BeoVision 9 – Plasma
The “space ship” like form factor is driven by the Acoustic Lens Technology (ALT) that delivers a unique 180 degrees horizontal dispersion that maintain a constant tonal balance in all locations, both from direct and reflected sound. Another exclusive feature is the Adaptative Bass Control (ABC): at the press of a button the speaker measure the acoustic properties of the room and adapts its performance accordingly.
The BeoVision 9 is a complete home entertainment solution with a 50 inch HD plasma TV, a powerful center speaker (with ALT) and a built-in BeoMedia. It can be connected to other manufacturers set-top boxes, and has an integrated access to net radio, digital music, photos and the web. In addition, this intelligent device automatically adjusts the brightness and contrast to the ambient light using a dedicated sensor. You can navigate the TV guide, the music and photo files, control the sound volume, orient the display around its axis, all this from the Beo 4 remote control.
David Lewis, the designer, thinks that a TV is not an appealing object, so he succeeds in transforming it in a beautiful piece of furniture.
BeoVision 9 – Plasma Product Details
Type Numbers
Please let us know
Designer
Manufactured
2007
Colour Options
Silver, Black, Dark Grey, Red and Blue
BeoVision 9 – Plasma Product Specification
Dimensions/Weight 127cm x 122cm x 56cm/123kg
Cabinet/Cloth Finish Silver/silver, silver/black, black/black,
dark grey/dark grey, red/black, blue/black
Power Comsumption Typically 335 watt / stand-by 29 watt
Mains Voltage Range 220 – 240 V 50–60 Hz
Contrast Screen Anti-reflex coated
HD Ready Yes
Screen Type 16:9 plasma (50″)
Resolution 1920 x 1080 (Full HD)
Pixel Count 2.073,600 pixels (1920 x 1080 x R, G, B)
Contrast Ratio 3000:1
Tuner Analogue built-in. ATSC*. DVB-S/T* (optional)
Picture And Picture/Text Yes
Play Timer Yes
Video Technology Motion compensated progressive scan
Operation Conditions Temperature: 0 – 35˚ C, Humidity: 20 – 80%,
Min. outside air pressure: 760 hPa
TV System B/G/L/L/I/D/K PAL, SECAM, NTSC on AV.
Tuning 99 programmes, autotune,
programme move and automatic naming
Teletext Level 2 1/2, 9 memory pages per programme.
2048 pages. National character-set
Viewing Angle 160°
Stereo System A2 + Nicam Stereo
Surround Sound System Dolby Digital 5.1/6.1 EX, Dolby 7.1 EX,
Dolby Pro-Logic ll/llx, DTS 5.1. DTS ES 6.1,
DTS Neo:6, AAC*
HDR Built-in (not available on all markets); 250Gb;
recording capacity: 59 hours in high quality,
126 hours in standard quality
Media Functions N.Music, N.Radio, Photo, WEB. (optional)
Loudspeaker Center speaker
Power Amplifiers 2 x 250 watts, Class D, ICEpower
Effective Frequency Range 45 – 20,000 Hz
Cabinet Principle Closed box
Magnetic Leakage Not shielded
Woofer / Tweeter 12.5 cm / 1.9 cm
Cabinet Volume 4.5 litres
Bass Equaliser Adaptive Bass Linearisation (ABL)
Record and playback Simultaneous: PAL, SECAM colour decoder.
Record NTSC signal at AUX scart
Meny Languages English, Danish, Dutch, Spanish, Italian,
German, French, Swedish
CONNECTIONS
Aerial Inputs TV: 75 ohms aerial female, DVB-T (optional):
DVB-S (optional): F-Con female”
AV1-6 (Inputs) 5 x CVBS, 2 x Y/C, 2 x RGB, 2 x component,
4 x HDMI, 5 x L/R, 5 x SPDIF(Coax)
AV1-2 (Record Out) 1 x CVBS, 2 x L/R
Front Projector Output 1 x DVI-D
Cinema D-sub 9 pin, 2 x outputs for control
of external functions
Beolink Video Distribution 75 ohms aerial male (system modulator
output). According to setup: G or I RF output
Stereo Headphones 1 x Mini jack
Loudspeaker Outputs 6 x Power Link
IR Control Outputs 5 x Mini jack
Beolink ML Connector
USB 2 x USB
Internet Ethernet 10/100Mb
Optional Extra DVB-S/T module, BeoMedia
Remote Control Beo5 recommended
*not necessarily available on all markets
BeoVision 9 – Plasma FAQs
Please let us know
