BeoGram 9500
In design, technology and operating philosophy, the Beogram 9500 turntable was a perfect match for the Beocenter 9500 system. Using a light-weight MMC2 cartridge, its electronic tangential arm played each record at the exact angle it was cut giving the most precise reading of the grooves ensuring that every nuance of a recording was captured. The arm […]
The arm was suspended by a patented Bang & Olufsen system which helped prevent vibrations from any source reaching the cartridge. And the chassis suspension acted as an effective buffer against external vibrations.
Speeds: 33 – 45 rpm.
Speed deviation < +/- 0.2 %
Wow and flutter, DIN: 80 dB
Power supply:
5966: 220 V
5968: 120 V
5969: 100 V
5970: 240 V
Power consumption: < 10 W
Weight 5.3 kg
Link compatibility: Data Link
No downloads available.
Photo Gallery
No gallery images.
