Posted on
BeoLab 11
Bang & Olufsen Beolab 11
The Beolab 11 is the new lower priced subwoofer, designed in particular to accompany the Beovision 10. It utilises a design principle seen in other subwoofers of having identical units firing in opposite directions and hence making the structure more stable. Indeed the B&W PV1 does just this using B&O ICE amplification.
B&O however have added a new twist to the equation by having the two 130mm drive units firing inwardly and so allowing the external casing to be made from the same polished aluminium seen in the Beovision 10.
Amplification is via a 250W ICE unit and so the speaker can be seen to fit below the Beolab 2 in the range.
Mounting Options
As a result of the balanced drive units, the Beolab 11 will be offered both as a floor standing model and with a wall bracket. This is again designed to match the Beovision 10. The Beovision 10 in both 40″ and 46″ versions is designed so that it can be used as a stand alone set but still utilise the subwoofer output.
This should add the lower frequencies not able to be produced due to the small speaker enclosure of the Beovision 10.
The Beolab 11 will stand just 320mm high on the floor stand. The cross over frequency and bass lift is set with a collection of switches on the base. There is a Powerlink connection and two Powerlink outputs so it can be used in a stereo system.
Posted on
BeoLab 9
Bang & Olufsen BeoLab 9
After much anticipation, Bang & Olufsen have released the BeoLab 9. This acoustic lens speaker had been expected for some time, and it effectively replaces BeoLab 1 which was discontinued.
The design of BeoLab 9 continues B&O’s move away from elegant though easily imitated column loudspeakers to shorter, rounder forms with larger cabinet volumes and better potential for strong bass performance. B&O’s distinctive acoustic lens is also present, and the speakers’s height means that it is perfectly positioned at ear-level when the listener is seated.
The acoustic lens is cast from zinc and plated with matt chrome. Its prominent position gives the speaker a slightly hunched appearance – but B&O compare it to a lighthouse. The overall proportions are pleasing and there are some very nice details. For example, the power LED is concealed inside the acoustic lens, and the cooling fins/vents at the rear match the curve of the cabinet. The majority of the cabinet is fabric covered – black will probably be the most popular choice here, but it is also available in dark grey, blue and red.
There are three drivers: a 10” bass unit in an 18 litre enclosure, a 5” mid-range unit in a 4 litre enclosure and a 0.75” treble unit in the acoustic lens. All drivers are separately amplified, but there is only one ICEpower amplifier of 500W which drives the bass unit. The mid-range and treble units each have their own 100W analogue hybrid amplifier.
Posted on
BeoLab 7-1
Bang & Olufsen BeoLab 7.1
Hi-fi television acoustics
Packed with advanced technology, BeoLab 7 is, quite simply, the most powerful stereo speaker ever developed for TV. With six individual driver units, all powered by their own digital ICEpower amplifier, BeoLab 7 delivers an unequalled sound performance for your TV viewing. The beam-shaped loudspeaker below the screen provides superb acoustic performance and signifies the presence of sound as an integral part of your viewing experience. Musically, the speaker rivals many hi-fi systems, and is quite capable of being used as a BeoLink speaker.
The natural fit
BeoLab 7 is specially developed for BeoVision 7 to contribute the ultimate stereo sound performance to the viewing experience. BeoLab 7-1 is the natural accompaniment for the BeoVision 7-32 LCD television, while the broader beam of BeoLab 7-2 is designed for BeoVision 7-40. In addition, BeoLab 7 stereo loudspeakers fit naturally under the BeoVision 4 plasma screen, or under a projection screen. In this application, the speaker can be either wall-mounted or placed on a special tabletop stand.
Colours to match
Long and lean, BeoLab 7-1 and BeoLab 7-2 look at home under a BeoVision 7 or BeoVision 4, or as part of a projection screen setup. The shorter BeoLab 7-1 is best suited for the BeoVision 7-32” screen. The loudspeaker cabinet is made from a single piece of aluminium and coated in a resilient black soft-touch lacquer. The perforated aluminium front grill now comes anodised in five different colours: Light and dark grey, blue, red and black.
A firm grip on powerful sound
A special three-way bass reflex construction incorporates six individual units – two each for treble, mid-range and bass. Each driver is powered by a unique built-in ICEpower amplifier, delivering a combined effect of 750 watt. In addition, BeoLab 7-1 and 7-2 are equipped with thermal protection circuits and Adaptive Bass Linearisation (ABL), which ensures maximum performance without distortion, even at very high volume. Bang & Olufsen has a quarter of a century of experience making loudspeaker cabinets from extruded aluminium. This technique allows for very rigid and compact enclosures with powerful sound performance.
Note that BeoLab 7-1 was designed to be used with the BV4-37 and BV4-42. The wider BeoLab 7-2 may be used with the larger-version BeoVision 4: BV4-50 and BV4-65.
