Posted on
Beovox RL 1000
Bang & Olufsen Beovox RL 1000
Beovox RL 1000
Beovox RL was available in four sizes, each with its own sound experience generated by size and strength. The large RL 7000 model was equipped with two bass speakers, a mid-frequency unit with separate inner cabinet and a powerful dome treble unit. The cabinet was slightly concave in the treble area to eliminate reflection.
Beovox RL series included three smaller loudspeakers equipped with a selection of units varying in size and number.
The speakers accentuated different sound facets when positioned in different ways. Special fittings allowed you to position the three largest RL speakers as you wished. Suspended from the ceiling or on the wall. Standing in a corner or on a shelf. Or placed discreetly on the floor – either on a stand or in direct contact with the floor if you really wanted heavy bass sound – for dancing for example. The hard moulded plastic shell had no parallel surfaces, and the space between the bracing ribs was covered with asphalt. This special construction ensured a pure and authentic sound experience – with minimal cabinet resonance.
The special fittings, available as accessories, made it possible to tilt and turn Beovox RL speakers, in order to focus the sound towards your listening position, giving you the perfect stereo perspective.
Beovox RL 1000 Product Details
Type Numbers
6520 (1991 - March 1995)
Designer
Manufactured
1991 - 1995
Colour Options
Black, White
Beovox RL 1000 Product Specification
Dimensions W x H x D/Weight: 32 x 40 x 12.5 cm / 3.5 kg
Cabinet finish: Black or white
Black front cloth
Impedance: 8 ohms
Long-term maximum output* 63 W
Effective frequency range* 57 – 20,000 Hz
Sensitivity* 86 dB +/- 2 dB
Cabinet principle: Bass reflex
Woofer: 13cm
Tweeter:1.8cm
Net volume per channel 10 litre
(* According to IEC 268-5)
Connections: Spring Terminals
Beovox RL 1000 FAQs
Please let us know
Posted on
Beovox RL 2000
Bang & Olufsen Beovox RL 2000
Beovox RL 2000
Beovox RL 2000 Product Details
Type Numbers
6521 (1991 - Jan 1994)
Designer
Manufactured
1991 - 1994
Colour Options
Black, White
Beovox RL 2000 Product Specification
RMS power handling capacity 45 W
Music power handling capacity: 60W
Impedance: 8 ohms
Frequency range +4 -8 dB 48 – 20,000 Hz
Power at 96 dB SPL 2.5 dB
Sensitivity 1 W 92 dB
Acoustic principle: Bass reflex
Woofer: 16cm
Tweeter: 1.9cm
Crossover frequency: 2500 Hz
Net volume: 16 litre
Dimensions W x H x D: 54 x 40.5 x 16cm
Weight:6.8 kg
Beovox RL 2000 FAQs
Please let us know
Posted on
Beovox RL 35
Bang & Olufsen Beovox RL 35
Beovox RL 35
The idea behind Beovox Red Line speakers was one of flexibility. A Red Line speaker was so flexible that it could be placed anywhere. On the ceiling, the wall, or on the floor.
You could hang them semi-permanently on the wall, and if you had a party you could place them on the floor and thereby add extra emphasis to the bass. The different ways of placing them accentuated different frequencies. You could also tilt them if you chose to hang them on the wall. This allowed you to adjust the sound image and direct the sound right at your listening position. However, Red Line was more than merely flexible. It was an impressive bass reflex speaker with a revolutionary new cabinet that ‘curved’ round the sound thereby eliminating irritating resonance because there were no parallel surfaces.
Music that never stands still
Red Line loudspeakers followed your music tastes right up the wall if you wanted! All models except the RL35 could be hung on the wall or be suspended from the ceiling; and, if your dancing feet wanted to make the most of the bass notes, then Red Line could be positioned on the floor, supported by the built-in floor stand. By using Red Line speakers, you weren’t plagued by cables that wrapped themselves around your feet like spaghetti either; Red Line’s flexible spiral cables provided the decorative and practical answer.
The shell was cast in a hard synthetic material and the shape that was devised for the range was characterised by the fact that it allowed for practically no resonance whatsoever.
