Posted on
BeoGram 1800 (1984)
Bang & Olufsen BeoGram 1800
This radial-tracking deck combined ease of operation with superb performance specifications. It featured a new, advanced type of tone arm carrying the remarkable MMC5 pick-up with its unframed, elliptical diamond stylus. The platter was of a lightweight design (400 grams) to reduce torque at starting.
Its carefully milled profile, with large metal surfaces set between slim bands of Nextell, ensured high electrical capacitance between the record and the metal, effectively earthing static charges without actual contact. It was driven by a flat rubber belt from a tacho-controlled DC motor. The belt’s compliance acted as a mechanical filter, preventing motor vibrations from reaching the record and stylus.
To complement this improved arm/cartridge combination Beogram 1800 had a new faster-acting movement control system with separate cam wheels for vertical and horizontal arm movement, so that automatic operation gave you music within a very few seconds. So cueing was really fast, but still careful of your records.
For improved record safety, you could operate normal PLAY and STOP functions while the lid was closed. Just one touch – the rest was automatic. Record size and speed was identified by the Beogram’s logic circuits. Beogram 1800’s slim plinth had a brushed aluminium finish.
Opening the lid gave access to three further function controls: CUE, 33 and 45 speed overrides (for non-standard discs).
Beogram 1800 was designed by Jacob Jensen and at the 1969 Hanover Fair Bang & Olufsen and Jacob Jensen were presented with the iF award for no less than 4 products for ‘outstanding industrial design’ including Beogram 1800.
Types: 5811 (1984 – Aug 1984); USA 5813 (1984 – Feb 1986)
These are probably the slimmest looking record player available. Quite a bit of this is down to clever visual tricks and surprisingly, the decks related to this model all looked thicker. It sold well and may were bought to work with non B&O systems. It shared the excellent suspension of its predecessors and had the new cartridge mounting. Now available for little money, this is a superb sounding deck. Highly recommended.
Posted on
BeoGram 1700
Bang & Olufsen BeoGram 1700
Beogram 1700 combined ease of operation and advanced technology in a simple, matter-of-fact way. To play a record, all you had to do was press ’33’ or ’45’ and let the Beogram do the rest. At the end of play the pickup arm returned to its resting position and the motor switched off.
The anti-skating device worked automatically. Another advantage of the simple, integrated design was immunity to external shock and vibrations. The electronic servo drive system ensured correct rotary speed at all time.
The low mass, low inertia pick-up arm with its plug-in MMC 20S cartridge made it virtually impossible to scratch records.
Beogram 1700 could be made up as part of the Beosystem 1700 or Beosystem 2600, when linked together with other compatible Bang & Olufsen products.
This is quite possibly the best value Beogram made. It has excellent sound and vibration isolation, a very simple and lightweight arm, easy to use and understand controls and is elegant both in looks and operation.
Blindfold, the sound quality is quite frankly indistinguishable from the higher models and it is far more likely to work. Weak spots are few but record support would probably be the main issue. A felt mat suitably cut could well improve record support qualities.
Posted on
BeoGram 1600
Bang & Olufsen BeoGram 1600
Beogram 1600 was manufactured primarily for the US and French markets; therefore in the overall scheme of things, there weren’t many of these around.  A fairly basic machine, Beogram 1600 was designed for use within the Beomaster 1600 and Beocord 1600 system when it complemented these other products nicely.  It fitted with the MMC 20E combined cartridge/stylus.
Posted on
BeoGram 1500 (1967)
Bang & Olufsen BeoGram 1500
Beogram 1500 is the acclaimed Beogram 1000 3-speed stereo record player equipped with a built-in stereo output amplifier delivering 2 x 8 watts of audio output. The Beogram 1500 has no built-in loudspeakers but may be se with external speakers e.g. the Beovox 800 or the Beovox 1000.
