Posted on
BeoCenter 4000 (1985)
Bang & Olufsen BeoCenter 4000 1985
Beocenter 4600 was a multi-way combination unit incorporating a 2 x 25 watts RMS AM/FM receiver, an easy to use hi-fi cassette deck and an automatic record player. The lightweight arm had built-in bias compensation and carried Bang & Olufsen’s MMC 20S pickup cartridge with spherical diamond stylus.
The AM radio covered long and medium wavebands. Outstanding reception quality and high selectivity was secured by an Automatic Gain Control circuit, active noise suppression and hybrid filters.
The FM tuner was highly sensitive. Four stations could be pre-set for subsequent instant recall. The hi-fi cassette deck had all the features and qualities normally expected only in a separate deck:
* 3-digit counter with memory function
* electronic tape stop at end of play
* Dolby B Noise Reduction
* chrome or normal tapes could be used
The super Permalloy tape head was hard-wearing and had a long, useful lifetime. The record player too was automated: all functions were controlled by a single button. The anti-skating device worked automatically too. Bang & Olufsen’s MMC 20 S pickup cartridge with a spherical diamond was an integral part of this unit. Two Beovox S40 speakers complete this system if this was your choice.
Posted on
BeoCenter 6-26
Bang & Olufsen BeoCenter 6-26
The widescreen BeoCenter 6 LCD television is available in 23” and 26” versions. Both come custom-fitted to match your needs. For example, you could have built-in FM and DAB radio in the compact 6-23 in your kitchen and Surround Sound and DVB-S modules in a 6 – 26 used for watching TV in a small living room or a bedroom. Or you could mix and match. Your ‘second television room’ just became the place to be. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept.
Gorgeous from good morning to good night
The handcrafted cabinet of the BeoCenter 6 speaks volumes about the dedication that went into its creation. The sleek lines of the BeoCenter 6 blend in anywhere in your house. Both in your kitchen, drinking your morning coffee, or in your bedroom – enjoying the late night comedy before you go to sleep. The elegant aluminium front and frame are available in a selection of dashing colours as well as discrete aluminium, black and dark grey versions. Using its special digital input, BeoCenter 6 can function as a spectacular computer monitor that would take pride of place in any room, especially if matched with the compact BeoLab 3 or BeoLab 4 loudspeakers in striking red or blue – or perhaps the golden anodised aluminium of BeoLab 4000.
Fewer boxes. More TV and radio
The new BeoCenter 6 takes intelligent integration to a new level and introduces DAB radio options together with a TV for the first time ever. When you are listening to the radio, the screen can display available programme information. Equipped with wake-up timer and timer play the BeoCenter 6 makes the perfect choice for a second room television. A selection of wall mounting brackets and stands are available for versatile placement. The motorised floor and table stands can be controlled from the Beo4 remote control, turning the TV 35° to each side. In addition, the tilt mechanism means easy adjustment of the television up and down on the vertical axis.
The definitive BeoLink screen
BeoCenter 6 can function as a stand-alone television, or as the second-room TV in a BeoLink setup. You can enjoy all sources from the main room on the BeoCenter 6, such as DVD, digital music, etc. For instance, you can watch satellite TV in your bedroom on your BeoCenter 6 – 23, even though the satellite receiver is in your living room. BeoCenter 6 can also be used as an ‘audio link master’ that lets you access the radio function from other rooms, if linked to a pair of BeoLab speakers.
True Bang & Olufsen picture and sound
The BeoCenter 6 uses the best LCD screens available, and has been further improved with Bang & Olufsen VisionClear picture technologies, which are implemented in all TV solutions from Bang & Olufsen. Whenever BeoCenter 6 is switched on, VisionClear adjusts the image automatically in relation to light conditions in the room. Within seconds, the TV automatically adjusts contrast levels, brilliance and colour to match the light conditions at any given time. BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26 a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6 – 26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television´s loudspeakers will in this setup function as a powerful centre speaker.
The new BeoCenter 6 takes intelligent integration to a new level and introduces DAB radio options together with a television for the first time ever. One of the best LCD screens available has been further improved with Bang & Olufsen’s own VisionClear picture technologies, to ensure the best possible picture in all situations.
When BeoCenter 6 is switched on, these picture-optimising technologies adjust the image automatically in relation to light conditions in the room. Within seconds, the television automatically adjusts contrast levels, brilliance and colour to match the current light conditions – and will carry on doing so until the television is switched off again.
