BeoGram 6000 (1974)
BeoGram 6000 (1974)
This deck was a variant of the Beogram 4002 but fitted as standard with a CD4 decoder. As with the 4002, there were two clear models , the earlier with the AC motor and the later with a DC motor. The DIN plug was unusual in that it carried 4 discrete channels and was therefore […]
The DIN plug was unusual in that it carried 4 discrete channels and was therefore best suited to the Beomaster 6000 or 3400. It did have a built in RIAA though and would play stereo records perfectly happily as the rear channels could be switched off.
The cartridge specified was the MMC6000, the ultimate cartridge in the range designed by and bearing the name of one of B&O’s pre-eminent engineers, Subir Pramanik.
Type Number:5512
Release Date:1974, 1975, 1976, 1977, 1978
Designer:Jacob Jensen
Colour / Finish:Rosewood, Teak, White
Cartridge Type:MMC6000
Sound system CD – 4, stereo, matrix
Output 4 x 200 mV / 470 komhs
Speeds 33 – 45 rpm.
Tonearm
Tangential
Automatic record-size
Yes
Automatic pickup movement Yes
Automatic speed selection Yes
Wow and flutter DIN
45 dB
Rumble DIN weighted > 65 dB
Speed deviation 6 %
Dial for speed 2 pointers
Stylus pressure range 0 – 1.5 gram
Tangential tracking
< 0.04°
Lift system Electronic
Antiskating Parallel tracking, error angle
Motor
Servo controlled DC
Drive system Belt
Turnable 30 cm 1.3 kg
Power supply
110 – 130 – 220 – 240 volts
Power consumption 30 watts
Dimensions W x H x D 49 x 10 x 38 cm
Weight 11 kg
Pickup
MMC 6000
Stylus Pramanik diamond
Radius of curvature (CD-4 quadro)
Frequency range 20 – 15,000 Hz +/- 1.5 dB
Recommended stylus pressure 1 gram
Language
Language
User Guide
EN
BeoGram 6000 User Guide
Service Manual Part 1
EN
5501, 5502
BeoGram 6000 Service Manual
Service Manual Part 2
EN
5501, 5502
Service Manual
EN
5514, 5515
Service Manual
EN
5502, 5505
Service Manual
EN
5751, 5753, 5754
