Posted on
BeoCord 2400 (1969)
Bang & Olufsen BeoCord 2400 1969
BeoCord 2400 (1969)
“What Advantages does your Beocord 2400 give you in the Form of Facilities, Performance and Reliability? Pressure diecast chassis for the mechanical section – provides a high degree of mechanical stability, assuring you that your Beocord 2400 is transport-proof. Silicon transistors in the fully transistorized amplifiers – a guarantee of highly stable operation, good signal-to-noise ratio, minimum distortion, and low power consumption.
Separate tape heads for record and playback – permit you to monitor the tape while a recording is in progress. 4-track record and playback – permits maximum playing time for your tapes, both mono and stereo. Two-hand operating of record function – protects you against accidental erasure of tapes.
High degree of channel separation – in mono recordings, too, you will have good separation between the two channels. Twin-faders – make it easy for you to adjust for stereo balance on both record and playback.
Besides, the dual amplifier of your Beocord 2400 gives you the following interesting facilities: Sound on sound (part-song) recordings; adding echo to recordings; synchronous recordings such as pilot signals for slide projectors synchronized with sound reproduction; language laboratory: recording a foreign-language text on one track and conversation exercises synchronously on the other track.
Photo-stop feature – permits you to stop tape during programme scanning, if tape breaks, and at end of tape. Line jack – facilitates tape-copying from or to another Beocord; also permits connection to a large hi-fi system such as the BEOLAB 5000.
Your Beocord 2400 will operate as a hi-fi amplifier – the amplifier may be used without the motor running. It has separate inputs for microphone, gramophone, radio or FM/AM tuner and provision for connection of two pairs of stereo speakers. And your Beocord 2400 meets the minimum specifications for the DIN 45 500 Standards”
BeoCord 2400 (1969) Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1969 – 1972
Colour Options
Please let us know​
BeoCord 2400 (1969) Product Specification
Please let us know
Language
Brochure
EN
BeoCord 2400 Brochure
User Guide
EN
BeoCord 2400 User Guide
User Guide
EN
BeoCord 2400 R-R User Guide
Service Manual
EN
4129, 4132, 4133, 4134, 4135, 4138
BeoCord 2400 Service Manual
Service Manual
EN
4134
BeoCord 2400 R-R Service Manual
Service Manual
EN
2663, 2665, 2667
BeoCord 2400 (1969) FAQs
Please let us know
Posted on
BeoCord 1200
Bang & Olufsen BeoCord 1200
BeoCord 1200
Beocord 1200 Type 4207 was a reel-to-reel tape recorder. Among its features it had sound-on-sound, automatic recording level control and mixing. The in-built PA amplifier could be operated without the motor running.
Beosystem 1200 – made up of Beomaster 1200, Beocord 1200 and Beogram 1200 was Bang & Olufsen’s B&O’s first designed system. The design ‘kinship’, which emphasised the interdependence between B&O’s various products, became a characteristic of B&O for many years. Beosystem 1200 was one of the first products selected by New York’s Museum of Modern Art for the museum’s permanent collection (not exhibition) in 1972.
In 1969 the Danish Society of Industrial Design awarded Bang & Olufsen and Jacob Jensen the ID prize for the Beomaster 1200 radio/amplifier, Beogram 1200 turntable and Beocord 1200 tape recorder for unusually beautiful and user friendly design. The jury emphasised in particular the Beomaster 1200 receiver which pointed in a new direction for the design of radios.
The 1200 series represented the logical continuation of the line of development and design which put B&O at the forefront of manufacturers of entertainment electronics.
BeoCord 1200 Product Details
Type Numbers
4207
Designer
Manufactured
1969 – 1972
Colour Options
Teak, rosewood, white
BeoCord 1200 Product Specification
Tape speeds 19 and 9.5 cm/sec. (7 1/2 and 3 3/4 in/sec.)
