Posted on
BeoSystem 10
Bang & Olufsen Beosystem 10
Small, compact and elegant, Beosystem 10 was the ideal companion when you were away from a main audio system.
It offered stereo radio with FM and AM/LW reception with three pre-set FM stations. The cassette recorder played every type of tape with the built-in stereo speakers providing excellent sound quality. There was also an optional wall bracket, and you could connect a turntable or extra cassette recorder, external speakers and Form 1 or Form 2 headphones.
Posted on
BeoSystem 2500
Bang & Olufsen BeoSystem 2500
David Lewis’ Beosystem 2500 from 1991 marked a new era of design for hi-fi. In its design, he set out to emphasise the function of the machine. The front is protected by a Perspex eyeshade which slides inwards when in use. Lewis here introduced the flat, standing shape which has come to characterise his Bang & Olufsen designs; for instance BeoSound 9000.
Its interface, designed by Sally Beardleys, is simple and well thought out. Since Beosystem 2500 is very compact it has taken a lot of work to make its small loudspeakers effective and harmonious. Among other things this has been solved by making use of separate power sources to the loudspeakers in order to optimise their sound. The design was followed up by BeoSound Century, which, compared to the 2500 is smaller and cheaper.
Tradition had it that music systems should be recognised at such. However, not so at Bang & Olufsen. In spite of its size, Beosystems 2300 and 2500 featured operation and performance on a level that compared with larger B&O audio systems. And adding to the magic of the fascinating new sound experience at the time of its introduction, was the way that the smoked glass doors slid open the instant the beams are broken by a wave of your hand – revealing the controls beneath.
Beosystem 2300 / 2500 gave you two extremely powerful active loudspeakers – BeoLab 2500 – which acted as completely integrated components in the system. The source selection and programming keys you needed to operate Beosystem 2300 / 2500 were located in a central keypad. And just above them was an illuminated display which could keep you informed of the source and track you were listening to. Every time you touched a key, the display told you exactly which function you activated.
Beocenter 2500, or Beosystem 2500 as it was called when used with BeoLab 2500 active speakers, was developed from the idea of a flexible music system that could compete with the sound quality of heavy music systems. Thanks to the advent of active speakers, this was a possibility with both Beocenter 2500 and its CD-only capable Beocenter 2300. With active speakers, each of the powerful bass and treble units were equipped with their own separate amplifiers. In addition, the electronic cross-over network ensured full bass reproduction.
The loudspeakers were located on both sides of a centre console, where two clear glass covers automatically glided to the side when a hand was passed in front of them. Behind the glass covers there was access to the operating panel, receiver, CD player and a cassette recorder.
The receiver allowed the option of presetting 2 x 20 FM/AM radio stations. The cassette recorder featured Auto Reverse, Automatic Recording level, search function and Bang & Olufsen’s HX-PRO recording system, a system which ensures that the sensitive treble range is captured in recording. The memory in Beocenter 2300’s CD player allowed you to edit up to 100 CDs.
Both systems could be operated via their operating panel or a Beolink 1000 or Beolink 5000 remote control. There were sockets for headphones and connection to additional sound sources; extra loudspeakers can also be connected.
Beocenter 2500 was available with loudspeaker panels in cobalt grey, black, white, cerise or jade. It was later known as BeoSound Ouverture and could be made up to the Beosystem 2500 when incorporated with the BeoLab 2500 active loudspeakers.
Mounting Options
Posted on
BeoSystem 3500
Bang & Olufsen BeoSystem 3500
Beosystem 3500 was unique, both in looks and price
The system’s lines were pure with everything superfluous omitted. It was specially designed to hang either on a wall or sit on a shelf or table. A light touch on its illuminated display gave immediate access to AM/FM receiver, CD player and cassette recorder; all of which were the latest and best in their respective fields. The system was completed by a pair of RedLine RL35 speakers and operated via a Beolink 1000 remote control unit.
Posted on
BeoSystem 4500
Bang & Olufsen BeoSystem 4500
BeoSystem 4500 – A touch of magic
The simplicity of the exterior was matched by simplicity of operation. A light touch directly on the illuminated display gave immediate access to the system. Or, you could operate BeoSystem 4500 with the BeoLink 1000 terminal, summoning forth magical sounds from the comfort of your favourite chair.
BeoMaster 4500
The BeoMaster 4500 receiver received both FM and AM – and was your communication link to the other sound sources in the system. Its operation was simplicity itself with an illuminated menu presenting all the options available. 20 radio stations could be pre-set providing you with instant access together with automatic fine tuning.
