Beosystem 3000c
An iconic turntable from our past meets audio mastery of the future The iconic Beogram 3000 series, upgraded into one modern-day turntable hifi system. Limited edition of 100 units. Engraved, sealed, delivered Available in a limited edition of 100 pieces, each Beogram 3000c is engraved with its edition number and certificate of authenticity. Your […]
Available in a limited edition of 100 pieces, each Beogram 3000c is engraved with its edition number and certificate of authenticity. Your chance to own a piece of history, remastered for tomorrow.
Uncompromising design
Unheard of precision. In 1972, we invented the world’s first electronically controlled tangential tracking turntable, and it sounds as revolutionary today as it did then.
Released in the 1980s, Beogram 3000 carried tangential tracking into the next decade. Beogram 3000c’s tonearm still sits securely in the grooves, guaranteeing a rich listening experience and high-quality playback — as it was in the studio.
Coming full circle
Our signature patterned platter sits centre stage, while an elevated base gives the sense that Beogram 3000c is hovering above the surface. According to the designer, Steve McGugan, the idea was to create the illusion of a floating object. This is classic Bang & Olufsen design language, brought forward.
Less is more
When Beogram 3000 was introduced in 1985, it represented a new archetype of the tangential tracking turntable era. Cutting-edge advancements allowed for a more compact design that revolutionised turntable silhouettes in the years that followed.
Included in the box
1 x Beogram 3000c Grey Aluminium/Artisan Walnut
2 x Beolab 8 Grey Aluminium/Artisan Walnut
3 x carefully selected LP’s
Recommended Room Size
10-60 m² 100-600 ft²
Speaker Configuration
Per Speaker: 1 x 0.6″” tweeter 1 x 3″ mid-range 1 x 5 ¼” woofer
Amplifier
Per Speaker: 1 x 50 W class D for tweeter 1 x 50 W class D for mid-range 1 x 200 W class D for woofer
Total: 300 W
Frequency Range
28 – 23.000 Hz
Maximum Sound Pressure Level (SPL) @1m
Per Speaker: 101 dB (SPL) Per pair: 104 dB (SPL)
Bass Capability @1m
Per Speaker: 84 dB (SPL) Per pair: 90 dB (SPL)
Advanced Sound Features
Active Room Compensation Fluid Sweet Spot Beam Width Control Adaptive Bass Linearization Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Designer
Beogram 3000: Steve McGugan Beolab 8: Noto GmbH
Materials
Beogram 3000c: Aluminium Walnut Polymer
Beolab 8: Aluminium Walnut Polymer
Dimensions W x H x D
Beogram 3000c: 42 W x 7.5 H x 32.5 D cm Per Beolab 8: Table Stand: 18.9 W x 29 H x 16.5 D cm
Weight
Beogram 3000c: 5.3 kg Per Beolab 8: 4.1 kg (without stand)
Power
Beogram 3000c: 100-240V 50/60Hz mains cable Beolab 8: 100-240V 50/60Hz mains cable
Bluetooth Version
Beolab 8: Bluetooth 5.3
Bluetooth Codecs
Android: SBC iOS: SBC, AAC
Ultra-Wide-Band
Yes
WiFi
Beolab 8: Dual-Band Wi-Fi (2.4 & 5 GHz) IEEE 802.11 b/g/a/n/ac/ax
Streaming Services
Via Beolab 8: Apple AirPlay Spotify Connect Google Cast TIDAL Connect B&O Radio Deezer QPlay 2.0
Beolink Multiroom
Seamlessly connect multiple Bang & Olufsen speakers to expand your music experience.
Wireless Power Link / WiSA
Yes (up to 24 bit / 96 kHz)
Physical Connections
Beogram 3000c: 1 x Powerlink (DIN) 1 x Power
Per Beolab 8: 2 x Ethernet (for Internet and Digital Power Link) 1 x Power Link (RJ45) 1 x Line-in via USB-C 1 x Power
Remote Control
Bang & Olufsen App Beoremote One BT Beoremote Halo
On-Device Controls
Yes
System Items
| Title | Categories | View |
Photo Gallery
