Beomaster 1000 – a compact all-transistor hi-fi 2 x 15 watt stereo amplifier equipped with a highly selective FL radio with extended FM band (to 108 MHz), 3-gang tuning capacitor and 4-stage intermediate-frequency amplifier, automatic control circuit which locks on FM stations and keeps them accurately tuned.
It is prepared for single-transmitter stereo broadcasts, having a B&O multiplex adaptor (stereo decoder); it is also equipped with a pilot lamp (“Beo-Beacon”) which lights up when the receiver is tuned to a station transmitting an FM stereo programme.
The stereo amplifier, which plays both stereo and mono gramophone records, delivers no less than 2 x 15 watts of power output; piano-key speaker change-over switches which control two sets of stereo speaker systems, separate extra-efficient bass and treble controls; balance control for correct stereo sound distribution; physiologically compensated volume control (provides full balance at all volume levels throughout the tonal range); separate scratch and rumble filters; piano-key switching between mono and stereo reproduction; piano-key selectors for switching between the following types of operation: FM Broadcasting, FM Automatic Frequency Control; Tape Recorder; Gramophone 1; Gramophone 2.
Dimensions: 87mm high, 505mm wide, 24mm deep.
Choice of teak or Brazilian rosewood finish. Awarded the 1966 iF Prize for Industrial Design”
BeoMaster 1000 Product Details
Type Numbers
2302
2304
2317 (1966 - Dec 1972)
2318 (1966 - Dec 1973)
Designer
Please let us know
Manufactured
1964 - 1971
Colour Options
Rosewood, Teak, White, Oak
BeoMaster 1000 Product Specification
Power output: 2 x 15 W continuous 2 x 20 W music power Frequency range 30 – 25,000 Hz- +/- 2 dB Distortion <1% at 40 Hz – 1 kHz – 12.5 kHz / 15 W
Tone controls: Bass control: + 10 dB – 17 dB at 60 Hz Treble control: + 12 dB – 16 dB at 12.5 kHz Built-in stereo decoder Only type 2317
Wave bands: FM 88 – 108 MHZ RIAA amplifier: Built-in Voltage: 110 – 130 – 220 – 240 V Power consumption 20 – 120 W Dimensions H x W x D: 9 x 51 x 24cm Weight 5.5 kg Connections: Gramophone 1 Gramophone 2 Tape Aerial Speakers 2 sets