Mounting Options
All four versions of BeoLab 7 were designed for incorporation with Bang & Olufsen’s motor stand options.
Posted on
BeoLab 5
Bang & Olufsen BeoLab 5
” If your ultimate passion is to get as close to the music of your favourite artists as possible, the new BeoLab 5 will take you there. Conceived, designed and built by Bang & Olufsen, BeoLab 5 is (their) latest loudspeaker concept developed for everyone with a passion for listening and living with the ultimate in audio and video entertainment.”
Power
The amplifiers are made up of 1000W each for the main and upper woofers, together with 250W each for the midrange and tweeter giving a total of 2500W output. “Such power permits B&O to address the issues of thermal power compression (by calculating it and adding back sufficient gain offset) and to run effortlessly at something approaching real concert hall levels (i.e. sustained real-world levels of 108 dB SPL with peaks of 120 dB SPL, should you care to entertain all of the folks on your block). A typical high — end audiophile speaker system with two gigantic mono — block amplifiers running at 500 W apiece will run out of steam at probably 10 dB below these levels, all other things being equal. Such power also means that at all sane levels, the BeoLab 5 is simply loafing along, never stressed in the slightest, and if you encounter any signs of distortion, you can know for sure it is occurring elsewhere in your signal path.
Finally, the speaker is fully digital, so you can plug in an S/PDIF feed if you wish. The A/D and D/A converters are of extremely high quality, so no problems will be encountered there either. But the real payoff is that extensive DSP is present, which permits each speaker to be quickly and precisely matched (+/- .25 dB) and documented during manufacture. This, to my mind, is a huge breakthrough. It means that for all intents and purposes, speakers will not be audibly different (a first for mass-produced speakers), and because of thedocumentation, they can be maintained to hold that tolerance! (Just so you know, there’s an RS 232 port included, so the speaker can “talk” to the factory and its DSP is recalibrated to accept a replacement driver).” (Source)
The new technology:
Acoustic Lens Technology (ATL) * – invented by Dave Moulton and Manny LaCarrubba of Sausalito Audio Works LLC – which delivers sound in a 180 degree horizontal plane unlike ‘normal’ speakers which aim their sound directly away from themselves and towards the listener. The ATL technology is a new and effective means to redistribute the acoustic power of a conventional dome radiator. The resultant dispersion pattern has a very uniform frequency response over an extremely wide horizontal coverage angle
Adaptive Bass Control (ABC) actually ‘listens’ to the ambient sound within the room in which BeoLab 5 is placed and adjusts its output to suit the listening position
ABL (Adaptive Bass Linearisation)
As well as the two brand new technologies, BeoLab 5 employs Bang & Olufsen’s Adaptive Bass Linearisation which is a process patented by B&O and incorporated in newer (digital) BeoLab loudspeakers. The idea is to use the surplus capacity in amplifiers and driver units, arising by normal listening levels, for a bass extension – a sound reproduction with more bass, than the loudspeaker otherwise would be able to produce.
The function is adaptive. This means that the loudspeaker adapts to the signal it receives. Loudspeaker drivers are therefore fully exploited, without suffering mechanical or electronic abuse, and the built in amplifiers are not subjected to signals would otherwise create an overload situation.
ABL gives stunning bass reproduction considering the size of the loudspeaker in which it is incorporated, under normal listening levels.
Note: for BeoSound 9000 owners wish to use BeoLab 5 fully, there is a direct digital feed from the optical output of BeoSound 9000 (S/PDIF = Sony/Philips Digital Interface)
Acoustic Lens Technology for Loudspeakers: an introduction
Acoustic Lens Technology is a new and extremely effective means to improve the dispersion of high frequencies in loudspeakers, so that dispersion is much more uniform across the audible spectrum without the deleterious side-effects encountered with other engineering solutions to this problem.
The problem is fundamental: in an ideal loudspeaker it is axiomatic that frequency response should be flat across the audio spectrum. Flat response is designed for and measured “on-axis,” which is to say, in one direction only from the loudspeaker. In fact, the theoretical ideal loudspeaker (i.e. a pulsating sphere) should exhibit the same flat frequency response in all directions. Such a performance quality is, at the present time, impossible to achieve. All loudspeakers are more or less directional in output. Worse, loudspeaker directionality varies wildly as a function of frequency, crossover design and driver size.
So, not only is it virtually impossible for a loudspeaker to have a flat frequency response in all directions, it is equally difficult for a loudspeaker to have constant frequency response in all directions. As a rule of thumb, loudspeakers are omni-directional at low frequencies and highly directional at high frequencies, with erratic variations in between, particularly near cross-over frequencies.
