BeoLab 90
BeoLab 90
Unprecedented power and acoustic performance. Floor standing speakers that seamlessly adapt to your living space and music preferences. Built for audiophiles Crafted to meet the needs of even the most discerning of listeners, Beolab 90 brings a truly powerful sound into a home entertainment set up. With no less than 8,200 watts per speaker, 18 […]
Crafted to meet the needs of even the most discerning of listeners, Beolab 90 brings a truly powerful sound into a home entertainment set up. With no less than 8,200 watts per speaker, 18 premium drivers, 14 channels of ICEpower, 300 watts amplifiers and 4 channels of 1000 watts class D Heliox amplifiers, these speakers ensure music and soundtracks can be enjoyed to their fullest.
Intelligent stereo sound
Advanced stereo speakers adapt to your living space and preferred listening experiences to create unforgettable, everyday excellence. With 18 premium drivers and 8.200W per speaker, Beolab 90 has powerful, very high-quality sound for sensational music listening and home entertainment.
Active Room Compensation
Active Room Compensation acoustically optimises the sound of your speaker to deliver your music perfectly. The technology analyses your room to adjust for speaker placement, as well as walls and furniture, to ensure a sensational listening experience in any room.
Beam Width Control
Beam Width Control gives you the power to control the sound dispersion to suit your needs. A narrow sound beam offers precise delivery to a particular listening spot. Wide is perfect for movies, while 360-degree omnidirectional sound is superb for parties.
Beam Direction Control
Created for flexible living spaces, Beolab 90 is designed to ensure you always have a front row seat. Our Beam Direction Control technology lets you define one of five directions as the acoustic front, giving you a tailored sweet spot listening experience.
Creating a masterpiece
A floor speaker with the size and complexity of Beolab 90 is quite something to manufacture. The top tower is cast in 10mm thick plastic, and the main cabinet is solidly cast in aluminium. These are fitted together and all the amplifiers and drivers are mounted, the software is then installed and as the last step the “naked” loudspeaker is clad in the semi-transparent fabric and the aluminium crowns are installed.
Designed to perform
Shaped to optimise performance, Beolab 90 has been carefully engineered for the best possible sound every time. The bold design is based on a complex aluminium cabinet with a rock-solid structure, yet its curved wooden base and fabric sails create an aura of lightness.
Advanced features. Simple controls.
The power to harness the mighty Beolab 90 lies in the palm of your hand. Use your Beoremote One, Beoremote Halo or the Bang & Olufsen App to play music, adjust settings and access your presets. You can also control your sound via your Beovision TV, for seamless entertainment experiences.
Designer:Noto GmbH
Recommended Room Size
30-200 m²
300-2000 ft²
Speaker Configuration
Per Speaker:
7 x 1″” Scan-Speak Illuminator tweeter
7 x 4 ½”” Scan-Speak Illuminator mid-range
3 x 10″” Scan-Speak Discovery woofer
1 x 13″” Scan-Speak Revelator front woofer
Amplifier
Per Speaker:
7 x Bang & Olufsen ICEpower AM300-X for tweeter
7 x Bang & Olufsen ICEpower AM300-X for mid-range
3 x Heliox AM1000-1 for woofer
1 x Heliox AM1000-1 for front woofer
Frequency Range
43.000 Hz
Maximum Sound Pressure Level (SPL) @1m
Per pair:
126 dB SPL
Bass Capability
Per pair:
118 dB SPL
Advanced Sound Features
Adaptive Bass Linearization
Advanced Active Room Compensation
Beam Direction Control (5 sides)
Beam Width Control
Thermal Protection
Materials
Aluminium
Fabric
Wood
Dimensions
73.5 W x 125.3 H x 74.7 D cm
Weight
Per Speaker:
137 kg
Power supply
100-240V 50/60Hz mains cable
Wireless Powerlink / WiSA
Yes (up to 24 bit / 96 kHz)
Physical Connections
Primary Speaker:
1 x RCA (L/R)
1 x MIC / IR
1 x Power Link (RJ45)
1 x S/P DIF (24 bit / 192 kHz)
1 x XLR (L/R) (fully balanced)
1 x Optical (24 bit / 96 kHz)
1 x USB-B (Audio) (24 bit / 192 kHz)
1 x USB-A
2 x Digital Power Link
1 x Digital Power Link / Ethernet
1 x Power
Secondary Speaker:
1 x USB-B (Audio)
1 x USB-A
3 x Digital Power Link
1 x Power
Language
Data Sheet
EN
BeoLab 90 Data Sheet
