Posted on
AV Terminal
Bang & Olufsen AV Terminal
Beolink 1000 was Bang & Olufsen’s entry remote control terminal, released in 1986. Its bigger brothers were the two-way Beolink 5000 and Beolink 7000 terminals. It originally came in a number of guises: released in 1987 was Terminal A, followed by Terminal V and then Terminal AV. Their purpose was to control the audio section of various hi-fis (Terminal A); the video sections (Terminal V) and combined functions (Terminal AV).
From the Commander to the Beolink 1000 – a leap in ideas
Beomaster 2400’s new element was the Commander – the remote control – which no High-Fidelity producer had even dreamed of making before. In America, however, remote- controlled TVs had already become a reality and in Europe, the first TV commanders, with a plethora of buttons, had turned up in Germany.
Bang & Olufsen’s idea was not to supply remote controls for its systems, it was to provide the user with easier operation – to put the entire selection of sound and picture in users’ hands. Although today, this is perhaps self-evident, this was not the case at the time. Nobody had so far dared to pursue such an obvious concept.
It did not take long for the idea to take root. Soon afterwards, all Bang & Olufsen’s systems enabled the user to operate the system from a commander.
The Bang & Olufsen Idea Group insisted that users should be able to operate the commander with one finger on one hand, the thumb. This was vastly different from the commanders manufactured by other producers where the many buttons meant that the user had to hold the commander in one hand, the manual in another while the index finger of the third hand pressed the button selected by the eye.
The concept was dubbed ‘the feel commander’. This meant that the TV could be operated by the thumb on one hand – almost as if the user was feeling his way through a new type of Braille, allowing the eye to concentrate on the essential, the picture.
The culmination of the development of the idea of a ‘total commander’ came in 1985 when David Lewis designed a Beolink terminal where the user, without using his eyes, could control picture, sound and light by applying a slight pressure of the thumb. Incredibly, it could be used in all the rooms of a house. This later system, known as Beolink®, eventually incorporated most of Bang & Olufsen’s audio and video products.
The Beolink 1000 family of remote controls is made up of four unique products; all similar in appearance, but each was brought out at a different time, for a variety of differing functions. First there was the Audio Terminal (or ‘Terminal A’). This was then followed by both the ‘Terminal V’ (used by Beovisions LX2800 and LX2500) and then the ‘Terminal AV’. Lastly was the Beolink 1000 as we recognise it today. Both of these latter Terminals are shown above.
The Audio and Video Terminals are similar in appearance to each other. However, they both accommodate different sets of buttons. With both these controls the bottom plate is stamped to differentiate them as either an Audio or Video Terminal. Size-wise, both Terminals are around 1,5cm shorter than a (current) Beolink 1000 Terminal.
Beolink 1000 Mk III was the last model produced and does not include a ‘turn’ button. To turn over the tape of your Beocord cassette deck, press SHIFT + SOUND.
In order to access ‘Balance’ press SOUND twice and then use the volume up and down to adjust.
To alter ‘Treble’, press SOUND three times and adjust in the same manner; for ‘Bass’ press SOUND four times.
To save your new settings, press SOUND and then STORE.
In comparison, the Terminal AV is about 1cm longer than a Beolink 1000. The Terminal AV could operate both audio and video and again was released before Beolink 1000. All three Terminals were black and dark grey coloured.
With Beolink 1000 (introduced in 1986), there have been six models. Beolink 1000 Mk 1 and 2 were also black and dark grey. The Mk 1 version would not work with light controllers such as LC1. However, Mk2 could, by simply pressing SHIFT + LINK more>>
Since its introduction in 1986, the Beolink 1000 family of remote controls has been able to control all subsequent Bang & Olufsen products – both audio and video. Beo4 is a direct descendant of these remote controls, together with its (former) smaller brother, Beo1.
Most infra-red remote controls work on a 40KHz carrier. Only Bang & Olufsen and a handful of Sony and Kenwood products use 455KHz as the carrier frequency. This more powerful frequency allows the Terminals to command products from a greater distance and often, it is not a requirement to ‘fire’ them directly at the items’ sensors.
Posted on
Video Terminal
Bang & Olufsen Video Terminal
Your key to operational comfort
Around half of Bang & Olufsen’s colour TVs in the late 1970’s and early 1980’s were supplied complete with an advanced remote control handset – the Beovision Video Terminal. It was called a Video Terminal because it did so much more than just switch on the set or change programmes for you.
For normal entertainment viewing you simply touched the required programme number. Volume level, colour strength and picture brilliance could be adjusted up and down as desired – or returned instantly to a pre-determined norm by pressing RESET. You could even mute the sound instantly (perhaps if the phone rang) or check through the programmes showing on all the other channels – all at the touch of a single button.