We all have to accept this universal deficiency of loudspeakers. The cost of this deficiency is significant in terms of the quality of musical illusion, imaging and timbral accuracy in stereophonic music playback. Acoustic Lens Technology represents a successful effort to reduce this deficiency.
Acoustic Lens Technology is the outgrowth of more than a decade of invention, research and development. The lenses gather the sound output of a given speaker driver, re-focus it and emit it in the desired directions. Specifically, we have worked to develop a speaker with essentially flat frequency response to 15 kHz that remains constant across a horizontal angle of at least 180° with no lobing, phase anomalies, interference patterns or other undesirable side effects, and a vertical angle of 30°. At the same time, we have made Acoustic Lens Technology compatible with conventional drivers, comparatively inexpensive to manufacture, and reasonably small in size.
Speakers using Acoustic Lens Technology exhibit excellent imaging, depth of illusion and compelling timbral quality. Further, they exhibit an excellent “invisibility,” or sense of not being the source of sound. In surround sound production applications, Acoustic Lens Technology is extraordinarily effective for all speakers in the system.
* ATL Technology is licensed from Sausalito Audio Works LLC
For further information on Acoustic Lens Technology and Dave Moulton – developer of ALT – visit his site by clicking here.
“In BeoLab 5 design and acoustic engineering converge in the world’s most complete and powerful all-digital loudspeaker ever designed for use in domestic surroundings. The result is an intelligent loudspeaker with a pure and transparent sound uncoloured by the placement of the loudspeakers, the room itself or by your own listening position”
BeoLab 5 & Acoustic Lens Technology
ALT is short for Acoustic Lens Technology and is a patented geometric shape that when properly mated to a conventional dome radiator yields an extremely wide, uniform horizontal dispersion characteristic. Acoustic Lenses redistribute the sound power of a driver (a tweeter, for instance) such that the resulting dispersion is very uniform over at least 180° horizontally. The vertical radiation pattern is asymmetrical. It is limited such that very little sound is directed towards the floor. Somewhat more energy is directed upwards than towards the floor but, in general, the radiation pattern may be described as a ‘hemidisc’.
ALT’s unique dispersion characteristics help in several ways. The most obvious is that listeners seated off-axis hear virtually the same timbre as those on the reference axis. An ALT loudspeaker has a flatter power response curve than a conventional loudspeaker. This means that the total sound energy radiated by the speaker is more closely related to the axial frequency response or direct sound. This type of behaviour correlates positively with listener preference in controlled listening tests. This is why some manufacturers have rear firing tweeters. ALT does this while minimising reflections from the floor and the wall behind the speaker. The Archimedes Project, a 5-year multimillion dollar research project that delved into the relationships between acoustic reflections and the perception of timbre, revealed that such behaviour is desirable. Finally, ALT loads the driver to which it is mated so that less electrical energy needs to be applied to achieve the same SPL as a baffle-mounted driver. This increases power handling and lowers distortion. ALT does all of this while maintaining excellent axial frequency response.
Room placement of ALT speakers
As with most speakers, Sausalito Audio Works LLC – as inventors of the system – recommend placements of at least 1m and preferably 1.5m – 2m from any wall. Normally you would not aim an ALT speaker directly at the primary listening position – the reference axis for these speakers is 30° so it is advisable to keep them pointed straight ahead.
The only exception to this is if you must put the speaker less than 1m from a sidewall. In such an instance, aiming the speaker directly at the listening position usually yields better results.Sausalito also recommends that the primary listening position be located at the apex of the equilateral triangle formed by the speakers and the listener. Many audiophiles prefer to sit farther away from the speakers than this.
Member Review by Mr 10%
I purchased my Beolab 5s mid-June (2004) on spec via a telephone call without ever listening or seeing them “live” in a showroom. Slightly prejudiced by reading the information in the hi-fi press, I though they must be good if the normal hi-fi bores think they are. My first actual contact with the Beolab 5 was in the Manchester King Street Store, just as my units were being delivered to my overseas home. To say I was a little disappointed and began to questioned why I’d parted with so much cash on these things so easily. The listening room – annexed from the showroom was only sufficient to hold a Beovision 4, a Beosound 9000, the Beolab 5’s themselves and a 2-seater sofa. Too late.
A few weeks later I was presented with two boxes strapped on a couple of wooden pallets. The shipper trollied them into the living room and departed. The Beolabs arrived very well packed. One thing you cannot gauge from any of the sales literature is their size – much smaller than I had imagined before going to the store. Also the weight is incredible. Each weighs in at around 61kg! Moving them carefully on your own is a struggle even with the handy ring lifting point under the lower lens disk.
