BeoLab 8
Compact and powerful as a surround, stereo, or standalone speaker, Beolab 8 adapts to your space, offers versatile connections, and elevates your audio experience through advanced acoustics, materials, and stand options. Discover true adaptability. A surround sound powerhouse Cinema? Beolab 8 slots seamlessly into your current set up as a rear surround powerhouse. It connects […]
It connects with your TVs and speakers – even older models – using Powerlink and Wireless Powerlink. Time is no problem. Space is no issue.
Beolab 8 takes the floor with a range of elegant stand options. Or truly elevate it with an elegant wall or ceiling mount.
Contact your Bang & Olufsen store to get more support on Beolab 8 in a cinema setup.
A stirring stereo experience
Left meets right: two Beolab 8s deliver a more stunning soundstage. They’ll work in concert to fill the room.
And no matter how you move your Beolab 8s around, a dedicated mic reads the space, adapting and fine-tuning for optimal playback. So you can immerse yourself in precise, powerful stereo sound.
Setup? It’s is as easy as plug, pair and play using the Bang & Olufsen App. It’ll even adapt to your favourite spot in the room.
A standalone masterpiece
Hear it perform in harmony. Have it fly solo. Either way, the sound soars.
Use Beolab 8 on its own and experience a new world of detail, tuned at the ears of our in-house Tonmeisters. Crisp vocals. Thumping drums. Hard-hitting bass. It’s a speaker that stands apart – but it also bands together. Use it as a multiroom speaker and create soundscapes around your home, so you’re always in the music.
Everything is configured easily using the Bang & Olufsen app.
Your room. Mapped.
Every room is unique. That’s why Beolab 8 carefully maps its environment with a dedicated microphone – to deliver crystal clear quality and musical fidelity no matter the size or setup of your space. A neodymium motor drives the sound home. So you can enjoy a soundscape adapted to your surroundings and your immersion.
Always hits the spot
Beolab 8 does more than adapt to your room. It adapts to you. Using ultra-wideband technology, it directs the acoustic sweetspot to wherever you are. As long as your phone is on you, the sound is too. No need to readjust your speaker, or your room. *Expected early 2024. Fluid Sweet Spot only works when using Beolab 8 in a stereo setup with Apple iPhone (Apple iPhone 11 or newer).
Narrow. Wide. You decide.
Beolab 8’s beam width control lets you switch seamlessly between two listening experiences. Narrow down with precision audio channelled directly to you. Or go wide and diffuse sound throughout your space. Which mode is it in? The LEDs on the front will enlighten you.
Recommended Room Size
10-60 m²
100-600 ft²
Speaker Configuration
Per Speaker:
1 x 0.6″ tweeter
1 x 3″ mid-range
1 x 5 ¼” woofer
Amplifier
Per Speaker:
1 x 50 W class D for tweeter
1 x 50 W class D for mid-range
1 x 200 W class D for woofer
Frequency Range
28-23.000 Hz
Maximum Sound Pressure Level (SPL) @1m
Per Pair:
104 dB (SPL)
Bass Capability
Per Pair:
90 dB (SPL)
Advanced Sound Features
Active Room Compensation
Fluid Sweet Spot (expected early 2024)
Beam Width Control
Adaptive Bass Linearization
Thermal Protection
Customisable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Fabric / Wood
Polymer
Dimensions
Per Speaker:
Table Stand: 18.9 W x 29 H x 16.5 D cm
Floor Stand: 30 W x 114 H x 30 D cm
Wall Bracket: 21.5 W x 27.9 H x 16.5 D cm
*dimensions depend on the speaker placement & tilt angle
Weight
Per Speaker:
4.1 kg (without stand or bracket)
Power Supply
Power supply built-in
Power Cable
Bluetooth Version
Bluetooth 5.3
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Ultra-Wideband
Yes
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac/ax
Streaming Services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Wireless Powerlink / WiSA
Yes (up to 24 bit / 48 kHz)
Physical Connections
Per Speaker:
2 x Ethernet
1 x Power Link (RJ45)
1 x Line-in via USB-C
1 x Power
Remote Control
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Type | Language | Type | |
User Guide | EN | Beolab 8 User Guide | |
Data Sheet | EN | Beolab 8 Data Sheet |
Photo Gallery
No gallery images.