BeoCord 4500
The BeoCord 4500 cassette recorder housed exciting details and distinguished technology. Like Auto Reverse, so you did not need to turn over the tape. Automatic registration of the type of tape, and Bang & Olufsen’s patented HX-PRO recording system that provided optimal sound reproduction.
BeoGram CD 4500
The sound reproduction achieved by Bang & Olufsen’s CD 4500 CD player was truly outstanding. It played both 12cm and 8cm compact discs and had an ingenious ‘step’ function which allowed you to go straight to a chose track selected from anywhere on the disc.
BeoGram 4500
In building the BeoGram 4500 turntable, Bang & Olufsen applied all its classic principles to ensure reproduction as close to perfection as possible. The electronically-controlled tangential arm played each record exactly as it was recorded. And there were built-in systems that helped prevent vibrations reaching the cartridge or turntable. BeoGram 4500 employed a finer, ultra-light MMC2 cartridge that combined distinguished sound reproduction with maximum protection for your records.
Designed by Jacob Jensen, Beosystem 4500 in 1989 received the Japanese Good Design Award for its elegant design
If you crave maximum audio-visual performance for your hard-earned cash, there’s only one route to take: go for separates. Buying separate audio and AV components means you cherry-pick the very best in each category. What’s more, beefier (with individual power supplies), selected components plus better screening against interference inevitably deliver a higher standard of baseline performance.
Alright, they usually take up more space, but separates-based audio and AV systems are much more interference-resilient and offer vastly more potential for future expansion – an important advantage in the fast-changing world of hi-fi, video and home cinema. The only real downer is that you have to sift through hundreds of components in order to find the gems but if its sound and performance you’re after, there’s only one way to go!
Posted on
BeoSystem AV 9000
Bang & Olufsen Beosystem AV 9000
Bang & Olufsen’s Beosystem AV 9000 was a complete home theatre system introduced in 1992 and was designed by the company’s chief designer, David Lewis. The superlative system – in production for seven years – comprised a Beovision AV9000 TV set, a pair of BeoLab 8000 speakers, a pair of BeoLab 6000 speakers, and a Master Control Panel AV9000, similar to a BeoSound Ouverture. In addition, Beovision AV9000 contained not just the television, but also a Dolby Surround Sound processor, a modified Beocord VX7000 and an active centre speaker.
Beosystem AV 9000 was, in the early 1990’s the most advanced combination of sound and vision from Bang & Olufsen and was the B&O approach to complete home entertainment. The TV, video and music system used the same set of loudspeakers, so the sound always comes as close to reality as possible. AV 9000 gave you the freedom to choose one of five different sound-settings for every audio/video source – ranging from Dolby Surround Sound to monologue newsflash. Surround Sound was built into the AV 9000 monitor-unit, while the CD, radio and cassette was handled by BeoSound Ouverture, all seamlessly connected to each other. The whole system was surrounded by two set of loudspeakers: tall, slender BeoLab 8000 in front and BeoLab 6000 at the rear. A fifth source was the central loudspeaker in the triangular bottom-half of the television set. The whole system was controlled by one remote control, the Beo4.
Today it is relatively easy to build a television. But at Bang & Olufsen the company is more committed to bring customers the best possible experience. VisionClear is a simple name for a list of advanced electronics which the viewer experiences, but hardly notices, simply because they work. Automatic picture control, current colour balance correction, automatic cut-off and fine tuning of the aerial signal and a contrast screen.
If you often watch television during the day, you will recognise the problem of carpets, furniture and other home furnishings reflecting in the screen. The solution to this problem is an ultra-thin coating on the contrast screen, which reduces reflection by 90% and makes the black areas appear pitch black.
The anti-reflective contrast screen is standard on the Beovision Avant and was supplied as standard on the Beosystem AV9000. On the AV 9000 even the picture tube was coated with anti-reflective material to ensure 100% reflection-free viewing comfort.
A small electronic sensor in all Beovision TV sets registers the prevailing light conditions in the room and adjusts the picture, so that it’s always sharp, no matter whether a reading lamp is on or the rays of the sun suddenly breaks through the window. Automatic Picture Control is part of the VisionClear concept and only available on televisions available from Bang & Olufsen.
Bang & Olufsen’s products are enchanting! And the magic, the good idea, often comes into being in the course of finding a solution to some practical problem. The practical problem here was that there was a short time lag between pressing the button and a picture appearing on the screen. So you would sit and wait expectantly for a little while.
