Posted on
BeoCord VHS63
Bang & Olufsen BeoCord VHS63
BeoCord VHS63
Like Beocord VHS 91 and VHS 66, this video tape recorder was fully remote controlled through the Beovision keypad. A touch of the button activated record, playback, fast forward and rewind, single frame, freeze frame and picture search which operated at 4 times normal speed.
This a fairly basic Philips video recorder, little disguised for its role as a B&O machine.
BeoCord VHS63 Product Details
Type Numbers
4402 (GB ) (1985 - Nov 1986)
4403 (S-CH) (1985 - May 1987)
Designer
Please let us know
Manufactured
1985 - 1987
Colour Options
Please let us know​
BeoCord VHS63 Product Specification
Specifications: CTV system PAL I
Channel range UHF (21-69)
Max. playing time 4 hours, E-240
Fast forward en rewind Max. 5 minutes
Still picture Max. 8 minutes
Aerial impedance 75 ohms coax
Frequency range
40 – 10,000 Hz 4 dB
Signal-to-noise ratio > 43 dB
Wow and flutter < 0.4%
Power supply
240 V/50 Hz
Consumption, normal use 26 watts
Consumption, stand-by 10 watts
Dimensions, W x H x D 44 x 10.5 x 36 cm
Weight 7 kg
Connections: RF IN 75 ohms
RF OUT 75 ohms
A/V socket 21-pin SCART
Audio socket 5 pin DIN
BeoCord VHS63 FAQs
Please let us know
Posted on
BeoCord VHS62
Bang & Olufsen BeoCord VHS62
BeoCord VHS62
To the unwary, this machine looked remarkably similar to the Video 2000 machines which preceded it. But as the name suggested, it was a VHS machine though supplied by Grundig again. Not sold in the UK.
BeoCord VHS62 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1985 - 1985
Colour Options
Please let us know​
BeoCord VHS62 Product Specification
Mains voltage 220 – 240 V +/- 10%
Frequency 48 – 62 Hz
Power consumption in ON 30 W
Power consumption in STANDBY 10 W
Ambient temperature + 10 to +35° C
Relative humidity 30 – 80 %
Wind/rewind time: < 300 sec. with E-240
Position of normal end use Horizontal: max:15°
Number of programmes 35 + AV
Number of pre-programmable blocks 5
Maximum period for pre-programming 0 – 30 days or every day
Video:
Signal-to-noise ratio > 46 dB (CCIR 421 – 2 annex)
Resolving power > 3.1 MHz (- 26 dB)
Audio:
Frequency response 40 – 10,000 Hz +/- 8 dB
Wow and flutter < 0.4 % (DIN45507)
Distortion < 6 %
Signal-to-noise ratio > 45 dB (DIN45500)
Tuner:
Band I 48.25 – 105.25 MHz (Ch. E2 – S1)
Band III 112.25 – 294.25 MHz (Ch. S2 – S20)
Band IV/V 471.25 – 855.25 MHz (Ch. E21 – E69)
Modulator:
Adjustable modulation Channel 30 – 40 (543 – 623 MHz
Output voltage 3 mV (RMS) +/- 3 dB
Connections: 21-pin A/V
Audio DIN connector
BeoCord VHS62 FAQs
Please let us know
Posted on
BeoCord VCR70
BeoCord VCR70
The last Video 2000 made by B&O, this again was based on a Grundig machine. The format had however not managed to get a foothold in the rental market and therefore had lost out to the inferior VHS system. As a European format, it did last longer in the core market but gradually B&O realised that they had to serve all their markets and so introduced a VHS machine.
BeoCord VCR70 Product Details
Type Numbers
4471 (1984 - Jan 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoCord VCR70 Product Specification
Infra-red remote Control
Cassette system Video 2000
Max. playing time
2 x 4 hours, VCC 480
Fast forward and rewind: 2 min. 40 sec. VCC 480, 4 hours
Still picture Max. 8 min.
Slow motion Half-speed
Search forward 7 x normal speed
Search rewind 5 x normal speed
TV channels VHF 2 – 12, UHF 21 – 69) Play channel UHF 37 (adjustable 30 – 40)
Power supply 220V
Placement min. height : 25cm
Ambient temperature: +10/+35°C
Relative humidity: 30 – 80 %
Dimensions W x H x D: 44 x 12 x 27.5cm
Weight 8 kg
Connections: A/V socket 21-pin SCART
AUDIO socket 6-pin DIN
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VCR70 FAQs
Please let us know
Posted on
BeoCord VCR61
BeoCord VCR61
A development of the VCR60, changing due to changes in the donor Grundig machine. Not sold in the UK.
