Posted on
BeoVox 2200
Bang & Olufsen BeoVox 2200
BeoVox 2200
B&O loudspeakers will meet very exacting conditions as their specifications exceed international hi-fi standards. All B&O speakers are of the pressure-chamber type with an impedance of 4 ohms. They are available in matched pairs only in a choice of teak or Brazilian rosewood finish
Only being available for two years, these small bookshelf speakers
are not that well known. With their old style cone tweeter but a modern small size, they can be considered a link between the 1960s and 70s. The small power handling capacity probably was to be blamed for their demise though, as most receivers introduced in the early ’70s already well exceeded the rated power.
These aren’t the speakers to use at a party, but at moderate volume they produce a very pleasing warm sound especially with acoustic music. The cone tweeter however makes them highly directional, so they are best used in set-ups where you can direct them straight at the preferred listening position.
Beovox 2200 bass drivers have rubber roll edges, so there is no need to worry about foam rot. If the speakers sound fine with all drivers working, they should be a safe buy even without further investigation. The frets, constructed on a wood/metal frame, are however easy to carefully pry off for inspection.
These speakers blend very well on a bookshelf, taking only a little bit more space than, say, a CX100 – and a small, golden old style B&O emblem on the fret accentuates the look. Highly recommended
to complete a vintage set-up with a contemporary Beomaster 900M, for example.
BeoVox 2200 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1969 - 1970
Colour Options
Rosewood, Teak
BeoVox 2200 Product Specification
Speaker units: low frequency unit and high frequency unit.
Crossover frequency: 5 000 Hz. Frequency response: (DIN 45570) 50 – 18 000 Hz.
Power rating: 10W (RMS), 15W (music)
Volume 7.5 litres.
Dimensions: 285mm high, 170mm wide, 255mm deep
BeoVox 2200 FAQs
Please let us know
Posted on
BeoVox 1600
Bang & Olufsen BeoVox 1600
BeoVox 1600
The plain exterior of the Beovox 1600 concealed an interesting design. Designed for wall mounting, either vertically or horizontally, the Beovox 1600 was the ideal for the mid range B&O models of the period such as the Beomaster 1200 or Beocord 2400.
The Beovox 1600 was a three-way design. The units comprised a 12cm woofer, a 2.5cm dome midrange and a 4cm cone tweeter. These units were supplied by Wharfdale (England), Philips (Holland) and SEAS (Norway) respectively. An odd mix, though they were all of good quality and were well made, the woofer had a rot-resistant soft rubber roll edge and a pressure die-cast basket for example. Using a cone driver as the tweeter and a dome for the midrange was odd practice, though it has to be remembered that these were early days for dome loudspeakers in general.
The crossover network was of a fairly standard three-stage parallel design complete with a band pass section for the midrange. Unusually for B&O, a film capacitor was used as the pass element for the tweeter, normally a cheaper electrolytic capacitor would be found here.
The slim cabinets also had an unusual feature, they were braced from front to back to make the large front and rear panels more rigid. This may have been done to stiffen the rear panel in particular, to reduce the amount of acoustic energy that was transmitted into the wall. The cabinets were constructed on the pressure chamber principle and were fronted by a cloth grille that was supported on a pressed steel sheet.
B&O had clearly put a lot of work into the Beovox 1600. It was later replaced by the Beovox 1800.
BeoVox 1600 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1969 - 1972
Colour Options
Rosewood, Teak
BeoVox 1600 Product Specification
Dimensions W x H x D 44 x 33 x 10,5 cm
Weight 5 kg
Performance
Music load 20 watts
Continuous load 15 watts (DIN 45,573)
Frequency response 50 – 20,000 Hz (DIN 45,570)
Distortion Max. 3 % (DIN 45,403)
Sensitivity 4 watts (DIN 45,500)
Crossover frequency 4000 Hz
Capacity 10 litres
Resonance of woofer 35 Hz
Dispersion 90°
Number of units
Bass unit One 15cm
Mid-range One dome unit
Tweeter One 5cm
BeoVox 1600 FAQs
Please let us know
Posted on
BeoVox 1500
Bang & Olufsen BeoVox 1500
BeoVox 1500
The crowning glory of Beolab 20 is the Acoustic Lens that delivers smooth high-frequency sound in full 180 degrees. The results are uncompromising listening experiences across your room and much greater freedom in terms of where you place your speaker for optimal sound.
Review thanks to BeoWorld member Sajpratty – Thanks Steve.
