Both Beovision LE 6000 and ME 6000 were equipped with Black Line picture tubes, which made the picture sharper. A toned-contrast screen in front of the tube enhanced the contrast level, making the picture more pleasant to watch. And Bang & Olufsen’s Colour Transient Improvement improved the sharpness of colour transitions, which eliminated irritating shadows. The powerful loudspeakers – under the screen on Beovision ME 6000 and to the side of the screen on Beovision LE 6000 – were based on the full-tone bass reflex loudspeaker system that gives sound power and fullness. Both were equipped with A2 and NICAM stereo systems.
They had Teletext that could be operated with the help of the remote control. The same remote control operated all video functions, if you connected a Bang & Olufsen video recorder.
Beovision MS6000 was basically an MX 6000, but the bass reflex loudspeakers were replaced by full tone units and it had no connections for Beolink® and A/V integration. It did however, have stereo loudspeakers and its equipment was otherwise similar to the MX 6000. It was controlled by the remote control Beolink 1000 handset and was available in a dark grey finish. Later editions featured the MS6000 in a silver-grey finish. Teletext was included, together with the option of Beo4 control.
The TV was an upgrade from Beovision ME6000 in 1996 and was a TV featuring all the fundamental Bang & Olufsen qualities, at the same time representing “simplification, innovation and common sense”. With the slightly tinted contrast screen and the VisionClear system with Automatic Picture Control, it offered excellent, sharp pictures under all lighting conditions.
The MS6000 could be placed on an optional motorised BeoStand and could be fitted with an optional BeoSat LM receiver.
Beovision MX1500 was a portable, remote controlled colour TV. It used a newly-developed 39cm flat-square picture tube and the special contrast screen ensured superior picture quality lifelike colours and the sharpest contrast – even in broad daylight. The MX1500 was ideal as a personal TV which could be used anywhere or as a TV set for a family which didn’t watch much television. It was great for use as a second set or as a TV which was moved from room to room. You could just take hold of the built-in recessed handle and move the 12,5 kg set around with you. Even the viewing angle could be adjusted to suit your own personal preferences; Beovision 1500 was designed so that it could be tilted when placed low down on the floor for example.
It came in four colours: bright red for the colourful, high-contrast home; elegant white as either a neutral or a highlight; distinguished silver-grey to radiate calm; and black to fit in almost anywhere.
Because of its more modest size, this great little performer didn’t have all the features of its big brother, Beovision MX3000.
Features:
Flat square picture tube – produced pictures in studio quality
Contrast screen – reduced effects of surrounding light and ensured clear conditions, even in broad daylight
Built-in support offered a perfect angle of viewing when Beovision 1500 was placed low… on the floor, for instance
35 channels for preset stations – the built-in memory guaranteed you favourite channel was always there on demand
Remote controlled channel tuning – one touch of the Beolink 1000 button and you could delegate search and tuning functions to the world of electronics
Full tone mono loudspeakers based on Bang & Olufsen’s many years of experience with small, compact loudspeakers. 2 watts sine power output
Optional built-in Teletext decoder (available as a separate option)
Clear and stable picture from PCs and TV games
Ready for cable TV
Front panel display made it easy to adjust sound and picture and clearly indicated which channel had been selected
Emergency operation – if Beolink 1000 had been misplaced, there was an on/off button on the set itself. The same button could be used to programme the channels if the terminal was not at hand
Connections for video and tape recorder, earphones, PC, TV games and decoder
Beovision MX2000 was a completely different kind of TV. In terms of design, colour and uses it was a departure from tradition. Beovision MX2000 was one of the most stunning and versatile television sets ever created.
