BeoVision 4002
Beovision 4002 and 4402 were colour receivers with 26″ screens. Natural colours, sharp, precise image definition and high-fidelity sound reproduction are all features you can take for granted, according to the 1970 – 80 Bang & Olufsen product catalogue. Their high reliability levels were due to modular construction techniques and low heat-generation. Beovision 4002 consumed […]
Beovision 4002 and 4402 were colour receivers with 26″ screens. Natural colours, sharp, precise image definition and high-fidelity sound reproduction are all features you can take for granted, according to the 1970 – 80 Bang & Olufsen product catalogue. Their high reliability levels were due to modular construction techniques and low heat-generation. Beovision 4002 consumed only 110 watts – less than a black and white set of years previously.
Both sets were extremely easy to use. There were facilities for presetting up to eight stations so that subsequent programme selection was just a matter of pressing one button. This turned the set on at the same time.
Beovision 4402 had the additional convenience of a cordless (ultrasonic) remote control. The set could also be supplied equipped for Teletext reception. There was automatic synchronisation of VCR programmes on all channels.
Picture tube size: 66cm
Cabinet: wood veneer
Number of programmes: 8 VHF – UHF
Easy touch
Range: UHF 21 – 69, VHF 2 – 12
Start time: approx. 5 sec
Speakers:
1 forward-facing pressure chamber
Sound power output: 6.5 W
Harmonic distortion: < 0.8 %
Frequency range: +/- 1.5 dB 60 – 15,000 Hz
Power bandwidth: 60 – 20,000 Hz
Power supply: 180 – 265 V
Power consumption: 110 W
Standby: 0 W
Dimensions W x H x D: 69.5 x 49 x 46cm
Weight: 36 kg
Undercarriages: Cross-base with castors 3043, Table with castors 3055
No downloads available.
Photo Gallery
No gallery images.
