Posted on
BeoVox 5000 (1988)
Bang & Olufsen BeoVox 5000 (1988)
Bang & Olufsen’s BeoLab and Beovox 5000 speakers had both the voice and the looks for a leading, acoustic role. And because of their looks, they were known as Bang & Olufsen’s range of panel loudspeakers. Panel loudspeakers were one of the most exciting and interesting examples of how Bang & Olufsen united advanced technology and stunning design to achieve totally new effects.
They may not have looked like high-specification loudspeakers – more like works of art – but their sound immediately gave them away. Even at full volume, they kept the total sound picture in perfect balance.
Design as a work of art
The elegant, flat panel loudspeakers were created to hang on the wall. And with their calm surfaces of blue or grey fabric coupled with polished steel, they could be taken for works of art. But the design was only partly for visual effect. The form of the panel speakers was founded on an advanced, acoustic principle that uses the wall as an active part of the sound reproduction process – without causing the wall itself to vibrate.
Optional display and amplifier
The panel loudspeakers were available in two sizes – each with or without amplifier and a display showing which source was playing and at what volume. Also it told you which track number on a CD or tape you were listening to.
With display and amplifier the loudspeakers were called BeoLab. Without, they were called Beovox. The option depended upon which Bang & Olufsen sound system was connected. BeoLab speakers were designed to match Beosystem 6500, 4500, 3500 and Beocenter 9500 and 8500.
Mounting Options
Wall mounting brackets were supplied with this model. No other mounting solution wall offered.
Posted on
BeoVox 500
“B&O loudspeakers will meet very exacting conditions as their specifications exceed international hi-fi standards. All B&O speakers are of the pressure-chamber type with an impedance of 4 ohms. They are available in matched pairs only in a choice of teak or Brazilian rosewood finish”
Posted on
BeoVox 3800
Bang & Olufsen BeoVox 3800
A British Institution
Were it not for the arcane British Tax system, this speaker would never have existed. As it was , the presence of a 12″ Goodmans woofer signified that this was a professional class loudspeaker, and hence one paid reduced purchase tax. It replaced the Beovox 4700 in the range in the UK for this reason.
Beovox 3800 loudspeakers were recommended to the listener who liked his/her music to sound really natural and uncoloured. These high-fidelity pressure chamber enclosures contained a 30,5cm bass unit, an 8,5cm mid-range unit and a 2,5cm dome tweeter or treble unit. Beovox 3800 gave a finely balanced reproduction of all types of music. It had a power handling capacity of 40 watts RMS or 90 watts music power. Frequency range was 35~20.000 Hz. It was a full-size, floor-standing model, or it could be mounted on the trumpet-shaped pedestal which was available as an elegant accessory. Beovox 3800 exceeded the DIN 45500 norm by a wide margin.
Trumpet stand
Nearly all Beovox loudspeakers of this period were designed for either wall mounting or placing on a shelf. This included Beovox 3800. However, owing to its size, it could also be used as a floor-mounted speaker. For this reason, Bang & Olufsen produced the trumpet stand, type 8906007. The stand had a top on which the loudspeaker could be placed, not only elegantly but also practically in order to achieve a good sound dispersion.
Posted on
BeoVox 3000 (1967)
Bang & Olufsen BeoVox 3000 (1967)
Beovox 3000 was the ideal smaller loudspeaker for the Beolab system: it had a special bass unit, a separate mid-range and two high frequency units. There was provision for individual adjustment of mid-range and high-frequency levels, and a socket for a high-frequency diffuser (Beovox 2500).
Beovox 3000 type 6220 and 6238 was a pressure-chamber loudspeaker with a specially-designed bass unit, a separate mid-range speaker and two high-frequency speakers – a total of four units. There was a crossover network and provision for individual adjustment of mid-range and high-frequency levels. There was also provision for the connection of a high-frequency diffuser. The maximum power handling capacity was 50 Watts.
Posted on
BeoVox 3000 (1988)
Bang & Olufsen BeoVox 3000 (1988)
Bang & Olufsen’s BeoLab 5000, Beovox 5000 & Beovox 3000 speakers had both the voice and the looks for a leading, acoustic role. And because of their looks, they were known as Bang & Olufsen’s range of panel loudspeakers. Panel loudspeakers were one of the most exciting and interesting examples of how Bang & Olufsen united advanced technology and stunning design to achieve totally new effects.
Mounting Options
Posted on
BeoVox 2700
Bang & Olufsen BeoVox 2700
In 1972 the Museum of Modern Art in New York (MoMA) chose seven Bang & Olufsen products designed by Jacob Jensen to be included in their Design Collection as representing excellent examples of the Museum’s criteria for quality and historical importance; design, in fact, which had influenced the twentieth century. Beovox 2700 were one of those seven products. That same year Beovox 2700 won the iF Design Award.