Number of tracks 4 tracks record and playback
Real size Max. 18 cm
Playing times Tape Speed 19 cm/sec:
360M 2 x 30 min
540M 2 x 45 min
720M 2 x 60 min
1080M 2 x 90 min
Tape Speed 9.5 cm/sec:
360M 2 x 60 min
540M 2 x 90 min
720M 2 x 120 min
1080M 2 x 180 min
For mono, multiply above playing times by 4
Fast forward and rewind Approx. 200 sec for LP tape
Counter Pushbutton reset, 4 digit readout
Wow and flutter 19 cm/sec +/- 0.15% (DN 45507)
Speed deviation Less than 1 %
Tape stop Photo-electric stop at end of tape
Amplifier:
Frequency response 19 cm/sec: 30 – 20,000 Hz (DIN 45500)
Equalization 19 cm/sec: 50 µsec, 3180 µsec
Distortion Less than 5% over tape at VU 0
Less than 1% in amplifier
Signal-to-noise ratio 65 dB (DIN 45500, 4 – 2.5)
Cross-talk select Mono: Better than 60 dB at 1000 Hz
Stereo: Better than 40 dB at 1000 Hz
Erasure Better than 70 dB
Erase frequency 100 kHz
Dimensions W x H x D: 44 x 14.7 x 33 cm
Weight: 11 kg
Voltage: 110 – 130 – 220 – 240 volts AC
Power consumption: 20 – 52 W
Connections: Inputs Microphone:
Radio DIN
Radio US standard
AUX DIN
AUX US
Outputs Headphones:
Radio DIN
Radio US
Language
User Guide
EN
BeoCord 1200 User Guide
Service Manual Prt1
EN
BeoCord 1200 Service Manual Prt1
Service Manual Prt2
EN
BeoCord 1200 Service Manual Prt2
BeoCord 1200 FAQs
Please let us know
Posted on
BeoCenter 2200
Bang & Olufsen BeoCenter 2200
BeoCenter 2200
Beocenter 2200 was a distinctive high fidelity system offering 3-waveband radio, record player and cassette facilities in a very compact, slim-line format. Maximum power output was 2 x 25 watts RMS.
The radio section covered long, medium and FM bands. Four favourite FM stations could be pre-set for instant recall. A horizontal thumbwheel on the front of the unit controlled manual tuning: the large graph-grid tuning scale was very easy to see and use.
The record deck featured the (then) latest Bang & Olufsen tone arm carrying the ultra-light MMC 5 pickup. Operation was entirely automatic and needed just a single touch on the PHONO button. Built-in logic circuits identified the size and speed of any record placed on the lightweight turn-table and would cue the pickup arm onto the run-in groove with absolute accuracy and safety.
The cassette recorder had electronic control so you could switch directly between, say, fast rewind and PLAY without danger of straining the mechanism or damaging the tape. Dolby B noise reduction and automatic selection between ferric and chrome tapes was included. Metal tapes could also be used, so you were assured of top class sound quality for those really special recordings.
Listening to tapes was also quick and easy: the NEXT button allowed you to scan the tape track by track until you found the one you wanted to hear.
The recommended speakers for use with this system were the Beovox X25.
Connections: Mono microphone; 2 pairs speakers; headphones; external tape recorder with two-way copying; AM and FM aerials
BeoCenter 2200 Product Details
Type Numbers
2421 (1983 – Sept 1986)
2422 (GB) (1983 – Sept 1986)
2423 (US)(1983 – Aug 1986)
2425 (AUS) (1983 – Jan 1986)
2427 (GB) (1983 – Nov 1986)
2428 (CDN) (1983 – May 1986)
2429 (D) (1983 – May 1986)
Designer
Manufactured
1983 – 1986
Colour Options
Aluminium, Black
BeoCenter 2200 Product Specification
Power output RMS DIN/IEC: 2 x 25 watts / 4 ohms; 2 x 20 watts / 8 ohms
Type No. 2423: 2 x 15 watts / 4 ohms
Total harmonic distortion < 0.2 %
Intermodulation < 0.5 %
FM usable sensitivity mono < 15 dBf-2.5 µV/75 ohms
FM usable sensitivity stereo < 19 dBf-2.5 µV/75 ohms
FM Harmonic Distortion 65 dBf < 0.5 %
MW range 520 – 1610 kHz
Stylus (MMC 5) Elliptical diamond 6 x 17 µm
Recommended tracking force 15 mN / 1.5g
Frequency range 20 – 20,000 Hz +/- 3 dB
Wow and flutter, DIN < +/- 0.07 %
Wow and flutter, WRMS < +/- 0.035 %
Rumble weighted > 70 dB
Rumble unweighted > 50 dB
Noise reduction: Dolby B
Tape switch Auto ferro/chrom, manual metal
Wow and flutter < +/- 0.2 %
Frequency range metal/chrom/ferro 30 – 15,000 Hz
Metal Dolby NR
Chrome Dolby NR
Ferro Dolby NR
> 66 dB
> 65 dB
> 63 dB
Power supply:
2421: 220V
2422: 240V
2423: 120V
2425: 240V
2427: 240V
2428: 120V
2429: 220V
Power consumption 18 – 135 W
Dimensions W x H x D: 74 x 9.5 x 32.5 cm
Weight: 11 kg
Sockets for:2 pairs of speakers, extra cassette recorder, Compact Disc player, headphones, Microphone, AM10 Active Antenna
Connections: Headphone jack
Language
User Guide
EN
BeoCenter 2200 User Guide
User Guide
GER
Service Manual
EN
BeoCenter 2200 Service Manual
BeoCenter 2200 FAQs
Please let us know
Posted on
BeoCenter 2000
Bang & Olufsen BeoCenter 2000
BeoCenter 2000
Beocenter 2000 was a compact high fidelity music system incorporating an FM/AM tuner, a 2 x 25 watts RMS stereo amplifier, an integrated record player and a high quality cassette deck.