BeoCenter 6 can function as a stand-alone television, or as the second-room television in a BeoLink setup. In the latter case, you can enjoy all sources from the main room on the BeoCenter 6, such as DVD, digital music, etc. BeoCenter 6 can be used as an ‘audio link master’ that lets you access the radio function from other rooms, if linked to a pair of BeoLab speakers.
Four placement options help BeoCenter 6 fit in, even in the smallest of spaces. The motorised turning function on the floor and table stand is controlled from the Beo4 remote control, and turns the television 35° to each side. In addition to this, the tilt mechanism means easy control of the television 13° up and down on a vertical axis.
The widescreen and high-definition ready LCD monitor is available in 23” and 26” versions. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept. Connections for earphones, external entertainment sources, and BeoLab loudspeakers, are combined with digital interface for computers (DVI) – making the BeoCenter 6 the perfect companion for both work and entertainment.
When the FM radio, which is standard in the 23” version and optional in the 26” version, or the DAB radio feature, which is optional in both, is switched on, available radio text information rolls across the screen. A factory fitted wake-up timer supports the radio functionality still further.
BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26 a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6 – 26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television’s loudspeakers will in this setup function as a powerful centre speaker.
Mounting Options & Stands
The tilt table mount was available for counter top mounting, designed to allow the bass port on the underside of the TV to ‘breath’. Motorised floor and table stands were complimented by a wall mount bracket which gave manual tilt and turn.
Posted on
BeoCenter 6-23
Bang & Olufsen BeoCenter 6-23
The widescreen BeoCenter 6 LCD television is available in 23” and 26” versions. Both come custom-fitted to match your needs. For example, you could have built-in FM and DAB radio in the compact 6 – 23 in your kitchen and Surround Sound and DVB-S modules in a 6-26 used for watching TV in a small living room or a bedroom. Or you could mix and match. Your ‘second television room’ just became the place to be. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept.
BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26” a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6-26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television’s loudspeakers will in this setup function as a powerful centre speaker.
Bang & Olufsen’s preferred supplier for brackets and stands, STBbrackets, have made a range of solutions specifically for this model including a direct replacement for the tilt table mount. Distributed throughout the World by the Bang & Olufsen store network, the STB options add to the diversity of mounting options and positions available.
Posted on
BeoCenter 1
Bang & Olufsen BeoCenter 1
BeoCenter 1 combines a state-of-the-art TV, a superior-quality DVD player and an intelligent FM radio in one product, and lets you control everything with a single, easy-to-use remote control – the Beo1.
With its impressive picture quality and powerful active speaker system, Beocenter 1 provides total entertainment in a minimum of space. And the integration doesn’t end with the technology. With six strong colours and five diverse stands – all with motorised turning – to choose from, Beocenter 1 can easily be assimilated into any setting.
In a world full of choices, Bang & Olufsen has already made the best ones for the consumer – and put it all at the command of a four-buttoned Beo1 remote control – the remote control unit dedicated to both Beovision 1 and Beocenter 1.
However, as from October 2002, both Beovision 1 and BeoCenter 1 were delivered with Beo4 remote control instead of Beo1 which was discontinued. In January 2003 a Dolby Digital Surround Sound kit will be available for both these TV models.
BeoCenter 1 is able to read and play DVD-R and DVD-RW discs.
BeoCenter 1 – Press Release 2000
” Bang & Olufsen announces the newest addition to it’s product portfolio. In combining an FM radio, a DVD player, a 25″ TV and a pair of active loudspeakers, BeoCenter 1 offers experiences as yet unmatched on the marketplace. Featuring appealing design and simple operation, the product also has the flexibility to fit in anywhere.
In continuance of the Beovision 1 concept, launched in November of 1999, the key features of BeoCenter 1 remain focused on versatility, simplicity and uncompromising picture and sound quality.
With the new BeoCenter 1, Bang & Olufsen is taking account of the varying needs of consumers when it comes to usage of audio and video equipment in the home. “
Different uses
Bang & Olufsen’s second compact A/V product (the first was BeoCenter AV5, launched in 1997), BeoCenter 1 features an elegant and unmistakably B&O design that makes its presence known, while astonishingly remaining discreet. And a wealth of the company’s long-standing values and innovative finesses lie packed in beneath the surface.
