Master Control Panel 5000
The main remote control for the Beosystem 5000, the MCP 5000 allowed full control of your Beosystem from your armchair.
Two way control allowed the status of the system to be ascertained easily and complex timer programming was possible using the controls under the flip down panel.
The MCP 5000 could only be used with the Beomaster 5000 and could be part of a multi-room system allowing full control in a link room. MCP5000 will not operate any of the other systems such as the Beosystem 5500, 6500 and 7000.
Master Control Panel 5000 Product Details
Type Numbers
2038 (1983 – May 1987)
Designer
Manufactured
1983 – 1987
Colour Options
Silver, Grey
Master Control Panel 5000 Product Specification
Dimensions: 32 x 8 x 18cm
Display: Total
Radio programmes: 9FM or AM
Other programmes: PH-TP1-TP2-CD
Beocord Controls: 10
Beogram Controls: 6
VHS91 Controls: 8
Compact Disc Controls: Total
Programming: Timer + CD50
Volume Control: Yes, memory
Bass, treble: Yes, memory
Balance: Yes, memory
Muting: Yes
Status: Yes
Language
User Guide
EN
Master Control Panel 5000 User Guide
Master Control Panel 5000 FAQs
Please let us know