Technically the TV was new at the time of its release because of its stereo sound, automatic search for channels and its remote-control. Visually the TV was remarkable because of its contrast screen which reduced the inconvenience of incident light and left the TV dark and discrete when turned off. When turned on the TV was reduced to its function – that of displaying a picture. David Lewis’s design on the MX2000 was detailed and highly aesthetic which made the TV look good from all angles. Because of the pyramidal shape the TV was suitable for placement in corners. The set was a 50cm stereo colour TV that you could literally take with you. Bang & Olufsen’s special VisionClear system ensured that lifelike colours and the best contrast conditions were always obtained… both night and day. And Beovision MX2000 had so many different positioning possibilities that the perfect sound and picture quality could be taken advantage of and enjoyed to the full. Beovision MX2000 was controlled by the remote control Video Terminal. The TV could work with any video tape recorder but the Beocord VHS 82 was a specially designed video recorder that was created to harmonize with the MX2000. Not just when it came to operation but also in design and colour. And the complete, remote-controlled video system could deliver much more than perfect pictures with sound. Beocord VHS 82 was also a stereo audio tape recorder that offered up to eight hours recording on one tape, with hi-fi stereo quality playback. The choice of colour for MX2000 was a matter of personal taste, and style. The choice was yours: rich red for a home abounding in colour and striking contrasts; elegant white; distinguished metallic grey; or black to go with most colour schemes. Beovision MX2000 wasn’t portable TV but it was easy to move around. Grab hold of the built-in handle and Beovision MX2000 went with you. The TV could be put most anywhere. On the floor, shelf, table, window sill and so on. The built-in support on the base even made it possible to tilt the TV backwards. This ensured for a natural, perfect viewing angle when placed low on a floor. The set could of course be put on the practical TV stand which was equipped with solid, easy rolling wheels. And the special mounting platform made it possible to swivel the TV from side to side. The complete remote controlled – Video Terminal – video system could be grouped on a video stand to create one space-saving piece of furniture. It too had solid, easy rolling wheels and allowed the TV to be swivelled from side to side. Beovision MX2000 won the ID Award in 1986. Beovision MX2000 could be both manually operated or operated by remote control. The concealed panel in the top of the TV adjusted all sound and picture functions. But once adjustments to volume, sound, balance, bass, treble, contrast, colour balance and brightness had been made according to the viewer’s wishes and surrounding conditions, the Terminal took over day-to-day usage. Fine-tuning of TV channels, which is generally a once-only task, and stereo width-adjustment were also part of manual control. It was also possible of course, to change over stations and turn on and off the set with the controls on the panel. “Beovision MX2000 gives the impression of lightness and extended freedom of positioning. Now, all of a sudden, the TV could be positioned anywhere – even in the middle of a room” The MX concept began as Beovision M20 in a modest grey cabinet and without a contrast screen. It sort of heralded what a monitor television by Bang & Olufsen might look like. Basically, a monitor is just a screen with a box around it. In the mid-1980s, the emphasis was on the picture and efforts to achieve a monitor look.
The clean screen.
Bang & Olufsen elected to make the television slim by placing the loudspeakers below the screen. This broke with the practice of several decades of placing the loudspeakers at the sides of the picture tube. The latest MX 8000 model incorporates active loudspeakers and the sound has become even better. Previously, and with its Beovision MX 5000, Bang & Olufsen introduced yet another element that, so far, is unique to he company: a motorised base. Now the television turned to face the viewer – not vice versa. Bang & Olufsen had a lot of difficulty explaining Bang & Olufsen’s picture quality, which comprises many individual factors that have been optimised over the years. In1985-86, the decision was made to combine everything that came under the term
“picture quality” into a single concept – VisionClear.
MX2000 was born out of the ideas for the Beovision M20 and was further equipped with VisionClear, including a contrast screen. The MX family became extremely popular and remains so (it is still being produced and sold). Designer David Lewis created a cabinet that fitted around the back of the picture tube, thereby achieving the purely psychological effect of making the picture tube appear smaller than it actually is. Beovision MX 2000 gave the impression of lightness and extended freedom of positioning. Now, all of a sudden, the TV could be positioned anywhere – even in the middle of the room. Bang & Olufsen’s first television in the the US market was a variant, Beovision MX 5000 US. But, because of sales factors and market conditions at the time, it was not a great success. The many features of the Beovision MX2000 were market leaders in their day; however, many of these features are still included, even today, in Bang & Olufsen television sets:
In-line black matrix picture tube.
Part of the VisionClear system which reduces the chance of unintentional mixing of picture colours and ensures perfect pictures throughout the life of the set
Automatic Cut-Off.
Also part of the VisionClear system. This is an electronic circuit that regulates colour balance 50 times a second. A patented Bang & Olufsen circuit that ensures lifelike colours… automatically, and constantly
Contrast screen.
The most visually stunning part of the VisionClear system. At the time of the MX2000 introduction, this was a newly-developed Bang & Olufsen screen that ‘tones down’ the effect of bright light. It ensures that colours are bright and that there is optimum contrast – even in daylight. The rectangular contrast screen provides a wider picture and thereby creates the impression of watching a larger screen Remote-controlled station tuning based on digital technology. Search and tuning of up to 100 channels was carried out automatically after a couple of touches on the Terminal 32 permanent channels and 3 AV channels. Built-in memory which ensured that your favourite channels were right at hand. A touch of one button was all that was needed – and still is right up to the 21st century! Fine tuning: a help feature that was activated manually on the MX2000 when reception conditions were poor or if a TV signal’s frequency was non-standard e.g. in the case of cable TV, home computer etc.. Fine tuning could also be stored in the TV’s memory Display: a small illuminate display in the upper right-hand corner of the screen provided clear responses to almost all orders received from the Terminal Log Line speaker system: a special principle that ensured perfect, lifelike sound reproduction in very compact speakers. The power output was 7 watts sine Stereo-width adjustment: creating the illusion of increased distance between the speakers and providing a wider, fuller sound image Enhanced mono broadcasts: the special stereo-width circuit also improved the sound quality of mono broadcasts Teletext decoder: an optional extra which with a couple of touches on the Terminal gives direct access to the latest news, TV listings, weather forecasts, sports results and so on Built-in clock: during Teletext broadcasts, the correct time can be called on to the screen. This was shown discreetly in the upper right-hand corner On top of this was a wealth of connection options. Beovision MX2000 was awarded the Danish Design Centre’s IP Prize in 1986.