The semi-automatic stereo record player benefited from Bang & Olufsen’s unique engineering method (integration) which ensured that all components were matched to give optimum performance. The (then) newly designed low-mass pickup with its MMC 20 S cartridge was an example.
Operating the radio and cassette sections was equally straight-forward. Sliding controls regulated volume, bass, treble and balance. Four FM stations could be pre-set for subsequent push button recall. The cassette deck had a green/red indicator that made it easy to set accurate recording levels. You just needed to add headphones and/or a pair of Beovox speakers for a complete entertainment system. Beocenter 2000 is incorporated with Beovox S45 loudspeakers to make up Beosystem 2000.
The SC20 system cabinet, designed specifically for Beocenter 2000 provided a functional and elegant furnishing option. It lifted Beocenter 2000 to the correct operating height and stored LPs, cassettes and other audio accessories within easy reach.
Dimensions: 77 x 74 x 35cm. Finish: teak or rosewood veneer
BeoCenter 2000 Product Details
Type Numbers
2101 (1979 – Aug 1981)
Designer
Please let us know
Manufactured
1979 – 1981
Colour Options
Vinyl wood effect
BeoCenter 2000 Product Specification
Power output RMS DIN: 2 x 25 watts / 4 ohms
Harmonic distortion -26 dB < 0.15%
Harmonic distortion < 0.2%
Intermodulation < 0.4%
Frequency range +/- 1.5 dB 20 – 25,000 Hz
Damping factor > 30
Input tape copy 600mV / 15 Kohms
Signal-to-noise ratio phono > 78 dB
Output external tape 30 mV / 100 Kohms
Output headphone Max. 2.8 V / 22 ohms
Channel separation 1000 Hz > 50 dB
Bass control at 40 Hz +/- 14 dB
Treble control at 12.500 Hz +/- 14 dB
Tuner:
FM range 87.5 – 108 MHz
AM range LW 147 – 350 kHz
AM range MW 520 – 1610 kHz
Record player: MMC 20S
Stylus Spherical diamond
Radius of curvature 15 µm
Speeds 33 – 45 rev. / min
Wow and flutter, DIN < +/- 0.09%
Wow and flutter, WRMS < +/- 0.045%
Rumble weighted > 62 dB
Rumble unweighted > 42 dB
Tape Recorder:
Compact cassette: C60 – C90
Tape head: Super Permalloy
Noise reduction: Dolby NR
Tape switch Manual ferro-chrome
Speed deviation < +/- 1.5%
Fast forward and rewind C60 75 sec
Frequency range ferro-chrome 30 – 14,000 Hz
Signal-to-noise ratio Chrome Dolby NR > 63 dB
Chrome > 56 dB
Power supply: 110 – 130 – 220 – 240 V
Power consumption: 18 – 135 W
Dimensions W x H x D: 73.5 x 12.5 x 38cm
Weight 11.2 kg
Connections: headphones, microphone
Language
Service Manual
EN
BeoCenter 2000 Service Manual
BeoCenter 2000 FAQs
Please let us know
Posted on
BeoCenter 4000 (1978)
Bang & Olufsen BeoCenter 4000 1978
Beocenter 4000 was an elegant combination of an AM/FM stereo receiver (in effect the Beomaster 2200) and a high quality cassette deck whose performance levels matched those of more expensive separate decks. The Sendust tape head ensured the best possible playback and combined long life with optimum frequency response characteristics. There were two motors – one for fast wind, the other for normal play – so tape transport was smooth and stable at all times. A Dolby B Noise Reduction circuit ensured high quality, low-noise recordings. Despite its many technical refinements and comprehensive facilities, Beocenter 4000 was simple to operate.
Beocenter 4000, in which all parameters concentrate on the quality of radio and tape reproduction, was an unusual alternative to a disc system. The addition of a matching Beogram from the Bang & Olufsen range, plus two Beovox S45 bookshelf or P45 wall-mounting speakers converted it into the complete top-quality Beosystem 4000.
Beocenter 4000 comprised a 2 x 40 watts RMS amplifier, an FM, Long and Medium wave radio and a stereo cassette deck incorporating all the features you would expect to find only in separate high quality decks.