A combined A/V solution like this represents a whole new way of living with these different media – at least in modern times. But look back a few decades and radiograms and combined TV/gramophone units were de rigueur. Back then the TV was the altar at which the family congregated. But as the TV came to play a less dominant role in the home, so consumers rejected large combined systems in favour of smaller, individual audio and video products – thanks in part to new technology requiring less space.
Goes anywhere
Now the combined solution is back with a vengeance – but in minimalist guise, expressed through a design with an emphasis on flexibility rather than dominance.
BeoCenter 1’s flexibility stems primarily from a choice of five unique placement possibilities: from floating almost magically out from the wall, to sitting on a more traditional floor stand, to standing tall on a 160 cm column. Utilising the built-in motor, BeoCenter 1 can also be turned to face in different directions, simply and intuitively operated with the Beo1 remote control.
Externally, BeoCenter 1 offers a truly colourful experience. It is available in six different colours: green, black, yellow, blue, red and grey. This finishing touch helps ensure that BeoCenter 1 blends into any home interior.
But for a A/V centre to blend in absolutely anywhere, it needs to look good from every angle – not just head-on. So a lot of time was spent on making BeoCenter 1 look good from the back too – wave goodbye to gaping sockets and ungainly cable holders.
Furthermore, an A/V centre that goes anywhere also needs to produce a picture that looks good anywhere. BeoCenter 1’s automatic contrast, brightness and colour control means superb picture quality in more or less any light. Add the standard anti-reflection coated contrast glass to the 25″, 4:3 format screen, and the amount of incoming light is reduced by almost 99%, when compared with ordinary front glass.
To top it all off, the sound is rather special too. Two powerful active loudspeakers once again make Bang & Olufsen’s acoustic competencies heard loud and clear. Topping out at 96 dB stereo, the sonic experience remains true to the Bang & Olufsen goal of natural reproduction of sound.
Integrated DVD player
Surprising, intelligent, magical and discreet are some of the words of praise attracted by the DVD player. The DVD tray glides out like a tongue beneath the TV screen and naturally you get all the functions you would expect from a DVD player: Instant access to any particular film episode, pictures in studio quality and a thrilling sound experience.
Built-in FM radio
Seamlessly integrated into the compact cabinet of BeoCenter 1, the FM radio features 59 programme presets and a standard Radio Data System (RDS) module. The RDS module allows the user to see the name of the radio station in the display, provided the broadcaster transmits the proper identification signal.
Personalised Channel Groups
Another major innovation is that each user can create his or her own personal group of up to 18 TV channels (terrestrial, satellite and cable) and radio stations. Again this is in the name of simplicity – it can be hard to keep track of the rapidly increasing number of TV channels available. Another option is to have subject groups rather than personal groups – like sports channels or movie channels. Up to eight different channel groups can be created.
Simplicity even extends to remote control
The Beo1 remote control is a miniature sculpture completely unlike its traditional counterparts, in that it features a built-in base so that it can stand upright on the table. And with only a few buttons, it is also striking in its simplicity – one of the themes in BeoCenter 1. All system components are operated by using the Beo1. Simply navigate through the simple options on the display beneath the TV screen.”
Posted on
BeoCenter 2
Bang & Olufsen BeoCenter 2
The Socket Unit contains most of the electronics, as well as all external connections. This greatly helps the organising and concealment of the numerous cables needed in a typical A/V set-up. In BeoCenter 2 only a single thin cable, available in 1.8, 3, 5 and 10 metre lengths, connects the Master Unit to the Socket Unit. A 1.8 metre cable is delivered as standard.
The Socket Unit is fitted with MasterLink, RGB, PowerLink, power connections and other connectors so that you may connect a pair of BeoLab active speakers or link it to a home cinema system.
A great advantage of the compactness and relative lightness of the BeoCenter 2 Master Unit is great flexibility in placement. It can be wall mounted, attached to a dedicated floor or table stand, or simply placed on a table or shelf.
Digital Radio Module
BeoCenter 2 DAB digital radio module: this module allows users access to terrestrial free-to-air broadcasting of high quality audio and data. DAB digital radio is a new way of broadcasting radio via a network of terrestrial transmitters. It provides listeners with more choice, better sound quality and more information. DAB digital radio is like analogue radio, only much better. When available – from 3 November 2004 – the module will become a standard feature of BeoCenter 2 in the UK.
