Posted on
Beovox MS150
Bang & Olufsen Beovox MS150
Beovox MS150
Beovox Uni-Phase MS150 and M150 were Bang & Olufsen’s answer to the need for loudspeakers that could cope with greater dynamic range and increased demand for serious, no-gimmick sound reproduction.
They were B&O’s biggest and most perfected loudspeakers up to the time of their introduction, designed to reproduce sound with a natural, linear phase quality – even at very high sound pressure levels. Their power handling capacities were specified at 150 watts RMS. However, effective overload protection circuits enabled them to handle brief passages of music way above their ratings
Both speakers reproduced all types of music – from the faintest to the loudest notes – with extreme accuracy and precision, without adding to or subtracting from the signals they received.
In addition, the MS150 was designed to reproduce a clean, powerful bass in a relatively large room. That is why it was fitted with a monitor quality sub-woofer and had a net volume of 64 litres. It reproduced the lowest of tones that any record, tape or FM broadcast could deliver. Apart from the sub-woofer, all other speaker drivers in both models were identical.
Beovox Uni-Phase MS150 were well-balanced loudspeakers that would reproduce all types of music – from the faintest to the loudest tones – with accuracy and precision. They were an excellent match for the BeoLab 8000 music system, and other serious high fidelity systems.
Beovox Uni-Phase MS150 loudspeakers had linear phase and linear amplitude transfer characteristics. This meant that they would reproduce sound accurately, without adding to, or subtracting from the signals they received. Power handling capacity was specified at 150 watts RMS but an effective overload protection circuit enabled them to handle much greater loads.
Behind this successful design lay a new acoustic technology, an integrated loudspeaker design which put Bang & Olufsen in control of all the parameters that affected the loudspeakers’ performance. That is, all, except the room acoustics in which they were situated. The new technology was based upon the use of Fourier analysis, computer-aided design and simulation techniques and laser holography. It helped prove measuring, calculating and testing techniques and thereby led to better cross-over filters’ design, refinement of patented linear phase techniques, control cabinet resonances and the minimisation of diffractions caused by the cabinet’s traditionally sharp-edged profiles. There was also a redesigning of the necessary drivers in order to meet precise construction requirements and perform optimally.
A monitor quality sub-woofer, a 20cm bass unit and a 64 litre net cabinet secured clean, powerful, bass reproduction. The mid-range unit, a 7,5cm dome tweeter, was aperiodically tuned to secure the exact frequency response characteristic required, while the super tweeter ensured excellent high frequency response.
Beovox MS150-2 handled a full 150 watts of power easily and accurately. Even musical peaks exceeding this level offered no danger to the drive units as they were protected by an automatic safety cut-out. All frequencies were reproduced faithfully via the 25cm sub-woofer, 20,5cm bass, 7,5cm mid/phase-link and a 2,5cm tweeter unit. Overall, frequency range was 30 – 20000Hz; the extended bass response being a benefit of the ported reflex cabinet design. Sturdy metal pedestals were included to place the speakers at the correct height and vertical angle.
Beovox MS150 Product Details
Type Numbers
6431
Designer
Manufactured
1980 - 1985
Colour Options
Rosewood
Beovox MS150 Product Specification
RMS power handling capacity 150 W
Music power handling capacity 200 W
Impedance: 8 ohms
Frequency response 4+ -8 dB 30 – 20,000 Hz
Frequency response +/- 4 dB 48 – 22,000 Hz
Sensitivity 2.5 W
Distortion: 250 – 1000 Hz
<1%
Distortion: > 1000 Hz <0.5%
Subwoofer: 25 cm, throw +/- 8mm
Woofer: 21 cm, throw +/- 5mm
Phase-link unit: 7.5 cm dome
Tweeter: 2.5 cm dome
Net volume: 64 litre
Gross volume:102 litre
Dimensions W x H x D: 36 x 83.5 x 34cm
Weight: 30 kg
Beovox MS150 FAQs
Please let us know
Posted on
Beovox MS150.2
Bang & Olufsen Beovox MS150.2
Beovox MS150.2
Beovox MS150.2 Product Details
Type Numbers
6411
Designer
Manufactured
1980 - 1985
Colour Options
Rosewood
Beovox MS150.2 Product Specification
Specifications: RMS power handling capacity 150 W
Impedance: 8 ohms
Sensitivity 2.5 W
Distortion 250 – 1000 Hz
<1%
Distortion > 1000 Hz <0.5%
Gross volume: 102 litre
Weight 30 kg
Beovox MS150.2 FAQs
Please let us know
Posted on
Beovox P30
Bang & Olufsen Beovox P30
Beovox P30
Beovox Uni-Phase P30 loudspeaker handled up to 30 watts RMS power and reproduced sound with neutral, linear phase quality.