The experience of waiting reminded designer David Lewis of a theatre before the curtain went up! Behind the curtain, preparations were being made for the performance. The lighting and sound were adjusted and the actors took their places. The curtain only went up when everything was ready. The first television to have a curtain was Beovision AV 9000. The curtain was a thin steel sheet that was slid to one side by a clever mechanism when the stage was set. Bang & Olufsen’s wide-format television, the Beovision Avant, is equipped with an electronic curtain. From the moment you press the button until the curtain slides away, the technology is busily working unnoticed. No pop from the loudspeakers, no random flash of light from the screen. Only when the sound is ready and the picture is in place can the performance begin!
A brilliant problem
We all know the frustration of trying to watch television in daylight when the brilliance of a window reflection on the picture tube makes it impossible to see a part or all of the picture. This also happens to a smaller degree when light-coloured furniture or a lamp is reflected. In general, reflections lower the quality of the picture on a television screen and reduce the pleasure of watching a TV programme.
The optical process of what happens in such a case is that the contrast of the picture is effectively reduced. The Bang & Olufsen solution to the problem has traditionally been to incorporate a contrast screen. Ensuring that ambient light (which creates the reflections) travel twice through a light absorbing contrast screen whereas the picture formed in the picture tube travels only once, the brightness of the reflection is substantially reduced.
If it were possible, a better solution would be to reduce reflections directly. One method is to make the surface of the picture tube rough, either by sanding or etching the front surface of the tube or spraying a matt coating on the glass. This type of treatment does not actually reduce reflections, but by making reflections more diffuse, reduces their visibility. However, it also makes the picture itself fuzzy and less sharp, so that the overall quality is reduced.
A more attractive method is to use coatings. Coatings for glass surfaces have been used for a long time and for many purposes. The first use was probably for camera lenses, where coatings corrected for optical faults in the lens. Later, coatings were used to reduce reflections and also to correct colour reproduction when colour films became available. Most people will know of coatings from the more expensive spectacles, where coated glass is used to reduce reflections.
Anti-reflection coatings can reduce reflections to between 5% and 10% of their original brightness. They work by what is known as destructive interference and use the fact that light travels in waves of specific wavelengths. By coating the picture tube or other glass surfaces with a transparent layer of a thickness of one quarter of the wavelength of light, the light failing on the surface is reflected twice – once from the front surface and again from the rear surface of the coating. The two reflections are now half a wavelength apart and therefore in opposite phase and thus virtually cancel each other to destroy the reflection.
Of course, this happens perfectly for just one wavelength of light (or light of a single colour) and to lesser degrees for the wavelengths close to this. By adding more than one coating of different thicknesses, a more broadband removal of reflections can be achieved. Thus, for example, three coatings are used for the front screen of the Beosystem AV9000. One of the reasons that antireflection coatings are not used more often is that currently the manufacturing process is extremely expensive for large screens, allowing its use only in high-end television sets. However, as it is considerably less expensive for small screens, especially where only a single coating is used, it is a reasonably popular feature for computer monitors.
One of the features of coated picture tubes is that although reflections are drastically reduced, the coated glass appears to have a residual colour. This happens because some light is still reflected from the surface, the colour of which depends on the number and thickness of the layers. The colours that are not perfectly removed result in the colouring of the glass. This does not affect the colours of the picture, which is viewed through the coating and does not depend upon its thickness.
Also, the effectiveness of the anti-reflection coatings falls off at an angle to the screen, as the effective thickness of the coating changes. Seen from an angle, the colour of the reflections changes for the same reason.
The AV9000 also uses another coating, a thin layer of chrome on the back of the contrast screen. This is an anti-static layer, which is earthed to prevent the build-up of static charge, which can give problems with electrostatic shock. An appealing side effect of the anti-reflection coating of the AV9000 is that when the black curtain behind the contrast screen is closed, the effect of the coating is apparently considerably reduced, so that the whole screen surface appears to reflect. As soon as the curtain is removed, the anti-reflection coating takes full effect, forming a window in which the brightness of reflected light is reduced.
“There was a time when people bought TV and radio in order to keep informed. Today, TV and radio have developed into entertainment media, and here at Bang & Olufsen, we are convinced that this trend will continue. At any rate, that is the reason for what is perhaps our greatest innovation yet.
Beosystem AV 9000 is not just an independent video system and independent music system. It is an epoch-making combination of picture and sound options contained within an exciting Dolby Surround System. What is Dolby Surround anyway?
