| BeoCenter 9000 – Has limitations. Not recommended | BeoSystem 3500 – Beolink Converter required | BeoVision LX2500/2800 – not compatible | BeoCenter AV9000 – Compatible |
| BeoCenter 8000 – no link connections | BeoSystem 4500 – Beolink Converter required | BeoVision LX2502/2802 Beolink Converter required (Limited use as main TV) | BeoVision Avant – Compatible |
| BeoCenter 2300 – Beolink Converter required | BeoSystem 5500 – Beolink Converter required | BeoVision MX3500/5500 – Beolink Converter required | BeoVision AV5 – Compatible |
| BeoCenter 2500 – Beolink Converter required | BeoSystem 5500 – Beolink Converter required | BeoVision LX4500/5500 – Beolink Converter required | BeoVision 3 – Compatible |
| BeoCenter 8500 Beolink Converter required | BeoSystem 7000 – Beolink Converter required | BeoVision MX 4000/6000/7000 – Beolink Converter required | BeoVision 5 – Compatible |
| BeoCenter 9300 – Beolink Converter required | BeoSound 2300/2500 – Beolink Converter required | BeoVision MX8000 – Compatible | BeoVision 1L – Compatible (Options 1 or 2) |
| BeoCenter 9500 – Beolink Converter required | BeoSound Ouverture/3000 – Compatible | BeoVision LX5000/6000 – Beolink Converter required | BeoVision 6 – Compatible |
| BeoSound 9000 – Compatible | BeoSound 3200 – Compatible | BeoVision AV9000 – Compatible | |
| BeoSound Century – Not compatible | BeoCenter 2 – Compatible | BeoVision 1 – Not compatible | |
| BeoSound 1 – Not compatible | BeoCenter 1 – Compatible (only with BC1 updated model: Options 1 or 2) |
| BeoVision MX4002 – Compatible |
| BeoLab 2000 – Compatible |
| BeoLab 3500 – Compatible |
| BeoCenter 9000 – may need Beolink SW | BeoSystem 3500 – compatible | BeoVision LX 2500/2800 – not compatible | BeoVision AV9000 – ML/MCL Converter required |
| BeoCenter 8000 – no link connection | BeoSystem 4500 – compatible | BeoVision LX 2502/2802 – Compatible | BeoVision Avant – ML/MCL Converter required |
| BeoCenter 2300 – needs ML/MCL Converter | BeoSystem 5500 -compatible | BeoVision MX3000/4500/5000 – Compatible with limitations | BeoVision AV5 ML/MCL Converter required |
| BeoCenter 2500 – needs ML/MCL Converter | BeoSystem 6500 – compatible | BeoVision MX3500/5500 – Compatible | |
| BeoCenter 8500 – compatible | BeoSystem 7000 – compatible | BeoVision LX4500/5500 – Compatible | |
| BeoCenter 9300 – compatible | BC Ouverture – needs ML/MCL Converter | BeoVision MX4000/6000/7000 – Compatible | |
| BeoCenter 9500 – compatible | BeoSound 9000 – needs ML/MCL Converter | BeoVision LX 5000/6000 – Compatible | |
| BeoSound Century – not compatible | BeoSound 1 – not compatible |
| BeoVision MX 4002 – Beolink Converter required (SW 1.3) | |
| BeoLab 2000 – Beolink Converter required (SW 1.3) | |
| BeoLab 3500 – Beolink Converter required (SW 1.3) – BeoLab 3500 works with both ML and MCL |
NOTE: for Software updates (SW) always consult your B&O dealer
