Hi all! I have a Beo4 paired to a BS9000.
Through the stress and joy of replacing the laser – I’ve realised the remote has limited functionality. Seems certain buttons are not working.
7/8/9 and TEXT/0/MENU all not working. Even the down arrow.
It’s paired correctly (A.OPT Mode 1) . I’ve pulled it apart and gave it a clean with electrical component cleaner – thought I knew what I was doing – it seemed to temporary (and briefly) fix it then now I lost the top row of buttons.
TV / Light / Radio all now don’t work.
SAT/DVD/CD and VTAPE / RECORD/ ATAPE are all fine.
I replaced the electrical membrane inside but same issue persists. So the button membrane is fine, but by process of elimination something else is wrong, assuming circuit board.
Wondering if anyone else has encountered this type of issue and what they discovered was the cause and/or what they did to fix it?
Appreciate the help and advice! Cheers!