BeoCord VCR61 Product Details
Type Numbers
4455 (1984 - Jan 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoCord VCR61 Product Specification
Power consumption in ON 45 W
Maximum playing time
2 x 4 hours with VCC 480
Wind/rewind time < 160 sec. with VCC 480
Dimensions: W x D x H 43.8 x 27.4 x 11.7 cm / Weight 8 kg
Position of normal end use Horizontal: max. 15°
Video:
Signal-to-noise ratio > 47 dB (CCIR 421 – 2 annex III)
Signal drop-out consumption Max. 5 lines
Audio:
Wow and flutter < 0.3 % (DIN45507)
Distortion < 6 %
Signal-to-noise ratio > 50 dB (DIN45500)
Tuner:
Band I 45 – 85 MHz (Channels 2 – 4)
S-channels 105 – 168 MHZ (Channels S1 – S10)
Band III 163 – 224 MHz (Channels 5 – 12)
S-channels 231 – 287 MHz (Channels S11 – S19)
Band IV/V 471 – 855 MHz (Channels 21 – 69)
Modulator:
Connections: Audio in/out
21-pin AV
BeoCord VCR61 FAQs
Please let us know
Posted on
BeoCord VCR60
Bang & Olufsen BeoCord VCR60
BeoCord VCR60
The next stage in B&O’s foray into the V2000 technology, this machine was based on a Grundig machine and was not sold in the UK.
BeoCord VCR60 Product Details
Type Numbers
4451 (1983 - Jan 1985)
4454 (F) (1983 - Jan 1985)
4453 (Oscar) (1983 - Jan 1985)
Designer
Please let us know
Manufactured
1983 - 1985
Colour Options
Please let us know​
BeoCord VCR60 Product Specification
Power consumption in ON 45W
Power consumption in STANDBY 10W
Ambient temperature +10 to + 35 degrees
Maximum playing time 2 x 4 hours with VCC 480
Wind/rewind time <160 sec. with VCC 480
Dimensions 43.8 x 27.4 x 11.7cm
Weight: 8 kg Position of normal end use horizontal: max. 15°
Maximum period for pre-programming 31 days or every day
Adjustable modulation frequency
Channel 30 – 40 (560-640 MHz)
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VCR60 FAQs
Please let us know
Posted on
BeoCord V8900
BeoCord V8900
The final development of the V8800 model.
BeoCord V8900 Product Details
Type Numbers
4441 (1982 - Dec 1983)
4443 (1982 - Feb 1984)
Designer
Please let us know
Manufactured
1982 - 1984
Colour Options
Rosewood, Teak
BeoCord V8900 Product Specification
Infra-red remote control
Max. playing time
2 x 4 hours VCC 480
Fast forward and rewind Norm. 3 min. VCC 480, 4 hours
Picture freeze Max. 4 min
Forward picture search 7 x normal speed
Reverse picture search 5 x normal speed
TV channels: VHF 2 – 11, UHF 21 – 69
Play channel UHF 37 (adjustable 31 – 43) Number of TV programmes: 26
Time programming 5 broadcasts
Number of days 16
Power supply: 220 V (110 – 120 – 240 V)
Placement max. slope: +/- 15°
Placement max. height: 24cm
Ambient temperature: +10 / +35°C
Dimensions W x H x D: 55 x 16 x 43cm
Weight 18 kg
Connections: Aerial 75 ohms
A/V 6-pin DIN
BeoCord V8900 FAQs
Please let us know
Posted on
BeoCord V8804
Bang & Olufsen BeoCord V8804
BeoCord V8804
A further development of the Video 2000 video recorder.
BeoCord V8804 Product Details
Type Numbers
4434 (1982 12-83)
Designer
Please let us know
Manufactured
1982 - 1983
Colour Options
Rosewood, Teak
BeoCord V8804 Product Specification
Max. playing time
2 x 4 hours VCC 480
Picture freeze Max. 4 min.