The Beolab 5’s are typically constructed from the same materials as the rest of the B&O range. The top of the lenses are roughly polished aluminium – almost identical to the trumpet foot stands of the Beovision 1 TV’s. The frets are standard fabric but give the impression of being thick, dense and softly cushioned. The remainder of the loudspeaker is metal (quite distinct from plastic) with the new-style rubberised coating found on the backs of the Beovision 1 and the Beocentre 2. The foot appears to be cast metal –a solid disk with the microphone mounting in the middle.
When closely examining the form of the Beolab 5, you actually have to appreciate the design rather than slate it. The complex and intricate ellipse shapes states everything on how the sound is dispersed over the lens. The neck – often an element of intrigue is quite clear:- nothing else would work design-wise giving each a distinction or separation between the lens structure and the bass section. This gives the loudspeaker an unexpected visual lightness in the flesh.
Setting them up was straightforward. You connect power, Powerlink and the Dig. Coax cable up in typical a la B&O style. I use a Beocentre 2. The whole set-up took 5 minutes. Including connecting them to two separate Belkin AV Pure surge protectors – an investment which I hope I will never need to rely on. Calibration is easy; one at a time, a light 3 second touch of the top lens activates the ABC calibration. Like a light-sabre from StarWars, the LED glows green and menacing. In the first 20 seconds the Beolab 5 emits a monotone so low in frequency you can only just hear it. However it was “loud” and the give-away was the fact your clothes throbbed. Sequentially, the emitted tones increased in frequency and shortened in duration. The cycle repeated twice per speaker with increasing extension of the microphone.
Then “that” moment had finally arrived. I selected Pink Floyds legendary “Dark Side of the Moon”. Having been used to playing CD’s with the Beocentre 2 via my Beovision 1 loudspeakers, the volume was set default at 50 (out of 90). Pheww! The first notes are of the heartbeat, which make you feel very strange –like having an embolism in your head. Your blood-pressure rises with each beat as the music gets louder and louder until breaking out into the main track. Quickly realising that the listening room in Manchester was way too small for these brutes and better suited to my larger living room, I reached for my classical music CD collection.
First, I played the last 5 minutes of Tchaikovsky’s 1812 Overture. Bang! Bang! Blown away! The clarity, separation and detail of these loudspeakers is totally awesome. I cannot write justice here of how they sound; only a poet could do so. The music presses right into you, envelops you, penetrates you. The cannon shots pounded the plasterboard walls with precise and punchy sound salvos. No hint of common or garden low-frequency smudge associated with separate sub-woofers. Even the Beolab 2, which I have owned, loved and sold for these loudspeakers just does not come anywhere close.
Further, the Beolab 5’s mock you to turn the volume right up. I reached for Coplands “Fanfare for the Common Man”. I went straight for the jugular:- Max Volume. Dum dum dum, blarrrrr went the kettledrums and horns blowing my eardrums to jelly. Everything remained crystal clear and totally undistorted (only the room bent and bowed). Just how loud that track was is unknown but after taking 5 minutes outside in the garden for some air, my ears were still ringing and I know that prolonged listening like this will, no matter how good it sound, will result in me selling-up all my audio equipment though hearing loss. These Beolab 5’s should carry a health warning; the total lack of any distortion fools the brain it to believing the sound is not loud. It is.
Over the weekend, I practically listened to every CD I own. Classical, Opera, Rock, Blues, Chill etc..etc.. Everything was delivered precisely and in a way I can only describe as emotional. I have fallen back in love with music – all music again. There was no hint of stress, aggressiveness or even coming close to the loudspeakers operating envelope with anything I played. It is totally incredible and like a blind man who can now see, I had several hundred new CD’s to listen to – and I’m a seasoned B&O owner. Track’s like Satie’s – Gymnopedie No.1 – that melodic piano solo is so moving. Get the volume right, close your eyes and you can see every key being pressed, every foot pedal depression, every string being struck and reverberate to decay – I kid you not. In fact, simple uncomplicated tracks containing solos, unplugged, blues etc. is delivered so life-like, it is easy for the loudspeakers to convince you that the artists are actually performing inside your living room. Yesterday, Norah Jones came to visit.
These loudspeakers do it all. They have enough brute power for you never to need more but delivered with a grace and finesse so life-like. They dare you to play them loud in a “come-and-have-a-go-if-think-your-hard-enough” way (And you do). They expose pirated CD’s for what they are and finger some recording studios for poor quality mixing and for not doing their job properly. Everything sounds good; even with music genres you may never have liked before. The acoustic lenses work magnificently making very little difference tonally from one side of the room to the other. (Naturally balance does change – but only slightly it seemed).
These controversial loudspeakers will I am sure be a design classic and in time be a true benchmark for all other loudspeakers – both B&O and others alike. Watch out Wilson and Sonus.
I cannot recommend them more highly enough. You will be moved.
  • Sound quality 100%
  • Ease of use 100%
  • Design 100%
  • Build quality 100%
  • Value for money 200%
  • Desirability 100%
  • Emotionally does it.
