Posted on
Beolit Teena FM
Bang & Olufsen Beolit Teena FM
Beolit Teena FM
The Beolit Teena FM uses the latest type transistors, the input transistor in the FM section is the best available in the market and secures excellent FM reception with a minimum of hiss and noise.
The Beolit Teena FM is compact and handy, and uses printed circuit boards throughout and is therefore rugged and reliable. The battery used in the Teena FM is securely enclosed yet is easily and quickly replaced.
The Beolit Teena FM has weather- resistant cabinet of impact-proof leather-grained polystyrene.
Available in many beautiful colour combinations.
Beolit Teena FM Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1962 - 1964
Colour Options
Please let us know​
Beolit Teena FM Product Specification
Please let us know
Beolit Teena FM FAQs
Please let us know
Posted on
Beolit
Beolit
The first transistor radio!
Beolit AM-FM, the sensational Danish transistor radio. Housed in beautiful rugged weather-resistant cabinet of impact-proof leather grained polystyrene. Available in the following elegant colours: red, green, buff, light grey, blue, dark grey and black.
The battery, protected by, a plastic case, is easily and quickly replaceable. Large B&O high quality loudspeaker assures superb tone quality. The Beolit AM-FM has jacks for external aerial, external speaker, and gramophone – the gramophone jack may be quickly and easily rewired for use as tape recorder jack.
Best, newest, and most sensitive transistors obtainable in the world market. Precision engineered ferrite aerial composed of two different ferrite materials. The Beolit AM-FM has unsurpassed dependability of operation, thanks to use of B&O printed circuit boards throughout.
The Beolit AM-FM has a built-in ‘Radicator’ (a small moving coil meter) that puts you in a position to check the condition of your battery at any time. The Radicator is also a tuning aid.
Accessories: Type 2920 Gramophone Plug. Type 2920 Loudspeaker Plug. Type 10079 Aerial Plug.
Beolit AM and Beolit FM were the first radios to be manufactured with transistors instead of tubes – the very first ‘transistor radios
Beolit Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1960 - 1963
Colour Options
Beolit Product Specification
Please let us know
Beolit FAQs
Please let us know
Posted on
BeoCord VHS91.2
Bang & Olufsen BeoCord VHS91.2
BeoCord VHS91.2
With Beocord VHS 91.2 Bang & Olufsen created a stereo video tape recorder which, in 1987, was close to studio equipment in terms of sound and picture quality. And when it came to design, operation and uses it was a natural, integrated part of home entertainment and communication.
Beocord VHS91.2 could record up to four hours of video or eight hours of stereo hi-fi sound on just the one four-hour tape. And it could of course be remote-controlled regardless of which Bang & Olufsen TV and music system you put it to work with.
The many picture functions included such things as distortion-free single frame pictures, play back just one picture at a time, ‘flickerless’ breaks between recordings and automatic picture search with the help of the tape counter. And Beocord VHS91.2 could also be programmed to record daily or weekly for an unlimited period of time.
With a completely new recording technique and one built-in stereo decoder, Beocord VHS 91.2 provided unlimited possibilities for combining TV, video and music systems, such as recording stereo simulcasts.
In terms of design, colours and uses, Beocord VHS 91.2 was created to harmonise with Beovision MX2000. And the same remote control Terminal could be used to control both units.
BeoCord VHS91.2 Product Details
Type Numbers
4500 (1986 - Aug 1989)
4502 (GB) (1986 - May 1989)
4505 (MULTI) (1986 - Aug 1989)
4503 (VPS) (1986 - Jan 1990)
Designer
Please let us know
Manufactured
1986 - 1990
Colour Options
Please let us know​
BeoCord VHS91.2 Product Specification
Description: TV system I (4502)
B/G all Band + UHF (4500, 4503)
Colour system PAL/SECAM east modified (4500, 4503)
PAL (4502)
Cassette format VHS
Remote control system Built-in for Video and Audio terminal
Tape heads 3 video, 2 Hi-Fi audio
Sound, compatible normal/Hi-Fi Stereo, Hi-Fi sound
Max. playing time, audio/video 4 hours, E-240
Max. playing time, audio only 8 hours, E-240
Fast forward and rewind Approx. 6 min. E-240
Relative humidity: 30-80 %
Dimensions W x H x D: 40 x 10.5 x 37.5 cm
Weight 10 kg
Step advance 1 frame
Search forward 4 x normal speed
Search rewind 4 x normal speed
Counter Electronic, 4 digits
TV channels All band: VHF 2 – 12, S-channels 46 – 300 MHz, UHF 21 – 69 (4500)
UHF 21 – 69 (4502)
All band: VHF 2 – 12, S-channels 46 – 300 MHz, UHF 21 – 69 (4503)
Play channel UHF 37 (adjustable 30-39)
Number of programmes 39
Time programming 3 programming up to 14 days in advance, or daily, + 1 weekly
Power supply
220V (4491)
240V (4492)
220V (4493)
BeoCord VHS91.2 FAQs
Please let us know
Posted on
BeoCord VHS91
BeoCord VHS91
Beocord VHS 91 was a genuine hi-fi sound recorder as well as a high quality VCR. It not only gave 4 hours of video recording, but also 8 hours of stereo sound with a level of quality approaching that of compact disc..