You have probably had the experience of sitting in a cinema, where the film was so real you almost ducked at the sound of horses’ hooves approaching your seat. That is Dolby Surround. With Beovision AV9000, you can benefit not only from film, but also from the many televised recordings and sports events that are produced and transmitted today with Dolby Surround.
Technically, Dolby Surround is created with the help of three front and two rear speakers. By delaying the sound in the rear speakers relative to the front speakers, you get a three-dimensional sound picture, and suddenly you are in the midst of a giant soccer stadium, a concert hall, or the action of a film. I am not exaggerating when I say that even in smaller rooms, Dolby Surround is incredible.
However, it is one thing to have cinema experience at home in your living room. The other side is that when we developed AV9000, we wanted to make sure that your living room wouldn’t look like a cinema when no one was using the system. Every element is designed to be a beautiful part of the rest of the decor of the room. Otherwise, it wouldn’t be Bang & Olufsen.“
Movies no longer have to be seen in the cinema. With Dolby Surround and Bang & Olufsen active loudspeaker technology it is possible to create a sound environment that even surpasses that of cinema. The technology makes sound so pure, that it can be called natural – just the same that you would hear in a concert hall. With the AV9000 Bang & Olufsen achieved the goal of perfect sound. But, this was only one half of the secret of reproducing cinema in your living room. The other half is gained when you give Bang & Olufsen’s engineers free hand in pursuit of the perfect picture, achieved in the monitor of Beosystem AV 9000.
The built-in video tape recorder had the same capability and operations as Beocord VX7000. The VCR was PAL/NTSC compatible and discreetly hidden from view, unlike a normal free-standing recorder. Together with the active central loudspeaker, it was positioned in the triangle below the 66cm 4:3 screen. The location of the speaker enhanced the impression that the voice came directly from the screen. To direct the voice to face your sitting position, the monitor could be turned 33 degrees to both the left and right by operating its motorised stand with the Beo4 remote control. As all B&O motorised stands, movement of the monitor was entirely soundless.
Perhaps the first thing that the viewer noticed upon looking at the set, was that there appeared to be no screen! Just like in the cinema, the screen was only revealed when the mechanical curtains parted. When the TV was turned on, a black, completely light-resistant curtain glided to the left and right to reveal the picture, creating further the illusion of a small cinema screen. At the same time the monitor turned toward you to its pre-set position. The picture was incredibly sharp, with deep and clear colours.
Beosystem AV 9000 was more than a music system and more than a video system. It was an integrated approach to home entertainment, which fitted unobtrusively into any living room. The polished aluminium surfaces of the active BeoLab 8000 and BeoLab 6000 speakers took on the colours of their surroundings, while the black cloth covers blended in with outmost grace. In regard to sonic qualities, the loudspeakers are still second to none.
Carlton Sarver, a writer specialising in audio and video, with life long experience within the development of electronic media in Europe as well as the USA concluded that “I feel free to give unrestrained opinion of the Beosystem AV9000 in the larger context of integrated audio-video systems. Which is, that somebody finally got it right”.
The Master Panel AV9000 – or MPAV 9000 – was the ‘audio source module’ designed especially for the AV9000 system and was very similar in appearance to the BeoSound Ouverture. The earlier types of AV9000 were sold with the module and used four active speakers to create a full surround system. It used the Beolink 5000 or Beolink 7000 as a remote and was a two-way system. This was replaced when the system was updated to use the Beo4 remote control and the Master Panel was replaced with the Ouverture.
Besides its ability to play music sources, the Master Panel – as its name implies provided the user with a control interface for the entire Beosystem AV9000. This meant, for example, that it could be used to search, play and rewind all the sources in the system. At the approach of a hand the tinted glass doors automatically slid open and the panel lit up. For CD play, a touch of a button caused the CD player’s motorised clamp to lift upward for convenient loading. At another button touch the clamp moved into place, holding the CD in precise position for play. Tracks could be programmed to play in any sequence, using a Beolink 5000 terminal.
The cassette deck offered the same playback convenience as a CD. Sequential track numbers were automatically assigned to selections on a cassette. Any track on a cassette could be quickly located, simply by entering the track number. Playback in any sequence could be programmed. HX-Pro – a headroom extension system developed by Bang & Olufsen and licensed to Dolby Laboratories – was standard. It secured that high music frequencies were optimised during the recording process.
Bang & Olufsen’s microcomputer-based Auto Record Level controlled the recording level more accurately than would be possible manually. Because it subtly reduces recording level when required, never increasing it, its action is virtually undetectable.