They were panel speakers designed to be hung on the wall and are therefore ideal for rooms where space was limited. Only 9cm deep, its volume was 12,9 litres. Fitted with a 16cm woofer and a 2,5cm tweeter. Frequency range 49 – 20000Hz.
The Beovox P30 were effectively a wall mounted S30. They appeared very thin though were in fact slightly deeper than one thought as the resin back protruded a fair bit at the back. Sound quality mirrored that of the S30 with generally good quality sound though they are bass light and must be wall mounted to achieve their best.
Beovox P30 Product Details
Type Numbers
6306 (1975 - May 1980)
Designer
Manufactured
1975 - 1980
Colour Options
Rosewood, Teak, White
Beovox P30 Product Specification
Continuous load 30 W
Music load 50 W
Impedance: 4 – 8 ohms
Frequency response +4 -8 dB 49 – 20,000 Hz
Sensitivity 5 W
Net volume 9 litre
Gross volume 12.9 litre
Woofer: 16cm
Tweeter: 2.5cm
Dimensions W x H x D: 30 x 54 x 9cm
Weight: 5 kg
Beovox P30 FAQs
Please let us know
Posted on
Beovox P45
Bang & Olufsen Beovox P45
Beovox P45
Beovox Uni-Phase P45 loudspeaker was a revised version of the Beovox P50 and was a high fidelity panel speaker for wall-mounting.
Weighing only 8kg the P45 had a net volume of 25 litres. Frequency range was 40 – 20 000 Hz with less than 1% harmonic distortion. There were two 12,5cm woofers, a special 8cm Phase Link unit and a 2,5cm dome tweeter.
The P45 was a superb loudspeaker. This was a wall mounted version of the superb S45 but replaced the single bass driver with two smaller 12.5cm units. This were asymmetrically mounted with the lower one being extremely close to the edge of the cabinet. Despite this, when properly mounted, the sound quality was superb. B&O again played the trick of making the speakers look thin by limiting the depth of the wood cabinet but extending the resin back. These are lovely well balanced speakers – if you find a pair, buy them!
Beovox P45 Product Details
Type Numbers
6307 (1975 - May 1980)
Designer
Manufactured
1975 - 1980
Colour Options
Rosewood, White
Beovox P45 Product Specification
Continuous load 45 W
Music load 75 W
Frequency response +4 -8 dB 45 – 20,000 Hz
Sensitivity: 4.2 W
Net volume:15 litre
Gross volume: 25 litre
Woofer: 2 x 12.5cm
Phase link unit: 9 cm
Tweeter: 2.5 cm
Dimensions W x H x D: 35 x 65 x 14cm
Weight: 8 kg
Beovox P45 FAQs
Please let us know
Posted on
Beovox P50
Bang & Olufsen Beovox P50
Beovox P50
“A sound panel in which high-fidelity reproduction and compactness were successfully reunited” – 1974 Catalogue.
Beovox P50 represented a new concept in the design of pressure chamber loudspeakers. They were developed with convenience and homeliness in mind. Their remarkable design provided the sound quality of a “large” speaker without the dominating size and appearance which speakers of this standard had hitherto necessitated. It was possible to place even four top-quality speakers in your living-room without inconvenience.
Beovox P50 could be easily mounted on a wall where their presence would not obtrude upon their surroundings, yet they presented the most excellent sound quality. Frequency response was 40-20 000 Hz with distortion less than 1%. The “P” stood for “panel” and “50” signified power handling capacity – 50 watts RMS (or 80 watts music power). The speaker units were two 12,5cm woofers, a 8cm mid-range dome and a 2,5cm dome tweeter.
Beovox P50 Product Details
Type Numbers
6305 (to Sept 1975)
Designer
Manufactured
1974 - 1975
Colour Options
Rosewood, White
Beovox P50 Product Specification
Continuous load: 45 W
Music load:75 W
Sensitivity 4.2 W
Net volume:15 litre
Gross volume:25 litre
Woofer: 2 x 12.5cm
Phase link unit: 9cm
Tweeter: 2.5cm
Weight 8 kg
Beovox P50 FAQs
Please let us know
Posted on
Beovox X25
Bang & Olufsen Beovox X25
Beovox X25
Beovox X25, X35 and X40 speakers were, at the time of their introduction, newly-developed speakers. The two speakers were very similar in appearance.