Equipped with Bang & Olufsen’s advanced HX Professional recording system and Dolby B Noise Reduction, Beocord VHS 91 could be used for recording directly from the television and stereo sound from your hi-fi during simulcasts. And as a hi-fi sound recorder, it could also be connected to the Beolink® system to take music all over your house. When connected to your B&O TV, VHS91 could be controlled by the Video Terminal remote control.
BeoCord VHS91 Product Details
Type Numbers
4491 (1985 - June 1986)
4492 (GB) (1985 - Oct 1986)
4495 (MULTI, S-CH) (1985 - Oct 1986)
4493 (OSCAR) (1985 - March 1987)
Designer
Please let us know
Manufactured
1985 - 1986
Colour Options
Please let us know​
BeoCord VHS91 Product Specification
Description: TV system B/G VHF + UHF( 4491)
I UHF (4492)
B/G all Band tuner + UHF (4493)
Colour system PAL/SECAM modified (4491)
PAL (4492)
PAL/SECAM modified (4487)
Cassette format VHS
Remote control system Built-in for Video terminal
Stereo decoder Stereo an bilingual, TV-broadcasts (4493)
TV channels VHF 2-12, UHF 21-69
Power supply
220V (4491)
240V (4492)
220V (4493)
Relative humidity
30-80 %
Dimensions W x H x D 40 x 10.5 x 37.5 cm
Weight 10 kg
Connections: A/V, audio/video socket 21-pin
LINE IN, audio 7-pin Datalink 50 mV/50 kohms
LINE OUT, audio 7-pin Datalink 800 mV/600 ohms
BeoCord VHS91 FAQs
Please let us know
Posted on
BeoCord VHS90
BeoCord VHS90
Beocord VHS 80 was Bang & Olufsen’s entry into the VHS arena. Both Beocord VHS 90 and VHS 80 had stereo sound circuitry with Dolby B Noise Reduction. So when combined with a stereo Beovision they ensured the fullest enjoyment from stereo videotapes. You could also record stereo TV/FM Simulcasts if you used a stereo Beovision model.
One of the many plus points for owning a Bang & Olufsen VHS recorder from this period meant that for the first time, you could operate both the Beocord and the Beovision using the same remote Terminal. Whichever Beovision you chose, whether mono or stereo, Beocords VHS 80 or 90 would have been an ideal match for it. One touch on the TV’s remote Terminal allowed you to play a videotape, make recordings, fast wind or rewind the tape, scan the tape in either direction or freeze a single frame on-screen. If you wished to combine a Beocord VHS 80 or VHS 90 with a non-Bang & Olufsen TV, the remote Video Terminal could be purchased separately to provide chairside control of all primary playing and recording functions.
Beocord VHS 90 offered the best of both worlds – a high quality stereo sound recorder that, when connected to a hi-fi system, achieved performance characteristics that were close of compact discs; and a video recorder that combined superb picture quality with true hi-fi sound. When used as an audio recorder, up to 8 hours of music could be stored on one VHS tape and replayed non-stop. For hi-fi video recording, 4 hours was the maximum. With Beocord VHS 90, you could instruct the automatic timer to record up to five different programmes up to 14 days ahead. A repeat button enabled you to record the same show at a specific time every day of the week.
Unlike most most dual-purpose machines the Beocord VHS 90 records two versions of video track simultaneously: a hi-fi stereo track for replay on the same machine and an ‘ordinary’ stereo track which meant that your cassettes could be replayed on a non-hi-fi stereo video recorder.
Beocord VHS 80 also had stereo sound circuitry for video recording and playback. In fact, it offered the same video facilities as Beocord VHS 90, including an identical 39 channel search-and-store tuner and 5 programme/14 day timer.