In order to make the module compatible it has been necessary to update both the Socket Unit and the Master Unit. This, however, means that DAB will not be available with past and current BeoCenter 2 models. It was originally stated upon the launch of BeoCenter 2, that it would be possible to ‘upgrade’ to DAB. Where customers purchased the model on that understanding, Bang & Olufsen will honour that commitment. The first Master Unit serial number with software suitable for the DAB functionality is 18139286.
Note: To have the DAB module fitted to your BeoCenter 2 is essential that both the Socket Unit and Master unit are the latest versions. Mixing existing stock of Master Units (pre-serial number 18139286) and DAB Socket Units (part number 1280020) is not possible.
Master unit connections: MasterLink x 1, Digital Out, SCART, S-VHS, FM Aerial, AM Aerial, audio in (L&R), audio out (L&R), PowerLink x 1 (See Specifications).
By touching ‘load’ on the anodised aluminium top panel, BeoCenter 2 opens to receive your chosen media. The product is made up of two units linked together by a special cable: the Master Unit (or Media Unit which is the player itself) and the Socket Unit.
BeoCenter 2 Press Release October 2003
Bang & Olufsen’s new music system, the BeoCenter 2, is in many ways a classic Bang & Olufsen product. It has mystique, it is elegant, it is simple and logical.
If you look at the BeoCenter 2 from a distance, the design says nothing about the many functions the system contains. Only when you make physical contact is the content behind the symmetrical polished aluminium doors revealed. If you press “load” lightly, the two wing-shaped aluminium doors slide aside elegantly to reveal a combined CD and DVD player. When the music or film is playing, the doors slide back to conceal the disc, clearly signalling that the experience is more important than the source.
It is by no means unusual for a DVD player to play CDs, but a system that offers radio, CD, DVD and MP3 CD playback is a new way of combining all sources of entertainment in one unit. “At Bang & Olufsen we always focus on integrating technologies and with the BeoCenter 2 we give our customers the chance to combine music and video sources in one unit,” says President and CEO Torben Ballegaard Sorensen.
With the oval shape of the master unit, BeoCenter 2 is yet another design step away from the traditional box-shaped units of yesteryear for playing music and images. The size of the display ensures that it can be read at a distance and a light meter behind the glass adjusts the intensity of the display according to the brightness of the room. This avoids the display completely illuminating a dark living room.
In addition to RDS (Radio Data System), the tuner in BeoCenter 2 allows you to program and name up to 60 radio stations. And, of course, the BeoCenter 2 can be integrated into a Beolink network. When connected to a Beolink PC2 it can also play digital music files stored on a computer.
Clean up the Mess
It has always been important for Bang & Olufsen to make it nice and easy for consumers to enjoy music and moving pictures. Most obviously, the concept helps to eliminate the many remote controls that typically pile up on the coffee table, replacing them with one remote control – the Beo4 – which can control all the functions of all the appliances connected, plus the lighting in the room.
Another example is the tradition of concealing cables in stands and behind screens so that the necessary cables do not mar the visual appearance of the products. And where it is not possible to conceal the cables completely, special holders are provided for the cables, making a virtue out of necessity. Finally, there is the design itself. By avoiding visual trivialities and unsightliness, which can mar an audio/video product in themselves, the products look simple and elegant.
BeoCenter 2 is a continuation, a natural development, of this line of thought. The division of the product into two separate parts means that there is great freedom to place the elegant master unit where it is best suited in the room. This may be on a table, mounted on the wall or on an aluminium floor stand specially designed to match the oval shape of the master unit.
From the master unit there is just one cable to the socket unit containing the sockets for all the cables connecting BeoCenter 2 to the mains, speakers, TV, aerials, etc. The socket unit can be concealed under a piece of furniture or behind a curtain. This means that the visible part of the BeoCenter 2 is not spoiled by the jumble of cables required to integrate it into the network of the TV and speakers.
World Class Aluminium Processing
BeoCenter 2’s two sliding aluminium doors were a challenge to Bang & Olufsen. Both doors are cut from the same piece of aluminium, but only after the front has been polished in the oval shape that follows the lower edge of the display. This ensures that all details in the polishing are echoed on both doors. Both these sliding doors stay together throughout the complicated process of milling and the two surface treatments. So the doors on the final product match perfectly.
