BeoCom 600
BeoCom 600
BeoCom 600, the classic telephone from Bang & Olufsen… what else is there to say? A well-equipped telephone with superb sound quality. The design is truly timeless. BeoCom 600 is a simplified version of the BeoCom 2000 and lacks the extensive display and memory facilities but has the same sound quality. In addition to high […]
A well-equipped telephone with superb sound quality. The design is truly timeless. BeoCom 600 is a simplified version of the BeoCom 2000 and lacks the extensive display and memory facilities but has the same sound quality. In addition to high sound quality and ergonomic design, it has a display, short number memory, call waiting loudspeakers, listening-in function and volume control.
The ergonomically arranged keypad with large easy touch buttons makes using BeoCom 600 a delight from the very start. With a bass reflex speaker in the handset, 10 numbers in memory, 3 quick call keys, last number redial, volume control, microphone mute (for secrecy), tone ringer with 2 settings plus off.
Release Date:1996, 1997, 1998
Corded analogue telephone
Placement: desktop
Finish: black, Saxon blue, gothic green or cardinal red
Memory (Phonebook):
10 numbers
Redial: 1 numbers.
Quick call / service 3 buttons
Features:
Volume control
Microphone mute
Ringer settings
Dimensions W x H x D: 210 x 80 x 210mm inc. handset
Weight: 900g ( handset 115g )
No downloads available.
