BeoMaster 2000 (1983)
Beomaster 2000 was an advanced 2 x 25 watts RMS receiver with Long, Medium and FM band radio coverage. Four FM stations could be pre-set for instant recall. There was also provision for pre-setting one AM station. The low-distortion stereo amplifier included a new feature unique to Bang & Olufsen. It was called Automatic Power […]
The low-distortion stereo amplifier included a new feature unique to Bang & Olufsen. It was called Automatic Power Handling Control (APHC). This was a technique whereby the dynamic range and power parameters of the signal were continuously monitored, and if their combined effect threatens to cause amplifier clipping or damage to the speakers, the APHC circuit instructed the set’s microcomputer to turn the volume down to a safe level.
All primary functions were operated by finger-tip contact on the Beomaster’s Sensitouch control panel. There were no knobs or buttons to press. The status of all controls was shown on an illuminated display panel. Secondary controls were protected beneath a self-opening lid that was released by touching the unit’s front edge.
Beomaster 2000 could be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products. The receiver was designed by Jacob Jensen and was a direct descendant of Beomaster 2400.
Type Number:2917, 2915, 2913, 2912, 2911, 2919
Release Date:1983, 1984, 1985, 1986, 1987
Designer:Jacob Jensen
Colour / Finish:Grey
Power output RMS DIN/IEC: 2 x 30 W / 8 ohms
Harmonic distortion DIN/IEC: < 0.08 %
Power output 20 – 20,000 Hz IHF: 2 x 25 W / 8 ohms
Total harmonic distortion IHF: < 0.1 %
Dynamic headroom: 1.6 dB / 8 ohms
Intermodulation IHF: 75 dB
Tape A-weighted: > 80 dB
FM range: 87.5 – 108 MHz
Signal-to-noise ratio at 65 dBf mono: 72 dB
Signal-to-noise ratio at 65 dBf stereo: 67 dB
Distortion at 65 dBf stereo: 0.35 %
Stereo channel separation: 36 dB
Sub-carrier product rejection: 55 dB
AM tuner section
Only types: 2912, 2915, 2917
LW range: 150 – 350 kHz
MW range: 520 – 1610 kHz
LW sensitivity: 20 dB S/N ratio 120 µV
MW sensitivity: 20 dB S/N ratio 100 µV
Power supply:
2911 – 2917: 220 V
2912 – 2915: 240 V
Power consumption 20 – 170 W
Dimensions W x H x D: 62 x 7 x 25cm
RIAA: built-in
Connections: Speakers 2 set
Phono: DIN
Tape: 1 DIN
Tape: 2 Phono
Headphone: jack
Language
  Date
User Guide
EN
BeoMaster 2000 User Guide
Service Manual
EN
2801
09-75
BeoMaster 2000 Service Manual
Service Manual
EN
2911, 2913, 2915, 2917, 2919
01-84