BeoCenter 4000 (1978) Product Details
Type Numbers
1603 (1978 – Dec 1980)
Designer
Manufactured
1978 – 1980
Colour Options
Rosewood. Teak, White, Oak
BeoCenter 4000 (1978) Product Specification
Power output 2 x 40 watts / 4 ohms
2 x 30 watts / 8 ohms
Music power 2 x 75 watts / 4 ohms
2 x 40 watts / 8 ohms
Speaker impedance 4 ohms
Harmonic distortion < 0.05 %
Intermodulation < 0.1 %
Frequency range 20 – 30,000 Hz
Signal-to-noise ratio pickup low impedance > 60 dB
Bass control at 40 Hz: +/- 12 dB
Treble control at 12,500 Hz: +/- 12 dB
Tuner:
FM tuner range 87.5 – 108 MHz
LW 147 – 350 kHz
MW 520 – 1610 kHz Cassette:
C60 – C90
Wow and flutter < +/- 0.15 %
Speed deviation < +/- 1.5 %
Fast forward/rewind 80 sec
Frequency range chrome 30 – 15.000 Hz
Signal-to-noise ratio chrome > 58 dB
Dolby NR chrome > 66 dB
Power supply:
Power consumption 20 – 200 W
Dimensions W x H x D 65.5 x 8.5 x 31cm
Weight 15 kg
Connections: Extra Tape recorder DIN
Gramophone DIN
Headphone jack
Language
User Guide
EN
BeoCenter 4000 User Guide
Service Manual
EN
BeoCenter 4000 Service Manual
Service Manual
EN
BeoCenter 4000 (1978) FAQs
Please let us know
Posted on
BeoCenter 2100
Bang & Olufsen BeoCenter 2100
BeoCenter 2100
Beocenter 2100 – three variations and a one-finger exercise
Beocenters 2200, 2100 and 4000 – each with a totally distinctive style but sharing the unmistakeable themes of Bang & Olufsen quality and simplicity.
If you loved true hi-fi but you weren’t a record fan, then Bang & Olufsen ‘had your radio perfectly taped’! Beocenter 2100 had all the features of Beocenter 2200 but without the record deck so that it took up even more of a conveniently small space.
Beovox X25 loudspeakers were the offered choice but you could equally mix and match the Beocenter with any other Bang & Olufsen speaker on the market at that time. When linked with Beovox X25 loudspeakers, the combined system was known as Beosystem 2100. A recommended record deck to complement your system would be either the Beogram RX2 or TX2.
BeoCenter 2100 Product Details
Type Numbers
2441 (1985 – May 1988)
2442 (GB) (1985 – May 1986)
2449 (D) (1985 – Sept 1987)
Designer
Manufactured
1985 – 1988
Colour Options
Aluminium, Black
BeoCenter 2100 Product Specification
Power output RMS DIN/IEC 2 x 25 watts / 4 ohms
Harmonic distortion < 0.2 %
Intermodulation < 0.4 %
Frequency range 1.5 dB 20 – 20,000 Hz
Signal-to-noise ratio > 78 dB
Channel separation 1000 kHz > 50 dB
Tuner:
FM frequency range 87.5 – 108 MHz
LW frequency range 147 – 350 kHz
MW frequency range 520 – 1610 kHz Tape deck:
Compact cassette C46 – C60 – C90 – C120
Frequency range 30 – 15,000 Hz
Signal-to-noise ratio CCIR/ARM
Metal Dolby NR > 67 dB TDK-MA
Chrome Dolby NR > 65 dB TDK-SA
Ferro Dolby NR > 63 dB BASF LH I
Metal > 59 dB
Chrome > 57 dB
Power supply:
2441: 220V
2442: 240V
2449: 220V
Power consumption 25 – 140 W
Dimensions W x H x D: 64 x 9.5 x 33cm
Weight 10 kg
Language
Service Manual
EN
BeoCenter 2100 Service Manual
BeoCenter 2100 FAQs
Please let us know
Posted on
BeoCenter 4000 (1985)
Bang & Olufsen BeoCenter 4000 1985
An original that defied comparison
Beocenter 4000 had two cassette decks and a tuner/amplifier and was described as the ‘ultimate machine for tape professionals – and for the true enthusiasts’ upon its release.
The recording deck was equipped with both the Bang & Olufsen HX-Pro recording system and Dolby B Noise Reduction circuitry to give the finest possible recording quality. You could mix sound from the Beocenter 4000’s FM, Medium and Long Wave tuner/amplifier. And even do a DJ talk-over with a microphone. Auto-reverse turned the tape direction automatically giving up to 2 hours (C120) recording time or 3 hours continuously in playback using both decks. You also had an entire evening’s entertainment at your fingertips because you could repeat both sides of Tape 1 and one side of Tape 2.
The FM, Medium and Long Wave tuner/amplifier of Beocenter 4000 had all the features of Beocenters 2200 and 2100 – including presets for 4 stations and sockets for an impressively wide range of connections.