Picture quality was of equally high standard too, but Beocord VHS 80 did not offer audio-only recording or hi-fi sound characteristics. However, it did incorporate a Dolby B Noise Reduction Circuit for maximising the recorded sound.
Placement of both VCRs: a practical stand from Bang & Olufsen organised your video system into a complete remote-controlled centre which could easily and discreetly be placed in your viewing room.
BeoCord VHS90 Product Details
Type Numbers
4465 (1984 - Jan 1986)
4469 (D) (1984 - Feb 1986)
4468 (F) (1984 - Feb 1986)
4466 (GB) (1984 - Jan 1986)
4467 (OSCAR) (1984 - Dec 1985)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Metal Grey
BeoCord VHS90 Product Specification
Description: CTV system B/G PAL (4465)
I PAL (4466)
B/G PAL S-tuner (4467)
B/G PAL (4469)
Max. playing time audio/video 4 hours, E-240
Fast forward and rewind Nom. 6 min. E-240
Still picture Max. 6 minutes
Aerial impedance 75 ohms coaxial
Number of TV programmes 39
Power supply
220V (4465)
240V (4466)
220V (4467)
220V (4469)
Placement, min. height
22 cm
Ambient temperature +5/+40 degrees
Relative humidity 10-75%
Dimensions W x H x D 48 x 12 x 37.5 cm
Weight 12 kg
Line, audio sockets 315 mV/50 Kohms
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VHS90 FAQs
Please let us know
Posted on
BeoCord VHS82.2
BeoCord VHS82.2
A mildly updated VHS82 designed to work with the new range of MX televisions.
BeoCord VHS82.2 Product Details
Type Numbers
4550 (1988 - March 1989)
4554 (AUS) (1988 - March 1989)
4552 (GB) (1988 - March 1989)
4555 (MULTI) (1988 - March 1989)
4558 (SECAM) (1988 - March 1989)
4553 (VPS) (1988 - Mach 1989)
4557 (VPS, MULTI) (1988 - March 1989)
Designer
Please let us know
Manufactured
1988 - 1989
Colour Options
Red, Black, Grey, White
BeoCord VHS82.2 Product Specification
Description: TV system B/G All band + UHF (4550, 4554, 4558)
I UHF band (4552)
B/G All band + UHF (4553, 4557)
Colour TV PAL
Cassette format VHS
Remote control system Via Beovision LX 2800/MX 2000
Stereo decoder Stereo and bilingual TV
VPS, Video Programming System No (4510)
No (4512)
Yes (4513, 4517)
Max. playing time, audio only 8 hours, E 240
Fast forward and rewind Approx. 5 min. E-240
Still picture Max. 8 minutes
Step advance Typically 4 frames (2-10)
Play reverse Normal speed
Search forward 3 and 7 x normal speed
Search rewind 7 x normal speed
TV channels All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4550, 4554, 4558)
UHF 21-69 (4552)
All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4553, 4557)
Play channel
UHF 37, (adjustable 30-40)
Number of TV programmes 35 + AV
Time programming Max. 2-4 programmes: up to 31 days, in advance, daily or weekly
Programmed end time Intervals of 30 min.
Power supply
240V (4550, 4554, 4558)
220V (4552)
240V (4553, 4557)
20 cm
Ambient temperature +10/+35 degrees
Relative humidity 30/80%
Dimensions W x H x D 42 x 8.4 x 32.5 cm
Weight 7.5 kg
Audio IN/OUT sockets 4 Phono plugs
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VHS82.2 FAQs
Please let us know
Posted on
BeoCord VHS82
BeoCord VHS82
Beocord VHS 82 was Bang & Olufsen’s 1987 addition to the stereo video cassette recorder line-up with up to four hours of video playing time and eight hours of hi-fi quality stereo sound on just one video tape!
In terms of design, colours and uses, Beocord VHS 82 was created to harmonise with Beovision MX2000. And the same remote control Video Terminal could be used to control both units. Control was so integrated that the TV screen acted as an open instruction manual for the video cassette recorder.
All of the functions on Beocord VHS 82 were described and stored on ‘menus’ that were brought to the screen with the assistance of the Terminal. This step-by-step instruction ensured fast, faultless operation. So even things like presetting channels, time programming and picture search were as easy as was possible. And although the special menu operation was only possible in connection with the latest TV generations from Bang & Olufsen, Beocord VHS82 was an ideal video supplement for ant TV.
The fact that Beocord VHS 82 could take its place as a technically superior audio tape recorder in any music system emphasizes just how outstanding this stereo video recorder was.
