Power output RMS: 2 x 2.5 watts / 4 ohms
Power output music: 2 x 4 watts / 4 ohms
Bass control at 50 Hz: +/- 10 dB
Treble control at 10,000 Hz: +/- 10 dB
FM range: 87.5 – 108 MHz
Harmonic distortion stereo: < 0.5%
AM range: LW 147 – 350 kHz, MW 520 – 1610 kHz
Tape recorder:
Wow and flutter DIN: < 0.25 %
Tape switch: ferro, chrome, metal Frequency range: 60 – 14,000 Hz
Signal-to-noise ratio: > 54 dB
Microphones: built-in, L and R
Power supply: 220 – 240 V
Batteries: 6 x 1.5 volts IEC R 20
Power consumption 220 V: max. 9.5 W
Battery: FM 170 – 790 mA
Rec: 420 – 1000 mA
Dimensions W x H x D: 50.5 x 24 x 7cm
Weight incl. batteries: 5.2 kg
Connections: headphone max. 1.7 V/ 200 ohms
Phono Input 3.5 mV
Tape Input 650 mV
Extra speakers