The FM/AM tuner incorporated Bang & Olufsen’s developments that increased sensitivity, selectivity and tuning stability. Its use was exceptionally easy. Touching a station preset button – on either the Panel or the Beolink 5000 terminal – caused that station to instantly start playing, even if the system had previously been turned off. With an optional RDS decoder, FM station identification was automatically displayed on the Panel. Users could also manually name individual FM or AM presets.
Posted on
Beolink 1000
Bang & Olufsen Beolink 1000
David Lewis’ Beolink 1000 from 1985 was the first step towards the intelligent audio-visual equipment that B&O continues to strive for. It was the first remote control on the market which could control both sound and picture. It is kept in a simple and harmonic design which is both timeless and functional.
” When you’ve got a superb picture and perfect sound, don’t you think it’s a shame to tie it down to one room? We think so. That’s why we’ve designed sound and pictures you can enjoy all over your house – and operate from your armchair. Say you’ve got a Bang & Olufsen TV, video and music system in your living room. And you’d like to extend the entertainment to your bedroom. It’s easily done, with some simple wiring, a small electronic box of tricks, and an extra TV.
Then you can watch not only TV and video from the equipment in your living room, but also enjoy CD, tape, radio and records. How does the remote control work? Easily, again. The Beolink 1000 remote control unit operates both sound and picture with our latest equipment. So you’ve got all the TV and audio equipment in the house at your fingertips.
It’s no good having one of the wonders of modern technology in your living room unless it’s easy to use and enjoy. We believe that truly advanced equipment should make life simpler, not more complicated. That’s why we do more than giving you remote control TV and video. And remote control music systems. We give you just ONE remote control for all of them.
It’s called Beolink 1000 remote control. All you do is put your feet up. And operate the cassette tape recorder with exactly the same buttons you use for the video tape recorder (just leave it to the equipment to sort it out). And you can do more. For example, if there’s a concert on, you can switch the sound from the TV to the loudspeakers in the music system. And courtesy of our latest technology, you can even dim the lights to suit your mood. Simple, but rather clever too ” (1988 B&O catalogue)
Beolink 1000 was the first remote control unit in the world designed to provide common access to both hi-fi systems and TV and video units. Programming like a magic wand, Beolink 1000, via its elegant an logical keypad, transmitted your every instruction. It allowed you to move from CD to TV, from radio to video, from record player to cassette recorder. It even allowed you move from TV speakers to hi-fi system stereo speakers to take full advantage of stereo video recorders.
Features
Beolink 1000 offered one-way remote control for audio, video and light control. Battery powered operation (3 x AAA) provided both primary and secondary function buttons. Could be used in any room with X-tra speakers or X-tra TV, providing easy access to all functions in the system. Could be placed conveniently on a wall as a stationary keypad held securely in place by the Beolink 1000 clip and was particularly well-suited to operate Beosystem 3500, Beocenter 8500, Beovisions LX5500 and LX4500 and Beovisions MX5500 and MX3500. The unit measured 40 x 15 x 230mm and weighed 230g.
Beolink 1000 was Bang & Olufsen’s entry remote control terminal, released in 1986. Its bigger brothers were the two-way Beolink 5000 and Beolink 7000 terminals. It originally came in a number of guises: released in 1987 was Terminal A, followed by Terminal V and then Terminal AV. Their purpose was to control the audio section of various hi-fis (Terminal A); the video sections (Terminal V) and combined functions (Terminal AV).
Beolink 1000 won the ID Award in 1986.
Posted on
Beolink 5000
Bang & Olufsen Beolink 5000
To keep up with Beolink’s ability to move sound and picture not only from one product to another, but from one room to another, Bang & Olufsen developed remote control units capable of two-way interactive and visual communication. The handheld Beolink 5000 provided a visual display which helped guide you through every stage of an operation giving you visual feedback of each system’s current status even when you were in a different room.
As the expanded capability of the terminal called for more operating buttons, Beolink 5000 had visual displays and operational buttons on both sides of the unit. Secondary-function buttons were recessed and placed to the rear while primary control buttons were positioned at the front.
Beolink 5000 added a new dimension to Bang & Olufsen’s remote control range in the early 1990’s. A fascinating transparent display, with numbers and letters apparently hanging in mid-air kept you constantly informed about the status of the Bang & Olufsen equipment that you were either watching or listening to. The layout of the unit was similar to that of Beolink 1000. However, because of its expanded capability it called for more operating buttons. To maintain its slim design, these were found on both sides of the hand-held unit. At the front, under the visual display, were the source selection buttons. Below these were the multi-function buttons arranged in a circle and designed for easy thumb operation. The circle contained buttons for analogue operation and menu-operated functions; a total of eleven buttons.