The same terminal also controlled Teletext viewing on sets fitted wit the optional Teletext circuitry. And for those who chose to include Bang & Olufsen video cassette recorder (like Beocord Video 8800) as part of their domestic entertainment system, the controls for operating all the primary VCR functions were also right there in your hand. The Terminal let you make recordings, play the tape or wind it to any position without having to move from your comfortable armchair.
The Beovision Video Terminal was supplied with, for example, Beovisions 5100, 7100 and 8100. The Terminals for other models in the B&O range included all these keys and functions plus three more. Of course, it was still possible to operate a Beovision even if the remote Terminal was temporarily mislaid or out of action. The set’s direct controls were mounted in a hinged compartment behind the loudspeaker grille. The panel pivoted outward at a touch and in addition to the direct function controlled governing picture and sound adjustments and programme scanning, it contained the buttons for pre-tuning the buttons. Your dealer could use these to tune the set as part of the installation service. Thereafter you would probably never need to touch them again.
Posted on
BeoSound 1 (2001)
Bang & Olufsen BeoSound 1 2001
” BeoSound 1 is maximum expression. Simple, elegant and easy to move around. Use it in your home, in the office, or bring it with you on holiday. Sleek and sturdy the BeoSound 1 fits in wherever you have a desire for great sound “ B&O Catalogue 2001 – 2002
With a tough, robust construction, BeoSound 1 is constructed to be moved and used anywhere. From the home to the work place, and everywhere in between, it offers you CD and radio with the simplest of plug-and-play functionality. And hidden behind the compact design lies a set of exceptionally powerful loudspeakers, capable of producing a dynamic sound far beyond the modest dimensions of the cabinet.
Sound
From intense rhythms to laid-back listening – the impressive three-way loudspeaker system hiding behind the cool aluminium front will handle the deepest bass and highest notes with ease. With its integrated handle, BeoSound 1 is easy to pick up and move around. It’s small enough to fit in anywhere, but still big enough to power a party with a sound that’s true, pure and clear. With its integrated handle, BeoSound 1 is easy to pick up and move around. It’s small enough to fit in anywhere, but still big enough to power a party with a sound that’s true, pure and clear.
Design
Life can be rough, but BeoSound 1 is built to take all the knocks. Tough, robust and solid, it’s a piece of musical freedom that’s always ready for take off. Do you want BeoSound 1 to stand out or blend in? Should it make a statement or become a part of its surroundings? The perforated aluminium front comes in 5 different colours – natural aluminium, black, blue, green and russet – which lets you decide for yourself.
Operation
Just plug it in and BeoSound 1 is at your command. All the buttons are concealed behind the front panel and in a layout that’s easy to understand and simple to use. BeoSound 1 can also be controlled via a Beo4 remote control. The discreet display keeps you in touch with what source you’re listening to.
CD and radio
Press “Load” and watch the CD holder flip up to accept your disc. Or switch over to Radio and listen to one of the 60 stations that can be stored in the programme memory. And if you ever need better reception, the aerial will rise at the touch of a button. BeoSound 1 was updated mid-October 2002 with an addition of a Wake Up Timer. There is also a new colour to the existing range – violet – with jade green being discontinued.
BeoSound 1 wins Japanese design award
In late 2002, the monthly magazine Nikkei BP Design marked its 15th birthday by conferring gold, silver, bronze and special “Nikkei Design” awards. Bang & Olufsen won an impressive bronze award for BeoSound 1. In their citation, the judges emphasised the striking design and that Bang & Olufsen are challenging the market for portable music . They also emphasised that the relatively low price will appeal to young people, while the straightforward functionality will “appeal to the older generation”. (From Beolink magazine 5, March 2003) BeoSound 1 – a golden opportunity to purchase the first models on the Internet – Press Release August 2001 Reach out for BeoSound 1 on the Net – Limited edition of new movable sound system may only be ordered via Internet ” On 15 September the first ever Internet event from Bang & Olufsen will be launched. Running simultaneously with the release of a newly revised home page, this special event will feature on-line reservation of a limited edition BeoSound 1. The newest audio product from B&O integrates a CD player, FM radio and powerful active loudspeakers in a surprising design. Encased in an exclusive Internet-only russet yellow colour, these 1,000 units will be available for pre-launch reservation only through visiting the Bang & Olufsen Web site.
On-line reservation
On-line reservation of the limited edition BeoSound 1 takes place quickly and simply; the visitor only needs to click on the appropriate photograph and fill out the registration fields that appear next. Filling out his or her name, address, e-mail and the like, he or she will receive a special BeoSound 1 screen saver as well. The 1000 units will be reserved on a first-come, first-served basis. When they are no longer available, the special BeoSound 1 screen saver will be provided to event visitors, along with an invitation to visit their local B&O dealer to receive a product demonstration.
Choose their own dealer
One of the most important elements in this campaign is that the visitor chooses from which Bang & Olufsen dealer he or she will purchase the physical product. It is through this dealer, and not Bang & Olufsen a/s, that all purchase-related elements will take place, including delivery and after-sales service.
