Posted on
BeoSound Century
BeoSound Century
If you want superior sound, but not the size, and a full array of functions but without the complication – then take a look at the BeoSound Century. Designed by David Lewis, it has a very slim depth and brings together CD, tape and FM radio into a slim-line form that can stand by itself or hang from a wall. Everything is operated by buttons that light up to guide you quickly through the various playing options.
BeoSound Century is a clever combination of excellent performance and ease-of-use. This system is known in fact by two different names – BeoSound Century in Europe and BeoSound 2000 in North America. With everything built in, this is the perfect stereo for those who with a limited space as it’s only 11cm deep. It’s for those who don’t want Beolink® capabilities and can be equipped with a handle with a built-in active antenna making it very portable. The speakers use the active construction as that of all BeoLab speakers. In the late nineties the Century was released in a special limited series with polished aluminium instead of the black plastic on the CD holder. This became so popular that it became the standard! There are two different stands available: a wall stand and a special table stand. The unit may also be controlled by the optional Beo4 remote control.
Deep bass
BeoSound Century integrates a powerful sound reproduction system: two active loudspeakers with electronic crossover network and Adaptive Bass Linearisation, for the optimum relationship between bass reproduction and sound pressure level. The very small two-way bass reflex loudspeakers comprise a net volume of only 1,1 litres, but the large front grille gives room for fairly large woofer membrane diameters.
Bass and treble have separate power amplifiers, which means that they can be tailored to compensate for one another’s shortcomings and deliver a sound spectrum as close to reality as possible. On top of that, BeoSound Century can play at high volume, but cuts out before it has an opportunity to burn out its units.
The fine art of control of BeoSound Century
The backlit push buttons of the BeoSound Century are cast in opalescent plastic, painted black on the inside and the text is then burnt away with a laser. The light of a diode behind each button is muted for even distribution, and the button is hinged in four places. A sturdy and relatively inexpensive construction, but it takes just a bit more work!
Operation of BeoSound Century
How do you make operation easy when there are 26 buttons to push? On BeoSound Century, only the buttons you need for the specific function will light up and guide you step by step through operations.
BeoSound Century was awarded the Danish Design Centre’s IP Prize in 1994.
Mounting Options
Supplied with a table mount foot for mounting on top of a cabinet. The optional wall mount bracket allowed for wall mounting.
BeoSound Century Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1993 - 2004
Colour Options
Black
BeoSound Century Product Specification
Tuner: Built-in
Pretuned radio programmes: 30 FM (or AM according to type)
Radio ranges: According to type
Compact disc: Built-in
Disc sizes: 12 cm, 8 cm
Frequency range: 20 – 20,000 Hz
Signal-to-noise-ratio: > 91 dB, A weighted
D/A converting: Bitstream
Features: Random
Tape recorder: Built-in
Recording system: HX PRO
Tape transport: Auto reverse
Noise reduction: Yes
Frequency range: 50 – 14,000 Hz
Signal-to-noise-ratio: > 64 dB, noise reduction, chrome
Power amplifier: built-in
Loudspeaker system: Built-in
Sound pressure level: 95 dB
System frequency range: 70 – 20,000 Hz
Connections:
AUX (input only)
FM aerial, 75 ohm
AM aerial (Dedicated)
Headphone/Mini jack
Recommended remote control: Beo4
Accessories:
Type No. 2088 Wall bracket
Type No. 2036 Handle/antenna, FM
Type No. 2035 Handle/antenna, FM, Japan
Dimension W x H x D / Weight: 75 x 37 x 17 cm / 12 kg
Cabinet finish: Front cloth; green, red, blue, yellow, grey, black
Power consumption: Typical 20 W, standby <1 W
Language
Service Manual
EN
2651, 2652, 2653, 2654
BeoSound Century Service Manual
BeoSound Century FAQs
Please let us know
Posted on
BeoSound 2000
Bang & Olufsen BeoSound 2000
BeoSound 2000
Deep bass
Mounting Options
BeoSound 2000 Product Details
Type Numbers
Please let us know​
Designer
Manufactured
1993 - 2004
Colour Options
Black
BeoSound 2000 Product Specification
Tuner: Built-in
Features: Random
Connections:
AUX (input only)
FM aerial, 75 ohm
Headphone/Mini jack
Accessories:
[wptb id="47366" not found ]
BeoSound 2000 FAQs
Please let us know
Posted on
BeoSound Edge
Bang & Olufsen BeoSound Edge
BeoSound Edge
BeoSound Edge is a compact and powerful wireless speaker, which through magical interaction, timeless design and cutting-edge acoustic innovation, offers a mesmerising listening experience.