On the back were the secondary function buttons such as programming and recording, recessed in a channel to help prevent accidental operation.
Beolink 5000 was the ideal terminal to use where extra speakers or a second television were linked to a central system in a different room. Its display gave you feedback about the system’s current status to assist you in issuing your instructions.
It allowed you to fully utilise the timer recording, play and play next facilities on the Beosystem 4500 and Beocenter 9500. It was also particularly well-suited for Beosystem 2300. The remote control also maximised the programming capabilities of Beocord VX5000 video system and, via Beocenter 9500, allowed you to program LC1 and LC2 light control units.
Features
Beolink 5000 had the added benefit of a transparent display panel to guide users through complicated operations. Combining this display with fixed buttons which were positioned to provide a clear distinction between primary and secondary operations, allowed for simple and logical overall operation. The unit was light and slim, its display had low power consumption (LCD supertwist which produced map definition and detail even in bright sunlight) with a dot matrix display capacity of two lines, each with seven characters. The display could be read from either side of the handset dependant on which operations were carried out (to be read from either the back or the front).
Other important highlights of Beolink 5000 were:
Hand-held terminal for all video, audio and AV operation in central rooms and Local Control Systems
Two-way operation with display feedback
One-button source selection, video and audio
Logical layout with grouping of related functions
Secondary functions placed on the back to prevent inadvertent operation
Comprehensive secondary functions, e.g. record/time programming with display support and guidance
Companion infra-red remote control units that were available at the time of Beolink 5000’s introduction, were Beolink 1000 and Beolink 7000.
Component features
Beolink 5000 was the key to TV and video systems of the early 1990s. It was recommended for operation of such TV/video packages as Video System 5500 or Video System 6000, because these systems contained numerous advanced functions, especially in the fields of recording- and timer-programming. Beolink 5000 was optimised for the operation of such complex functions where you were guided through the options via prompts on the display of the terminal.
The display responded whenever you activated a function. When you carried out a primary operation, e.g. selected a source, you received status feedback. The feedback was dynamic, i.e. it changed according to the operation you carried out and the subsequent response the terminal received from the system. An example of this was in the adjustment of sound, where the centre balance function was only displayed when the function was available at that time in the system.
When you were in the secondary operation mode, e.g. for recording and programming, the display acted as a menu for operation, i.e. it became an active part of the operation. Thus the display was a reassuring response to your actions when you were in the primary operation mode, and an active guide when you were in the secondary operation mode.
The display was transparent, because some of the operation where the display is an active part, was initiated on the back. One example of this is when you activated the RECORD buttons on the rear of the remote control, the display read out the appropriate cues as seen from the back of the terminal i.e. V.REC PAUSE and the source you selected for the recording.
As most of the timer programming procedure was by the circle buttons on the front of Beolink 5000, the display read out the appropriate cue seen from the front as soon as you activated the PROGRAM button in the back recess. In this way it prompted you to turn the Beolink 5000 around for the rest of the programming procedure.
The advanced functions available via the Beolink 5000 included e.g. clearing TV stations, or making advanced (timer) recordings on your Bang & Olufsen VCR. The hazard with the record and program functions of course is that you could by accident clear or erase programs that you’d already made e.g. a recording on a video tape. So it was vital that the advanced functions were kept separated from the other main functions. By placing the buttons for operation of the advanced functions on the back of the terminal, Bang & Olufsen were able both to extend the number of secondary functions, and to make timer operation a real asset without risking inadvertent operation and confusing clutter on the front. Beolink 5000 was the first hand-held Beolink terminal where timer operation was possible with all recommended systems and even in stand-by.
The buttons for recording were grouped in the back recess to preclude inadvertent recording. To further secure against the inadvertent start of a recording, it was necessary first to point out the recorder and secondly start the recording on a second button.
Recording operation was refined with the Beolink 5000: all record buttons are grouped in the recess, you could address two video recorders, and no matter which one you used, you had direct access to start or stop of the recording and to make a record return.
Once you had summoned the source you wanted to record on to the TV, all you had to do was to turn the Beolink 5000 around and activate the [V.RECORD][REC.START] sequence to initiate a simple recording.