Certificate and individual numbering
A special welcome envelope containing a Special Edition Certificate will accompany each product, in addition to a special silver label indicating the individual production number of the product, such as 1/1000, 2/1000, 3/1000 and so on.
Delivery upon market launch
Whilst the customer may reserve a BeoSound 1 already from 15 September, the delivery will not take place until the actual launch of the product in his or her market. This rolling launch process stretches from week 45, 2000 until week 6, 2001, dependant upon market. ”
BeoSound 1 with timer: a movable music centre
“Place your BeoSound 1 where you like. The compact design enables you to bring it with you anywhere. BeoSound 1 gives you an excellent sound experience no matter how near or far you are from the speakers. The sound is optimised and no additional settings.”
CD operation:
All buttons on BeoSound 1 are located at the back of the operation panel together with the CD compartment. Press LOAD to raise the CD compartment. With the CD compartment raised, offer the CD into the slot provided. Always load the CD with the CD label facing upwards. Press LOAD again to lower the compartment or just press CD to play your CD. If no CD is loaded when you press one of the CD buttons, the CD compartment raises, ready for you to load a CD. When the CD has stopped playing and no commands have been received for 30 minutes, BeoSound 1 switches to standby.
Radio operation:
You can store up to 59 different radio stations. To step between stored radio stations, the programme number or frequency must be shown in the display. To listen to the radio, just press one of the radio buttons, the radio will start playing on the radio station you last listened to. You can extend the built-in aerial by pressing the AERIAL button.
Features
the speakers will be muted when headphones are connected. BeoSound 1 presents essential audio sources in a compact and easily operated way the compact design and the built-in handle lets you to take the music with you remove the cover at the back of BeoSound 1 and connect the headphones to the socket the radio finds the first available station the first time you press the RADIO button press AERIAL to extend or retract the built-in aerial. You can also push the aerial down manually if no CD is loaded when you press CD, the CD compartment raises automatically, ready to be loaded with your favourite CD you can adjust and store the volume level at any time. The display will keep you informed of what you have chosen and you can set the display light to the level suitable for you. Also, choose the display mode you prefer for radio stations; programme number or frequency
Timer facilities
BeoSound 1 has a built-in 24-hour clock. If you wish to make use of the Wake-up Timer function, you must first make sure that the built-in clock in the BeoSound 1 has been set correctly. If BeoSound 1 has been disconnected from the mains for about 30 minutes, the clock must be set again. You can program BeoSound 1 to wake you in the morning. The Wake-up Timer is a once-only timer. Like an alarm clock it is deleted once it has been executed. While the Timer is being carried out, the time is shown in the display. When you operate or switch off your BeoSound 1, the display returns to the mode you have chosen. Once you have made one Wake-up Timer, BeoSound 1 automatically suggests the time you entered for the latest Wake-up Timer in the display when you enter a new one. Wake-up Timers can of course also be deleted again. When you choose radio as your source, the radio will start playing on the station you last listened to. If you choose CD as your source, it is essential that a CD is first loaded. If you do not choose a source, the radio, by default, will be used for your Wake-up Timer.
Beo4 operation
Although designed primarily for close-up operation, BeoSound 1 can also be operated from a distance. The Beo4 remote control operates all the primary functions in your BeoSound 1. With Beo4, you can switch on or off, select radio programmes or CD tracks and adjust sound. You can also use the Beo4 remote control to enter a Wake-up Timer. This is carried out while BeoSound 1 is in standby by pressing the MENU button on Beo4. Pressing the red button on the Beo4 remote control will show the time in the display. Note that if the clock has not been set, or BeoSound 1 has been disconnected from the mains for approximately 30 minutes, it is not possible to set a Wake-up Timer. The clock must be set first. You can call up the settings for the Wake-up Timer in the display to check the time or to delete the Wake-up Timer.
Protecting your BeoSound 1
You can choose whether or not to activate the PIN code system as a security measure against unwanted usage or theft. By activating this, BeoSound 1 is protected with a four-digit PIN code. The use of a PIN code means that if BeoSound 1 is disconnected from the mains for more than 30 minutes, the system can only be activated again by keying in your own personal PIN code. If the PIN code is not entered, BeoSound 1 automatically switches to standby after 3 minutes. If a wrong PIN code is entered, you are allowed five attempts to key in the code, after which the system is switched off and cannot be switched on for 3 hours. Should you forget your PIN code, it is necessary to contact a retailer who can assist you in receiving a Master Code from Bang & Olufsen. You need this code in order to reactivate your BeoSound 1. Note that if a wrong code is entered a second time, the cue ‘Err’ appears in the display and you must enter and confirm the code again. If you accidentally store a wrong digit, pressing STOP will delete all digits again and you can enter new ones. You may change your PIN code at any time. However, for security reasons it is only possible to change the PIN code five times within a period of 3 hours. You must enter your current PIN code before changing the code.
