Remote Switch
Remote Switch
This device allowed the use of devices not normally controlled by remote to be added to a B&O system. It could be used to switch on any item which could be left on but which you did not want to be powered up all the time. It worked with the Beocenter 9000 and Beomaster 5500 […]
This device allowed the use of devices not normally controlled by remote to be added to a B&O system. It could be used to switch on any item which could be left on but which you did not want to be powered up all the time. It worked with the Beocenter 9000 and Beomaster 5500 in particular.
No specifications provided.
No downloads available.