Test environment…
  • BeoMaster 1000 (white key version, tone controls all at neutral)
  • BeoGram 1000 (SP 6-7)
  • Side-by-side comparison with BV1000 (all speakers still on original capacitors)
Correct period (for sound balance) sources:
  • Arthur Lyman “Taboo” (chosen for range of instruments and no remix “work”) – (a 1958 pressing recorded 16-20000 cps, mono)
  • The Beatles “Please Please Me” – (a 1964 pressing, mono)
  • Dvorak’s Symphony No. 9, Alexander Gibson and the LPO – (a 1967 pressing, stereo)
Bass response
  • Very deep, deeper than the BV1000 and better defined. Close to the lower limits of my ears but still easy to hear the different notes played.
  • The BV1000, in contrast, never gave the impression that the lower ranges of my hearing were being tested.
Treble response
  • Very similar in quality to the BV1000, but reached a bit higher without losing detail. Very sensitive to positioning, quite directional, possibly more so than the BV1000.
Midrange balance
  • Adjustable to taste (5-position switch at rear.)
General impressions
  • Double bass – low, defined, easy to hear the different notes played, very easy to tell the difference from electric bass.
  • Grand piano – I’ve stood next to real pianos being played, this sounded and felt exactly the same.
  • Flute – nice and “woody” sounding.
  • Sleigh bells – sounded clear and resonant.
  • Cymbals – bright and well defined.
  • Snare drum – I’ve had a go on one of these, this also sounded exactly the same.
  • Orchestral – sounded nice on the BV1000’s but the BV1500’s raised goosebumps.
  • In use – I prefer the BV1000’s for voice and the BV1500’s for music.
BeoVox 1500 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1967 - 1969
Colour Options
Please let us know​
BeoVox 1500 Product Specification
Dimensions: 635 (width) x 280 (height) x 305mm (depth),
Volume 38 Liters.
Three-way with crossover frequencies at 800Hz and 5KHz.
Woofer : Seas 28/17 TV-GW
Midrange : Peerless G 50 MRC
Tweeter : Peerless MT 25 HFC
Frequency range 45-18000Hz (DIN 45570).
Power rating 15W (25W max).
Impedance 4 Ohms.
Available in Teak and Rosewood.
Has a midrange adjustment (rotating switch with 5 settings) at the back.
A 2 pin DIN socket is provided to attach an external tweeter such as the Beovox 2500.
BeoVox 1500 FAQs
Please let us know
Posted on
BeoVox 1200
Bang & Olufsen BeoVox 1200
BeoVox 1200
BeoVox 1200 Product Details
Type Numbers
6218
6235
Designer
Please let us know
Manufactured
1969 - 1972
Colour Options
Rosewood, Teak
BeoVox 1200 Product Specification
Dimensions W x H x D 50 x 20 x 24 cm
Weight 5,5 kg
Performance
Music load 20 watts
Frequency response 40 – 20,000 Hz (DIN 45,570)
Capacity 17 litres
Dispersion 90°
Number of units
Bass unit One 6 in.
Tweeter One 2 in.
Connections: Input DIN socket – 4 ohms Dimensions W x H x D 50 x 20 x 24 cm
Weight 5,5 kg
Type 6235
Performance
Music load 20 watts
Continuous load 15 watts RMS (DIN 45,573)
Distortion Max. 2,5 % (DIN 45,403)
Crossover frequency 3 kHz / 10 kHz
Capacity 17 litres
Dispersion 120 °
Number of units
Bass unit One 7 in.
Mid-range One DOME unit
Tweeter One 2 in.
BeoVox 1200 FAQs
Please let us know
Posted on
BeoVox 1100
Bang & Olufsen BeoVox 1100
BeoVox 1100
However, it was fitted with higher quality drive units (one 6” woofer and one 1.5” dome tweeter), which gave it a considerable performance advantage. The dome tweeter in particular was a great improvement over the cone type of the Beovox 600. The superior quality meant that the Beovox 1100 met the DIN 45 500 requirements for hi-fi. While it was still suitable for use with the same models as the Beovox 600, it could also be used with some of the better Beomasters, such as the 1000, 1200, 1400 and 1600.