Posted on
BeoLab 2
Bang & Olufsen BeoLab 2
BeoLab 2 Subwoofer: Put yourself at the eye of the storm and enjoy a new sound experience. Just when you thought it couldn’t get any better – it does. The BeoLab 2 subwoofer has only one purpose: to exploit the new world of sound that Digital technology has opened up. Sit back, hold on tight – and experience a deep bass sensation you only thought possible at the cinema or concert hall. BeoLab 2 is the latest (2001) member of the loudspeaker family and has been specially designed to handle the low end of the sound spectrum. It completes your surround set-up and allows you to experience details in movies and music that you’ve never heard before. It just about as good as bass gets!
it’s the smallest things that make all the difference!
The new powerful BeoLab 2 adds a totally new dimension to the Bang & Olufsen sound experience. As digital technology opens up a whole new world of sound, the compact BeoLab 2 subwoofer lets you experience a deep bass sensation that you only thought possible at the cinema or concert hall. Reproducing the low frequency sounds that normal loudspeakers can’t reproduce, BeoLab 2 utilises its built-in 850 watt amplifier to ensure that you no longer only hear your favourite piece of film or music, but feel it as well.
Adaptive Bass Linearisation (ABL) is a process patented by B&O and is incorporated in BeoLab loudspeakers. The idea is to use the surplus capacity in amplifiers and driver units, arising by normal listening levels, for a bass extension – a sound reproduction with more bass, than the loudspeaker otherwise would be able to produce.
Press Release July 2001
“The ultimate home entertainment experience: Bang & Olufsen launches two new products to complete its Home Cinema system
The introduction of Bang & Olufsen’s new generation of widescreen Beovision Avant television and a new BeoLab 2 subwoofer have completed a powerful home cinema experience the Bang & Olufsen way. Available from June 2001, these two products are perfect for film aficionados who want a trip to the movies from the comfort of their favourite sofa.
As the electronic curtain sweeps aside, the TV turns noiselessly to face the viewer and begins the feature screening with Dolby Digital® surround sound to ensure the best picture and sound quality ever produced from the integrated video recorder and/or the separate DVD system.
The new flat widescreen surface (called Real Flat) is not only unique, attractive and contemporary, but offers technically advanced picture quality in either 28” or 32” versions. True to Bang & Olufsen’s philosophy of simplifying rather than over-complicating technology, the whole cinema set-up is controlled by just one remote the Beo4 – it can even dim your room lighting when used with compatible light control systems.
• With the introduction of BeoLab 2, it’s now possible to fully exploit the multi-channel surround sound offered by today’s digital media. It is powerful enough to effectively reproduce the deepest bass effects, and visually appealing enough to fit into the entire Bang & Olufsen cinema set-up.
• Beovision Avant features a built-in Dolby Digital® surround sound decoder, and includes automatic detection of this 5.1 channel digital sound format
• Accessing Bang & Olufsen’s DVD 1 is fast and simple through seamless Beo4 operation
• The BeoLab 2 subwoofer delivers an exceptionally deep bass reproduction compared to it’s modest physical size. Powered by a 850 watt ICE Power amplifier, it is characterised by a combination of compactness and efficiency.
• The BeoLab loudspeaker programme features freedom in choice regarding loudspeaker design, colour and placement possibilities.
• A/V compatibility – Connecting Beovision Avant to a Bang & Olufsen audio product creates synergy, and provides a number of benefits, such as easy operation of all sources via only one remote control, and logical system functions.”
“When it comes to sound reproduction we believe there’s only one relevant parameter: How close can we come to the originally recorded sound. We feel an obligation not to disturb the intentions of the artist by adding unnatural elements to the acoustic image. Therefore all Bang & Olufsen loudspeakers share the same goal. They differ in size and shape and in terms of sound pressure level. But they are all developed to reproduce the natural, unaltered sound as closely as possible ” – Bang & Olufsen catalogue 2001 – 2002
BeoLab 2: an evolutionary history
The first design model of BeoLab 2, was finished in high gloss black . Its width was 230mm and the loudspeaker membranes were shielded behind a round grille. The model expressed the wishes of designer David Lewis to reflect proper balance between both the demands for excellent sound reproduction and good looks.
In designing the new sub-woofer, the next step was to make a drawing of the exterior as a starting point, in relation to its internal components. In allowing these components to be fitted, BeoLab 2’s specifications had to be enlarged. This new width became 4cm larger. However, it was widely agreed that this was marginally too large so a compromise of 260mm was agreed upon by the design group at Struer. And this is the width of the BeoLab 2 today!