Changing your BeoSound 1 cover:
You can change the front cover of your BeoSound 1 to complement your new room décor by using the following tips. Like always, if you’re unsure about what you’re doing then consult a professional Bang & Olufsen technician who will be able to do this task for you easily and safely. Use the floor or some soft furnishing to avoid damaging your unit: With the BeoSound 1 isolated from mains electricity lie it down on the floor with the front panel facing upwards and the controls away from you, at the top Press firmly but gently on the outside rim of the front cover about one-third of the way down from the top; at the same time pushing the cover up, away from you This will release the mechanism and the cover will slide up and off the front of the unit To replace the cover position it onto the front of the unit- ensuring that the inner black plastic ‘screen’ is positioned in the sliders within the metal cover Gently place the cover back into its cut-out grooves on the unit, about one centimetre or so from the base Firmly but gently push down the cover towards you. The cover should gently ‘snap’ into place!
BeoSound 1 Special Edition
In 2001, before BeoSound 1 was available to purchase in High Street stores, a gold-coloured version – limited to 1000 models – could be bought only from the Internet. Needless to say, this limited edition was sold very quickly and at the time was very desirable. However, as the CD format has sadly lost it’s appeal, the value of these units has declined to the point of them only being worth what someone is prepared to pay – which isn’t much!
Posted on
BeoSound 2 (2016)
Bang & Olufsen BeoSound 2 2016
Captivating no matter where you place it, this powerful home speaker sounds as beautiful as it looks.
Aesthetic functionalism
Beosound 2 is designed for flexibility. Delivering the morning news from the kitchen table or playing discreetly from the living room floor. With its clean lines and small footprint, it has an adaptable design that fits in everywhere in your home.
The essence of control
Beosound 2 has a built-in proximity sensor that makes the control panel light up when your hand is hovering over the controls. The top of the speaker works as a minimalistic control panel. Simply tap one of the four favourite buttons to start one of your preferred radio stations or playlists, turn the wheel to adjust the volume and tap on one of the arrows to change tracks.
Active RoomSense
Beosound 2 works out where it is in the room to give you perfect playback, every time. Ensuring bass, mids and highs are never too overpowering or weak. Wherever you place it, it gives a standout performance. No muddiness. No fuzziness. Just pure, clean sound. As the artist intended.
A seamless piece of beauty
Crafted in high-grade aluminium with incredible attention to detail. But our material choice go well beyond aesthetics. It also provides superior acoustic properties thanks to its material stiffness and seamless surfaces that eliminate any distortion of your sound.
Posted on
BeoSound 3000
Bang & Olufsen BeoSound 3000
” BeoSound 3000: the design may be a Bang & Olufsen classic, but BeoSound 3000 and BeoSound Ouverture refuse to rest on their laurels. Access to new musical sources and fresh loudspeaker options ensure that the concept remains an open invitation to make something special out of your music.
With BeoSound 3000 everything is upright and out in the open so that you can see how it works and understand how it reacts when you press its buttons. Even the simple act of placing a CD has been made part of the overall experience and enjoyment. It combines radio with an advanced CD player, and – as something new – lets you access your digital music files directly from your own PC. As well as offering radio and CD, the BeoSound Ouverture also has an intelligent tape function ” (B&O catalogue 2001 – 2002)
Both products can be put together with any BeoLab loudspeaker – which gives you the option of an impressive set up on matching stands with two BeoLab 4000 speakers, or a more compact solution between newly redesigned BeoLab 2500 speakers.
With a design that’s undoubtedly becoming a Bang & Olufsen classic, BeoSound 3000 and BeoSound Ouverture are an open invitation to make something special out of your music. BeoSound 3000 is the former Beocenter 2300 (first introduced in 199) but with a whole host of new electronics, features and look including a larger metal CD ‘cover’ and N.MUSIC. The new styling was released to the UK market in September, 2001.
With BeoSound 3000, everything is upright and out in the open, so that you can see how it works and understand how it reacts when you press its buttons. Even the simple act of placing a CD has been made a part of the overall experience and enjoyment.
It combines radio with an intelligent CD player that can name your favourite 200 discs, store your own preferred track sequences for them or skip unwanted ones permanently. With the latest Beolink® PC2 software application, you can also access your digital music collection directly from the BeoSound 3000.
Features
Bring new life to old CDs by changing their track sequence with the Random Play function. Or program it to skip over any unwanted tracks and to play the ones you want, in the order you prefer. Name your favourite 200 CDs and store your own track preferences for them in the extended memory and the BeoSound 3000 will remember it the next time you play one of the CDs. With the CD function of the BeoSound 3000 you’re also able repeat a desired passage of a CD, whether it is within the same track or stretching over a number of tracks.
There’s room for up to 60 pre-set stations on the BeoSound 3000’s intelligent AM/FM radio. You can also name each individual radio station, to give you a complete overview of your radio listening. With the BeoSound 3000 you can wake up to your favourite piece of music. The BeoSound 3000 can be programmed for the entire week and will automatically turn itself off again after playing for any length of time you choose.