TV channels: UHF 21 – 69
Time programming 5 programmes
Number of days 16
Power supply: 240 V (110 – 120 – 220 V)
+/- 15°
Placement max. height 24 cm
Ambient temperature +10 / +35°C
55 x 16 x 43 cm
Weight 18 kg
A/V 6-pin DIN
BeoCord V8804 FAQs
Please let us know
Posted on
BeoCord V8802
Bang & Olufsen BeoCord V8802
BeoCord V8802
If your choice of TV viewing included video, the Beovision Video Terminal supplied with your Beovision 5100, 7100 or 8100 (or Beovision models 5500, 7700, 8800 and 9000 featured in the 1982 Autumn catalogue) could also be used to operate the Beocord V8802 video cassette recorder.
There were two types of video stand available, specially designed to accommodate any Bang & Olufsen VCR and combine them into a complete video system that was easy to install, easy to live with and a joy to use.
Beocord V8802 used the technical superiority of the V2000 format to guarantee top-quality recording and playback on economical flip-over cassettes. The 2×4 hour flip-over cassettes gave you 8 hours of recording time in one tape, which worked out cheaper in cost-per-minute terms than any other video format.
Microcomputer technology gave Beocord 8802-V a wide range of features and facilities and, at the same time, ensures that operation was fast, straightforward and fool-proof. Automatic track adjustment meant that even well-worn tapes recorded on another machine were reproduced accurately – that was important if you intended to hire feature film cassettes for home screening.
Sound quality was also of the highest quality with a technique called Dynamic Sound Suppression, reducing distortion and unwanted noise to negligible levels.
Freeze-frame and picture search are useful features, especially for sports fans, and both could be operated by remote control.
Another outstanding benefit was the ease with which Beocord’s computer-controlled timer could be programmed to make up to 5 automatic recordings from any 5 TV channels within a 16-day period. Of course, you could also record one programme while watching another. The Beovision Video Terminal kept you in control of the whole system without moving more than a finger.
The Terminal was supplied as part of the TV; if you purchased Beocord V8802 separately, or with a manual Beovision TV, the Terminal had to be purchased as an optional accessory in order for you to obtain the extra convenience of remotely controlled video.
Programming Beocord V8802 to make unattended recordings was quick and easy, thanks to logical control systems and microcomputers. Simply key in the channel, the day and the start and stop times of the programme you wanted recording. Each instruction was confirmed on the illuminated communications panel. The microcomputer’s memory could store 5 such sets of instructions covering the period of 16 days ahead. You could even check your programming for accuracy and correct mistakes by operating the ‘clear’ button. When all the programmed recordings had been completed the machine rewound the tape ready for instant replay.
The 8-hour flip-over cassette was more convenient and economical to use than any other type then on the market. The cassettes were tamper-proof: it was impossible to damage them by touching any moving parts or the tape itself. A safety switch built into the cassette casing prevented the inadvertent erasure of recordings you wanted to keep.
BeoCord V8802 Product Details
Type Numbers
4421 (1982 - Nov 1983)
4424 (F) (1982 - Dec 1983)
4422 (GB) (1982 - May 1983)
4423 (OS) (1982 - May 1983)
Designer
Please let us know
Manufactured
1982 - 1983
Colour Options
Teak, Rosewood, White
BeoCord V8802 Product Specification
CTV system: PAL-AI
Remote control: Built in, infra-red
Cassette system: Video 2000
Max playing time: 2 x 4 hours VCC 480
Fast forward & rewind: Max 2 mins VCC 480, 4h
Counter: Electronic 4 digits
Play channel: UHF 36 (adjustments 31 – 43)
Number of TV progs: 26
Time programming: 5 programmes Number of days: 16
Frequency range b/w picture: 3 MHz (<= – 20dB)
Colour: 625 kHz
Signal-to-noise ratio: >44dB (CCIR 421-1)
Frequency range (sound): 40 – 10000 Hz +/- 8dB
Distortion max load: <7%
Signal-to-noise ratio: > 50dB (DIN 45405)
Wow and flutter: <+/- 0,3%
Power supply: 240V (110-120-220)
Power frequency: 48-62 Hz
Consumption at normal use: <75W
Consumption stand-by: 15W
Placement: Horizontal +/- 15 degrees
Placement min height: 24cm
Ambient temp: 10 – 35 C
Relative humidity: 30-80%
Dimensions WxHxD: 55 x 16 x 43cm
Weight: 18kg
Accessories:
  • Video table (Type 3059)
  • Camera/mic connection (Type 8053174)
  • Beovision Video Terminal (Type 3319)
BeoCord V8802 FAQs
Please let us know
Posted on
BeoCord V8800
Bang & Olufsen BeoCord V8800
BeoCord V8800
Beosystem 8800 Video was the only fully integrated home video system on the market in the early 1980’s. It comprised the Beocord 8800 video recorder, the Beovision 8800 colour TV, the Beovision Video Terminal and an elegant custom-built stand.