Active Bass Port.
For the calm and for the storm.
BeoSound Edge employs cutting-edge acoustic innovation to deliver a powerful and accurate listening experience. Through our latest patent for the world’s first Active Bass Port, the speaker provides perfect potent bass at high volumes and maintains accurate bass at low volumes.
Magical Interaction
Interacting with BeoSound Edge is enchanting. A push either way from BeoSound Edge’s centre of gravity controls the volume. Subtle resistance and damping make the instinctive rolling motion feel both luxurious and intuitive.
Music for you, me and everyone
With Directional Sound Control, BeoSound Edge allows the user to define the direction that the sound radiates. For instance, a room can be divided into an active listening area and a more passive listening area. Alternatively, the user can choose to blast true 360° room-filling sound from both sides of the speaker to fill the entire room.
Defy gravity
Keep your Beosound Edge casually on the floor or mount it on a wall as a stunning display. Enjoy the magical experience as the speaker rolls back into position as you pull or push the aluminium ring to adjust the volume.
A presence that adapts to you
Meet a speaker that feels your presence. As you approach, Beosound Edge comes to life, lightning up its touch-sensitive control interface through the aluminium surface. Simple and sophisticated.
BeoSound Edge Product Details
Type Numbers
Please let us know​
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoSound Edge Product Specification
Recommended Room Size
20-120 m² 200-1200 ft²
Speaker Configuration
1 x 10” dual coil woofer 2 x 4” midrange 2 x 3/4” tweeter
Amplifier
2 x 200 W class D for woofer (2 x 425W peak power) 4 x 100W class D for midranges and tweeters (4 x 200W peak power)
Frequency Range
12 – 23.200 Hz (Closed port) / 28 – 23.200 Hz (Open port)
Maximum Sound Pressure Level @1m
104 dB SPL
Bass Capability
92 dB SPL
Stereo Pairing
Pair two Beosound Edge to enjoy a stereo listening experience. Set up the stereo pairing through Google Home.
Advanced Sound Features
Active Bass Port Acoustic Placement Settings Adaptive Bass Linearization Beam Direction control (two sides) Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Highly polished aluminium body Black fabric covers Warm taupe covers
Weight
13 kg
Dimensions
50.2 W x 50.2 H x 13 D cm
Bluetooth Version
4.2
Wi-Fi
Wi-fi/WLAN 802.11 b/g/n/ac (2.4 GHz & 5 GHz)
Streaming services
Google Cast Airplay Beolink Multiroom Spotify Connect UPnP
Integrated music services
B&O Radio Deezer (incl Deezer HiFi) QPlay 2.0 (China Specific)
Inputs and outputs
1 x Mains Connection 1 x Line-in (analogue & digital combo) with sensing 1 x Ethernet 10/100 Mbit/s
Remote controls
Bang & Olufsen App Beoremote One BT Beoremote Halo
BeoSound Edge FAQs
Please let us know
Posted on
BeoSound Core
Bang & Olufsen BeoSound Core
BeoSound Core
The essential connectivity hub that turns your Beolab speakers into a future-proof and wireless speaker system.
STREAMING
Stream from your favourite music app
With Beosound Core, nothing stands between your music and your beloved speakers. Stream directly from your favourite music apps on your phone via Google Cast, AirPlay or Bluetooth. Or play your own digital music collection via UPnP.
SOUND
Uncompromising sound quality
Only the very best for your Beolab speakers. Beosound Core renders music in ultra high resolution to deliver the highest digital streaming quality we have ever offered.
CONNECTIVITY
All the connections you need
Beosound Core is the intelligent connectivity hub for your all your wired and wireless devices and speakers. Optical-in and optical-out interfaces provide end-to-end digital sound. We also included analogue interfaces for your older equipment.
FUTURE-PROOF
Extend the life of your speakers
In a time of fast-changing technologies, the Beosound Core safeguards your precious Beolab speakers or Beosound Shape through automatic software updates, keeping them up-to-date for many years to come.
MULTIROOM
Get the full Multiroom experience
Beosound Core adds Multiroom functionality to Beosound Shape or your Beolab speakers, allowing you to wirelessly connect multiple speakers throughout your home into one seamless audio system.