Sliding Doors
Just raise a hand and watch as the glass doors glide silently aside. It’s the BeoSound 3000’s way of saying “welcome” and reveals that a special experience is about to begin. Of course, a simple on/off button would do, but then what would be so special about that? Beocenter 3000’s unassuming rubber key pad hides a contact foil, which, in turn, covers a matrix of vertical and horizontal cords. When a control is pressed, the cords connect and the microprocessor is activated.
Placement
It’s a dream come true – a music system that can fill your life with music without filling your home with equipment. The flat upright design of BeoSound 3000 means that it’s slim enough to sit by itself upon the narrowest shelf or light enough to be hung directly on a wall with any pair of loudspeakers in the BeoLab range.
Setup
It used to be that your music system was placed in one room in your home and you had to go there to listen to it. Not anymore. With Beolink®, you can place extra loudspeakers in any room in the house and access the musical options of your BeoSound 3000. The BeoSound 3000 is also equally at home in a Surround Sound setup and will give you an unmatched sound experience.
Internet Music
There’s so much good music on the Internet, but until now you had to be in the same room as your computer to enjoy it. Not anymore. With the latest Beolink® PC2 software application, you can access your digital music collection directly from the BeoSound 3000 in the living room – and send it from there to any other room in the house via the Beolink system.
How the glass doors work
The glass doors on the BeoSound 3000 and BeoSound Ouverture are opened and closed by steel wires driven by an electric motor via a gearbox. The motor is triggered by an infrared system that detects your approach.
Mounting Options
Posted on
BeoSound 3200
Bang & Olufsen BeoSound 3200
BeoSound 3200: the new music system with a warm welcome and cool intelligence
“BeoSound 3200 lights up in a soft glow of anticipation as soon as you reach out with your hand. Everything is out in the open so that you can see how it works and understand how it reacts”
BeoSound 3200, has a Hard Disk Drive with the capacity to store up to 396 compact discs. The CDs are stored in four groups of 99 and each group can be edited and named, in order to facilitate the easy location of your music. All other main functions are as the existing BeoSound 3000.
” Technology may be the foundation of the experience, but it should never get in the way of the senses. It’s the simple understanding that has created the concept behind BeoSound 3200.” It integrates a unique CD memory function that can store up to 396 of your favourite CDs in four individual groups. For simple and effective operation, each group is designated a colour that matches both the coloured buttons on the control panel and those on the optional Beo4 remote control you can choose to store an entire CD or just your favourite tracks and each entry can be named for easier recognition. Groups can be arranged according to type or be designated to different members of the family.
While the technology behind BeoSound 3200 is new, it retains a characteristic Bang & Olufsen personal feel. The glass doors slide open at a wave in an invitation to be used . Everything is upright and in the open, functions are clearly displayed and easy to understand. Even the simple act of placing a CD has been made part of the overall enjoyment.
BeoSound 3200 may be placed on a wall, positioned on a shelf or on the floor on a floor stand. When placed on a self or table, the system has a natural 13 degree slant for easier viewing and control. It may be used with any BeoLab loudspeaker enabling a number of impressive setup possibilities. It could be place between a pair of BeoLab 2500 active loudspeakers for example, or on matching stands with BeoLab 4000.
Features:
BeoSound 3200 is an audio system embracing CD, radio, CD memory and digital music files via Beolink®. It comes in one colour – aluminium and black – and can be positioned in different ways.
Placement
BeoSound 3200 may be positioned on the wall using a discreet (optional) bracket, placed on a shelf or displayed on one of two dedicated floor stands .
BeoSound 3200 Press Release 1 – February 2003
Digital Jukebox
The new BeoSound 3200 sees Bang & Olufsen introduce new technology that allows storage of almost 400 CDs – giving you the chance to create their very own digital jukebox.
Bang & Olufsen is bringing out a new system that allows you to record a CD as it plays. This gives the BeoSound 3200 the capacity to reproduce ‘first play’ quality of over 4,000 tracks. By creating technology that memorises almost 400 CD compilations, Bang & Olufsen is revolutionising the way we use and store CDs.
Music Selection
The technology is such that you will be able to select the tracks to be recorded, freeing up memory for the favourites only. The system will also allow you to file the CDs into 4 different personalised categories, be it Jazz, Classical, Dance or Hip Hop, allowing you to match the music to the moment at a touch of a button.
Other functions
The signature Bang & Olufsen craftsmanship is naturally seen in the new system. As your hand approaches, the smoked glass doors opens without a touch. The system boasts 60 radio station presets and a facility to function as a Beolink® master, distributing music to any Bang & Olufsen speaker in the house. Furthermore, if you wish to connect the BeoSound 3200 to a PC, the Beolink® PC2 connection facilities allow access to MP3 and WMA music files stored on the PC hard drive.