These individual components were designed to match and function harmoniously as one complete system, from a technical, functional, aesthetic and operational point of view. That is why you could operate all primary functions in the entire system from a distance using one infra-red remote control module. This gave you fast, easy, direct access to all facilities, whether these were ordinary TV programmes, recording or playback of video cassettes or Teletext home information services (when the Teletext circuitry is installed). Naturally, you could also make all important sound and video adjustments from the comfort of your chair.
The heart of Beocord 8800 Video was the 2 x 4-hour flip-over cassette – as part of the V2000 video system (similar to VHS and Betamax). It allowed you to make use of up to 8 hours recording time on one cassette, whereas most competing systems offered just 3,25 hours. Thus, the cassette was not only more convenient, it was also more economical to use than any other cassette on the market.
Another outstanding feature was that you could programme the Beocord to make 5 unattended recordings from 5 different TV channels at 5 different times up to 16 days in advance. You could have a relaxing holiday or travel on business, and be rest assured that you wouldn’t have to miss any of the programmes in your favourite TV series.
This creative use of machine intelligence (micro-computers) and the degree of flexibility and convenience afforded were unparalleled in competing video recorders. So too was the ease and speed with which you could operate the machine, thanks to its logical operation facilities and its large communication panel.
Optional stand
The optional stand for the Beosystem 8800 Video was both functional and attractive. It combined the TV receiver and recorder into one harmonious system, making the units even easier to install and convenient to live with at home. The positions of TV and VCR were reversible and the TV shelf had a rotating plate so you could alter its viewing angle at will. Beneath the shelf was a drawer for storing cassettes, headphones and other accessories. The stand was made of black anodised aluminium.
Programming the Beocord 8800 Video to make up to 5 unattended recordings during a 16-day period was both quick and easy, thanks to its logical operation facilities and microcomputers.
Illuminated symbols on the machine’s communication panel guided you through programming, step by step, confirming each step and keeping you informed at all times. You could even check your programming for accuracy and correct mistakes using the clear button. The 8-hour flip-over cassette allowed you to make high quality recordings at a lower cost per programme than ever before. The cassette had a tamper-proof design. Quite simply, it was impossible to damage it by accidentally touching the tape or any of its moving parts. A unique safety slider prevented you from inadvertently erasing a recorded cassette.
The Beovision Video Terminal was a remote control module which transmitted your instructions to the Beovision colour TV or the Beovision 8800 Video on a beam of infra-red light. It gave you immediate access to all primary functions on the Beosystem 8800 Video from anywhere in your room. You could select any of 16 TV channels on the Beovision. Or up to 26 if you made use of the Beocord’s TV tuning and storing facility. You could make video recordings or play a cassette. And if you had Teletext installed in your TV, you could operate this advanced home information service from a distance.
Naturally, you could also adjust volume levels, brilliance and colour without leaving your chair. Or mute the set but retain the picture, if the phone rang.
The Beovision Video Terminal was an integral part of Beovision 8800. Beocord 8800 Video could also be used with non-Bang & Olufsen TVs. If you chose to do so, you could still operate Beocord’s functions from a distance using the Beovision Video Terminal which was available separately (Type 3319).
BeoCord V8800 Product Details
Type Numbers
4411 (1981 - Dec 1981)
4412 (GB) (1981 - Jan 1982)
Designer
Please let us know
Manufactured
1981 - 1983
Colour Options
Rosewood, Teak
BeoCord V8800 Product Specification
Max. playing time
Max. 2 min. VCC 480
Fast forward and rewind Max. 2 min. VCC 480, 4 hours
TV channels: VHF 2 – 11, UHF 21-69
Play channel UHF 37 (adjustable 31-43)
Number of days 16
Placement min. height: 24cm
Ambient temperature: + 10/ + 35°C
Relative humidity: 30 – 75 %
Weight 18 kg
BeoCord V8800 FAQs
Please let us know
Posted on
Beocord Unitape 512 K
Bang & Olufsen Beocord Unitape 512 K
Beocord Unitape 512 K Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1957 -
Colour Options
Please let us know​
Beocord Unitape 512 K Product Specification
Please let us know
Beocord Unitape 512 K FAQs
Please let us know