Posted on
BeoGram CDX 2
Bang & Olufsen BeoGram CDX2
This advanced CD player was straight from tomorrow’s world – but it would still marry up happily with any Bang & Olufsen system created over the previous decade. It was as simple to use as a tape recorder. The track search system was invaluable for finding your way quickly around the disc. A display indicated the number of the track you’re on.
Recording was just as straight forward. And you could time recordings to the second – just press the sensi-touch panel and you could find out how much time was left on a particular track or on the whole disc.
This replacement for the former Beogram CDX used at that time, new 16-bit technology and an all-new optical system. The player itself though, was derived from the Philips CD150 machine; the same as that in the Beocenter 9000. After one year the machine was discontinued and replaced by the Beogram CD 3300 – a similar sensi-touch CD player – as part of Beosystem 3300.
Posted on
BeoGram CDX
A featherlight touch on the glass control panel brought up an illuminated display of numbers which corresponded to the tracks on the disc. You could select tracks in any order; you could see how long a track lasted and a motorised dust cover and automatic light were among the features that this stand-alone CD player possessed.
The CD player was based around the Philips CD104, built in Belgium.
As a standalone player, it lacked the Datalink and remote control facilities that its predecessor, the Beogram CD50, possessed. A good-looking CD player which performed well, it was later superceded by the Beogram CDX-2 in 1987.
Bang & Olufsen Sales Training System
Beogram CDX
Beogram CDX is a Compact Disc player in a classical Bang & Olufsen design
Features:
Top operation
Motor driven dust cover
Sensi-touch operation
ADVANCE and RETURN functions
Replay up to 4 times
Display with indication of playing time of individual tracks, elapsed time and index
Analogue and digital filter (176.4 KHz over sampling)
Connection with Phono plugs
Operation
If Beogram CDX is in standby position and there is a compact disc on the platter, one push at the PLAY button will start the playback.
If there isn’t a compact disc inserted, you push the EJECT button and the motor driven dust cover will open, the platter will lift and the compact disc can be inserted.
Apart from the above-mentioned PLAY and EJECT buttons, all operations are sensi-touch fields, which are operated with a slight touch.
When pushing the field PLAY, the dust cover closes automatically and playback starts.
The display indicates the individual tracks on the inserted Compact Disc. If it has more than 20 tracks, the two first digits in the time display will show the total.
The time display has 3 main functions, which can be ordered by pressing DISPLAY, namely the time of the individual tracks, the elapsed playing time and index, which is a sub-division of the time of the individual tracks.
ADVANCE and RETURN are used for jumping to the next or the previous track and are indicated with a flashing of the selected track on the display.
With the digits 1 to 0, a track can be selected at random and the jump is marked on the display.
With STORE and CLEAR you can select or leave out up to 40 tracks on the Disc.
REPEAT replays the Disc up to 4 times.
One push at STOP gives pause, and by keeping the finger on the field till the Disc stops, you get actual STOP. << and >> are used for fast search within the individual tracks.
When activating it once, you search in jumps of 1 second
By keeping the finger on the field you search in jumps of 10 seconds and after 10 seconds the jumps are 1 minute
Connection
Beogram CDX is provided with a fixed signal cable with Phono plugs and can be connected to all LINE inputs. For amplifiers with TAPE inputs which are already being used, we can deliver a CD/TAPE adaptor, type 8950060 (accessory at additional price)
1985 Magazine Review
” The CDX is one of two ‘Beograms’ which have been promised by B & O for some considerable time. It would seem that to a large extent B & O have edged, their bets, for the CDX is a Philips-based machine while the alternative model uses Sony-sourced assemblies. The CDX is an extraordinarily beautiful machine yet, as we shall learn, is based entirely upon the ever so humble Philips CD?101 (the same player as used by Meridian for the MCD conversion). The styling is obviously intended as match the other B & O units and so the company has an untapped market of existing owners who have been patiently waiting for a CD player. But it is a player well worth considering in its own right as a separate purchase.
Unusually the CDX is a top loader but the lid assembly is powered and in response to the eject button the lid assembly smoothly folds back to allow the disc to be loaded. With the exception of the Eject and Power switches, all the controls are touch sensitive (using a type of capacitive sensing) a choice which I found far from reassuring since I kept wanting to use extra finger pressure to ensure a good contact! My overall lack of confidence was further encouraged by the all black control panel which reveals nothing until the power is applied. Perhaps it’s too much like computer screen ‘soft keys’ for me for I kept wondering if the Play switch would be still in the same place every time I went back to this player!
Two types of display are provided; a digital readout to show track time, total elapsed play time, and track numbers up to 99; and a bar scale of 20 LEDs to show the status of the first 20 tracks. A reasonable range of facilities is offered with both track skipping and fast searching (both backwards and forwards). Tracks can be pre-selected for playback and programming is possible for combinations of up to 40 tracks stored in the memory. Finally a Repeat mode allows continuous playback of the whole disc or of individual tracks.