BeoCenter 4000 (1985) Product Details
Type Numbers
2431 (1985 – May 1988)
2435 (AUS) (1985 – Jan 1986)
2439 (D) (1985 – Sept 1987)
2432 (GB) (1985 – Nov 1987)
Designer
Manufactured
1985 – 1988
Colour Options
Black/Aluminium
BeoCenter 4000 (1985) Product Specification
Amplifier:
Tuner:
Tape deck:
Freuqency range 30 – 15,000 Hz
Metal > 59 dB
Chrome > 57 dB
Power supply:
2431: 220 V
2432: 240 V
2435: 240 V
2439: 220 V
Weight 10 kg
Connections: CD Phono plugs
Phono Phono plugs
AUX Phono plugs
Language
User Guide
EN
Service Manual
EN
Service Manual
EN
BeoCenter 4000 (1985) FAQs
Please let us know
Posted on
BeoCenter 6-26
Bang & Olufsen BeoCenter 6-26
BeoCenter 6-26
The widescreen BeoCenter 6 LCD television is available in 23” and 26” versions. Both come custom-fitted to match your needs. For example, you could have built-in FM and DAB radio in the compact 6-23 in your kitchen and Surround Sound and DVB-S modules in a 6 – 26 used for watching TV in a small living room or a bedroom. Or you could mix and match. Your ‘second television room’ just became the place to be. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept.
Gorgeous from good morning to good night
The handcrafted cabinet of the BeoCenter 6 speaks volumes about the dedication that went into its creation. The sleek lines of the BeoCenter 6 blend in anywhere in your house. Both in your kitchen, drinking your morning coffee, or in your bedroom – enjoying the late night comedy before you go to sleep. The elegant aluminium front and frame are available in a selection of dashing colours as well as discrete aluminium, black and dark grey versions. Using its special digital input, BeoCenter 6 can function as a spectacular computer monitor that would take pride of place in any room, especially if matched with the compact BeoLab 3 or BeoLab 4 loudspeakers in striking red or blue – or perhaps the golden anodised aluminium of BeoLab 4000.
Fewer boxes. More TV and radio
The new BeoCenter 6 takes intelligent integration to a new level and introduces DAB radio options together with a TV for the first time ever. When you are listening to the radio, the screen can display available programme information. Equipped with wake-up timer and timer play the BeoCenter 6 makes the perfect choice for a second room television. A selection of wall mounting brackets and stands are available for versatile placement. The motorised floor and table stands can be controlled from the Beo4 remote control, turning the TV 35° to each side. In addition, the tilt mechanism means easy adjustment of the television up and down on the vertical axis.
The definitive BeoLink screen
BeoCenter 6 can function as a stand-alone television, or as the second-room TV in a BeoLink setup. You can enjoy all sources from the main room on the BeoCenter 6, such as DVD, digital music, etc. For instance, you can watch satellite TV in your bedroom on your BeoCenter 6 – 23, even though the satellite receiver is in your living room. BeoCenter 6 can also be used as an ‘audio link master’ that lets you access the radio function from other rooms, if linked to a pair of BeoLab speakers.
True Bang & Olufsen picture and sound
The BeoCenter 6 uses the best LCD screens available, and has been further improved with Bang & Olufsen VisionClear picture technologies, which are implemented in all TV solutions from Bang & Olufsen. Whenever BeoCenter 6 is switched on, VisionClear adjusts the image automatically in relation to light conditions in the room. Within seconds, the TV automatically adjusts contrast levels, brilliance and colour to match the light conditions at any given time. BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26 a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6 – 26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television´s loudspeakers will in this setup function as a powerful centre speaker.
The new BeoCenter 6 takes intelligent integration to a new level and introduces DAB radio options together with a television for the first time ever. One of the best LCD screens available has been further improved with Bang & Olufsen’s own VisionClear picture technologies, to ensure the best possible picture in all situations.
When BeoCenter 6 is switched on, these picture-optimising technologies adjust the image automatically in relation to light conditions in the room. Within seconds, the television automatically adjusts contrast levels, brilliance and colour to match the current light conditions – and will carry on doing so until the television is switched off again.
BeoCenter 6 can function as a stand-alone television, or as the second-room television in a BeoLink setup. In the latter case, you can enjoy all sources from the main room on the BeoCenter 6, such as DVD, digital music, etc. BeoCenter 6 can be used as an ‘audio link master’ that lets you access the radio function from other rooms, if linked to a pair of BeoLab speakers.
Four placement options help BeoCenter 6 fit in, even in the smallest of spaces. The motorised turning function on the floor and table stand is controlled from the Beo4 remote control, and turns the television 35° to each side. In addition to this, the tilt mechanism means easy control of the television 13° up and down on a vertical axis.
The widescreen and high-definition ready LCD monitor is available in 23” and 26” versions. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept. Connections for earphones, external entertainment sources, and BeoLab loudspeakers, are combined with digital interface for computers (DVI) – making the BeoCenter 6 the perfect companion for both work and entertainment.