Beovox RL 35 Product Details
Type Numbers
6515 (1988 - Dec 1991)
Designer
Manufactured
1988 - 1991
Colour Options
Grey
Beovox RL 35 Product Specification
Dimensions W x H x D 32 x 40 x 12.5cm
Weight 3.5 kg
Long-term max. input power 60 W
Maximum noise power 35 W
Speaker impedance 8 ohms
Frequency range 48 – 20,000 Hz
Power at 96 dB SPL 2.5 W
Distortion < 0.7 %
Cabinet principle: Bass Reflex
Woofer: 13cm
Tweeter: 9cm
Crossover frequency 3500 Hz
Net volume:10 litre
Connections:: spring terminals
Beovox RL 35 FAQs
Please let us know
Posted on
Beovox RL 6000
Bang & Olufsen Beovox RL 6000
Beovox RL 6000
Beovox RL 6000 Product Details
Type Numbers
6522 (1991 - Feb 1997)
Designer
Manufactured
1991 - 1997
Colour Options
Black, White
Beovox RL 6000 Product Specification
Dimensions: W x H x D/Weight: 40.5 x 54 x 18cm / 8.3 kg
Cabinet finish Black or White
Black front cloth
Impedance 8 ohms
Long-term maximum power:* 103 W
Effective frequency range* 42 – 20,000 Hz
Sensitivity:* 86 dB +/- 2 dB
Woofer: 2 x 13cm
Tweeter: 2.5cm
Net volume per channel 19 litre
Connections: DIN/Spring Terminals
Beovox RL 6000 FAQs
Please let us know
Posted on
Beovox RL 7000
Bang & Olufsen Beovox RL 7000
Beovox RL 7000
The large RL 7000 model was equipped with two bass speakers, a mid-frequency unit with separate inner cabinet and a powerful dome treble unit. The cabinet was slightly concave in the treble area to eliminate reflection. Beovox RL series included three smaller loudspeakers equipped with a selection of units varying in size and number.
Beovox RL 7000 Product Details
Type Numbers
6523 (1991 - Sept 1994)
Designer
Manufactured
1991 - 1994
Colour Options
Black, White
Beovox RL 7000 Product Specification
RMS power handling capacity 140 W
Music power handling capacity 200 W
Impedance: 8 ohms
Frequency range +4 -8 dB 40 – 20,000 Hz
Power at 96 dB SPL: 2W
Sensitivity 1 W 93 dB
Distortion 250- 1000 Hz <0.7%
Distortion >1000 Hz <0.5%
Woofer: 2 x 16.5cm
Mid-range: 13cm
Tweeter: 2.5 cm
Crossover frequency
800/3000 Hz
Net volume 38 litre
Dimensions x H x D: 70 x 50 x 24cm
Weight 15 kg
Beovox RL 7000 FAQs
Please let us know
Posted on
BeoCom 9800
Bang & Olufsen BeoCom 9800
BeoCom 9800
Battery chargers for mobile phones are not the most exciting objects in the world, but Bang & Olufsen have a continual habit of making a virtue out of what others see as ordinary. By combining the battery charger with a specially designed holder, BeoCom 9800 suddenly became a mobile phone that users really wanted others to see!
Weighing less than 100 grams and able to fit snugly in a pocket, the BeoCom 9800 mobile phone was one of the world’s smallest cellular phones when it was introduced, with an equally impressive list of features. Tell it the name of the person you wish to telephone and BeoCom 9800 dialled it. The inclusive BeoCharger combined holder and battery charger in an attractive package.
Features:
Caller ID; Call Forward; SMS; Voice Dial; Call Duration; Call Hold; redial function for last 10 numbers; 90 minutes’ battery talk time with 100 hours standby; graphic display; keypad lock; clock; data/fax connection; 100g with standard battery
Accessories
BeoCharger; extra battery; hands-free car kit
BeoCom 9800 Product Details
Type Numbers
Please let us know​
Manufactured
1998 - 2000
Colour Options
Please let us know​
BeoCom 9800 Product Specification
System: GSM 900/1800
Card: SIM Plug-in
Year of production: 1999
Length of calls:1h 30m
SMS Message System
Ability to turn off own number
Phone call costs display
Built-in modem
Caller ID
Call Forward
Voice Dial Call Duration
Call Hold
Redial function for last 10 numbers
Graphic display
Keypad lock
Clock
Data/fax connection
BeoCom 9800 FAQs
Please let us know
Posted on
BeoCom 9600
Bang & Olufsen BeoCom 9600
BeoCom 9600
Telephones are for speaking into and for listening to, but why stop at that? When Bang & Olufsen developed their own, they were built on the accumulated knowledge of natural sound, the durability of materials and of logical operation and function.