Once the CDX is opened some idea of B & O’s inventiveness can be gained. Into the plastic casing has been dropped a Philips CD101 player complete down to the signal and mains supply cables but less the Switch/Display board. Instead B & O plug in wires from their own front panel and wire connections to their Eject and Power switches. The whole conversion is very neat and since the Philips player is left unmodified all the standard parts fit thus ensuring ease of service.
It has to be said that providing the last word in performance is not needed; the Philips CD?101 is an excellent choice with the CDM mechanism being recognised for its good build quality and reliable operation (it is also to be found in the expensive Revox B225 player). The electronics design largely follows the familiar Philips circuit with 4 times oversampling conversion using a separate 14-bit DAC for each channel.
In the laboratory the performance was much as expected with a generally flat frequency response except for a mild dip of 0.25dB around 7kHz; very low noise (?104dB); low crosstalk between channels and quite reasonable linearity. No problems were experienced when using the error testing discs and this player did very well in playing back some of my badly scratched discs with very few garbled passages.
Auditioning was conducted through my usual system of passive control unit and Krell power amplifier with LC connecting cables. Essentially in terms of sound quality this was very much a case of re-reviewing a Philips CD101 (or Marantz CD63) and the expected high standards were
achieved. The sound can be characterised as open, exciting with a fine sensation of space and depth, and good stereo focus. The weaknesses were primarily at the extremes of the audio band with a warm, stodgy bass and a degree of harshness at high frequencies. However within the context of the B & O system the sound quality of this player would be considered quite excellent.
VERDICT: A beautiful model which will appeal to a wider market than just the traditional
B & O owner. The overall performance of the CDX is excellent and this player can be considered as good value
PROS: Good sound quality. Very good value for money. Beautiful looks
CONS: Rather fiddly to use. Old fashioned top loading ”
‘Which Compact Disc’ November 1985
Posted on
BeoGram CD 7000
Bang & Olufsen BeoGram CD7000
Beogram CD 7000 was distinctive because of its authentic sound reproduction as well as its large dynamic range. It was equally suitable for symphonic music and rock. Its many functions allowed you to pre-programme tracks for playback in any desired order. This CD player was the last in line as far as separates were concerned, replaced with the likes of Beocenter 2300 and Beocenter 2500.
Features:
Exclusive computer-controlled CD loading mechanism with extremely fast access time
CD tray machined from a 4mm solid aluminium plate for maximum mechanical stability and convenient loading
Disc tray cut-outs with rubber lining for 12 and 8cm discs
Spring-suspended CD mechanism and magnetic disc clamp
Special functions, such as scan and sequence programming, were carried out from Beolink 7000
Dynamic readout on Beolink 7000 of all functions, track bar, remaining time, elapsed time, scan, etc.
CD players are now among the simplest constructions in the electronic world and standard players are based on very few components, a simple electronic layout and use of economical materials, both inside the product and in the cabinet. In the construction of CD7000 the main objectives were the achievement of excellent mechanical stability, convincing sonic qualities and easy access to the CD functions.
The loading mechanism, the way the clamp function and the suspension of the CD mechanism were all points that received special attention. The high quality of the mechanical solutions was continued in the electronic circuitry and both were highly integrated and interdependent of each other.
The CD tray was very solid and elegant and the loading mechanism extremely durable. The tray was made from a 4mm thick sheet of aluminium and the conical recess for the CD was milled and diamond polished to the smallest of tolerances – to prevent dust gathering in the recess. The circular rubber profile protected the disc during loading and unloading, while the triangular cut-out facilitated unloading. To avoid static build-up the tray was connected to ground and to avoid ‘ringing’, a damping plate was placed at the innermost part of the tray, inside the cabinet.
The motorised movement of the CD tray was very fast and gentle. The movement was controlled by the microcomputer via an optocoupler and was a very stable mechanical solution with two parallel chrome plated brass rail tubes and precision plastic roller bearings. A nylon coated steel cord wire was applied for maximum duration and quiet transport. The electronically governed transport was very smooth, started the movement slowly, then speeded up very quickly, decelerating when the disc approached the clamp. Furthermore, it secured against possible damage occurring from obstacles either in front of the tray or in between tray and cabinet.
While the tray approached the clamp the disc was gently lifted off the tray and clamped between the CD mechanism and magnet. The magnet was placed on a bridge across the CD mechanism and when it engaged the disc the magnet was lifted away from the bridge. While the disc was rotating, the magnet was not in contact with the cabinet, but only the disc and CD mechanism.
