Terminal 3000 Remote Controller
An infra red controller for use with the Beosystem 3000, the Terminal 3000 was a simple one way remote allowing selection of source and volume and a limited amount of control of the sources. This era of controls tended to be specific to one particular device ad were superseded by the Beolink 1000 type remote […]
An infra red controller for use with the Beosystem 3000, the Terminal 3000 was a simple one way remote allowing selection of source and volume and a limited amount of control of the sources. This era of controls tended to be specific to one particular device ad were superseded by the Beolink 1000 type remote which provided a common remote for all products.
Dimensions: 6 x 4 x 17cm
Radio programmes: 5 FM
Other programmes: PH-TP (CD)
Beocord Controls: 6
Beogram Controls: 1
Compact Disc Controls: 1 (TP)
Volume Control: Yes
No downloads available.
Photo Gallery
No gallery images.