Active speakers
Choose any of the active loudspeakers from Bang & Olufsen’s BeoLab range for an experience that’s as pleasing to the eye as it is to the ear. Tall and elegant, the BeoLab 1 speakers deliver 300 watts of Bang & Olufsen ICE power digital amplifier driven bass. The appealing BeoLab 8000, slim BeoLab 6000 or placement friendly BeoLab 4000 speakers may be utilised as well. The recently redesigned BeoLab 2500 speakers easily allow you to opt for today’s spin on the original design expression.
BeoSound 3200 – Press Release 2 February 2003
A mountain of music – Built in CD memory in BeoSound 3200 allows storage of almost 400 CD
A vast amount of storage space, hidden within Bang & Olufsen’s BeoSound 3200, present a plethora of musical experiences this season. Operation is straightforward and simple, whether storing your own CD or playing one back from the CD memory. Compressed to allow more storage without sacrificing audible quality, a mountain of music is contained in the already sleek lines of this design classic.
“In 1991 Bang & Olufsen broke new ground with the introduction of the Beosystem 2500 concept – the first hi-fi system to stand tall amongst the flat contemporary rack systems of its day. We renew this classic product family with incorporation of a CD memory into its newest member, the BeoSound 3200”, states President and CEO Torben Ballegaard Sørensen, who continues,
“We’ll utilise the CD memory to offer our customers new benefits and convenience when enjoying their music collection. All your music, or at least a big part of it, waits for you at the touch of only one button”.
Stored simply
Just load a CD, decide in which one of the four possible groups you want to keep it, and press “Copy” on the hands-on operation panel. Storage of the entire CD begins! Don’t like all the tracks on your CD as much as the others? Don’t fret, because BeoSound 3200 gives you the opportunity to copy only the ones you yourself choose. You can always add them later, should your tastes change.
Name that disc
Whilst every one of your CDs contains inaudible information regarding the publisher, artist, batch production number and more, for you, they’re only about the music. Store the names of 200 physical CD’s in addition to the names of the almost 400 CDs already found on the 40 gigabyte hard disk. So sit back and experience “Romance” in the pleasing built-in display, rather than “Disk 1, track 5”.
Your music, your groups
Four 99-CD capacity groups are accessed by the coloured keys on the front of BeoSound 4300 or via the Beo4 remote control. Name them yourself, just as you wish: Rock, Pop, Jazz and Classics, or why not Dad, Mum, Brother and Sister? Enjoy music in your groups.
Magical experience through craftsmanship
Your hand approaches, and the smoked glass doors open magically. Wishing you welcome into a world of musical experiences, the door movement is designed to be smooth with a slow start, acceleration and a gentle stop when the door is at its final position. A magical experience provided by combing some infrared light, a bit of gearing, a length of steel wire and Bang & Olufsen ingenuity.
Beolink® master
Advanced CD memory functions are but one element in the entire BeoSound 3200 experience. Found between the high-gloss anodised aluminium clamper lid, the built-in CD-player accommodates both 12 and 8 cm discs. With 60 radio station presets, the AM/FM radio won’t leave your air-borne audio entertainment wishes behind either distributing music to any Bang & Olufsen speakers around the home in wish to connect your BeoSound 3200 to a PC, the Beolink® PC2 connection facilitates access to MP3 and WMA music files stored on your PC hard disk.
Active speakers
Choose any of the active loudspeakers from Bang & Olufsen’s BeoLab range for an experience that’s as pleasing to the eye as it is to the ear. Tall and elegant, the BeoLab 1 speakers deliver 300 watts of Bang & Olufsen ICEPower digital amplifier driven bass. The appealing BeoLab 8000, slim BeoLab 6000 or placement friendly BeoLab 4000 speakers may be utilised as well. The recently redesigned BeoLab 2500 speakers easily allow you to opt for today’s spin on the original design expression
Mounting Options
Posted on
BeoSound 8
Bang & Olufsen BeoSound 8
A late entry into the market but maybe the best sounding, the Beosound 8 benefits from the active speaker technology that B&O has championed for many years. Class D amplification is used for the two way loudspeakers and a placement switch is present which allows free standing, wall or corner settings.
The dock connection allows iPods, iPhones or iPads to be used and the provision of a line in connection allows other devices to attach.
In addition, a mini USB socket allows the customer to connect either a PC or Mac or an Airport Express to allow music to be played from their computer. A special Application written for the iPhone will be available which allows the music library to be browsed and also gives the BeoSound 8 both Alarm Clock functions and Net radio capabilities.
A wall bracket is available or the Beosound 8 can be used as a table top set.
Initially the speaker covers will be either black or white but Blue. Purple , Green and yellow covers will soon be available.
Control will either be via the iPod or with the Beosound 8 remote, which is aluminium. The set is also controllable with the Beo4,5 or 6.