If you wanted to make an advanced recording of a TV programme as a background job, in RECORD PAUSE you selected V.TAPE + the programme number on the front before starting the recording on the back. The REC STOP button was a useful refinement here. When you had commenced a recording and switched to another source, e.g. TV, [REC STOP] gave you direct and instant access to stop of the background recording.
The third record level, timer record, was also initiated on the back, by means of the PROGRAM button. Beolink 5000 allowed you to make the timer operation both when the system was playing and when it was in stand by. In this way you would not disturb other uses of the video system and you need not even switch the system on to make a timer programming.
Picture adjustment was shown on the TV screen, and not on the Beolink 5000. In this way you could monitor and judge the changes directly on the screen, e.g. with regard to contrast. Sound adjustments were displayed both on the screen and on the terminal. In this way the feedback was always placed at the optimal point for operation and adjustments.
Teletext contains a number of secondary functions to enhance its user value, such as enlarging the page, mixing Teletext with the TV program, revealing a hidden information (e.g. VPS information on TV program page), etc. Many users never access these secondary
functions, because they have been assigned low priority on the remote controls and therefore it is difficult to access them. Beolink 5000 accesses the functions easily and as guided by its transparent display. In TEXT-mode, if you pressed MENU the display would read out:
TEXT
MENU?
If the answer was ‘yes’ [PLAY] gave access to the first item of the menu, as shown here:
Secondary Teletext functions available via [MENU]:
MENU (Teletext time programming)
LARGE
MIX
REVEAL
UPDATE
SUBCODE
As an alternative you could step through the options or leave the menu. The menu operation procedure simplified access to the secondary Teletext functions considerably and showed the advantage of using two operation logics: one for routine operations and one for important, but rarely-used, operations.
Beolink 5000 was the key to video systems such as Video System 5500, comprising Beovision MX5500 and Beocord VX5500. It was recommended for operation of such systems because this system contained numerous advanced functions, especially in the fields of recording and timer programming. Beolink 5000 was optimised for the operation of such complex functions, where you are guided through the options via prompts on the display of the terminal. Other important highlights of Beolink 5000 were:
The display responded whenever you activated a function. When you carried out a primary operation, e.g. the selection of a source, you received status feedback. The feedback was dynamic, i.e. it changed according to the operation you carried out and the subsequent response the terminal received from the system. An example of this was in the adjustment of sound, where the previously mentioned centre balance function was only displayed when the function was available in the system. When you were in the secondary operation mode, e.g. for recording and programming, the display acted as a menu for operation, i.e. it became an active part of the operation. Thus the display was a reassuring response to your action when you were in the primary operation mode and an active guide when you were in the secondary operation mode. The display of Beolink 5000 was transparent, because some of the operations where the display was an active part, was initiated on the back. One example of this was when you activated the RECORD buttons on the back when the display read out the appropriate cues as seen from the back of the terminal, i.e. V.REC PAUSE and the source which you had selected for the recording.
As most of the timer programming procedure was by way of the circular button on the front of Beolink 5000, the display read out the appropriate cue as seen from the front as soon as you activated the PROGRAM button in the back recess. this way it prompted you to turn the Beolink 5000 around for the rest of the programming procedure.
The advanced functions available via Beolink 5000 include e.g. clearing (satellite) TV stations, or making advanced (timer) recordings on your VX5500. The potential problem with record and program functions was that you could by accident clear or erase previously-recorded programmes. So with Beolink 5000 the advanced functions were kept separate from the other main functions. By placing the buttons for operation of the advanced functions on the back of the terminal, Bang & Olufsen were able both to extend the amount of secondary functions, and to make timer operation a real asset without risking inadvertent operation and confusing clutter on the front. Beolink 5000 was the first hand-held Beolink terminal where timer operation was possible with all recommended systems, even while in stand by.
The buttons for recording were grouped in the back recess to preclude inadvertent recording. To further secure against inadvertent start of a recording, it was necessary first to put the VCR into a recording pause mode before commencing the recording by way of a second button.
Recording operation was refined with Beolink 5000: all record buttons were grouped in the recess; you could address two video recorders, and no matter which one you used, you had direct access to start or stop of the recording and to make a record ‘return
Posted on
Beolink 7000
Bang & Olufsen Beolink 7000
The BeoRemote One was launched alongside the new BeoVision Avant 55 LCD Television in 2015 and heralded the new, slimmer and more lightweight look and feel – in line with the new TV’s of the time.