The Beogram 1500 has jacks for radio and for tape-recorder – the Beocord 1500 de Luxe would be particularly suitable. If you use the Beogram 1500 in connection with an FM tuner e.g. the Beomaster 5000, you have a small but complete hi-fi system.
The Beogram 1500 has separate adjustment knobs for volume (with built-in balance adjustment), bass and treble. Pushbutton panel for control of on/off, tape recorder, radio, and gramophone. All these functions are conventionally placed on the top of the instrument. Built-in voltage selector for switching between 110, 130, 220 and 240 volts AC. The Beogram 1500 is very elegantly designed and has a transparent dust cover
In the real world, this is a Beogram 1000 with a rather nice 8W per channel amplifier attached. There are two types with the later ones using the same amplifier as the very upmarket Beocord 2400 reel to reel deck. Surprisingly good though the isolation of the deck was no better.
Posted on
BeoGram 1202
Bang & Olufsen BeoGram 1202
The Beogram 1202, although looking very similar to the earlier Beogram 1200, was an entirely new record deck and was far more sophisticated than the earlier model. It continued with the multi-peg system of record support – possibly the decks greatest weakness – and also lacked the hinged lid of the Beogram 3000 to which it was otherwise practically identical. This is the 1200 type deck to own!
The operating system was simplified from the 1200 though the same arm and motor were used. The suspension was however far better – imagine this deck as a Beogram 3000 with a silly platter and a less useful lid and you will not be far wrong. It is however the best of the ‘peg platter’ decks. Very collectible.
Posted on
BeoGram 1200
Bang & Olufsen BeoGram 1200
Beogram 1200 – Types 5213, 5214, 5216, 5217 – was Bang & Olufsen’s first ‘designer’ system. The design ‘kinship’ which emphasised the interdependence between B&O’s various products, became a characteristic of B&O for many years. Beosystem 1200 was one of the first products selected by the Museum of Modern Art for the museum’s permanent collection (not exhibition) in 1972. The system components were designed by Jacob Jensen.
In 1969 the Danish Society of Industrial Design awarded Bang & Olufsen and Jacob Jensen the ID prize for the Beomaster 1200 radio/amplifier, Beogram 1200 turntable and Beocord 1200 cassette recorder for unusually beautiful and user friendly design. The jury emphasised in particular the Beomaster 1200 receiver which pointed in a new direction for the design of radios.
In 1972 the Museum of Modern Art in New York (MoMA) chose seven Bang & Olufsen products designed by Jacob Jensen to be included in their Design Collection as representing excellent examples of the Museum’s criteria for quality and historical importance; design, in fact, which had influenced the twentieth century. Beogram 1200 was one of those seven products.
The 1200 series represented the logical continuation of the line of development and design which put B&O at the forefront of manufacturers of entertainment electronics.
From an audio point of view, this was an advance in some ways – isolation from vibration was slightly better though still not up to the later decks. The peg support for the records was however not so clever as the excellent mat of the 1000 and 1800 offered far better cushioning. It did however look wonderful. Close inspection of the studs reveal that the inner studs are slightly shorter than the outer ones. They do remove for cleaning so do make sure you put them in the right places!!
Posted on
BeoGram 1102
Bang & Olufsen BeoGram 1102
Beogram 1102 was a fully automatic, hi-fi stereo record player with electronic servo-drive and high specification level. Operation was easy and straightforward. All functions were controlled by pressing the rectangular operating panel and if dissatisfied with the pitch of the record, speed could be adjusted by depressing the panel and rotating the little thumbwheel.
The pickup was an MMC 3000 with a spherical diamond. It tracked records at a stylus pressure of 1,2 grams. In order to fully exploit the pickup’s outstanding qualities, B&O constructed an extremely light magnesium pickup arm which, together with its unique suspension, ensured low inertia and thereby good conditions for correct contact between stylus and both walls of the record groove – at all times. Even warped records could be played satisfactorily.
Despite high specification levels, Beogram 1102 and 1902 automatic record-players are extremely easy to operate. All the technicalities are hidden under the surface.
