BeoGram 6006
This deck was the Beogram designed for use with the Beomaster 6000. To all intents the same deck as the Beogram 8000, it had a MMC20EN cartridge and black keys to differentiate it from its more expensive brother. Not replaced directly when the newer cartridges were released as the Beogram 6002 was belt drive rather than tangential drive. This was […]
This was a confusing product as it offered the same performance as the Beogram 8000 but was cheaper due to the lesser cartridge. It was not a big seller and it was not surprising that the range was rationalised by keeping a top performing Beogram in the Beogram 8002 and a substantially simpler deck in the Beogram 6002.
Wow and flutter DIN: 65 dB
Rumble DIN unweighted: > 45 dB
Speeds: 33 – 45 rpm
Speed deviation: < +/- 0.02 %, +/- 3 %: < 0.04°
Power supply:
5623: 120V
5625: 220V
5626: 240V
5627: 240V
Power consumption: 15 W
Dimensions W x H x D: 49 x 9 x 37.5cm
Weight: 9 kg
Pickup: MMC 20 EN
Tracking force: 12 mN / 1.2 g
Type | Language | Type | |
User Guide | EN | BeoGram 6006 User Guide | |
Service Manual | Multi | BeoGram 6006 Service Manual |
Photo Gallery
No gallery images.