The BeoSound 8 came in two ‘generations’ – the first being the regular BeoSound 8 with the old iPhone 20-pin connector, then the BeoPlay A8 (the ‘A’ standing for ‘Airplay’) which had no connector, but you could add a simple push-fit ‘Apple Lightning Connector’ for later Apple products if required.
Posted on
BeoSound 9000
Bang & Olufsen BeoSound 9000
BeoSound 9000 makes a strong statement with your music – but leaves it up to you to decide exactly how.
Music may not be essential to life, but it’s hard to live without it. That’s why BeoSound 9000 makes such a big thing about bringing your music out into the open and letting you create your own personal jukebox with the music that means the most to you. Combine BeoSound 9000 with the latest Beolink® PC 2 software application and you can access the digital music files on your computer’s hard disc. Place it upright in a bookcase, lay it flat on a shelf, or hang it directly on the wall – either vertically or horizontally. It can stand between a pair of BeoLab 1 or BeoLab 8000 loudspeakers, or with any other speaker in the BeoLab range. With BeoSound 9000, the possibilities – and the enjoyment – are endless ” (B&O Catalogue 2001 – 2002)
BeoSound 9000 represents the latest technology from Bang & Olufsen today. The 6-CD changer is the fastest in the world. If allowed to continue its momentum it would travel 100km/h in just 5,5 seconds… faster than a Ferrari from a stop position! It can be positioned in several different ways and the display text automatically adjusts itself to be readable. The unit too features a FM/AM tuner with RDS and is equipped with the new MasterLink connections and can be connected directly to the Beovision Avant and AV9000.
The CD returns to its original position
The discs are easily loaded and held by spring suspended jaws. Discs not in play can be replaced without interrupting the playback. The auto-positioning feature ensures that CDs are always returned to the position in which they were first placed. With the CDs visible and positioned correctly, there is easy access to the text information printed on the label. The glass-covered natural aluminium plate holds the CDs and the rails for the CD carriage, while a backlit acrylic plate illuminates the CD currently playing.
Glass cover to counteract gravity
BeoSound 9000 offers unprecedented flexibility for a product of this type, and to ensure the same uniform movement of the glass cover regardless of the placement of BeoSound 9000 vertically or horizontally, upright or flat. To counteract the effect of gravity, a digital time control constantly monitors the movement of the cover and adjusts the motor, keeping the complete movement within 3.5 and 4 seconds.
Safety first
Such an abundance of fast moving mechanics means that special measures have been taken to ensure that BeoSound 9000 is safe to operate. Small prismatic lenses are placed at each end of the aluminium frame, controlling an infrared beam across the front of BeoSound 9000. If the beam is violated, the CD clamper will stop immediately.
If the glass door is lifted while the clamper is in motion, it will decelerate immediately. A power failure feature ensures that the clamper is not damaged in a gravitational free-fall, if BeoSound 9000 is mounted vertically.
Ingenious engineering solutions and intricate mechanical movements in a product that continues to surprise and delight users today – and all this from the inspiration of old vinyl records spinning on the record player’s turntable.
The unit may be played in one of seven different positions. In each one, gravity has a different effect on the CD clamper (the aluminium ‘arm’ which rests over each CD when it is being read), yet it still works with the same precision and speed: a good example of how Bang & Olufsen uses technology to overcome acceptable limitations. Place BeoSound 9000 upright in a bookcase, lay it flat on a shelf or hang it directly on the wall – either vertically or horizontally. It can stand, for example, between a pair of BeoLab 1 or BeoLab 8000 loudspeakers (as above), or with any other speaker in the BeoLab range. With BeoSound 9000, the possibilities – and the enjoyment – are endless!
BeoSound 9000 starts with the technical excellence of the CD, but moves on from its limitations. A couple of good old-fashioned mechanical virtues make a welcome comeback. You can see it work and understand how it reacts when you touch its buttons. Or you can sit back with your Beo4 remote control and browse through over 7 hours of musical pleasure.
BeoSound 9000 makes a virtue of displaying the features that so many manufacturers try to hide away” welcoming the user with open arms to use it.
Features
BeoSound 9000 works so fast and so quietly that the change-over between two CDs seems no longer than the normal interval between tracks. Using the inaudible initial lead information on the discs, each CD can be named and memorised, and will be left in the same position as it was loaded, with its title clearly legible. Enter up to 200 titles in the memory and they’ll appear on the display whenever one of those CDs is played.
The FM/AM radio has memory for up to 60 stations which can be identified by their names instead of their frequency numbers. Set the timer and wake up to your favourite programmed CD sequence or radio station.
The fine art of control of BeoSound 9000
Lift the lid on BeoSound 9000 and the extensive control panel with timer, editing and sound adjustment operations is at hand. Since the BeoSound 9000 can be placed in a great number of positions, the control panel can turn as you prefer. The display follows the same orientation, of course!