Bang & Olufsen’s Electronic Servo Drive ensures that the rotatory speed of the Beogram 1102 and 1902 was always correct despite variations in the mains current supply. This is so because the system has a special feedback circuit which effects automatic corrections to compensate for these inherent variations
Beogram 1102 could be made up as part of the Beosystem 1100, together with other compatible Bang & Olufsen products
Beogram 1102 UK price in 1978: £97.00
These decks are beautifully made and offer super sound quality for almost no money. Much easier to maintain than the tangential decks simply because they are very simple! Excellent isolation from external vibrations – strongly recommended – and they were when new by Hi-Fi Choice! Simpler than the earlier 1100 – and better for that! A DC motor replaced the AC motor fitted to the 1100 and was electronically regulated with speed adjustment done through a potentiometer as opposed to the complicated measures used in earlier decks. This method would roll out across the range of Beograms.
Posted on
BeoGram 1100
Bang & Olufsen BeoGram 1100
The most basic of a new range of beograms, this model was amongst the first to use the new MMC range of cartridges.
In the case it used the bottom of the range MMC3000 and was designed to be partnered by systems such as the Beomaster 1100.
Much more slim and elegant than the 2000 that it replaced, it featured the triple leaf spring suspension that was a feature of all Beograms from that point onwards. As one of the earlier models in this range, the 1100 used a belt and idler wheel drive mechanism. This would be replaced in the later 02 models with a simple belt drive.
Posted on
BeoGram 1000
Bang & Olufsen BeoGram 1000
superbly designed, tastefully styled
The turntable and overall design was by Jacob Jensen; the tonearm and MMC cartridge principle was by Erik Rørbæk Madsen. Beogram 1000 was the recommended turntable for Beomaster 1000.
The First Beogram?
Beogram 1000 was the very first Bang & Olufsen turntable to be designated with the suffix ‘Beogram’. Before its introduction, earlier decks did not, strictly speaking, hold this product name.
This player has extremely low vibration and rumble – a decisive feature for playback of stereo gramophone records, due to the fact that the stylus must be sensitive to vibrations in all directions.
The Beogram 1000 has antimicrophonic suspension that takes up acoustic and mechanical vibrations from the support and prevents the stylus from leaving the groove. In practice, this means that mechanical vibrations from the support or from persons walking or dancing in front of the Beogram 1000 cannot make the stylus jump in the groove. Such vibrations will be absorbed in the antimicrophonic suspension and will not reach the turntable or the pickup.
Equipped with the world-famous B&O ST/L-15 pickup unit; heavy turntable designed as a stroboscope disc; built-in hydraulically damped pickup lift operating y means of a rocker button. Specially engineered speed selector (78, 45 and 33.3 rpm); built-in special centre insert for 45 rpm records. The Beogram 1000 is available in two versions: Beogram 1000V (for 240/110 volts AC) and Beogram 1000VF (for 240/110 volts AC with built-in preamplifier.
Choice of teak or Brazilian rosewood finish and with a practical transparent acrylic dust cover.
And so ends the brochure speak! The Beogram 1000 was heavily based on earlier decks and, despite what B&O said, was not that resistant to external forces. It also was not able to be played with the lid on and indeed the lid had a cut out at the back to allow the pick arm to protrude. It allowed reasonable play back and was reliable but performance led to B&O looking elsewhere for a turntable for the Beolab 5000 system.
Mounting Options
Posted on
BeoGram 1001
Bang & Olufsen BeoGram 1001
The Beogram 1001 was a slightly updated Beogram 1000. The major change which you may notice is the lack of the name on the front of the cabinet. You may then notice the lack of a 78 rpm setting and finally the cartridge changed to the SP14 rather than the SP6/7. Performance was however just the same – surprisingly good but poor isolation from external vibration. The lid was just as useless as before and did not allow it to be left on during playback.