The precision requirements Bang & Olufsen sets for the visual appearance of the product mean that the machine which grinds the edges of the doors works to very small tolerances. For every 1/100 millimetre along the edge, the machine calculates and self-corrects to ensure a perfect oval shape.
When the aluminium is surface-treated in the anodisation plant, tiny pores appear in the surface. These pores are used in the screen printing employed to apply numbers and characters to the front of the doors of the master unit. By pressing the coloured lacquer down into the pores and then surface-treating the doors, very durable printing is achieved. As a result, it is virtually impossible to wear the printing off, even with very frequent use.
Controlling the BeoCenter 2 is a masterpiece of precision. The area beneath the master unit is milled down to 0.5 millimetres. So when the user presses the unit, the thin aluminium sheet bends very easily. This activates the electrical circuits used for the control function. You can neither see nor feel this, but it is enough for it to make contact with the film of conductive material underneath.
The precision processing goes one stage further with the “wheel” on the right-hand door. In a wide circle around the control areas, a further 0.1 millimetre of aluminium has been milled off. The functions of the wheel include adjusting the volume, and it functions according to the same mechanical principle as the rest of the master unit.
Posted on
BeoVision 7
Bang & Olufsen BeoVision 7
“BeoVision 7 is more than just a TV; it’s a complete entertainment system specially created to offer a sound and picture experience far beyond expectations. With its 81cm LCD screen, built-in DVD player and powerful active loudspeaker system, BeoVision 7 offers all the benefits of flat-screen viewing, but with exceptional sound performance as well.”
BeoVision 7 combines both an 81cm LCD monitor with an integrated DVD Player, DSS surround sound module and a dedicated loudspeaker in BeoLab 7-1. The concept emphasises the separation of picture and sound together with a good number of placement options. With BeoLab 7-1 the very highest level of acoustic performance is delivered. BeoVision 7 has a higher display resolution than that of BeoVision 6 – 26: 1366 x 768 (WXGA) pixels against 1280 x 768 pixels of BeoVision 6.
BeoVision 7 may be used as either a stand-alone television set or as a large-screen monitor within a domestic surround-sound system. There are five different stand placement options available to the user:
Original Bang & Olufsen stands available at launch included: Fixed position Table Stand, motorised Table Stand, motorised Table Stand, moveable Wall Bracket for TV and Loudspeaker (close or extended versions) and a motorised Floor Stand. A fixed Wall Bracket for BeoVision 7 32 was added to the stand portfolio after launch.
Each of the above options hold both the monitor and the BeoLab 7-1 active speaker; with the exception of the Table Stand, each has the vertical tilt feature.
BeoVision 7 offers the following as standard:
Dolby Digital/DTS Surround Sound
MasterLink Module
Set-Top Box Controller
RF Modulator
Anti-Reflex Coated Contrast Screen
DVI PC input
Part Numbers:
BeoVision 7 – 1816089
Table Stand – 1409766
Wall Bracket – Fixed – 1409511
Motorised Floor Stand – 1409111
Wall Bracket – Moveable – 1409611
Motorised Table Stand – 1409211
Posted on
Beo5
Bang & Olufsen Beo5
The Beo5 is expected to become an important part of the new B&O range. It is designed to work with all of the range but is particularly suited to use with the TV range when partnered with the BeoMedia devices.
A backlit screen, which is able to be configured via a USB connection on the docking/charging station, sits on top of a very tactile metal control sphere. The interface is a modification of the well known Beo4 layout but with the addition of a click wheel and ring of control buttons. A numeric keyboard can be activated on the touch sensitive screen by pressing TEXT. Different set ups of screen can be customised by the user though this has to be set up by the dealer. Configuration is a dealer task.
One Way Traffic
The remote is not the hoped for return to two way remote control but does allow the screen to be customised to suit a user’s system. In particular it is thought that program logos could be able to be imported onto the screen. It would appear that these are B&O defined so may be somewhat limited.
Fully Compatible
As the Beo5 uses a derivative of the original Beolink 1000 codes, it is able to be used with many products dating right back to the eighties. It will replace the Beo4 in time and will be supplemented by a basic control for sets such as the Beovision 8.
Posted on
Beo6
Bang & Olufsen Beo6
The Beo6 replaces the Beo5 and adds a wide screen which is touch sensitive rather than the pressure sensitive screen of the Beo5. Initially, little will seem different but once the BeoSound 5 Encore is released and the BeoSound 5 is updated, two way control including tag information and cover art will be enabled.
