests (when placed on the floor) on three small metal feet.
Cabinet
BeoVision 5 Cabinet (part number 1417759) has two drawers side-by-side for BeoVision 5 to stand on.
BeoVision 5 can be shaped and coloured in such a way as to complement its surroundings. The aluminium frame and front loudspeaker cover are delivered in the same colour combinations as BeoLab 1 : Metallic black, silver, red, green and blue. It can be positioned in one of several ways. On a floor stand at a 9 degree angle, on a wall bracket at two different heights and either parallel to the wall or at a 9 degree angle to the wall, on the floor on a cabinet which can house two units such as DVD 1, Beocord V8000 or a Set-Top Box, and finally on a motorised floor stand.
Positioning
Ideally BeoVision 5 should be set up with BeoLab 1’s in aluminium in the front with BeoLab 2 and BeoLab 6000’s in the rear. DVD 1 and Beocord V8000 should both be housed in the purpose built silver cabinet.
The screen
Until the advent of plasma technologies, the idea of hanging a television set on the wall has been confined to the realm of science fiction films. Now that the dream has become reality, Bang & Olufsen takes this possibility a step further by offering a plasma solution that encompasses much more than a simple ‘picture on the wall’. BeoVision 5 is therefore a natural choice for people.
Dimensions:
The active speakers within BeoVision 5 are the same as the latest (2002) model of the BeoVision Avant. The unit is 17cm wide at the bottom and around 10cm at the top of its 1,10m frame. It leans 9 degrees back and rests (when placed on the floor) on three small feet.
Both BeoVision 5 and BeoLab loudspeakers are available in a variety of colours (to match the colours of BeoLab 1) including red, black, aluminium, blue and green, which together offer a solution to suit both you and your interior décor.
At the top of BeoVision 5 is a little plastic translucent dome which electronically surveys its surroundings. Not in the way of Big Brother – but in keeping a watchful eye on the light conditions in the room in which it is placed. It looks out for instructions from the Beo4 remote control and signals by either a red or green light dot if the television is switched either on or off. It also adjusts the picture according to the lighting conditions of the room itself: brightening the picture in a very bright room, or lowering its intensity in a darkened room. However, BeoVision 5 is not the first television to introduce this little dome. Beosystem AV9000, which was the first integrated AV system from Bang & Olufsen, accommodated it as well, placed in a similar position outside of the frame.
Beosystem AV9000 created a lot of attention in its time and was a breakthrough in home entertainment. But the dome created ill-feeling in that it challenged the expectations as to the general design of Bang & Olufsen products. It stood out in an unusual way. At the time of AV9000’s introduction there was a resistance movement challenging the company’s stance towards so much innovative, aesthetical design.
Ten years later it is a case of déjà vu. However, its reintroduction was proposed by the development team as an answer to a simple engineering problem.
BeoVision 5 Press Release
BeoVision 5 – Bang & Olufsen’s first plasma home-cinema solution
With a 107cm screen, advanced sound system and flexible placement possibilities, BeoVision 5 sets new standards for plasma technology and its integration into the home.
• A visual masterpiece
A sleek brushed aluminium frame, in a choice of six eye catching colours frames both screen and sound system, offering an integrated sound and picture plasma solution. Inspired by the world of classical art, both sound and image may be hung as one single item on the wall, like a painting in a gallery. However, BeoVision 5 has been designed with flexibility in mind and with the use of customised brackets and stands can be placed in a number of ways to suit individual interior set-ups.
Whether it be in the middle of the room on a motorised floor stand, so it turns towards your sofa via the remote control, leaning against the wall with an integrated drawer system to hide the DVD player and satellite receiver, or simply hanging flat against the wall, BeoVision 5 provides an outstanding home cinema experience.
• Superior Sound Quality
BeoVision 5’s 16:9, 107cm plasma screen sits on top of a pair of integrated active loudspeakers offering an enveloping stereo sound built with all the acoustic quality Bang & Olufsen is known for. BeoVision 5 is a Beolink® master product so can be connected seamlessly with all compatible Bang & Olufsen systems to distribute sound and picture throughout the home via the Beo4 remote control.
For the complete home cinema set-up, a powerful multi-channel digital surround sound experience can be created by linking BeoVision 5 to five active speakers from Bang & Olufsen’s extensive range. Both BeoVision 5 and BeoLab loudspeakers are available in a variety of colours, including red, black, aluminium, blue and green, which together offer a solution to suit both you and your interior décor.
BeoVision 4 offers greater flexibility and modular convenience to Bang & Olufsen customers than has previously been possible. BeoVision 4 is available in different sizes and consists of the screen, BeoSystem 2 and a cabinet. BeoSystem 2 is the master unit having the same functionality as BeoVision 5.
The recommended centre channel loudspeakers are BeoLab 4000. This plasma TV set has been previously only available in the North American market including Canada, Mexico and the US. When combined with speakers and stands, BeoVision 4 becomes an integral part of BeoSystem 1. However, from Spring 2004 the system – known as Beosystem 2 – arrived in Europe.
This European system incorporates different-sized screens and may be mounted on a wall. Available in 50″ and 65″ screen sizes (37″ and 42″ screen sizes available only to March 2006) The screen surround is of brushed aluminium and is based upon much the same design as BeoVision 5. VisionClear and an anti-reflection coating is included. Controlled by Beo4, the system comprises:
Cabinet 2168 is similar to cabinet type 2164 and has a shiny, aluminium-coloured front. Within it can be placed a satellite decoder, DVD 1 and/or Beocord V8000, if these are your required options.