The prize-winning MX series was a winner in more ways than one. Quite apart from its stunning looks, it was packed with Bang & Olufsen technology to give you breathtaking picture quality. The MX3000 had a 51cm flat-square picture tube, giving you a great view from almost any angle. It wouldn’t fade away in strong sunlight either, thanks to the contrast screen which kept the picture bright and clear. And, with automatic colour tuning 50 times per second, the colours were always natural and true to life.
Pure sound
A superb picture needs top-quality sound. You obtained both with the MX series. The special Log Line speaker system gave you extraordinary lifelike sound reproduction from very compact speakers. Your stereo videos gained an extra dimension from the stereo width adjustment, which provided a wider, fuller sound image. And to receive stereo TV broadcasts, all you’ll need to do is install a NICAM decoder. There’s good news if you’re planning a round-the-house TV, video and music system too – the MX3000 could team up easily, and also gave you an extra pair of speakers on demand.
Reach for the stars
Are you planning to receive the myriad of entertainment options which satellite TV will eventually offer? Just add Bang & Olufsen’s parabolic ‘dish’ antenna and the MX3000 is all set. You’ll also find the digital search and fine-tuning system invaluable when so many TV stations are competing for your attention. The system was first introduced on the L and LX TVs; working on the same principle as an electronic tune radio, it was a great success.
One remote control, multiple connections
If you add to your Bang & Olufsen TV with a B&O VCR, or broaden your horizons and go for the complete round-the-house system, you’ll still need just the one neat remote control. The Beolink 1000 remote control unit talks to tape recorders just as easily as it does to video recorders. You won’t be short of connections either – the MX3000 can accommodate a personal computer, video games, headphones and a loop amplifier for the hard of hearing.
Beovision MX 3500 appeared so light that to think of it hanging on the wall would have been quite logical. In fact, like other MX TVs, it could (and still can) be done. TV could then be watched from any angle; the set could be turned horizontally and adjusted vertically. You could also place the MX 3500 directly onto the floor. Or on one of the specially designed stands, which fully complimented such a handsome TV.
Beovision 3500 was born with perfect razor-sharp pictures colours and automatic contrast regulation. As well as quick-search Teletext. And stereo decoders that let you receive concerts in the finest stereo sound, regardless of the stereo system transmitted.
As with every Bang & Olufsen TV, you could connect Beovision 3500 to video recorders, extra loudspeakers, headphones, decoders, personal computers, TV games consoles and amplifier loops for those with hearing impairment. And if you wanted, you could also have Bang & Olufsen’s satellite receiver built into the cabinet.
You could choose from five different, clear colours for Beovision MX 3500; from the outright daring to the highly discreet.
The MX range was the first to bring the TV out into the open and it continues to show alternative ways of living with television. Beovision MX4000 was the little brother of the MX6000 having the same functions but with some minor differences when it came to sound and picture. The speaker was not a 2-way bass reflex as in the MX6000 but a 2-way Logline speaker.
Complete with a choice of colours, the specially-designed wall brackets of the MX 4000/4002 gave you the option of placing the MX on the wall. The placement options of the MX 4000/4002 also included a motorised stand with room for your VCR/DVD player.
The TV had a 51cm screen, the same features as MX 6000, but with conventional loudspeakers, optional wall bracket, available in pearlescent shades of: green, blue, red, grey, black or glossy white. With a Beovision MX 4002 as an extra TV in the bedroom, you could access the video and satellite options of the Avant in the living room or wake up to music from the radio and CD of the Ouverture or BeoSound 3000. Beovision MX4002 was replaced with the MX4200 in 2003.
Beovision MX 4000 was the smallest television of Bang & Olufsen televisions in the late 1990s and right up to 2003. It had a 51cm screen, and was equipped with the latest generation of the Black Line picture tube, contrast screen and VisionClear technology. Together they provided an optimum picture quality under any lighting conditions – even when faced with direct sunshine. In spite of their modest size, the log-line loudspeakers located under the screen gave full-tone stereo with great depth and amplitude. MX 4000 had both A2 and NICAM Stereo decoders and Teletext-functions.