Beovox X35 featured a 20cm bass unit and 2.5cm tweeter. Power handling capacity was 30 watts RMS. The cabinets measure 48cm high, 26cm wide and 18 cm deep. They had a built-in wall-mounting facility and were finished in a dark grey metallic effect.
Beovox X25 Product Details
Type Numbers
6335 (to Dec 1987)
Designer
Manufactured
1983 - 1987
Colour Options
Grey
Beovox X25 Product Specification
RMS power handling capacity 25 W
Music power handling capacity 35 W
Impedance: 8 ohms
Frequency response +4 -8 dB 55 – 20,000 Hz
Power at 96 dB SPL 6.3 W
Sensitivity 1 W 88 dB
Cabinet type Pressure chamber
Woofer: 16 cm
Tweeter: 6.6 cm
Net volume: 8.4 litre
Gross volume 12.4 litre
Dimensions W x H x D: 22 x 41 x 15cm
Weight: 4 kg
Beovox X25 FAQs
Please let us know
Posted on
Beovox X35
Bang & Olufsen Beovox X35
Beovox X35
BeoVision Avant – Turning to you
Unfolding s
ound
Redefining TV sound
Contrasted imagery
Beovox X35 Product Details
Type Numbers
6331(to Nov 1980)
Designer
Manufactured
1983 - 1987
Colour Options
Grey
Beovox X35 Product Specification
RMS power handling capacity 30 W
Music power handling capacity 50 W
Impedance: 8 ohms
Frequency response +4 -8 dB 65 – 20,000 Hz
Power at 96 dB SPL 2.5 watts
Sensitivity 1 W 92 dB
Woofer: 20 cm
Tweeter: 2.5 cm
Net volume: 12 litre
Gross volume: 22 litre
Dimensions W x H x D: 26 x 48 x 18 cm
Weight 5 kg
Beovox X35 FAQs
Please let us know
Posted on
Beovox X40
Bang & Olufsen Beovox X40
Beovox X40
Beovox X40 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1983 - 1987
Colour Options
Grey
Beovox X40 Product Specification
Please let us know
Beovox X40 FAQs
Please let us know
Posted on
BeoVox CX100
Bang & Olufsen BeoVox CX100
BeoVox CX100
Living proof that big sound need not take up more space than a couple of ring binders, Beovox CX50 snuggled in anywhere, even as extras in a Beolink® system.
Beovox CX50 and Beovox CX100 loudspeakers were the smallest loudspeakers from Bang & Olufsen up to the time that the manufacture of passive speakers ceased in 2002. They were mostly used to place within a passive Beolink® system (MCL), although they could also be used as main speakers. Thanks to different colour combinations they blended well into most people’s décor.
Beovox CX100 finally ceased production in September 2003 – the last of a long and successful line of passive speakers.
Description:
Passive loudspeaker, aluminium cabinet, available in black, white and brushed aluminium.
Replacement drive units: Top drive unit for CX50/CX100 Part number: 411743
Mounting Options
BeoVox CX50/CX100 replaced C40 and was designed to be optionally mounted with the wall brackets supplied in the box.
BeoVox CX100 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1984 - 2003
Colour Options
Aluminium, Black, White, Grey
BeoVox CX100 Product Specification
Dimensions 12 x 32 x 20.5cm/5kg
Cabinet Finish Black/White/Aluminium
Long Time Power Output per Channel 100 Watts
Max Sound Pressure Level 89 dB
Frequency Range 50-20 000 Hz
Cabinet Principle Bass Reflex
Woofer 2x 10cm
Tweeter 1x 2.5cm
Net Volume 4 litres
BeoVox CX100 FAQs
Please let us know
Posted on
BeoVox CX50
Bang & Olufsen BeoVox CX50
BeoVox CX50
Description:
Mounting Options
BeoVox CX50 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1984 - 2003
Colour Options
BeoVox CX50 Product Specification
Dimensions 12 x 20,5 x 20,5cm/3,5kg
Cabinet Finish Black/white/Aluminium
Long Time Power Output per Channel 80 Watts
Frequency Range 60-20 000 Hz
Woofer 1x 10cm
Tweeter 1x 2.5cm
Net Volume 2.5 litres
BeoVox CX50 FAQs
Please let us know