Auto Positioning
Auto-positioning was one of the challenges that Bang & Olufsen’s engineers had to meet because of BeoSound 9000’s clear versatility in placement. Using the inaudible initial lead information present on most compact discs, the BeoSound 9000 is able to detect and memorise a desired position for the CD.
When it’s time to stop the CD, a servo system decreases the speed of rotation, the position mark is detected, and this effects the final braking and halt. A servo calculates the braking length for the CD, processes and stores the information. So the next time the CD will stop even faster, because BeoSound 9000 now knows where and when to apply the brakes. A total of 360 perforations ensure that your CD will stop precisely at the point at which you placed it in the rack.
The secret behind the precision of the movable clamper lies in two sensors which monitor its exact position and speed more than 60 times a second, and in its digitally-controlled motor, which compensates for even the slightest variation in movement.
Note: For owners of BeoSound 9000 who wish to use BeoLab 5 with this particular CD player, another feature of these new active speakers will be a direct digital feed from the optical output of BeoSound 9000 – the output not used at present!
BeoSound 9000: an evolutionary movement
Since the early days of the gramophone, record changers have been known and appreciated for their long playing time. The modern version of the record – the CD – adds a new perspective to the old old idea.
In designing BeoSound 9000 from scratch, a number of design models were created in order to illustrate various ideas.
The ‘library machine’ was one of them. It could hold an entire CD collection ready for playback. However the stored discs disappeared out of sight into the innards of the machine. This was seen as a problem because compact discs are not able to give a readout of a library’s contents, making an automatic catalogue display impossible, and since the design group felt a primary manual entry of all CD data was out of the question, the idea was quickly abandoned.
In returning to square one, the dominating feature – as in a CD changer – is the ability to play continuously for a long period of time. In coming up with a solution for this problem, together with presenting visual feedback, the discs were placed with their covers upwards and in a line next to each other, protected, under a lid of transparent glass. This was the main idea behind the very first design model of BeoSound 9000.
However, David Lewis, as Bang & Olufsen’s chief designer presented the first design model of BeoSound 9000 in two editions: the one which we know today with its 6 CDs, as well as another model comprising ten compact discs laid out in a line next to each other (see picture above).
The design group liked the 10-CD edition; it looked stunning, but in use it was limited to just once placement (unlike the eight different placements that the currently-produced BeoSound 9000 offers). The 10—CD version was subsequently shelved with the 6-CD version going into production in 1996.
David Lewis’ BeoSound 9000 from 1996 makes a virtue of showing its function. It clearly displays, by the 6-CD slots, that its function is the playing of music It can be placed horizontally on a wall or vertically on a special column when it becomes almost a sculpture for the home. Like B&O’s other products BeoSound 9000 contains the most advanced techniques around but shies away from technical mystique with its interface being simple and self-explanatory.
Control
Lift the lid on BeoSound 9000 and the extensive control panel with timer, editing and sound adjustment operations is at hand. Since the BeoSound 9000 can be placed in a great number of positions, the control panel can turn as you prefer. The display follows the same orientation, of course. BeoSound 9000 may also be controlled by the optional Beo4 remote control.
Placement
On the optional bracket, the BeoSound 9000 displays itself raised at an angle, or standing tall. Attach it horizontally and watch all the CDs stop in exactly the same positions as they were loaded in. Or you might opt for the floor stand as a bold musical statement. Hang BeoSound 9000 vertically on the wall and see how the display automatically changes orientation if you reverse the control panel.
Internet Music
Combine BeoSound 9000 with the latest Beolink® PC2 software application and you can access the digital music files on your computer’s hard disc directly from your music system in the living room. And if BeoSound 9000 is part of a Beolink® setup, you can enjoy your virtual music collection in any room in the house.
Auto positioning: stopping in the same place every time
Six CDs presented neatly in a row, with all the titles legible. After playback, BeoSound 9000 simply stops its CDs in exactly the position in which they were first loaded.
When it’s time to stop the CD, a servo system decreases the speed of rotation, the position mark is detected and this effects the final braking and halt. A servo calculates the braking length for the CD, processes and stores the information. So the next time the CD will stop even faster, because BeoSound 9000 now knows where and when to apply the brakes. 360 perforations ensure that your CD will stop within just 1° of the position in which you put it on!
BeoSound 9000’s CD reader is propelled back and forth by a powerful motor. An optical system allows a microprocessor to monitor the reader’s movement between the six CD stations. The total distance of 63 cm is divided into 1,040 separate positions so that the reader can be positioned to an accuracy of just 0.6mm. Given that the reader accelerates from 0 to 100km/h in just over five seconds, it’s vital that the electronic and mechanical components are in perfect harmony. BeoSound 9000 is one of Bang & Olufsen’s most compact products, housing no fewer than 2,910 different components.
Mounting Options
Bang & Olufsen boasted 6 mounting positions for BeoSound 9000 from the range of stands and brackets launched with this super flexible icon. The table stand and floor stand were complimented with a pair of wall brackets giving the choice of horizontal or vertical mounting