When the FM radio, which is standard in the 23” version and optional in the 26” version, or the DAB radio feature, which is optional in both, is switched on, available radio text information rolls across the screen. A factory fitted wake-up timer supports the radio functionality still further.
BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26 a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6 – 26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television’s loudspeakers will in this setup function as a powerful centre speaker.
Mounting Options & Stands
The tilt table mount was available for counter top mounting, designed to allow the bass port on the underside of the TV to ‘breath’. Motorised floor and table stands were complimented by a wall mount bracket which gave manual tilt and turn.
BeoCenter 6-26 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
2006 -
Colour Options
Black, Silver, Dark Grey, Red, Blue, Yellow
BeoCenter 6-26 Product Specification
Please let us know
Language
Service Manual Reference Guide
EN
BeoCenter 6-26 Reference Guide
User Guide
EN
BeoCenter 6-26 User Guide
Service Manual
EN
BeoCenter 6-26
Service Manual
BeoCenter 6-26 FAQs
Please let us know
Posted on
BeoCenter 6-23
Bang & Olufsen BeoCenter 6-23
BeoCenter 6-23
The widescreen BeoCenter 6 LCD television is available in 23” and 26” versions. Both come custom-fitted to match your needs. For example, you could have built-in FM and DAB radio in the compact 6 – 23 in your kitchen and Surround Sound and DVB-S modules in a 6-26 used for watching TV in a small living room or a bedroom. Or you could mix and match. Your ‘second television room’ just became the place to be. The integration of picture and sound in the compact cabinet creates a simple and elegant plug-and-play television concept.
BeoCenter 6 – 23 utilises a compact one-way loudspeaker system, and BeoCenter 6 – 26” a two-way system, slightly more powerful to match the larger screen size and longer viewing and listening distances. The digital surround sound module available for BeoCenter 6-26 provides a digital surround sound experience in any setup with BeoLab loudspeakers. The television’s loudspeakers will in this setup function as a powerful centre speaker.
Bang & Olufsen’s preferred supplier for brackets and stands, STBbrackets, have made a range of solutions specifically for this model including a direct replacement for the tilt table mount. Distributed throughout the World by the Bang & Olufsen store network, the STB options add to the diversity of mounting options and positions available.
BeoCenter 6-23 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
2006 -
Colour Options
BeoCenter 6-23 Product Specification
DIMENSIONS / WEIGHT 61 x 49 x 17 cm + stand/ approx.18 kg
CABINET FINISH Silver, black, dark grey, red, blue, yellow.
REMOTE CONTROL Beo4 (Included)
POWER CONSUMPTION Typical 104 W, standby 1 W
PICTURE:
CONTRAST SCREEN Anti-reflex coated and high glare LCD panel
TELETEXT Level 2 1/2, 9 memory pages per programme.
National character-set
TV SYSTEM: According to type and setup:
B/G
B/G/L/L’/I/D/K
B/G/M/I/D/K
PAL, SECAM, (NTSC on AV)
TUNING 99 programmes, autotune, programme move and automatic naming
LCD: 23” 16:9 TFT LCD
Resolution 1366 x 768
Luminance of white
(centre of screen) typ. 450 cd/m2 (typical)
Contrast ratio
(centre of screen) typ. 800:1
Response time typ. 8 msec.
Viewing angle typ. +/- 89 degrees both vertical and horizontal
STEREO SYSTEM A 2 + Nicam
MENU LANGUAGES English, Danish, Dutch, Spanish, Italian, German,
French, Swedish
RADIO: 99 radio presets with naming
SYSTEMS: FM (standard) and DAB (optional)
IR CONTROL OUTPUT Built in Peripheral Unit Control (PUC) – Supports one
STB (IR-blaster included)
LOUDSPEAKERS: Stereo Channel
PLAY TIMER Yes
Language
Reference Guide
EN
BeoCenter 6-23 Reference Guide
Setup Guide
EN
BeoCenter 6-23 Setup Guide
User Guide
EN
BeoCenter 6-23 User Guide
BeoCenter 6-23 FAQs
Please let us know
Posted on
BeoCenter 1
Bang & Olufsen BeoCenter 1
BeoCenter 1
BeoCenter 1 combines a state-of-the-art TV, a superior-quality DVD player and an intelligent FM radio in one product, and lets you control everything with a single, easy-to-use remote control – the Beo1.
With its impressive picture quality and powerful active speaker system, Beocenter 1 provides total entertainment in a minimum of space. And the integration doesn’t end with the technology. With six strong colours and five diverse stands – all with motorised turning – to choose from, Beocenter 1 can easily be assimilated into any setting.
In a world full of choices, Bang & Olufsen has already made the best ones for the consumer – and put it all at the command of a four-buttoned Beo1 remote control – the remote control unit dedicated to both Beovision 1 and Beocenter 1.