Beovision MX 4000 was probably the most flexible television as far as placing was concerned. You could place it directly on a floor, and using the spring bar underneath the set you could tilt it in order to improve viewing angle. You could place the MX 4000 on the wall with an optional bracket, which also came as a motorised version. When on the wall, you could tilt the screen downwards, towards a bed, for example. Or you could of course place the TV on a stand on the floor, or on a stand on a table. Both stands were available in motorised versions and the floor-stand had an optional video-shelf available. The motorised stand was operated via the Beolink® remote control, that also operated the television and video (shown) as well as all B&O audio systems and light control units.
Beovision MX 4000 was a great addition to a multi-room Beolink® system, where it acted as one link itself and could play audio from the audio system that was located elsewhere in your home. And on the other hand, you could direct the sound from the television to the speakers of your audio system.
It had the same beautiful, sleek and modern design as all other Beovision televisions; the design of which has even been compared to sports cars!
MX Design
Filling a television with every conceivable gadget that technology offers is easy enough. What’s more difficult is identifying what really improves the overall experience of watching TV and eliminating the things that don’t. That’s the philosophy behind the MX range. In both form and function, it’s a clear-cut case of less being more.
Complete with a choice of 6 colours that included green and white, the specially-designed wall brackets of the MX 4000 gave you the option of placing your MX on the wall. The placement options of the MX 4000 also included a motorised stand with room for your VCR/DVD player. The TV was controlled by the provided Beo4 remote control.
Beolink® – Beovision MX 4002
Beovision MX 4002 was the Beolink® variation of the MX 4000. This model gave you numerous options when you were setting up your Beolink® system and needed an extra television in your bedroom, study or kitchen. The MX 4002 was available in the same colours as MX 4000 and had the same placement possibilities as well.
** Beovision 4000/4002 at the time of its introduction, was fitted with a plexi-glass (acrylic) screen. However, since the late 1990’s, the model has a glass screen, the same as the rest of the model range.
Complete with a choice of colours, the specially-designed wall brackets of the MX4000/4002 gave you the option of placing the MX on the wall. The placement options of the MX 4000/4002 also included a motorised stand with room for your VCR/DVD player.
The TV had a 51cm screen, the same features as MX6000, but with conventional loudspeakers, optional wall bracket, available in pearlescent shades of: green, blue, red, grey, black or glossy white. With a Beovision MX 4002 as an extra TV in the bedroom, you could access the video and satellite options of the Avant in the living room or wake up to music from the radio and CD of the Ouverture or BeoSound 3000. Beovision MX4002 was replaced with the MX4200 in 2003.
MX Design
The last word in a fine story, the MX4200 looked modern at its introduction despite being modelled on an 18 year old design. A testament to the vision of David Lewis.
Beovision MX4200 is a 52cm 4:3 television set, and is based on an updated chassis of Beovision MX4000/4002. It has the same design line as the previous MX model range but includes the following improvements:
Improved picture quality
16:9 format handling
Set-Top Box Controller as standard
Camcorder connection
Theft protection
MasterLink module (optional)
RF Modulator (optional)
Part numbers for Beovision MX4200:
MX4200 1813123 1813122 1813124 1813125
MX4200 with MasterLink 1813083 1813082 1813084 1813085
MX4200 with ML & RF Modulator 1813103 1813102 1813104 1813105
Motorised Wall Bracket 1408966
Accessories for Beovision MX4200 include the following:
At the time of its introduction in 1988, the 66cm Beovision MX4500 was the largest TV in B&O’s innovative and stylish MX Series. But it was not just a pretty face: within the elegant cabinet was the same technology as that featured in the classic LX series. The flat-square picture tube featured B&O’s advanced VisionClear system. Which means that, 50 times a second, the colour balance is automatically regulated to give you the most lifelike picture possible. The VisionClear system also included a Contrast Screen, which tones down the effects of strong light to ensure that your TV picture stays bright.
A new interest to Teletext was given with B&Os highly advanced computer module, which allowed you to flip through the pages without having to wait. You could also store four pages permanently and flash them up just by pressing the Teletext button on the remote-control. Say you regularly like to be updated on the weather, TV programmes or the sports news – you could have
them all at your fingertips with MX4500.
Equipped for tomorrow’s world
A NICAM decoder could also be installed in order to take full advantage of stereo broadcasts.
The choice is yours
Although the MX4500 was developed for the Beocord VHS 82.2 VCR, it also, needless to say, was perfectly happy to partner other video recorders. And there was a wealth of connecting options, including B&O’s Beolink System.