BeoVox 1100 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1970 - 1970
Colour Options
Rosewood, Teak
BeoVox 1100 Product Specification
Please let us know
BeoVox 1100 FAQs
Please let us know
Posted on
BeoVox 1000
Bang & Olufsen BeoVox 1000
BeoVox 1000
“B&O loudspeakers will meet very exacting conditions as their specifications exceed international hi-fi standards. All B&O speakers are of the pressure-chamber type with an impedance of 4 ohms. They are available in matched pairs only in a choice of teak or Brazilian rosewood finish”
– taken from the 1967 – 1968 Bang & Olufsen product catalogue
BeoVox 1000 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1966 - 1970
Colour Options
Rosewood, Teak
BeoVox 1000 Product Specification
Dimensions W x H x D 470 x 190 x 240mm
Weight 5 kg
Power handling capacity 10 watts continuous (DIN 45573)
15 watts peak power
Resonance, low-frequency unit 50-55 c/s
Frequency response (DIN 45570) 60-19000 c/s
Impedance 4 ohms
Angle of coverage 90°
Volume 14,5 litre
Speaker units: Low-frequency unit and high-frequency unit. Crossover frequency: 5000Hz. Frequency response (DIN 45570): 55 – 18000 Hz. Power rating: 10W (RMS), 15W (Music). Volume: 14.5 litres
Dimensions: 190mm high, 470mm wide, 240mm deep
Designed by Jacob Jensen, Beovox 1000 won the iF Award in 1967
BeoVox 1000 FAQs
Please let us know
Posted on
BeoVox ST606
Bang & Olufsen BeoVox ST606
BeoVox ST606
In 1960, Bang & Olufsen introduced the Danish public to the first stereophonic radio as used by ‘Radio Mercur’. That same year the company also introduced the first stereo loudspeaker: ST606.
BeoVox ST606 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1960 - 1964
Colour Options
Please let us know​
BeoVox ST606 Product Specification
Please let us know
BeoVox ST606 FAQs
Please let us know
Posted on
Beovox S60
Bang & Olufsen Beovox S60
Beovox S60
Large speaker which topped the S range. 4 way and able to be used as a bookshelf or free standing speaker. Optional trumpet stand.
Beovox S60 Product Details
Type Numbers
6303
Designer
Manufactured
1975 - 1976
Colour Options
Rosewood, Teak
Beovox S60 Product Specification
Continuous load: 60 W
Music load: 100 W
Impedance: 4 – 8 ohms
Frequency response +4 -8 dB: 36 – 20,000 Hz
Sensitivity: 5 W
Net volume: 28.1 litre Gross volume: 36.9 litre
Woofer: 25cm
Phase link unit: 12.5cm
Mid-range unit: 5cm
Tweeter: 2.5cm
Dimensions W x H x D: 32 x 59 x 20cm
Weight: 11 kg
Beovox S60 FAQs
Please let us know
Posted on
Beovox S55
Bang & Olufsen Beovox S55
Beovox S55
Beovox S55 was an ideal bookshelf speaker, but could also be used as a wall-mounted or free-standing model with the optional fittings available separately.
The pressure chamber cabinet contained a 21cm bass driver, an 11,5 mid-range/phase-link unit and a 2,5cm tweeter. Power handling was 55 watts RMS.
Beovox S55 Product Details
Type Numbers
6426 (to March 1987)
Designer
Manufactured
1981 - 1987
Colour Options
Rosewood, Teak, White, Oak
Beovox S55 Product Specification
RMS power handling capacity: 55 W
Music power handling capacity: 75 W
Impedance: 8 ohms
Frequency response 4+ -8 dB 50 – 20,000 Hz
Frequency response +/- 4 dB 60 – 17,000 Hz
Sensitivity 1W: 4 W
Distortion 250 – 1000 Hz: <1.5%
Distortion > 1000 Hz: <1%
Woofer: 21cm
Phase-link, mid-range: 11.5cm
Tweeter: 2.5 cm dome
Net volume: 20 litre
Gross volume: 32 litre
Dimensions W x H x D: 26.5 x 52.5 x 23cm
Weight 8 kg
Beovox S55 FAQs
Please let us know
Posted on
Beovox S50
Bang & Olufsen Beovox S50
Beovox S50
Uncommon in the UK, the smallest of the range at the time and a two way speaker. Replaced by the S45 which was also downgraded in comparison with a captive lead.
Beovox S50 Product Details
Type Numbers
6415 (to Jan 1982)
Designer
Manufactured
1980 - 1982
Colour Options
Rosewood, Teak
Beovox S50 Product Specification
RMS power handling capacity 50 watts
Music power handling capacity 90 watts
Impedance: 8 ohms
Frequency response +/- 4 dB 70 – 18,000 Hz
Sensitivity: 1W
Distortion 250 – 1000 Hz <1.8%
Distortion > 1000 Hz <1%
Woofer: 21cm, throw +/- 3 mm
Net volume: 22 litre
Gross volume: 34 litre
Dimensions W x H x D: 26.5 x 53 x 26.5cm
Weight 8 kg
Beovox S50 FAQs
Please let us know