However, as from October 2002, both Beovision 1 and BeoCenter 1 were delivered with Beo4 remote control instead of Beo1 which was discontinued. In January 2003 a Dolby Digital Surround Sound kit will be available for both these TV models.
BeoCenter 1 is able to read and play DVD-R and DVD-RW discs.
BeoCenter 1 – Press Release 2000
” Bang & Olufsen announces the newest addition to it’s product portfolio. In combining an FM radio, a DVD player, a 25″ TV and a pair of active loudspeakers, BeoCenter 1 offers experiences as yet unmatched on the marketplace. Featuring appealing design and simple operation, the product also has the flexibility to fit in anywhere.
In continuance of the Beovision 1 concept, launched in November of 1999, the key features of BeoCenter 1 remain focused on versatility, simplicity and uncompromising picture and sound quality.
With the new BeoCenter 1, Bang & Olufsen is taking account of the varying needs of consumers when it comes to usage of audio and video equipment in the home. “
Different uses
Bang & Olufsen’s second compact A/V product (the first was BeoCenter AV5, launched in 1997), BeoCenter 1 features an elegant and unmistakably B&O design that makes its presence known, while astonishingly remaining discreet. And a wealth of the company’s long-standing values and innovative finesses lie packed in beneath the surface.
A combined A/V solution like this represents a whole new way of living with these different media – at least in modern times. But look back a few decades and radiograms and combined TV/gramophone units were de rigueur. Back then the TV was the altar at which the family congregated. But as the TV came to play a less dominant role in the home, so consumers rejected large combined systems in favour of smaller, individual audio and video products – thanks in part to new technology requiring less space.
Goes anywhere
Now the combined solution is back with a vengeance – but in minimalist guise, expressed through a design with an emphasis on flexibility rather than dominance.
BeoCenter 1’s flexibility stems primarily from a choice of five unique placement possibilities: from floating almost magically out from the wall, to sitting on a more traditional floor stand, to standing tall on a 160 cm column. Utilising the built-in motor, BeoCenter 1 can also be turned to face in different directions, simply and intuitively operated with the Beo1 remote control.
Externally, BeoCenter 1 offers a truly colourful experience. It is available in six different colours: green, black, yellow, blue, red and grey. This finishing touch helps ensure that BeoCenter 1 blends into any home interior.
But for a A/V centre to blend in absolutely anywhere, it needs to look good from every angle – not just head-on. So a lot of time was spent on making BeoCenter 1 look good from the back too – wave goodbye to gaping sockets and ungainly cable holders.
Furthermore, an A/V centre that goes anywhere also needs to produce a picture that looks good anywhere. BeoCenter 1’s automatic contrast, brightness and colour control means superb picture quality in more or less any light. Add the standard anti-reflection coated contrast glass to the 25″, 4:3 format screen, and the amount of incoming light is reduced by almost 99%, when compared with ordinary front glass.
To top it all off, the sound is rather special too. Two powerful active loudspeakers once again make Bang & Olufsen’s acoustic competencies heard loud and clear. Topping out at 96 dB stereo, the sonic experience remains true to the Bang & Olufsen goal of natural reproduction of sound.
Integrated DVD player
Surprising, intelligent, magical and discreet are some of the words of praise attracted by the DVD player. The DVD tray glides out like a tongue beneath the TV screen and naturally you get all the functions you would expect from a DVD player: Instant access to any particular film episode, pictures in studio quality and a thrilling sound experience.
Built-in FM radio
Seamlessly integrated into the compact cabinet of BeoCenter 1, the FM radio features 59 programme presets and a standard Radio Data System (RDS) module. The RDS module allows the user to see the name of the radio station in the display, provided the broadcaster transmits the proper identification signal.
Personalised Channel Groups
Another major innovation is that each user can create his or her own personal group of up to 18 TV channels (terrestrial, satellite and cable) and radio stations. Again this is in the name of simplicity – it can be hard to keep track of the rapidly increasing number of TV channels available. Another option is to have subject groups rather than personal groups – like sports channels or movie channels. Up to eight different channel groups can be created.
Simplicity even extends to remote control
The Beo1 remote control is a miniature sculpture completely unlike its traditional counterparts, in that it features a built-in base so that it can stand upright on the table. And with only a few buttons, it is also striking in its simplicity – one of the themes in BeoCenter 1. All system components are operated by using the Beo1. Simply navigate through the simple options on the display beneath the TV screen.”
