BeoSound 5
Your Music At Your Fingertips The long awaited Digital Music player from B&O strikes out in a new direction for the Danish Company. Revolutionary control surfaces mean that the days or smudged touch screens are a thing of the past, yet the controls maintain a real sense of interaction with the music. More Of The […]
More Of The Same
This is what makes the Beosound 5 special. Unlike other products on the market, this actually compares the actual music using a complicated algorithm to make an never ending musical play list completely automatically. You can construct your own list but MOTS will still, if you wish continue this on once your choices have reached the end.
A Perfect Pair
The Beosound 5 is partnered with the new Beomaster 5. This is an updated Beomedia and has a storage capacity of 500Gb. All Beosound 5s will come with the Beomaster 5 and it is also possible to have the Beomaster 5 built into a Beovision 9. Up to 28,000 tracks at WMA Lossless quality can be stored on the disc which should mean enough music to play a new track without repeating itself for 75 days.
Later versions had the more reliable 1Tb HDD fitted which could store double the amount of music!
Mounting Options
The head unit is supplied with a flat to wall bracket in the box. Optional mounts extended (angled) wall mount, table mount and floor mount were all available from launch. A wall mount bracket for the connection box was launched with BeoSound 5
Type Number:2900, 1753, 1754, 1755
Release Date:2008, 2009, 2010, 2011, 2012
Colour / Finish:Black and Silver
DIMENSIONS/WEIGHT 12” x 7” x 3” / 5.8 lbs(31cm x 19cm x 8cm/2.65 kg)
DISPLAY 10.4”—1024 x 768
CONNECTIONS Only connects to BeoMaster 5 (DVI, power, USB)
POWER CONSUMPTION Power supplied via BeoMaster 5
FEATURES N.Music, N.Radio, MOTS (More Of The Same)
ACCESSORIES Wall bracket (included); Aluminum/black
Wall bracket extended; Aluminum/black
Table stand: Iron/black
Floor stand: Iron/aluminum
Language
User Guide
EN
BeoSound 5 User guide
Installation Guide
EN
BeoSound 5 Installation Guide
Service Manual
Multi
2900
BeoSound 5 Service Manual
Service Manual
Multi
1753, 1754, 1755
BeoMaster 5 Service Manual
Info
Multi
BeoMaster 5 Service Tool