BeoSound Core Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Black
BeoSound Core Product Specification
Material
LightWeight composite
Dimensions
15.1 W x 4.4 H x 15.1 D cm
Weight
290g
Power Supply
Power supply built-in USB-C Power Cable
Bluetooth Version
Bluetooth 4.1
Bluetooth Codecs
AAC SBC
WiFi
Dual-Band Wi-Fi 5 (2.4 & 5 GHz) IEEE 802.11 a/b/g/n/ac
Streaming Services
Apple AirPlay Spotify Connect Google Cast B&O Radio Deezer QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x USB-C (Power) 1 x USB-A (Connection to Beosound Shape) 1 x Line-in/Optical 1 x Optical Out 1 x Ethernet 1 x DPL 1 x Powerlink (RJ45)
Remote Control
BeoSound Core FAQs
Posted on
BeoSound Moment
Bang & Olufsen BeoSound Moment
BeoSound Moment
BeoSound Moment is an intelligent, wireless music system that integrates your music and streaming services into one.
BeoSound Moment brings the music listening experience back into your home. No more worrying about finding a track from one of your many devices that also receive emails, messages, and other notifications that can interrupt the listening experience. BeoSound Moment gets rid of the need to deal with distractions from other applications, by making your music available all in one place, and instantly accessible with just one touch.
ALWAYS IN THE RIGHT MOOD
Whatever your mood, there is a perfect playlist to match. Let the MoodWheel know how you are feeling, and BeoSound Moment will explore the vast Deezer catalogue, plus the sources of music in your home, and build a playlist for you, based on your selection.
BEAUTIFUL ON BOTH SIDES
There are two contrasting faces to BeoSound Moment: One side, made from pure aluminium, displays your full music library for browsing on the touch-screen interface or the aluminium wheel. The other side, a touch-sensitive solid wood interface, is designed to blend in with your interior.
BeoSound Moment Product Details
Type Numbers
Please let us know​
Manufactured
2015 - 2018
Colour Options
Aluminium/Wood
BeoSound Moment Product Specification
Features
MoodWheel – one touch to the music that moves you
PatternPlay – follows the rhythm of your life
Integrated music service with Deezer®
Integrated Internet radio with TuneIn®
DLNA (DMR) access to your personal music collection
Bluetooth for streaming from your mobile
Immaculate Wireless Sound concept integrated based on WiSA technology
Size and weight
Interface 0.5 kg
Base 1.9 kg
Display 1280 x 800 – 7 inch IPS.
POWER CONSUMPTION and Operating Conditions
Typical: 14 W, Standby: 0.4 W.
Temperature 10-40° C – Humidity 20-80%
Remote control options
BeoSound Essence Remote
BeoRemote One
Beo4
BeoMusic App
BATTERY
Li-Polymer Capacity 3500 mAh.
Standby capacity 76 hours.
Charging time 5 hours.
Wireless connection
WiSA technology integrated – full 24 bit uncompressed wireless audio streaming up to 8 channels.
WiFi — 2,4ghz 802.11 g/b
Bluetooth (A2DP) for streaming music from your mobile
CONNECTIONS
2 x Power Link (RJ45)
1 x Ethernet
1 x Power
1 x Line-in (RCA)
1 x USB for service purposes only
AUDIO FORMATS
MP3 (all) or VBR / CBR 32 – 320kbit
WMA, both VBR and CBR 20 – 320kbit (No support for WMA Lossless)
AAC (ISO and ADTS) – 320kbit
ALAC general + 88.2, 96 kHz
PCM (WAV) general + 88.2, 96 kHz
FLAC, 8-96 kHz, 16 or 24 bits, 2 channels
MATERIALS
Glass, aluminium, rubber, plastic and wood.
COLOURS
Natural aluminium and black.
BeoSound Moment FAQs
Please let us know
Posted on
BeoPlay A6
Bang & Olufsen BeoPlay A6
BeoPlay A6
BeoPlay A6 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoPlay A6 Product Specification
Please let us know
BeoPlay A6 FAQs
Please let us know
Posted on
BeoPlay A8
Bang & Olufsen BeoPlay A8
BeoPlay A8
BeoPlay A8 Product Details
Type Numbers
Please let us know​
Designer
Please let us know
Manufactured
Please let us know​
Colour Options
Please let us know​
BeoPlay A8 Product Specification
Please let us know
BeoPlay A8 FAQs
Please let us know