BeoCenter 1 Product Details
Type Numbers
8510 (NEU)
8512 (HK)
8513 (GB)
8515 (AUS)
8516 (SNG
8518 (F- GB)
Designer
Manufactured
2000 – 2006
Colour Options
Black, Blue, Yellow, Red, Green, Grey
BeoCenter 1 Product Specification
Terminal included Beo1
Stand turning function +-35 degrees, motorised
Picture tube/Visual picture 63 cm (4:3)/60cm, Black line, Black Matrix
Contrast screen Anti-reflection coated contrast screen
VisionClear Auto picture adjustment
Auto cut-off
CTI
Adaptive Luminance Peaking
Scan Velocity Modulation
Teletext Improved Teletext
CTV system According to type: B/G/D/K/I/L/L´/M, PAL/SECAM, NTSC on AV
Tuner range 45 – 860 Mhz, VHF band I-III, S, Hyper, UHF
Pretuned TV programmes 99, auto naming
8 Program Groups
Stereo decoders A2 + NICAM
DVD: built-in
Disc sizes 12cm
Frequency range 20Hz – 20KHz
Playback the following: DVD-Video, Video CD, CD-A, CD-R, CD-RW
Multistandard PAL/NTSC
Signal-to-noise-ratio Typical 100 dB, A weighted, in Audio mode
DVD Zone: according to type
FM: built-in
Pretuned radio programs 59
Tuner range 87,5 – 108 MHz
RDS Yes
Speakers:
Power amplifier modules 4 units
Frequency range 50-20.000 Hz
Max sound pressure level 96 dB
Cabinet principle/Net volume Bass Reflex/2.6 litre
Woofer 115mm
Tweeter 18mm
Bass equalizer Adaptive
Magnetic shielded Yes
Satellite module
Tuner range 950 – 2150 Mhz
Programmes 198 TV/Radio
Sound systems Mono/Stereo
Satellite radio Yes
Down conv. supply 14/18 Volts control, Tone Control (22 Khz)
DiSEqC (One way control)
Connections: Input TV and FM Arial, 2 x 75 ohms
V.Tape – AV/Decoder 2 x 21-pin for V.TAPE, A/V or Decoder. RGB and S-Video in
Camcorder/Auxiliary 3 x phono sockets (video in/audio L-R in)
Headphone socket: mini jack
Power Link 2 x 8-pin socket
Master Link (Optional) 1 x Master Link
Satellite (Optional) 1 x F-connecter
System modulator (optional) 1 x 75 ohm aerial mal (Splitter/System modulator Output)
Set-top box Controller (Optional) Mini jack
Optional features/modules: Satellite module 4190
Set-top box Controller 4195
System Modulator EU 4016
System Modulator GB 4018
Master Link Module 4015
Stands: Type: Height, incl. TV Diameter, plate
Table stand 4185 82 cm 29,5cm
Floor stand, low 4186 105 m 44 m
Wall bracket 4188 80cm
Video stand 4189, High Gloss Black 119cm
Floor stand, high 4187 (plate)
4194 (base)
4199 (tube) 231cm 60cm
Market specifications:
Market: Type: Country: Active CTV system Basic CTV system *) DVD Zone *) System modulator
NEU 8510 A-B-CH-D-DK-E-GR-I-N-NL-P-S-SF-Other B/G B/G 2 G
HK 8512 HK D/K/M/I B/G/L/D/K/M/I 3 I
GB 8513 GB I B/G/L/L’/I/D/K 2 I
AUS 8515 AUS B/G B/G 4 G
SNG 8516 SNG, EEU B/G/D/K B/G/L/L’/I/D/K 2 G
F-GB 8518 F-CH B/G/L/L’/I B/G/L/L’/I/D/K 2 G
*) Basic CTV systems can be switched ON in Service menu.
*) DVD Zone can be changed in Service menu. NB Can be changed up to 25 times
Dimensions W x H x D/Weight 61 x 73 x 42 cm/ 40 kg
Cabinet finish black, blue, yellow, grey, red, green
Power consumption Typical 81 watts, standby:< 0,8 W
Language
Reference Guide
EN
BeoCenter 1
Reference Guide
Setup Guide
NL
BeoCenter 1
Setup Guide
User Guide
DK
BeoCenter 1
User Guide
Setup Guide
EN
BeoCenter 1
User Guide
Setup Guide
ESP
BeoCenter 1
User Guide
Setup Guide
FIN
BeoCenter 1
User Guide
Setup Guide
FR
BeoCenter 1
User Guide
Setup Guide
GER
BeoCenter 1
User Guide
Setup Guide
IT
BeoCenter 1
User Guide
Setup Guide
NL
BeoCenter 1
User Guide
Setup Guide
POR
BeoCenter 1
User Guide
Setup Guide
RUS
BeoCenter 1
User Guide
Install Guide
SWE
BeoCenter 1
Install Guide
Service Manual
Multi
BeoCenter 1 On Site Service Manual
Service Manual
Multi
BeoCenter 1 On Site Update Service Manual
Service Manual
Multi
BeoCenter 1 Service Manual
Service Manual
EN
BeoCenter 1 Update Service Manual
Service Manual
Multi
BeoCenter 1 Update 2 Service Manual
BeoCenter 1 FAQs
Please let us know