The casing is milled from a single block of Aluminium then anodised (in various finishes and colours) and the main workings of the controller (including the batteries) are slid into place along the centre of the casing. Being soft aluminium, these remotes can very easily pick up dents and scratches – unlike the much tougher and heavier Beo4, but if it’s elegance you’re looking for, the BeoRemote One certainly ticks the boxes.
The bright LED style display is clear and easy to read, and buttons are simple and intuitive – but the lack of any backlighting can make it frustrating to use in low light or darkness!
The BeoRemote One was originally IR (infra-red) only, but the second generation heralded the new Bluetooth command as the added standard way of communicating with products.
The standard colour was the polished and anodised aluminium, with a ‘Silk’ option also available which had a satin look to it. Bang & Olufsen released a Limited Edition ’90’ housing in Rose Gold to mark their 90th Anniversary, which are quite rare, but not to everyone’s taste!
Posted on
A Terminal
Bang & Olufsen A Terminal
From the Commander to the Beolink 1000 – a leap in ideas
Beomaster 2400’s new element was the Commander – the remote control – which no High-Fidelity producer had even dreamed of making before. In America, however, remote- controlled TVs had already become a reality and in Europe, the first TV commanders, with a plethora of buttons, had turned up in Germany.
Bang & Olufsen’s idea was not to supply remote controls for its systems, it was to provide the user with easier operation – to put the entire selection of sound and picture in users’ hands. Although today, this is perhaps self-evident, this was not the case at the time. Nobody had so far dared to pursue such an obvious concept. It did not take long for the idea to take root. Soon afterwards, all Bang & Olufsen’s systems enabled the user to operate the system from a commander.
The Bang & Olufsen Idea Group insisted that users should be able to operate the commander with one finger on one hand, the thumb. This was vastly different from the commanders manufactured by other producers where the many buttons meant that the user had to hold the commander in one hand, the manual in another while the index finger of the third hand pressed the button selected by the eye.
The concept was dubbed ‘the feel commander’. This meant that the TV could be operated by the thumb on one hand – almost as if the user was feeling his way through a new type of Braille, allowing the eye to concentrate on the essential, the picture.
The culmination of the development of the idea of a ‘total commander’ came in 1985 when David Lewis designed a Beolink terminal where the user, without using his eyes, could control picture, sound and light by applying a slight pressure of the thumb. Incredibly, it could be used in all the rooms of a house. This later system, known as Beolink®, eventually incorporated most of Bang & Olufsen’s audio and video products.
The Beolink 1000 family of remote controls is made up of four unique products; all similar in appearance, but each was brought out at a different time, for a variety of differing functions. First there was the Audio Terminal (or ‘A Terminal’). This was then followed by both the ‘Video Terminal’ (used by Beovisions LX2800 and LX2500) and then the ‘AV terminal’. Lastly was the Beolink 1000 as we recognise it today. Both of these latter Terminals are shown above.
The Audio and Video Terminals are similar in appearance to each other. However, they both accommodate different sets of buttons. With both these controls the bottom plate is stamped to differentiate them as either an Audio or Video Terminal. Size-wise, both Terminals are around 1,5cm shorter than a (current) Beolink 1000 Terminal.
Beolink 1000 Mk III was the last model produced and does not include a ‘turn’ button. To turn over the tape of your Beocord cassette deck, press SHIFT + SOUND.
In order to access ‘Balance’ press SOUND twice and then use the volume up and down to adjust.
To alter ‘Treble’, press SOUND three times and adjust in the same manner; for ‘Bass’ press SOUND four times.
To save your new settings, press SOUND and then STORE.
In comparison, the AV terminal is about 1cm longer than a Beolink 1000. The AV terminal could operate both audio and video and again was released before Beolink 1000. All three Terminals were black and dark grey coloured.
With Beolink 1000 (introduced in 1986), there have been six models. Beolink 1000 Mk 1 and 2 were also black and dark grey. The Mk 1 version would not work with light controllers such as LC1. However, Mk2 could, by simply pressing SHIFT + LINK more>>
Since its introduction in 1986, the Beolink 1000 family of remote controls has been able to control all subsequent Bang & Olufsen products – both audio and video. Beo4 is a direct descendant of these remote controls, together with its (former) smaller brother, Beo1.
Most infra-red remote controls work on a 40KHz carrier. Only Bang & Olufsen and a handful of Sony and Kenwood products use 455KHz as the carrier frequency. This more powerful frequency allows the Terminals to command products from a greater distance and often, it is not a requirement to ‘fire’ them directly at the items’ sensors.