This assembly was insulated very efficiently from the cabinet to prevent vibrations from the outside. A special suspension was designed, with 4 steel springs, encased in rubber. The springs ensured that the CD mechanism was fixed in the horizontal plane (i.e. across the disc), while a certain amount of movement was allowed in the vertical plane (i.e. up and down). Test showed that the servo system counteracts movements in the vertical plane better than in the horizontal plane, and the suspension thus was a good compromise with regard to immunity from external vibrations. The inherent frequency of the suspension was placed at 25 Hz to avoid tracking and focusing errors, which were prone to emerge if the CD mechanism was subjected to vibrations around 100 Hz and upward. Furthermore, at this frequency interference with the inherent frequency of the CD cabinet was also avoided.
The electronics
The CD format is one of the most precisely defined audio formats, but it is still possible to design differentiated products. The electronic solutions in CD 7000 were just as elaborate, the computer controlled loading just being one of the elements. Separate power supplies were available for the digital and analogue parts, and in connection with a careful print layout Bang & Olufsen achieved the most respectable electronic specifications. The digital-to-analogue filtering was special as well. First, a standard digital filtering (4 x oversampling) was applied to filter away the sidebands below 176,4 kHz. The analogue filtering at 176,4 kHz was carried out by a modified order filter. To avoid remnants of the 176,4kHz sideband having an effect on the filtering, a special suction circuit cut off the frequencies above 156,4 kHz. The modified filter was known as a ‘Bessel elliptical filter’. It had a very gentle filter characteristic and was not susceptible to ripple phenomena, phase distortion or ageing.
The functions
As with the other sources, operation was via the Beolink 7000, with full display readout of all functions. Special functions available included: the space function, where a pause of 4 seconds was added between tracks to facilitate track search on a tape recorded from CD 7000. Scan gave playback of the first 15 seconds of each track and was especially useful in connection with a sequence programming.
While you were scanning the CD, tracks could either be selected (compiled) or omitted and when the last track had been scanned, playback of the programmed sequence commenced. Sequence programming could also be carried out independently of the scan function and if you used the select programming, playback could be non-chronological. If you used the reject programming to leave out specific tracks, playback would be chronological.
Beogram 7000 could, ideally, be used as part of Beosystem 7000
Posted on
BeoGram CD 6500
Bang & Olufsen BeoGram CD6500
If you wanted to indulge yourself with the finest sound quality then you’d do no better than listening to your favourite pieces of music on Bang & Olufsen’s Beogram CD 6500. Beogram CD 6500 was a replacement for its predecessor, Beogram CD 5500.
It played both 12cm and 8cm compact discs, and housed sophisticated and advanced digital technology. And it offered sound reproduction which would satisfy even the most demanding of listeners.
Beogram CD 6500 could be used as part of the Beosystem 6500 hi-fi system.
Posted on
BeoGram CD 5500
Bang & Olufsen BeoGram CD5500
The quality of the Beogram CD 5500 CD player took time to fully appreciate. For example, the elegant disc tray with its completely smooth and silent drive. Or the way that the disc drive system was mounted to isolate it from vibrations. Perhaps you were most impressed by the way that a built-in circuit in the player compensated for the tiniest faults on the disc itself (contrary to popular belief they’re not always perfect!). Finding tracks was both fast and easy – it was necessary to just ask the Master Control Panel for the track number you wanted. You could programme tracks to be played in any order, or sample each track briefly. There was a light display which showed you the length of the track you were playing and the remaining time on the disc – invaluable for recording.
Though very similar to look at to Beogram CD 50, this all-new Philips-based machine was a radical departure, both in manufacturing and technical terms. Beogram CD 5500 was the first CD player to be entirely designed by Bang & Olufsen and with the exception of the optical deck, it was entirely made by the company too. The performance and reliability of the Beogram CDX models probably influenced the choice of the Philips radial single beam pickup system and brushless DC spindle motor.
Externally, a slim aluminium plate machined out to the size of a compact disc replaced the Beogram CD 50 door and drawer loading system and it moved quickly and silently, again in marked contrast to its predecessor. The deck was on the right-hand side side of the fascia as opposed to Beogram CD 50 left-hand side arrangement, so that the loading of a cassette into the new Beocord 5500 tape recorder, which you had the option of placing below, was not obstructed. Later versions had a concentric 8cm circular recess machined into the loading plate, to accept CD singles.
With the Beogram CD 5500 there was no infra-red sensor option, and the front panel controls were even more basic, so at very least a Beomaster 5500 and Beolink 1000 terminal were needed to use it properly. On the back panel, there was a 7-pin Datalink socket for Beomaster 5500, and a single phono digital output connection, for which there was never a use within the B&O range.
The performance of this outstanding machine was never bettered, and with the exception of minor styling and software revisions, it remained virtually unchanged until the end of the separates system range with the Beogram CD 7000.
Beogram CD 5500 could be controlled via the two-way Master Control Panel MCP 5500 as part of Beosystem 5500.