The communication is wireless via the router the BS5 Encore is connected to.
Posted on
Beo4
Bang & Olufsen Beo4
Three variations on a theme… Beo4 over the years. From the Mark I version introduced in 1994 with its central ‘AV’ button, the Mark II version introduced in 1999 to accommodate the then recently introduced DVD format, and the November 2004 Mark III inception with its noticeable DTV, VMEM and AMEM buttons.
Beo4 is the key to all current Bang & Olufsen television and music systems. A remote control must be able to be operated in the dark, without glasses and without moving your eyes from the screen. That’s why the most often-used controls on the Beo4 are gathered together on one multi-functional button which you can control with just your thumb: programme shift, video play and wind. Choose a function and your command is registered on the Beo4’s LCD display. Simple and logical, so the manual can be put away after a few days. The design is ergonomical and so tough that Beo4 can be left in the hands of the youngest user.
Beo4 Mark III Update – November 2004
Released in order to ensure that the remote control keeps up to date with products currently sold, as well as new products on the horizon, Beo4 Mark III was produced for sale at the end of 2004.
Visual changes were made to the V.TAPE, A.TAPE and SAT buttons and are now renamed V.MEM, A.MEM and DTV. A number of changes have also been made to the ‘LIST’ functions. The part number of the new remote is: 1162700
Beo4 remote control is provided with all new Bang & Olufsen TV receivers. It may be purchased as a separate accessory (around £155 – 2004 prices) to control audio equipment and lights. It works with all recent (post-1994) Bang & Olufsen products and also Beolink® around-the-house systems. It is one of the most powerful remote controls on the market; so much so, that the user needs not point it directly at the appliance being controlled.
The star-shaped control can be operated by your thumb alone – you don’t need to move your eyes to look to see what you’re doing. Extra ‘buttons’ can be programmed into the unit to control other not so much needed functions of Bang & Olufsen products.
Plastic-free surface on remote control units
“Surface treatment is very important to Bang & Olufsen. It affects not only the appearance but also the feel of a piece of equipment” states Technology Director Peter Petersen. “A product is created to be used, and you can’t do that without touching it.”
“A Bang & Olufsen terminal – or remote control – must sit nicely and comfortably in the hand. So we don’t coat it with plastic. A plastic terminal somehow doesn’t feel as genuine as ours. And gets hot and sweaty, too. After a great deal of work on the choice of materials we have selected zinc for all our terminals. It sits well in the hand and is pleasant to touch. The heat from the hand is conducted away, so the terminal never feels clammy. In design terms, this choice represents an extra form of quality.”
Bang & Olufsen terminals, of course, are not just attractive to the eye and pleasing to the hand. User interface is in fact one of Bang & Olufsen’s main concerns, where technology is really put in the service of humankind. Through logic operations, in fact, B&O’s remote control units make life with the product a pleasant experience.
Handing it intuitively to Bang & Olufsen: a history of remote controls
Bang & Olufsen’s first remote control came on the market in 1974. That year, Bang & Olufsen launched two products, each with a remote control of the same design. It was the size of a small cigar case and had a steel top plate. These two remote controls, which were not integrated, were the Beovision 6000 Commander and the Beomaster 6000 Commander. The TV remote control allowed the user to select programmes and picture quality from the comfort of an armchair. The remote control for the stereo enabled the user to control a four-channel sound system.
Before too long remote controls became smaller, in the form of Beovision 6002’s Beovision Control Module. The buttons on its surface were designed so that you could use the remote control without looking at it. Those for turning down a setting were shaped to curve downwards, while the buttons for turning up a setting curved upwards.
The following Video Terminal was cast in zinc so that heat was conducted away from the palm of the hand. This remote control, which used an infrared beam, was launched in 1980. It was quite narrow, with a keypad that both resembled and functioned the same way as the buttons on a telephone. This was another way of helping the user to operate the remote control without looking at it. This version introduced additional buttons for operating Teletext TV.
The following year, Bang & Olufsen added functions for operating video recorders and a new version of the Beovision Control Module. System integration had advanced to the point of sharing a remote control between the Beovision 8800 and Beocord 8800 Video.
The next generation of remote controls arrived when it became necessary to transfer more operating information that, for purely technical reasons, could not be incorporated into a single remote control. Now sound could be transferred between the television and the stereo system. This became possible with the combination of a video terminal and an audio terminal into an AV Terminal – the forerunner of Beolink 1000 – in 1985.