Part:
Part Number:
BeoVision 4-37 silver – 1816608
BeoVision 4-37 black – 1816609
BeoVision 4-37 dark grey – 1816610
BeoVision 4 42 silver including wall bracket – 1816049
BeoVision 4 42 dark grey including wall bracket – 1816578
BeoVision 4 42 black including wall bracket – 1816577
BeoVision 4 50 black including wall bracket – 1816591
BeoVision 4 50 dark grey including wall bracket – 1816592
BeoVision 4 50 silver including wall bracket – 1816415
BeoSystem 2 – 1816403
Cabinet 2168 – 1216813
Cabinet BV4 – 1216813
BeoVision 4 65 silver – 1816632
BeoVision 4 65 black – 1816633
BeoVision 4 65 dark grey – 1816634
BeoSystem 2 (BV4 65) – 1816403
BeoVision 4 65 Wall Brackets – 1405866
Remote Control for BV4 stand alone – 8053460
BeoVision 4 Wall Bracket and Table Stands
A new wall bracket and table stand for the BeoVision 4 range will be available from December 2004. The new wall bracket is finished in black lacquered steel and with its reduced dimensions is suitable for use with the 37”, 42” and 50” screen options.
The table stands will be available in two options: one for BeoVision 4-37 and the other for either BeoVision 4-42 or BeoVision 4-50. The Table Stands will be finished in black, painted aluminium.
The only accessory for BV4-65 is the wall bracket. Introduced on BV4-65 will be a slightly darker Contrast Screen resulting in an improved perceived picture quality due to the lower black level.
Wall Bracket & Table Stand Part Numbers:
BV4 Wall Bracket 1407866
Table Stand BV4-37 1408566
Table Stand BV4-42/50 1407966
BeoVision 4 – 42 Newsletter April 2004
In view of the general expansion of flat screens in the market, Bang & Olufsen is now strengthening its flat screen portfolio by launching BeoVision 4 – 42. BeoVision 4 – 42 is a modular flat screen home-cinema system master consisting of:
A 107cm plasma monitor for wall mounting (wall bracket included)
BeoSystem 2 – a master unit offering the customer a genuine Bang & Olufsen system master
an elegantly designed cabinet for placement of BeoSystem 2 and a separate box solution, e.g. DVD 1.
In line with our vision of constantly questioning the ordinary in search of surprising and long-lasting experiences, it is crucial for Bang & Olufsen to stand out. The mere offering of a plasma solution with a separate master unit is far from unique in the market today. Still, we put great value in differentiating Bang & Olufsen products from our competitors.
BeoVision 4 – 42 is differentiated by:
A true Bang & Olufsen visual expression and craftsmanship to the last detail with the aluminium frame on the monitor, the design of the cabinet and the possible combination with BeoLab loudspeakers, BeoVision 4 – 42 has a true Bang & Olufsen visual expression. This is characterised by an elegant design, an exquisite choice of materials and craftsmanship to the last detail.
The aluminium frame is mounted on a handmade mainframe made of steel. There are no visible screws or welding notches – even the screws are handmade in order to ensure a smooth surface and not disturb the visual expression. By means of our special surface treatment competences, we have achieved a beautiful yet robust surface of the aluminium on the frame and the cabinet.
BeoVision 4 – 42: a system master that offers freedom of application.
The BeoVision 4 – 42 solution offers not only sublime experiences in a home-cinema setup. It also is fully compatible with the Beolink® system and can work as a system master that distributes sound and/or picture to up to 16 rooms. BeoVision 4 – 42 is a modular system, it has a built-in Dolby® Digital/DTS® module, and it can be integrated with the entire BeoLab loudspeaker range, as well as with Bang & Olufsen audio and video products. There is only one cable between the monitor and the master unit which increases the placement flexibility. All this maximises the freedom of application – only your imagination sets the limits for a true Bang & Olufsen experience.
Easy operation – One remote
Despite the possibility of integrating BeoVision 4 – 42 with many products and features, the operation is well-known and simple – based on one remote: Beo4. This is ensured via the IR-eye which is connected to BeoSystem 2. The built-in Set-top Box Controller is an example of the simplified operation principle of Bang & Olufsen; digital television can be received from a separate satellite box, but still operated with Beo4.
VisionClear – improved picture technologies
VisionClear is a concept developed by Bang & Olufsen that focuses on picture improvement technologies. Among the technologies is the peaking technology, which sharpens the picture by making a simulated contour around objects so that every detail stands out. There is a tendency in the market to overdo the peaking – so that the picture becomes unnaturally sharp. Bang & Olufsen focuses on creating a natural sharpness in the picture – therefore the picture is only peaked to a certain limit. The natural picture is moreover helped by noise reduction. As the peaking technology also makes noise more visible, a noise reduction circuit is incorporated in BeoVision 4 – 42 to compensate for the increased noise. This way BeoVision 4 – 42 offers sharp yet noiseless pictures.
Viewing Comfort – improved viewing experience
The Viewing Comfort concept focuses on the interface between the screen and the user, and between the screen and the room. It has been developed to improve the subjective viewing experience of the user. Viewing Comfort elements in BeoVision 4 – 42 include the anti-reflection coated contrast screen, which reduces reflections of incoming light and improves the black level. The black level of BeoVision 4 – 42 is better than what is generally seen in the market for plasma – meaning that what looks black is more black, rather than grey.
The result is deeper and richer colours. Other Viewing Comfort elements in BeoVision 4 – 42 are electronic curtains and automatic picture format optimisation. (Due to the separation of monitor and master in BeoVision 4 – 42, the Automatic Picture Control feature known from BeoVision 5 and other BeoVision products is not available in BeoVision 4 – 42).
Beovision 400 was a transportable television designed in 1965 by the young David Lewis and Henning Moldenhawer while working under the direction of Jacob Jensen.