BeoCord VHS82 Product Details
Type Numbers
4510 (1986 - May 1988)
4512 (GB) (1986 - May 1988)
4513 (VPS) (1986 - May 1988)
Designer
Please let us know
Manufactured
1986 - 1988
Colour Options
BeoCord VHS82 Product Specification
Description: TV system B/G All band + UHF (4510)
I UHF band (4512)
B/G All band + UHF (4513, 4517)
Colour TV PAL
Cassette format VHS
No (4512)
Yes (4513, 4517)
TV channels All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4510)
UHF 21-69 (4512)
All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4513, 4517)
Play channel: UHF 37, (adjustable 30-40)
Programmed end time Intervals of 30 mins
Power supply: 220V
Placement, min. height: 20cm
Dimensions W x H x D: 42 x 8.4 x 32.5cm
Weight 7.5 kg
Audio IN/OUT sockets 4 phono plugs
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VHS82 FAQs
Please let us know
Posted on
BeoCord VHS80
Bang & Olufsen BeoCord VHS80
BeoCord VHS80
Finish: metal grey
Finish: metal grey
BeoCord VHS80 Product Details
Type Numbers
4461 (1984 - Nov 1984)
4462 (GB) (1984 - April 1985)
4463 (Oscar) (1984 - May 1985)
Designer
Please let us know
Manufactured
1984 - 1985
Colour Options
Metal Grey
BeoCord VHS80 Product Specification
Description: CTV system B/G PAL (4461)
I PAL (4462)
B/G PAL S-tuner (4463)
Remote control Built in, infra-red
Cassette format VHS
Max. playing time 4 hours, E-240
TV channels UHF 21-69
Time programming 5 programmes, + 1 daily + 1 weekly
Number of days 14
Power supply
220V (4461)
220V (4462)
240V (4463)
22 cm
Relative humidity 30-80%
Weight 12 kg
Connections: A/V, audio/video socket 6-pin DIN
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VHS80 FAQs
Please let us know
Posted on
BeoCord VHS66
BeoCord VHS66
In the crucial quiet passages you heard only the sound of silence from the mono Beocord VHS66. The HX Professional recording system gave more ‘headroom’, enhancing the definition of high, delicate sounds, and Dolby B Noise Reduction cut down on hiss and noise.
Features:
  • Dimensions (WxHxD): 48 x 10,5 x 36cm
  • 4 hours of recording/playback on E240
  • Mono sound recording, HX Professional recording system; Dolby B
BeoCord VHS66 Product Details
Type Numbers
4485 (1985 - Nov 1986)
4489 (F) (1985 - Feb 1987)
4486 (GB) (1985 - Feb 1987)
4487 (Oscar) (1985 - Feb 1987)
Designer
Please let us know
Manufactured
1985 - 1986
Colour Options
Please let us know​
BeoCord VHS66 Product Specification
TV system B/G VHF + UHF( 4485)
I UHF (4486)
B/G all Band tuner + UHF (4487)
Colour system PAL/SECAM modified (4485)
PAL (4486)
PAL/SECAM modified(4487)
Cassette format VHS
Remote control system Video terminal
Tape heads 3 video
Sound Mono
Sound recording system HX PRO
Fast forward and rewind Approx. 6 min. E240
Power supply
220V (4485)
240V (4486)
220V (4487)
Placement, min. height: 22 cm
Ambient temperature +5/40 degrees
Relative humidity 10-75 %
Dimensions W x H x D 48 x 10.5 x 36 cm
Weight 9.5 kg
LINE IN/OUT, audio socket 7-pin
RF IN 75 ohms
RF OUT 75 ohms
BeoCord VHS66 FAQs
Please let us know
Posted on
BeoCord VHS65
BeoCord VHS65
Another Philips clone and not sold in the UK.
BeoCord VHS65 Product Details
Type Numbers
4481 (1984 - Oct 1986)
Designer
Please let us know
Manufactured
1984 - 1986
Colour Options
Please let us know​
BeoCord VHS65 Product Specification
CTV system B/G PAL
Cassette format VHS
Sound Mono
Connections: RF in 75 ohms ; RF out 75 ohms
Play channels UHF37, (adjustable 30-39)
Time programming: max. 6 arbitrary 14 days, daily, weekly
Power supply
220 volts
22 cm
Relative humidity 1075%
Dimensions W x H x D: 48 x 12 x 37.5
Weight 12 kg
BeoCord VHS65 FAQs
Please let us know