In 1987, all audio, video and audio/video remote controls were integrated into one unit with the Beolink 1000. Since then, Bang & Olufsen has pursued a strategy of only having one remote control for all products – most recently with Beo4, which is capable of operating all products. Beo1 is a minor exception to the strategy. It only operated Beocenter 1 and Beovision 1 and was intended for a new customer segment, which it did not completely succeed in capturing. For this reason, it was replaced by the Beo4 from autumn 2002.
Beo4 Specifications
In general, Bang & Olufsen’s development of remote controls can be summed up in a simple concept: Intuitive use. It is important to be able to adjust sound and picture from wherever you may be in the home. Accordingly, Bang & Olufsen has chosen simple functions – and that, of course, also has implications for the design of the remote control. It’s easy enough to pack a lot of buttons and functions into a remote control, but Bang & Olufsen has chosen a simple operational philosophy for the customer.
Beo4 has relatively few buttons, but it can retrieve a lot of information if required. That is what you call quality. Since the development of the first remote control cast in zinc, the company’s remote controls have had a certain intrinsic weight. This helps to give a sense of quality. Last but not least, the remote control is renowned for having a long range. You don’t have to get into a special position to communicate with the system. Once you have the remote control in your hand, you are ‘in total command’.
(Taken from Beolink Magazine: ‘The First 50 Years of Television’ © Bang & Olufsen a/s 2002)
Posted on
BeoLink PC2
Bang & Olufsen BeoLink PC2
As the boundaries between life and work blur, the computer is becoming more than just an information tool – it’s also a growing source of entertainment.
While others focus on bits, bytes and software updates B&O concentrates on possibilities. For Bang & Olufsen the challenge is about creating a link between the real and virtual world to give you options you never until now thought possible. Digital music stored on the computer can now be accessed throughout the home via Bang & Olufsen’s Beolink® system.
Combining Bang & Olufsen’s logical principles of operation and the successful BeoPlayer concept – Bang & Olufsen’s free MP3 player – Beolink® PC2 allows customers to extend the potential of their PC and receive additional enjoyment out of their Beolink® system. Twenty years of experience within distribution of sound and picture makes this integration between these two worlds possible.
It works like this: BeoPlayer has organised all your music on the PC in different categories such as artist, genre, album, etc. This means that you can access your entire collection of music just press N.MUSIC on the Beo4 remote control and the music starts playing through the loudspeakers in the room where you are placed.
You are able to record all you CD’s to your PC also with the Beolink® PC2, which means that you can have your entire music library stored the same place, but be able to access it from anywhere around the house.
If you want to improve the sound performance of your Internet music in the room where your computer is placed, a pair of BeoLab 4000 active speakers combined with Beolink® PC2 will turn your computer into an excellent music system. Furthermore, if you want to be able to remote control your Internet music, just add a Bang & Olufsen Beo4 remote control and an IR-receiver to your setup.
Whereas the music found on the computer may be distributed throughout the home, all other sources in your Beolink® system (Radio, TV, Satellite, DVD, VHS, etc.) can be accessed and operated via the on-screen Beolink® PC 2 control bar in the home office.*)
Tuner cards
To show video sources on your PC, you must have a Beolink compatible tuner card in your PC. For the moment, the following cards are compatible (Please check back on this site for latest updates on compatible tuner/graphic cards):
Beolink PC2 (From software version 3.10)
ATI All In Wonder 9000 and 8500, USA
ATI ALL-IN-WONDER 9600 PRO 128MB DDR
Hercules or Sapphire All In Wonder 9000 and 8500, EU
Hauppauge WinTV PCI-FM Model 747 (Pal B/G/I)
Hauppauge WinTV PCI-FM Model 628 (SECAM)
Hauppauge WinTV PCI-FM Model 401 (NTSC)
Hauppauge WinTV PCI-FM Model 647 (Pal I) UK
ATI ALL-IN-WONDER® RADEON Type: AGP Memory: 32MB DDR RAM
ATI ALL-IN-WONDER® RADEON Type: PCI Memory: 32MB DDR RAM
ATI ALL-IN-WONDER® 128 PRO Type: AGP Memory: 32MB RAM
BeoLink PC2 was renamed BeoPort from November 2005.
