Tuning a BEOMASTER 7000 with a BEOLINK1000
  • #1742
    TheHuf
      • Topics Started 1
      • Total Posts 3
      Hi there ,
      I’m new to the B&O scene. I have acquired a BEOMASTER 7000 with BEOLINK1000 controller +with Menu tab. Can I tune the radio with it. I’m presuming this is not possible & I need a BEOLINK 7000. Are there any key combinations I can use to tune each station.  Any help / tips grateful accepted.
      Best wishes, Keith
      #1749
      trackbeo
        • Topics Started 6
        • Total Posts 245
        Use single number keys 0-9 to go to radio station presets. Use the GOTO  button to type in tuning with number keys.  GOTO then TURN switches AM/FM.  There’s search mode, too, with << and >> buttons.  You may find the Beocenter 9500 manual helpful because it describes using the older Beolink rather than the special Beolink 7000, which is what the Beosystem 7000 manuals describe.
        #1754
        TheHuf
          • Topics Started 1
          • Total Posts 3
          Thanks for the suggestions, I’ll look at this when I’m back. Thank alot.
          #1760
          TheHuf
            • Topics Started 1
            • Total Posts 3
            Hi, I got the hang of the tuning quickly
            Once I worked out which stations had good reception.
            Thanks.