BeoCom 9600 was a GSM mobile phone in a class of its own as far as materials, manufacture and function were concerned. In spite of its unassuming appearance, it gave the user a loud and clear connection, even in noisy environments and with a card for fax and PC, it gave total mobility.
BeoCom 9600 could be charged with the table-top BeoCharger designed by Henrik Sørig Thomsen, designer of other Bang & Olufsen products such as BeoTalk 1100/1200, BeoCom 6000 and BeoCom 9800.
BeoCom 9600 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1996 - 1998
Colour Options
Please let us know​
BeoCom 9600 Product Specification
Dimensions: 49 x 130 x 24mm
System: GSM
Card: SIM plug-in
Year of production: 1996
Talk time: 2h 30m
Stand-by time: 37h
Battery: Ni-MH
Weight: 198g
SMS messages
Caller ID
Costs of calls display
BeoCom 9600 FAQs
Please let us know
Posted on
BeoCom 9500
Bang & Olufsen BeoCom 9500
BeoCom 9500
One of B&O’s first mobile telephones was created in partnership with Ericsson. The basic design was Ericsson’s while B&O contributed its expertise within sound reproduction. Technically identical to Ericsson’s own model, the B&O version had its own special design feature in the shape of its inclining buttons.
” Always there for you but never a burden – BeoCom 9500. Because of its extremely small size and low weight, you could easily forget that you were carrying around an extremely powerful communication tool in your pocket. The pressure chamber loudspeaker gave an extremely clean sound when you received calls.”
Designed for GSM systems the BeoCom 9500 had a pressure chamber loudspeaker; display, including status indication, a high number of numbers in memory dependant on the SIM card, redial function, volume control, microphone mute, adjustable tone ringer, keypad lock, phone lock, intelligent security lock, battery low warning, SMS, call hold/wait function, CLI (Caller Line Identification), call forwarding and DTMF tones.
Batteries: Standard battery giving 100 minutes talk time or 20 hours stand-by. Plus battery giving 180 minutes talk time or 30 hours stand-by. Light battery giving 80minutes talk time or 15 hours stand-by. Charging time: 1 – 2 hours depending on battery types
Weight: approximately 225g depending on battery types
BeoCom 9500 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1994 - 1997
Colour Options
Black
BeoCom 9500 Product Specification
System: GSM
Card: SIM plug-in
Year of manufacture: 1994 Talk-time: 3h (Plus battery)
Stand-by time: 30h (Plus battery)
Battery: 950mAh Ni-Cad
BeoCom 9500 FAQs
Please let us know
Posted on
BeoCom 9000
Bang & Olufsen BeoCom 9000
BeoCom 9000
Beocom 9000 was one of Bang & Olufsen’s mobile telephones. It was available in two models that used either the NMT network or the pan-European GSM network. The size of a glasses case and weighing under 300 grams, Beocom 9000 performed with the longest talk time on the market at the time of its introduction, relative to its weight
BeoCom 9000 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
1993 - 1994
Colour Options
Please let us know​
BeoCom 9000 Product Specification
Category: Cellular
Standard: GSM 900
Dimensions WxHxD:
Weight : 295 g. with standard battery
Finish : Dark blue
Acoustic principle for speaker Bass Reflex
Memory (Phonebook): SIM card
Redial: 6 number
Features: Volume control
Microphone mute
Phone lock.
Battery low warning.
Call Forward.
Ringer settings
DTMF ( tone )
Accessories: Standard battery (NiCd) 400 mAh.
plus battery (NiCd) 950 mAh.
High Capacity battery (NiCd) 1400 mAh.
Hands free car kit.
Portable hands free kit.
Basic Charger 230 V
Advance charge
Travel charger
Country Specifications:
Europe 1511
BeoCom 9000 FAQs
Please let us know
