Master Control Link 30 – MCL30
Master Control Link 30 makes it possible for you to have music all over the house from a BeoSystem 3000 Remote control of all primary functions in the BeoSystem 3000 Can also be used for the BeoSystem 6000 Connection of up to 4 link units Easily mounted with only one cable wide range of installation […]
wide range of installation accessories
MCL30 can convey the operation from the terminal 3000.
With a loudspeaker button on the Master Control Link you activate the loudspeakers in the link room, and not you can operate all the functions from the terminal 3000.
There is a wide range of accessories. How and for what they should be used is described in the Master Control Link handbook.
Note that there can be connected 4 link rooms, and that the total length of the cable should not exceed 150 meters.
When connected to BeoMaster 6000, MCL-kit type 1006/1007 should be used as well.
Type Number:2050
Release Date:1982, 1983, 1984, 1985, 1986, 1987
Relay box – W16 x H11 x D3.5 cm
Operation unit – W13 x H4 x D2 cm
Language
Date
User and Installation Manual
EN
2050
03-85
MCL30 User and Installation Manual
